GT25-24DP-2.2V(01)
GT25-24DP-2.2V(01)
    HRS(广濑)
    排针 间距:2.2mm 2x12P SMT
GT25-24DP-2.2V(01) 数据手册
GT5 Interface Connector GT13 GT19 GT21 Feb.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PO5G — SMT Multi-contact Connectors — GT16 GT25 Series GT26 GT36 GT11 GT17 GT32 GT3 GT 7 GT18W GT28 The width of tab is 025 size. Insulation Resistance 100MΩ min Withstanding Voltage AC650V for one minute GT9 Note 1 : When using different consitions, please consult with Hirose. Note 2 : Includes temperature rise caused by current flow. Contact Resistance Operating Temperature Range No more than 30mΩ (initially) −40℃ to +105℃(Note 2) GT8E ■ Product Specifications Rated Current 3A(Note 1) GT25 Metal holddowns to solder by reflow are used instead of screws for PCB mounting. GT23F GT15 195 Interface Connector GT10 Features ■ F Terminal GT13 GT5 GT25 Series ● Interface Connector 1.9 15.3 11.8 GT19 GT21 GT26 GT36 GT11 HRS No. 775-0039-6 775-0070-6 Material Finish Copper palloy Tin plating Conductor Size (AWG) 20 to 22 AWG 24 to 28 AWG Outer Diameter φ1.0 to 1.7 φ0.5 to 1.0 Packaging RoHS 10,000 pcs/reel YES ■ F Connector ● Housing(Pre-assembled retainer) GT3 18.5 GT32 GT17 Part No. GT25H-2024SCF GT25HB-2428SCF GZiV^cZgXdbeaZiZanVhhZbWaZYXdcY^i^dc GT 7 A 7.4 13 GT18W 2.8 GT10 9.5 2.7 GZiV^cZgiZbedgVg^anVhhZbWaZYXdcY^i^dc GZiV^cZg GT25 =djh^c\ GT28 GT8E GT9 GT23F GT15 Interface ConnectorCopyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Feb.1.2016 PO5G GT16 1.4 196 Part No. HRS No. GT25-8DS-HU/R 775-0059-3 GT25-12DS-HU/R 775-0062-8 GT25-24DS-HU/R 775-0046-1 GT25-32DS-HU/R 775-0044-6 Color Housing:Black Retainer:Dark Gray Material No. of Contacts A Dimension Housing:PPE Retainer:PBT 8 11 PBT 12 15.4 24 28.6 32 37.4 Housing:PPE Retainer:PBT Note 1 : Pre-assembled retainer into housing body Note 2 : After insert assembled contact, retainer has to be pushed-in correct position Note 3 : Available to purchase housing and retainer separately for repair. Packaging RoHS 1 YES GT25 Series ● Interface Connector GT5 Excellent strength type fpr excessive displacement 3 BRecommended PCB pattern GT13 0.4 D +0.1 3.6  0 16.9 0.75±0.03 .05 +00   +0.1 7.4  0 8.9±0.05 (8) B #' ¢& PO5G 9.65 A 4.3±0.05 GT25H-*DP-2.2H GT16 1.1±0.05 +0.1 E 0.8 4.3 8 0.4 C 1.4 0.64 0.1 2.2 GT21 2H GT26 Part No. HRS No. 775-0038-3 GT25H-20DP-2.2H (Under development) GT25H-32DP-2.2H (Under development) 12 23.7 19.3 20.73 12.1±0.05 20.73±0.05 20 32.5 28.1 29.53 20.9±0.05 29.53±0.05 24 36.9 32.5 33.93 25.3±0.05 33.93±0.05 32 45.7 41.3 42.73 34.1±0.05 42.73±0.05 Packaging RoHS 200 pcs/reel YES GT32 775-0045-9 PPS Brass/ Tin plating E Dimension GT17 GT25H-24DP-2.2H Black No. of A B C D Contacts Dimension Dimension Dimension Dimension GT11 GT25H-12DP-2.2H Material/ Finish Color GT36 Excellent strength type fpr excessive displacement 2.2±0.05 BRecommended PCB pattern +   0.0 0 5  0 +   0.0 0 5 7.4  0 +0.1 4.3±0.05 3.23 -0.05 +0.1 7.4  0 4.3±0.05 9.65  0 +0.1 2  0 E 推奨基板寸法図 18.8 9.65 GT18W 6.48 -0.05 13.25 3 1.15 + 2  B 1.2±0.05 .2 0.8 GT28 4.3 3.3 4.4 GT25 0.4 C 4.825 GT8E GT9 Part No. Material/ Finish Black PPS Brass/ Tin plating 775-0050-9 GT25H-24DP-2.2V (Under development) GT25H-32DP-2.2V 775-0053-7 No. of A B C D Contacts Dimension Dimension Dimension Dimension E Dimension 12 23.7 19.3 20.73 11±0.05 20.73±0.05 24 36.9 32.5 33.93 24.2±0.05 33.93±0.05 32 45.7 41.3 42.73 33±0.05 42.73±0.05 Packaging RoHS 1 YES GT15 Color GT23F GT25H-12DP-2.2V HRS No. 197 Interface Connector 0.64 Ø1 GT10 0.6 6× GT 7 2.2 2.2±0.05 +0.05 GT25H-*DP-2.2V D 0.64 6.92 0 1.2±0.05 .2 +0.05 1.5 Ø1 10.17  0 6× A GT3 Feb.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4 3 GT19 13 0.64 2  0 BRecommended PCB Pattern 8 PO5G 18±0.05 23.43±0.05 22 9.5 4.7 0.4 0.8 GT21 23.43 18 4.3 0.1 * 1.4 GT19 9.65 2.2 8 2 1. Part No. GT25-8P-2.2H(70) HRS No. Color Material/Finish Packaging RoHS 775-0001-3 70 Light Gray PPS Brass/ Tin plating 200pcs/reel YES BRecommended PCB Pattern 2 rows 3.6+0.1 0 D GT32 1.1±0.05 0.75±0.03 GT25-*DP-2.2H 2+0.1 0 12.7 9.65 φ E 2.2 0.64 0.4 0.8 4.3 8 GT28 GT25 C 0.1 GT18W 4 3 * 0.64 GT10 A B .05 +00 1.2 7.4+0.1 0 (8) 8.9±0.05 4.3±0.05 GT 7 8 17 GT3 3 0.4 1.4 GT17 GT11 GT36 GT26 φ GT9 GT8E Part No. GT23F 198 HRS No. Color Material/ Finish No. of A B C D Contacts imension imension imension imension E imension GT25-8DP-2.2H 775-0004-1 8 17.65 13.2 14.63 7.7±0.05 14.63±0.05 GT25-12DP-2.2H 775-0005-4 12 22.05 17.6 19.03 12.1±0.05 19.03±0.05 GT25-16DP-2.2H 775-0006-7 16 26.45 22.0 23.43 16.5±0.05 23.43±0.05 24 35.25 30.8 32.23 25.3±0.05 32.23±0.05 GT25-28DP-2.2H(01) 775-0040-5 01 28 39.65 35.2 36.63 29.7±0.05 36.63±0.05 GT25-32DP-2.2H 775-0008-2 32 44.05 39.6 41.03 34.1±0.05 41.03±0.05 GT25-40DP-2.2H 775-0003-9 40 52.85 48.4 49.83 42.9±0.05 49.83±0.05 GT25-24DP-2.2H GT15 Interface ConnectorCopyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Feb.1.2016 .1 +00 26.75 .3 Ø1 22 .1 +0 0 .2 Ø1 4±0.05 18 8 positions, 1 row 7.4±0.05 Right-angle Type 2.2±0.05 1.2±0.05 GT25-8P-2.2H 8±0.05 8.6±0.05 4 3±0 05 4.3±0.05 1.7 0.6 15.4±0.05 3.6 +0.1 0 ■ M connector (PCB type) GT16 GT13 GT5 GT25 Series ● Interface Connector 775-0007-0 Note : (01) is tray package. Light Gray PPS Brass/ Tin plating Packaging RoHS 200 pcs/reel YES or 1/tray GT25 Series ● Interface Connector GT5 BRecommended PCB pattern 5 +0.0 0 7.4 +0.1 0 4.3±0.05 1.5 0.6 2.2 GT16 3 12.9 2 rows 6.48 3.23 .2 φ1 6.92 1.5 Straight Type GT25-*DP-2.2V E 2.2±0.05 1.2±0.05 GT13 A B 10.17 ■ M connector (PCB type) PO5G 0 2+0.1 F 9.65 18.8 0.2 0.4 C D GT26 0.8 4.3 4.825 1.4 4.3 GT21 GT36 Color GT25-16DP-2.2V(01) 775-0020-8 01 GT25-24DP-2.2V(01) 775-0021-0 01 GT25-32DP-2.2V(01) 775-0022-3 01 GT25-40DP-2.2V(01) 775-0014-5 01 Light Gray Material/ Finish No. of A B C D Contacts Dimension Dimension Dimension Dimension PPS Brass/ Tin plating E Dimension F Dimension 16 26.75 22.3 15.4 23.73 15.4±0.05 23.73±0.05 24 35.55 31.1 24.2 32.53 24.2±0.05 32.53±0.05 32 44.35 39.9 33.0 41.33 33±0.05 41.33±0.05 40 53.15 48.7 41.8 50.13 41.8±0.05 50.13±0.05 Packaging RoHS 1/tray YES GT32 HRS No. GT17 Part No. GT11 B Crimping tools GT3 User's manuals are available. Please contact your Hirose Electric account representative. Specifications Automatic Crimping Machine Specification Stroke Length 30mm Number of strokes 200spm (50Hz) Weight 75kg Remarks --------- 240spm (60Hz) ----- Motor 0.2kw Crimping speed 2,000 to 4,000 pcs/hour AC100V GT18W 1.5tons GT10 Press capacity ----- GT25 GT28 Part No. CM-105C Terminal HRS No. Tool Part No. GT8E Terminal Product No. Tool HRS No. GT25H-2024SCF 775-0039-6 AP105-GT25H-2024S 901-5206-3 GT25HB-2428SCF 775-0070-6 AP105-GT25HB-2428S 901-5230-8 tooling HRS No. Part No. HT304/GT25H-2024S Applicable wire GT25H-2024SCF Note : HT304/GT25H-2024S is rated for 0.3SQ (22 AWG) or 0.5SQ (20 AWG) cable only. HT304/GT25H-2024S can not terminate 0.2SQ (24 AWG) cable. GT15 780-0044-1 00 GT23F ● Hand GT9 Note : Crimp height setting tables are available for each cable type. Pleace contact your nearest Hirose Electric account representative. Different cables will require different crimp height settings. 199 Interface Connector Item Picture reference only GT 7 Powered by TCPDF (www.tcpdf.org) GT19 Feb.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: GT25-24DP-2.2H GT25-28DP-2.2H(01) GT25-16DP-2.2V(01)
GT25-24DP-2.2V(01) 价格&库存
很抱歉,暂时无法提供与“GT25-24DP-2.2V(01)”相匹配的价格&库存,您可以联系我们找货
