Trailer Connector
TC7W-SC2-Z
Mechanical Dimensions: Inches [mm]
Tolerances ±0.012 [0.3] Unless Otherwise Specified
Material Specifications
Wiring Color Codes
A.T.A & S.A.E WIRING CODES RECOMMENDED STANDARD
NAME
MATERIAL
1
SOCKET SHELL
IRON
12 GA
2
HINGE PIN
IRON
Tail, License and Running Lights Green
14 GA
3
SPRING
STAINLESS STELL
Battery Charge
Black
10 GA
4
COVER
IRON
Stop & Left Hand Turn Signal
Red
14 GA
5
SET SCREW
IRON
Stop & RIght Hand Turn Signal
Brown
14 GA
6
WIRE BOOT
PVC
Auxiliary Circuit
Yellow
14 GA
7
SCREW
IRON
8
7-WAY TERMINAL
BRASS
CIRCUITS
POLE WIRING
COLOR CODE
RECOMMENDED
WIRE GAUGE
Ground Return
White
10 GA
Electric Brake
Blue
ITEM#
Rev A 07/2019
Trailer Connector
Rev
A
TC7W-SC2-Z
Designed Approved
Date of issue Revision Notes
07-16-2019
Initial Drawing
RC
Rev A 07/2019
OH
很抱歉,暂时无法提供与“TC7W-SC2-Z”相匹配的价格&库存,您可以联系我们找货
