IO-SL4FC
IO-SL4FC
    IO
    IO-SL4FC
IO-SL4FC 数据手册
SPEAKERLATCH™ CABLE CONNECTOR Specialized connector to drive passive speakers (Speaker Level Signal) IO-SL4FC SPECIFICATIONS PRODUCT MECHANICAL Gender: Female Lifetime: > 1000 Mating Cycles Contacts: 4 Wiresize: 12 AWG (2.75mm) Max O.D. ELECTRICAL Wiring: Screw Terminals Capacitance between Contacts: ≤ 2.5 pF Cable OD: 3.0mm - 10.0mm Contact Resistance: ≤ 3 mΩ Solderability: Complies with IEC 60068-2-20 Insulation Resistance: > 1 GΩ Dielectric Strength: 4 kV DC MATERIAL Current Rating: 16 A RMS / 250 V AC Contacts: Copper Alloy Contact Plating: Silver ENVIRONMENTAL Shell: Reinforced Plastic (PA66+30%GF) Flame-retardant Grade: UL94 V-0 Standard Compliance: IEC 61984 Working Temperature: -30°C to +80°C Shell Finish: Black Strain Relief: POM Locking Element: Zinc Alloy UL Listed (US): E500108 Product specifications may change without prior notification Io Audio Technologies® is a registered trademark of Knight Electronics, Inc. 10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 | www.ioaudiotechnologies.com DRAWING IO-SL4FC FEATURES & APPLICATIONS Speakerlatch™ connectors provide the safest connection for driving passive speakers. They feature a reinforced plastic shell with 4 silver plated contacts designed to withstand the abuse of stage productions. They also feature a plastic insert which clamps onto the cable to provide strain relief. The “twist-to-lock” motion makes each connection extremely robust and prevents accidental disconnection while protecting the user at all times from unintentional shocks and conductor damage. Additionally, these connectors are specifically keyed to prevent dangerous interconnection mistakes. All of this protection fits in a standard footprint to simplify installation. With a current rating of 16A @ 250V AC, Speakerlatch™ connectors are a perfect solution for applications where a high capacity connection is needed and safety must be maintained at all times. The sturdy, locking plastic connectors offer durability that will ensure years of reliable service without interruption or fatigue, even in harsh environments. The screw terminals allow the ability to install or remove them in the field, which means that installers and integrators can customize their use and get the job done. Speakerlatch™ connectors are compatible with current industry standard speaker receptacles and equipment, making it a safe investment. PART NUMBER BREAKDOWN: STANDARDS & CLASSIFICATIONS IO-SL4FC Series Identifier IO-SL4FC Number of Contacts IO-SL4FC Gender IO-SL4FC Cable Connector Product specifications may change without prior notification Io Audio Technologies® is a registered trademark of Knight Electronics, Inc. 10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 | www.ioaudiotechnologies.com
IO-SL4FC 价格&库存
很抱歉,暂时无法提供与“IO-SL4FC”相匹配的价格&库存,您可以联系我们找货
IO-SL4FC
  • 1+43.019521+5.59050
  • 10+36.5687210+4.75220
  • 25+34.2730725+4.45388
  • 50+32.6369750+4.24126
  • 100+31.07809100+4.03868
  • 250+29.13251250+3.78585
  • 500+27.74257500+3.60522
  • 1000+26.419241000+3.43325
  • 2500+24.766942500+3.21853
库存:163
