FGG.0B.304.CLAD52Z
FGG.0B.304.CLAD52Z
    LEMO(雷莫)
    CONN PLUG MALE 4P GOLD SLDR CUP
FGG.0B.304.CLAD52Z 数据手册
FGG.0B.304.CLAD52Z www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 0B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.0B.304.CLL Download Request a quote Eplan PHG.0B.304.CLLD52Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 8.48 g Performance Configuration 0B.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-contact): 850 V (AC), 1200 V (DC) Vtest (contact-shell): 700 V (AC), 1000 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 9.5 35 25 8 7 in. 0,37 1,38 0,98 0,31 0,28 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.0B.005.PA070 Caps: BFG.0B.100.PCSG Cables CMN.04.T22.047QGC TPR Grey CMN.04.T22.048QGZE TPR (medical) Grey 140240 PVC Black 140250 PVC Grey 40260 PVC Black 4080 PVC Grey 4221 PVC Black 4280 PVC Black 80080 PVC Grey 80082 PVC Red 80084 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0B.304.CLAD52Z 价格&库存
很抱歉,暂时无法提供与“FGG.0B.304.CLAD52Z”相匹配的价格&库存,您可以联系我们找货
FGG.0B.304.CLAD52Z
  • 1+320.94825
  • 10+272.81195
  • 25+255.72635
  • 100+231.91329
  • 250+217.41426
  • 500+213.07167
库存:1025
FGG.0B.304.CLAD52Z
    • 1+255.733261+32.65496
    • 10+246.7578810+31.50888
    • 25+230.5745025+29.44240
    • 50+216.3865550+27.63072
    • 100+203.84382100+26.02912
    库存:128
    FGG.0B.304.CLAD52Z
    • 1+277.47669
    • 5+272.18646
    • 25+266.42761
    • 50+260.46048
    库存:311
