PG2409
PG2409
    IFM(易福门)
    SMD
    PG2409
PG2409 数据手册
PG2409 Pressure sensor with analogue display PG-1-1-REB12-MFRKG/US/ 1 2 3 /P analogue display alphanumeric display 4-digit sensor field (programming button) Product characteristics Output signal switching signal; analogue signal; (configurable) Measuring range -1...1 bar Process connection -1000...1000 mbar -14.52...14.52 psi threaded connection G 1/2 external thread Application Special feature Gold-plated contacts Application for industrial applications Media liquids and gases Medium temperature [°C] -25...80 Min. bursting pressure 30 bar 435 psi Pressure rating 10 bar 145 psi Type of pressure relative pressure; vacuum ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PG2409-00 — 01.04.2021 — PG2409 Pressure sensor with analogue display PG-1-1-REB12-MFRKG/US/ /P Electrical data Operating voltage [V] 18...32 DC Current consumption [mA] < 70; (24 V) Min. insulation resistance [MΩ] 100; (500 V DC) Protection class III Reverse polarity protection Power-on delay time yes [s] 6 Integrated watchdog yes Inputs / outputs Number of inputs and outputs Number of digital outputs: 1; Number of analogue outputs: 1 Outputs Total number of outputs 2 Output signal switching signal; analogue signal; (configurable) Electrical design PNP/NPN Number of digital outputs 1 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 250 Switching frequency DC [Hz] 75 2 Number of analogue outputs Analogue current output Max. load 1 [mA] 4...20, invertible; (scalable) [Ω] (Ub - 10 V) / 20 mA Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range -1...1 bar Set point SP -1000...1000 mbar -0.992...1.6 bar Reset point rP -14.52...14.52 psi -14.4...23.22 psi -1...1.592 bar -14.52...23.1 psi Analogue start point -1...1.1 bar -14.52...15.96 psi Analogue end point -0.5...1.6 bar -7.26...23.22 psi 0.004 bar 0.06 psi In steps of Accuracy / deviations Switch point accuracy [% of the span] Repeatability [% of the span] Characteristics deviation [% of the span] Hysteresis deviation [% of the span] Long-term stability < ± 0,5; (Turn down 1:1) < ± 0,1; (with temperature fluctuations < 10 K; Turn down 1:1) < ± 0,25 (BFSL) / < ± 0,5 (LS); (Turn down 1:1; BFSL = Best Fit Straight Line) < ± 0,25; (Turn down 1:1) < ± 0,1; (Turn down 1:1; per 6 months) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PG2409-00 — 01.04.2021 — PG2409 Pressure sensor with analogue display PG-1-1-REB12-MFRKG/US/ /P [% of the span] Temperature coefficient zero point [% of the span / 10 K] < ± 0,2; (0...70 °C) Temperature coefficient span [% of the span / 10 K] < ± 0,2; (0...70 °C) Response times Response time [ms]
PG2409
物料型号为PG2409,是一款带有模拟显示的压力传感器。
器件简介包括模拟显示和数字显示,4位数字传感器场(编程按钮),以及CE标志。
引脚分配包括M12连接器,2个输出(OUT1为开关量输出,OUT2为模拟量输出)。
参数特性包括测量范围-1...1 bar,过程连接为G1/2外螺纹,应用为工业应用,特殊功能为镀金触点,适用介质为液体和气体,介质温度范围为-25...80°C,最小爆破压力为30 bar,压力额定值为10 bar,压力类型为相对压力和真空。
功能详解包括模拟和数字输出,开关量输出和模拟量输出,以及多种电气参数。
应用信息为适用于工业应用,材料为不锈钢、PA、FKM、PTFE和层压安全玻璃。
封装信息为IP67/IP69K防护等级,多种测试/认证,包括EMC、冲击和振动抵抗,MTTF为10^3年,以及符合压力设备指令。
PG2409 价格&库存
很抱歉,暂时无法提供与“PG2409”相匹配的价格&库存,您可以联系我们找货
