PN2594
PN2594
    IFM(易福门)
    Module
    PN2594
PN2594 数据手册
PN2594 Pressure sensor with display PN-010-REG14-MFRKG/US/ /V 1 2 3 4 5 alphanumeric display 4-digit red/green LEDs Display unit / switching status programming button upper part of the housing can be rotated 345° Sealing Product characteristics Output signal switching signal; analogue signal; IO-Link; (configurable) Measuring range -1...10 bar Process connection -14.6...145 psi -100...1000 kPa -0.1...1 MPa threaded connection G 1/4 external thread (DIN EN ISO 1179-2); internal thread:M5 Application Special feature Gold-plated contacts Measuring element ceramic-capacitive pressure measuring cell Application for industrial applications Media liquids and gases Medium temperature [°C] -25...80 Min. bursting pressure 150 bar 2175 psi 15 MPa Pressure rating 75 bar 1087 psi 7.5 Mpa Vacuum resistance Type of pressure [mbar] -1000 relative pressure; vacuum ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2594-00 — 16.06.2015 — PN2594 Pressure sensor with display PN-010-REG14-MFRKG/US/ /V Electrical data Operating voltage [V] 18...30 DC; (according to EN 50178 SELV/PELV) Current consumption [mA] < 35 Min. insulation resistance [MΩ] 100; (500 V DC) Protection class III Reverse polarity protection Power-on delay time yes [s] 0.3 Integrated watchdog yes Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Outputs Total number of outputs 2 Output signal switching signal; analogue signal; IO-Link; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 250 Switching frequency DC [Hz] < 500 2 Number of analogue outputs Analogue current output 1 [mA] 4...20; (scalable 1:5) Max. load [Ω] 500 Analogue voltage output [V] 0...10; (scalable 1:5) Min. load resistance [Ω] 2000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range -1...10 bar Set point SP Reset point rP -14.6...145 psi -100...1000 kPa -0.1...1 MPa -0.94...10 bar -13.6...145 psi -0.094...1 MPa -0.98...9.96 bar -14.2...144.4 psi -0.098...0.996 MPa Analogue start point -1...8 bar -14.6...116 psi -0.1...0.8 MPa Analogue end point 1...10 bar 14.6...145 psi 0.1...1 MPa In steps of 0.02 bar 0.2 psi 0.002 MPa Accuracy / deviations Notes on the accuracy / deviation Switch point accuracy [% of the span] Repeatability [% of the span] Characteristics deviation [% of the span] Hysteresis deviation switch point accuracy, linearity error under DNV GL: < ± 1%: < ± 1% < ± 0,4; (Turn down 1:1) < ± 0,1; (with temperature fluctuations < 10 K; Turn down 1:1) < ± 0,25 (BFSL) / < ± 0,5 (LS); (Turn down 1:1; BFSL = Best Fit Straight Line; LS = limit value setting) < ± 0,1; (Turn down 1:1) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2594-00 — 16.06.2015 — PN2594 Pressure sensor with display PN-010-REG14-MFRKG/US/ /V [% of the span] Long-term stability [% of the span] < ± 0,05; (Turn down 1:1; per 6 months) Temperature coefficient zero point [% of the span / 10 K] < ± 0,2; (-0...80 °C) Temperature coefficient span [% of the span / 10 K] < ± 0,2; (-0...80 °C) Response times Response time [ms] < 1.5 Delay time programmable dS, dr [s] 0...50 Damping for the switching output dAP [s] 0...4 Damping for the analogue output dAA [s] 0...4 Max. response time analogue [ms] output 3 Software / programming hysteresis / window; normally open / normally closed; switch-on/ switch-off delay; Damping; Display unit; current/voltage output Parameter setting options Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Process Data Variable; Device Identification, Device Diagnosis SIO mode yes Required master port type A Process data analogue 1 Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 2.3 Type of operation DeviceID Default 463 Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 65; IP 67 Tests / approvals DIN EN 61000-6-2 EMC DIN EN 61000-6-3 Shock resistance DIN EN 60068-2-27 50 g (11 ms) Vibration resistance DIN EN 60068-2-6 20 g (10...2000 Hz) MTTF [years] UL approval Pressure Equipment Directive 138 UL Approval no. J012 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2594-00 — 16.06.2015 — PN2594 Pressure sensor with display PN-010-REG14-MFRKG/US/ /V Mechanical data Weight [g] 264 Materials stainless steel (1.4404 / 316L); PBT+PC-GF30; PBT-GF20; PC Materials (wetted parts) stainless steel (1.4404 / 316L); Al2O3 (ceramics); FKM Min. pressure cycles Tightening torque 100 million [Nm] 25...35; (recommended tightening torque; depends on lubrication, seal and pressure rating) Process connection threaded connection G 1/4 external thread (DIN EN ISO 1179-2); internal thread:M5 Process connection sealing FKM (to DIN 3869) Restrictor element integrated no (can be retrofitted) Displays / operating elements Display unit Display 3 x LED, green (bar, psi, MPa) switching status 2 x LED, yellow measured values alphanumeric display, red/green 4-digit Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2594-00 — 16.06.2015 — PN2594 Pressure sensor with display PN-010-REG14-MFRKG/US/ /V Connection OUT1 switching output OUT2 switching output analogue output Core colours : BK = black BN = brown BU = blue WH = white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2594-00 — 16.06.2015 —
PN2594 价格&库存
很抱歉,暂时无法提供与“PN2594”相匹配的价格&库存,您可以联系我们找货
