II5916
II5916
    IFM(易福门)
    Cylinder,Threaded-M18
    INDUCTIVE SENSOR; M30 X 1.5 / L
II5916 数据手册
II5916 Inductive analogue sensor IIK3010A1PKG/US Product characteristics Housing threaded type Dimensions [mm] M30 x 1.5 / L = 70 Electrical data Operating voltage [V] Current consumption [mA] Protection class 15...30 DC < 20 II Reverse polarity protection yes Outputs Analogue current output [mA] Max. load [Ω] 4...20; (linear; gradient: 1,778 mA/mm; for frontal approach and for target made of mild steel: 30 x 30 x 1 mm) 500 Short-circuit protection yes Overload protection yes Detection zone Measuring range [mm] 1...10 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Linearity error of analogue output [%] ± 3 %; (of IA max) Repeatability analogue output [%] ± 2 %; (of IA max) [ms] < 10 [°C] -25...80 Response times Response time Operating conditions Ambient temperature Protection IP 67 Tests / approvals MTTF [years] 218 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — II5916-00 — 29.01.2021 — II5916 Inductive analogue sensor IIK3010A1PKG/US Mechanical data Weight [g] 149.5 Housing threaded type Mounting flush mountable Dimensions [mm] M30 x 1.5 / L = 70 Thread designation M30 x 1.5 Materials Tightening torque housing: brass white bronze coated; sensing face: PBT [Nm] 50 Displays / operating elements Display within the operating range 1 x LED, yellow lights outside the operating range 1 x LED, yellow flashing Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — II5916-00 — 29.01.2021 —
II5916 价格&库存
很抱歉,暂时无法提供与“II5916”相匹配的价格&库存,您可以联系我们找货
