IER200
IER200
    IFM(易福门)
    Cylinder,Threaded-M8
    INDUCTIVE SENSOR; M8 X 1 / L = 6
IER200 数据手册
IER200 Inductive full-metal sensor IEK3002BBPKG/AM/SC/US-104-DPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 2 [mm] M8 x 1 / L = 60 Housing Dimensions threaded type Application Special feature Gold-plated contacts; Increased sensing range; Full-metal housing; anti-spatter Application Pressure rating Use in welding applications [bar] Note on pressure rating 50 sensing face Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...36 DC < 20 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 100 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IER200-00 — 15.09.2009 — IER200 Inductive full-metal sensor IEK3002BBPKG/AM/SC/US-104-DPS Detection zone Sensing range [mm] 2 Real sensing range Sr [mm] 2 ± 10 % Operating distance [mm] 0...1.6 Increased sensing range yes Accuracy / deviations Correction factor stainless steel: 0.6 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 Operating conditions Ambient temperature [°C] 0...85 Protection IP 67; IP 68 Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B Impact resistance MTTF 1J [years] 1446 Embedded software included yes UL approval Ta 0...40 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 25.2 Housing threaded type Mounting flush mountable Dimensions [mm] M8 x 1 / L = 60 Thread designation M8 x 1 housing: stainless steel (1.4404 / 316L) anti-spatter; sensing face: stainless steel (1.4404 / 316L) anti-spatter; lock nuts: stainless steel (1.4404 / 316L) anti-spatter Materials Tightening torque [Nm] 3.5 Full-metal housing yes Displays / operating elements Display switching status 4 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IER200-00 — 15.09.2009 — IER200 Inductive full-metal sensor IEK3002BBPKG/AM/SC/US-104-DPS Connection Diagrams and graphs Installation ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IER200-00 — 15.09.2009 —
IER200 价格&库存
很抱歉,暂时无法提供与“IER200”相匹配的价格&库存,您可以联系我们找货
