IFT245
IFT245
    IFM(易福门)
    Cylinder,Threaded-M12
    INDUCTIVE SENSOR; M12 X 1 / L =
IFT245 数据手册
IFT245 Inductive full-metal sensor IFK3006-BPKG/AM/P/US Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 6 [mm] M12 x 1 / L = 70 Housing threaded type Dimensions Application Special feature Gold-plated contacts; Increased sensing range; Full-metal housing Application Pressure rating constant cleaning with aggressive cleaning agents; regular cleaning processes [bar] Note on pressure rating 100 sensing face Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...36 DC < 25 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 500 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT245-00 — 08.06.2011 — IFT245 Inductive full-metal sensor IFK3006-BPKG/AM/P/US Detection zone Sensing range [mm] 6 Real sensing range Sr [mm] 6 ± 10 % Operating distance [mm] 0...4.9 Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 1 / brass: 0.9 / aluminium: 0.75 / copper: 0.6 Hysteresis [% of Sr] 1...20 Switch point drift [% of Sr] -10...10 [°C] 0...100 Operating conditions Ambient temperature Protection IP 65; IP 67; IP 68; IP 69K Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 emission class B Impact resistance MTTF 1J [years] 1265 Ta UL approval 0...40 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 29.75 Housing threaded type Mounting Dimensions non-flush mountable [mm] M12 x 1 / L = 70 Thread designation Materials M12 x 1 housing: stainless steel (1.4404 / 316L); sensing face: stainless steel (1.4404 / 316L); LED window: PEI; lock nuts: stainless steel (1.4404 / 316L) Full-metal housing yes Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT245-00 — 08.06.2011 — IFT245 Inductive full-metal sensor IFK3006-BPKG/AM/P/US Connection Diagrams and graphs Installation ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT245-00 — 08.06.2011 —
IFT245 价格&库存
很抱歉,暂时无法提供与“IFT245”相匹配的价格&库存,您可以联系我们找货
