IGR203
IGR203
    IFM(易福门)
    Cylinder,Threaded-M18
    INDUCTIVE SENSOR; M18 X 1 / L =
IGR203 数据手册
IGR203 Inductive full-metal sensor IGB2006BARKG/AM/SC/0,3M/US/2LE Product characteristics Electrical design PNP/NPN Output function normally open Sensing range [mm] Housing Dimensions 6 threaded type [mm] M18 x 1 / L = 40 Application Gold-plated contacts; Increased sensing range; Fullmetal housing; Optical setting aid; anti-spatter Special feature Application Pressure rating Use in welding applications [bar] Note on pressure rating 20 sensing face Electrical data Operating voltage Protection class Reverse polarity protection [V] 10...36 DC III yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGR203-00 — 15.04.2013 — IGR203 Inductive full-metal sensor IGB2006BARKG/AM/SC/0,3M/US/2LE Outputs Electrical design PNP/NPN Output function normally open Max. voltage drop switching output DC [V] 2.5 Minimum load current [mA] 2 Max. leakage current [mA] 0.6 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 50 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 6 Operating distance [mm] 0...4.9 Increased sensing range yes Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.3 / copper: 0.1 [% of Sr] 1...20 Operating conditions Ambient temperature [°C] -25...70 Protection IP 67 Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 emission class B Impact resistance MTTF 1J [years] 1484 Ta UL approval 0...40 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 67.1 Housing threaded type Mounting flush mountable Dimensions Thread designation Materials Full-metal housing [mm] M18 x 1 / L = 40 M18 x 1 housing: stainless steel (1.4404 / 316L) anti-spatter; sensing face: stainless steel (1.4404 / 316L) anti-spatter; cable plug: PA; lock nuts: stainless steel (1.4404 / 316L) anti-spatter yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGR203-00 — 15.04.2013 — IGR203 Inductive full-metal sensor IGB2006BARKG/AM/SC/0,3M/US/2LE Displays / operating elements switching status Display 1 x LED, green setting aid Optical setting aid 1 x LED, red yes Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Cable: 0.3 m, PVC; 2 x 0.5 mm² Connector: 1 x M12; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGR203-00 — 15.04.2013 — IGR203 Inductive full-metal sensor IGB2006BARKG/AM/SC/0,3M/US/2LE Diagrams and graphs Installation ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGR203-00 — 15.04.2013 —
IGR203
1. 物料型号:IGR203 2. 器件简介:这是一款全金属外壳的感应式传感器,具有以下特性: - 电气设计:PNP/NPN - 输出功能:常开 - 感应范围:6毫米 - 外壳类型:螺纹型 - 尺寸:M18x1/L=40毫米 3. 引脚分配:文档中没有提供详细的引脚分配信息。 4. 参数特性: - 工作电压:10...36V DC - 保护等级:IP67 - 反极性保护:有 - 最大漏电流:0.6mA - 永久电流额定值:100mA - 开关频率:50Hz - 短路保护:有,脉冲式 - 过载保护:有 5. 功能详解: - 检测区域:感应距离为0...4.9毫米 - 修正系数:钢1/不锈钢0.7/黄铜0.5/铝0.3/铜0.1 - 滞后性:Sr的1...20% - 环境温度:-25...70°C - 冲击抵抗力:1J - MTTF(平均无故障时间):1484年 6. 应用信息:适用于焊接应用 7. 封装信息: - 重量:67.1克 - 安装类型:平面安装 - 螺纹规格:M18x1 - 材料:外壳和感应面为1.4404/316L不锈钢,防飞溅;电缆插头:PA;锁紧螺母:1.4404/316L不锈钢,防飞溅
IGR203 价格&库存
很抱歉,暂时无法提供与“IGR203”相匹配的价格&库存,您可以联系我们找货
