IGR207
IGR207
    IFM(易福门)
    Cylinder,Threaded-M18
    INDUCTIVE SENSOR; M18 X 1 / L =
IGR207 数据手册
IGR207 Inductive full-metal sensor IGB3008BBPKG/AM/SC/V4A/US-104 Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 8 [mm] M18 x 1 / L = 45 Housing Dimensions threaded type Application Gold-plated contacts; Increased sensing range; Fullmetal housing; Magnetic-field immune; anti-spatter Special feature Application Pressure rating Use in welding applications [bar] 100 Note on pressure rating sensing face Magnetic-field immune yes Max. magnetic field immunity [mT] 100 Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC < 10 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 2 Short-circuit protection yes Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGR207-00 — 19.01.2017 — IGR207 Inductive full-metal sensor IGB3008BBPKG/AM/SC/V4A/US-104 Detection zone Sensing range [mm] 8 Real sensing range Sr [mm] 8 ± 10 % Operating distance [mm] 0...6.48 Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.6 / aluminium: 0.5 / copper: 0.2 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] -40...85 Operating conditions Ambient temperature Protection IP 65; IP 66; IP 67; IP 68; IP 69K Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B EN 60068-2-6 Fc 20 g (10...3000 Hz) / 50 sweep cycles, 1 octave per minute, in 3 axes EN 60068-2-27 Ea 100 g 11 ms half-sine; 3 shocks each in every direction of the 3 coordinate axes EN 60068-2-27 40 g 6 ms; 4000 shocks each in every direction of the 3 coordinate axes EN 60068-2-14 Na TA = -40 °C; TB = 85 °C; t1 = 30 min; t2 = < 10 s; 50 cycles Impact resistance 1J Vibration resistance Shock resistance Continuous shock resistance Fast temperature change MTTF [years] 1176 Embedded software included yes Ta UL approval -25...70 °C Enclosure type Type 1 voltage supply Limited Voltage/Current UL Approval no. A012 File number UL E174191 Mechanical data Weight [g] 45 Housing threaded type Mounting flush mountable Dimensions [mm] Thread designation M18 x 1 stainless steel (1.4404 / 316L) anti-spatter; sensing face: stainless steel (1.4404 / 316L) anti-spatter; LED window: PEI; lock nuts: brass anti-spatter Materials Tightening torque Full-metal housing M18 x 1 / L = 45 [Nm] 20 yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGR207-00 — 19.01.2017 — IGR207 Inductive full-metal sensor IGB3008BBPKG/AM/SC/V4A/US-104 Displays / operating elements Display switching status 4 x LED, yellow operation 1 x LED, green Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGR207-00 — 19.01.2017 —
IGR207 价格&库存
很抱歉,暂时无法提供与“IGR207”相匹配的价格&库存,您可以联系我们找货
