KF5001
KF5001
    IFM(易福门)
    Cylinder,Threaded-M12
    CAPACITIVE SENSOR; M12 X 1 / L =
KF5001 数据手册
KF5001 Capacitive sensor KFA3040BBPKG/NI/US 1 2 LED 4 x 90° potentiometer Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 1...6 [mm] M12 x 1 / L = 60 Housing Dimensions threaded type Application Media dry bulk material; liquids Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...36 DC; ("supply class 2" to cULus) < 12 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 50 Short-circuit proof yes Overload protection yes Detection zone Sensing range [mm] Sensing range adjustable yes Factory setting sensing range [mm] Real sensing range Sr 1...6 [mm] 4 4 ± 10 % ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KF5001-00 — 27.10.2011 — KF5001 Capacitive sensor KFA3040BBPKG/NI/US Accuracy / deviations Correction factor glass: 0.6 / water: 1 / ceramics: 0.5 / PVC: 0.4 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -20...20 [°C] -25...70 Operating conditions Ambient temperature Protection IP 65 Increased immunity yes Tests / approvals EMC EN 60947-5-2 MTTF [years] 636 [g] 39.3 Mechanical data Weight Housing threaded type Mounting flush mountable Dimensions [mm] M12 x 1 / L = 60 Thread designation Materials M12 x 1 stainless steel (1.4404 / 316L); PEEK Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KF5001-00 — 27.10.2011 — KF5001 Capacitive sensor KFA3040BBPKG/NI/US Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KF5001-00 — 27.10.2011 —
KF5001 价格&库存
很抱歉,暂时无法提供与“KF5001”相匹配的价格&库存,您可以联系我们找货
