IIS241
IIS241
    IFM(易福门)
    Cylinder,Threaded-M18
    INDUCTIVE SENSOR; M30 X 1.5 / L
IIS241 数据手册
IIS241 Inductive sensor IIK3022-ANKG/2M/PUR 1 LED yellow Product characteristics Electrical design NPN Output function normally open Sensing range [mm] Housing 22 threaded type Dimensions [mm] M30 x 1.5 / L = 60 Application Special feature Increased sensing range Application Industrial applications / factory automation Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC < 10 III Reverse polarity protection yes Outputs Electrical design NPN Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 100 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 22 Real sensing range Sr [mm] 22 ± 10 % Operating distance [mm] 0...17.82 Increased sensing range yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIS241-00 — 04.09.2017 — IIS241 Inductive sensor IIK3022-ANKG/2M/PUR Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] -40...85 Operating conditions Ambient temperature Protection IP 65; IP 66; IP 67; IP 68; IP 69K Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B EN 60068-2-6 Fc 20 g (10...3000 Hz) / 50 sweep cycles, 1 octave per minute, in 3 axes EN 60068-2-27 Ea 100 g 11 ms half-sine; 3 shocks each in every direction of the 3 coordinate axes EN 60068-2-27 40 g 6 ms; 4000 shocks each in every direction of the 3 coordinate axes Fast temperature change EN 60068-2-14 Na TA = -40 °C; TB = 85 °C; t1 = 30 min; t2 = < 10 s; 50 cycles Salt spray test EN 60068-2-52 Kb severity level 5 (4 test cycles) Vibration resistance Shock resistance Continuous shock resistance MTTF [years] 837 Embedded software included yes UL approval Ta -25...75 °C Enclosure type Type 1 voltage supply Limited Voltage/Current UL Approval no. A002 File number UL E174191 Mechanical data Weight [g] 149.8 Housing threaded type Mounting non-flush mountable Dimensions [mm] M30 x 1.5 / L = 60 Thread designation Materials M30 x 1.5 brass white bronze coated; sensing face: PBT orange; LED window: PEI; lock nuts: brass white bronze coated Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIS241-00 — 04.09.2017 — IIS241 Inductive sensor IIK3022-ANKG/2M/PUR Electrical connection Cable: 2 m, PUR, Ø 4 mm; burning behaviour to ECE R118 rev. 2; 3 x 0.34 mm² Connection Core colours : BK = black BN = brown BU = blue ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIS241-00 — 04.09.2017 —
IIS241 价格&库存
很抱歉,暂时无法提供与“IIS241”相匹配的价格&库存,您可以联系我们找货
