IIS283
IIS283
    IFM(易福门)
    Cylinder,Threaded-M18
    INDUCTIVE SENSOR; M30 X 1.5 / L
IIS283 数据手册
IIS283 Inductive sensor IIK3022-BPKG/K1/V4A/US-104 Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing 22 threaded type Dimensions [mm] M30 x 1.5 / L = 60 Application Gold-plated contacts; Increased sensing range; Correction factor K = 1; Magnetic-field immune Special feature Application material handling; refrigerated warehouse / shock freezing Magnetic-field immune Max. magnetic field immunity yes [mT] 300 Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC < 20 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 2000 Short-circuit protection yes Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIS283-00 — 04.09.2017 — IIS283 Inductive sensor IIK3022-BPKG/K1/V4A/US-104 Detection zone Sensing range [mm] 22 Real sensing range Sr [mm] 22 ± 10 % Operating distance [mm] 0...17.82 Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 1 / brass: 1 / aluminium: 1 / copper: 1 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 Correction factor K = 1 yes Operating conditions Ambient temperature [°C] -40...85 Protection IP 65; IP 66; IP 67; IP 68; IP 69K Tests / approvals EMC Vibration resistance Shock resistance Continuous shock resistance Fast temperature change Salt spray test MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B EN 60068-2-6 Fc 20 g (10...3000 Hz) / 50 sweep cycles, 1 octave per minute, in 3 axes EN 60068-2-27 Ea 100 g 11 ms half-sine; 3 shocks each in every direction of the 3 coordinate axes EN 60068-2-27 40 g 6 ms; 4000 shocks each in every direction of the 3 coordinate axes EN 60068-2-14 Na TA = -40 °C; TB = 85 °C; t1 = 30 min; t2 = < 10 s; 50 cycles EN 60068-2-52 Kb [years] severity level 5 (4 test cycles) 475 Embedded software included yes Ta UL approval -25...70 °C Enclosure type Type 1 voltage supply Limited Voltage/Current UL Approval no. A005 File number UL E174191 Mechanical data Weight [g] 77 Housing threaded type Mounting non-flush mountable Dimensions [mm] M30 x 1.5 / L = 60 Thread designation Materials M30 x 1.5 stainless steel (1.4404 / 316L); sensing face: LCP white; LED window: PEI; lock nuts: stainless steel (1.4404 / 316L) Displays / operating elements Display switching status 4 x LED, yellow ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIS283-00 — 04.09.2017 — IIS283 Inductive sensor IIK3022-BPKG/K1/V4A/US-104 Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated Connection Diagrams and graphs Installation ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IIS283-00 — 04.09.2017 —
IIS283 价格&库存
很抱歉,暂时无法提供与“IIS283”相匹配的价格&库存,您可以联系我们找货
