UGT591
UGT591
    IFM(易福门)
    Module
    ULTRASONIC DIFFUSE REFLECTION SE
UGT591 数据手册
UGT591 Ultrasonic sensor UGQ01200F2KG/US 1 2 3 LED echo LED switching status teach button Product characteristics Electrical design NPN Output function normally open / normally closed; (parameterisable + 1x voltage output) Sensing range [mm] Housing Dimensions 80...1200; (Target: 200 x 200 mm) rectangular [mm] M18 x 1 Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC; ("supply class 2" to cULus) < 35 III Reverse polarity protection yes Power-on delay time [s] < 0.3 Converter frequency [kHz] 200 Inputs / outputs Number of inputs and outputs Number of digital outputs: 1; Number of analogue outputs: 1 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — UGT591-00 — 15.12.2021 — UGT591 Ultrasonic sensor UGQ01200F2KG/US Outputs Total number of outputs 2 Electrical design NPN Number of digital outputs 1 Output function normally open / normally closed; (parameterisable + 1x voltage output) Max. voltage drop switching output DC [V] 2.2 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 5 Number of analogue outputs 1 Analogue voltage output [V] 0...10 Min. load resistance [Ω] 3000 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 80...1200; (Target: 200 x 200 mm) Blind zone [mm] 80 Angle of aperture cylindrical [°] 14; (±2) Max. deviation from the 90° angle sensor/object [°] ±4 Accuracy / deviations Temperature compensation yes Hysteresis [%]
UGT591 价格&库存
很抱歉,暂时无法提供与“UGT591”相匹配的价格&库存,您可以联系我们找货
