IN5121
IN5121
    IFM(易福门)
    Module
    INDUCTIVE SENSOR; 40 X 12 X 26 M
IN5121 数据手册
IN5121 Inductive sensor IN-3002-BPKG 1 threaded bush M3 Depth 5.8 mm Tightening torque maximum 1.2 Nm screw fixing class 8.8 when brass insert in contact with counterpart Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing Dimensions 2 rectangular [mm] 40 x 12 x 26 Electrical data Operating voltage Current consumption [V] 10...36 DC [mA] 15; (24 V) Protection class II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 250 Switching frequency DC [Hz] 1400 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 2 Real sensing range Sr [mm] 2 ± 10 % Operating distance [mm] 0...1.6 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN5121-00 — 06.03.2003 — IN5121 Inductive sensor IN-3002-BPKG Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 [°C] -25...80 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] 2577 [g] 113.1 Mechanical data Weight Housing rectangular Mounting flush mountable Dimensions [mm] 40 x 12 x 26 Materials PBT Displays / operating elements Display switching status 1 x LED, yellow Remarks Pack quantity 1 pcs. Electrical connection Cable: 2 m, PVC; 3 x 0.5 mm² Connection Core colours : BN = brown BU = blue BK = black ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN5121-00 — 06.03.2003 —
IN5121 价格&库存
很抱歉,暂时无法提供与“IN5121”相匹配的价格&库存,您可以联系我们找货
