IM5115
IM5115
    IFM(易福门)
    Module
    INDUCTIVE SENSOR; 40 X 40 X 54 M
IM5115 数据手册
IM5115 Inductive sensor IMC3020BBPKG/US-100-DPS 1 2 LED yellow LED green Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing Dimensions 20 rectangular [mm] 40 x 40 x 54 Application Special feature Gold-plated contacts Electrical data Operating voltage Current consumption Protection class Reverse polarity protection [V] [mA] 10...36 DC < 20 II yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM5115-00 — 22.09.2005 — IM5115 Inductive sensor IMC3020BBPKG/US-100-DPS Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 200 Switching frequency DC [Hz] 100 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 20 Operating distance [mm] 0...16.2 Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.4 / copper: 0.3 [% of Sr] 1...20 Operating conditions Ambient temperature [°C] -25...70 Protection IP 67 Tests / approvals EMC MTTF EN 61000-4-2 ESD 8 kV CD / 4 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] UL approval 1590 Ta -25...70 °C Enclosure type Type 1 voltage supply Class 2 File number UL E174191 Mechanical data Weight [g] 146.5 Housing rectangular Sensing face 5 positions selectable Mounting Dimensions flush mountable [mm] 40 x 40 x 54 Materials PA Displays / operating elements Display switching status 1 x LED, yellow operation 1 x LED, green Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM5115-00 — 22.09.2005 — IM5115 Inductive sensor IMC3020BBPKG/US-100-DPS Electrical connection - plug Connector: 1 x M12; Locking: locking, rotatable; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM5115-00 — 22.09.2005 —
IM5115 价格&库存
很抱歉,暂时无法提供与“IM5115”相匹配的价格&库存,您可以联系我们找货
