IFT203
IFT203
    IFM(易福门)
    Cylinder,Threaded-M12
    INDUCTIVE SENSOR; M12 X 1 / L =
IFT203 数据手册
IFT203 Inductive sensor IFB3004BBPKG/M/V4A/US-104-DPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 4 [mm] M12 x 1 / L = 45 Housing Dimensions threaded type Application Special feature Gold-plated contacts; Increased sensing range Application regular cleaning processes Electrical data Operating voltage Current consumption [V] 10...36 DC [mA] 10; (24 V) Protection class II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 800 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 4 Operating distance [mm] 0...3.25 Increased sensing range yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT203-01 — 23.03.2009 — IFT203 Inductive sensor IFB3004BBPKG/M/V4A/US-104-DPS Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 [% of Sr] 1...20 [°C] 0...100 Operating conditions Ambient temperature Protection IP 68; IP 69K; ("COP") Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] 1676 Ta UL approval 0...40 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 27 Housing threaded type Mounting flush mountable Dimensions [mm] M12 x 1 / L = 45 Thread designation Materials M12 x 1 threaded sleeve: stainless steel (1.4404 / 316L); sensing face: PEEK; lock nuts: stainless steel Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT203-01 — 23.03.2009 — IFT203 Inductive sensor IFB3004BBPKG/M/V4A/US-104-DPS Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT203-01 — 23.03.2009 —
IFT203
1. 物料型号:IFB3004BBPKG/M/V4A/US-104-DPS 2. 器件简介:IFT203型感应式传感器,具有金镀触点和增加的感应范围,适用于常规清洁过程。 3. 引脚分配:文档中没有提供具体的引脚分配图,但提到了电气设计为PNP型,通常开路。 4. 参数特性: - 感应范围:4毫米 - 操作距离:0...3.25毫米 - 工作电压:10...36DC - 电流消耗:10mA(24V) - 保护等级:IP 68; IP 69K 5. 功能详解: - 具有反向极性保护和短路保护 - 短路保护类型:脉冲式 - 过载保护:是 6. 应用信息:适用于常规清洁过程,具有增加的感应范围。 7. 封装信息: - 尺寸:M12x1/L=45毫米 - 材料:螺纹套筒为不锈钢(1.4404/316L),感应面为PEEK,锁紧螺母为不锈钢 - 显示/操作元件:4个90°LED,黄色,显示开关状态 - 配件:2个锁紧螺母 - 电气连接:1个M12插头,触点金镀
IFT203 价格&库存
很抱歉,暂时无法提供与“IFT203”相匹配的价格&库存,您可以联系我们找货
