IF6124
IF6124
    IFM(易福门)
    Cylinder,Threaded-M12
    INDUCTIVE SENSOR; M12 X 1 / L =
IF6124 数据手册
IF6124 Inductive sensor with IO-Link IFK3007-FRKG/IO/US-104 Product characteristics Electrical design PNP/NPN; (parameterisable) Output function normally open / normally closed; (selectable) Communication interface IO-Link Housing threaded type Dimensions [mm] M12 x 1 / L = 60 Electrical data Operating voltage [V] Current consumption [mA] Protection class 10...30 DC 10 III Reverse polarity protection yes Outputs Electrical design PNP/NPN; (parameterisable) Output function normally open / normally closed; (selectable) Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 600 Short-circuit protection yes Overload protection yes Detection zone Switch point IO-Link [mm] 1.3...6.5; (parameterisable) Measuring range IO-Link [mm] 0.7...7 Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.5 / copper: 0.4 [% of Sr] 3...15 Linearity error of analogue output [%] ± 2 %; (of the final value of the measuring range) Repeatability analogue output [%] ± 1 %; (of the final value of the measuring range) Temperature coefficient ± 0,3 %/K; (of the final value of the measuring range) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF6124-01 — 22.05.2019 — IF6124 Inductive sensor with IO-Link IFK3007-FRKG/IO/US-104 Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 CDV Smart Sensor: Device Identification; Device Diagnosis; Device Teach Channel; Binary Data Channel; Process Data Variable Profiles SIO mode yes Required master port type Min. process cycle time A [ms] Supported DeviceIDs 3 Type of operation DeviceID Default 791 Operating conditions Ambient temperature [°C] -40...85 Protection IP 65; IP 66; IP 67; IP 68; IP 69K Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B EN 60068-2-6 Fc 20 g (10...3000 Hz) / 50 sweep cycles, 1 octave per minute, in 3 axes Shock resistance EN 60068-2-27 Ea 100 g 11 ms half-sine; 3 shocks each in every direction of the 3 coordinate axes Continuous shock resistance EN 60068-2-29 Eb 40 g 6 ms; 4000 shocks each in every direction of the 3 coordinate axes Fast temperature change EN 60068-2-14 Na TA = -40 °C; TB = 85 °C; t1 = 30 min; t2 = < 10 s; 50 cycles Vibration resistance MTTF [years] UL approval 672 Ta -25...70 °C Enclosure type Type 1 voltage supply Limited Voltage/Current UL Approval no. A008 File number UL E174191 Mechanical data Weight [g] 27.1 Housing threaded type Mounting non-flush mountable Dimensions Thread designation Materials [mm] M12 x 1 / L = 60 M12 x 1 brass white bronze coated; sensing face: PBT orange; LED window: PEI; lock nuts: brass white bronze coated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF6124-01 — 22.05.2019 — IF6124 Inductive sensor with IO-Link IFK3007-FRKG/IO/US-104 Displays / operating elements switching status 4 x LED, yellow SIO mode Display output stage supplied with current LED, yellow lights IO-Link mode target in measuring range LED, yellow lights Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12 4: OUT / IO-Link ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF6124-01 — 22.05.2019 —
IF6124 价格&库存
很抱歉,暂时无法提供与“IF6124”相匹配的价格&库存,您可以联系我们找货
