IN5225
IN5225
    IFM(易福门)
    Module
    INDUCTIVE SENSOR; 40 X 26 X 26 M
IN5225 数据手册
IN5225 Inductive dual sensor for valve actuators IND3004DBPKG/US-100-DPV Product characteristics Electrical design PNP Output function 2 x normally open Sensing range [mm] Housing Dimensions 4 rectangular [mm] 40 x 26 x 26 Application Special feature Gold-plated contacts Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...36 DC 15 II Reverse polarity protection yes Outputs Electrical design PNP Output function 2 x normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 250 Switching frequency DC [Hz] 1300 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 4 Real sensing range Sr [mm] 4 ± 10 % Operating distance [mm] 0...3.25 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN5225-00 — 15.12.2015 — IN5225 Inductive dual sensor for valve actuators IND3004DBPKG/US-100-DPV Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 [°C] -25...80 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EN 60947-5-2 EMC EN 55011 MTTF [years] UL approval class B 1064 Ta 0...40 °C Enclosure type Type 1 voltage supply Hazardous voltage File number UL E174191 Mechanical data Weight [g] 40 Housing rectangular Mounting non-flush mountable Dimensions [mm] 40 x 26 x 26 Materials Tightening torque PBT [Nm] 0.6...1.5; (Lock nut) Displays / operating elements Display switching status 2 x LED, yellow Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN5225-00 — 15.12.2015 — IN5225 Inductive dual sensor for valve actuators IND3004DBPKG/US-100-DPV Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN5225-00 — 15.12.2015 —
IN5225 价格&库存
很抱歉,暂时无法提供与“IN5225”相匹配的价格&库存,您可以联系我们找货
