UGT510
UGT510
    IFM(易福门)
    Cylinder,Threaded-M18
    ULTRASONIC DIFFUSE REFLECTION SE
UGT510 数据手册
UGT510 Ultrasonic sensor UGA01600E1KG/IO-LINK/US 1 2 LEDs teach button Product characteristics Electrical design PNP Output function normally open / normally closed; (parameterisable + 1x current output) Sensing range [mm] Communication interface IO-Link Housing Dimensions 150...1600; (Target: 200 x 200 mm) threaded type [mm] M18 x 1 / L = 97.5 Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC; ("supply class 2" to cULus) 55 III Reverse polarity protection yes Power-on delay time [s] < 0.3 Converter frequency [kHz] 230 Inputs / outputs Number of inputs and outputs Number of digital outputs: 1; Number of analogue outputs: 1 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — UGT510-01 — 15.10.2020 — UGT510 Ultrasonic sensor UGA01600E1KG/IO-LINK/US Outputs Total number of outputs 2 Electrical design PNP Number of digital outputs 1 Output function normally open / normally closed; (parameterisable + 1x current output) Max. voltage drop switching output DC [V] 2.2 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 3 Number of analogue outputs Analogue current output Max. load 1 [mA] [Ω] 4...20 500 Short-circuit protection yes Overload protection yes Resolution of analogue output < 3 mm Detection zone Sensing range [mm] 150...1600; (Target: 200 x 200 mm) Blind zone [mm] 150 Angle of aperture cylindrical [°] 15; (±2) Max. deviation from the 90° angle sensor/object [°] ±4 Accuracy / deviations Temperature compensation yes Hysteresis [%]
UGT510 价格&库存
很抱歉,暂时无法提供与“UGT510”相匹配的价格&库存,您可以联系我们找货
