I85000
I85000
    IFM(易福门)
    Module
    TUBE SENSOR; 70 X 20 X 12 MM; OP
I85000 数据手册
I85000 Inductive tube sensor I8-3014-BPKG/AS-610-DPS 1 2 3 Sensing face LED operating status LED switching status Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing < 14 rectangular Dimensions [mm] 70 x 20 x 12 Application Operating principle static Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...35 DC < 15 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2 200 Short-circuit protection yes Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — I85000-00 — 06.11.2009 — I85000 Inductive tube sensor I8-3014-BPKG/AS-610-DPS Detection zone Sensing range [mm] < 14 Resolution of steel ball (diameter) [mm] 3 Max. part speed [m/s] 35 Pulse stretching [ms] 100 Max. fall time [ms] 100 Response time [ms] < 0.5 [°C] -25...70 Response times Operating conditions Ambient temperature Protection IP 67 Tests / approvals MTTF [years] UL approval 1332 Ta -25...70 °C Enclosure type Type 4X (indoor use only) / 12 and 13 voltage supply Class 2 File number UL E174191 Mechanical data Weight [g] 50 Housing rectangular Dimensions [mm] 70 x 20 x 12 Materials housing: PC Displays / operating elements Display switching status 1 x LED, yellow operation 1 x LED, green Accessories Items supplied fixing straps: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M8 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — I85000-00 — 06.11.2009 — I85000 Inductive tube sensor I8-3014-BPKG/AS-610-DPS Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — I85000-00 — 06.11.2009 —
I85000 价格&库存
很抱歉,暂时无法提供与“I85000”相匹配的价格&库存,您可以联系我们找货
