IFC204
IFC204
    IFM(易福门)
    Cylinder,Threaded-M12
    INDUCTIVE SENSOR; M12 X 1 / L =
IFC204 数据手册
IFC204 Inductive sensor IFB3004BBPKG/US-104 Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 4 [mm] M12 x 1 / L = 45 Housing Dimensions threaded type Application Special feature Gold-plated contacts; Increased sensing range Application Use in machine tools, coolants and lubricants Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC < 10 II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 700 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 4 Real sensing range Sr [mm] 4 ± 10 % Operating distance [mm] 0...3.24 Increased sensing range yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFC204-01 — 06.10.2014 — IFC204 Inductive sensor IFB3004BBPKG/US-104 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] -25...70 Operating conditions Ambient temperature Protection IP 68; ("Coolant") Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] 1528 Embedded software included yes Ta UL approval 0...40 °C Enclosure type Type 1 voltage supply Hazardous voltage UL Approval no. A003 File number UL E174191 Mechanical data Weight [g] 24.5 Housing threaded type Mounting flush mountable Dimensions [mm] M12 x 1 / L = 45 Thread designation Materials M12 x 1 brass white bronze coated; sensing face: LCP white; LED window: PEI; lock nuts: brass white bronze coated Displays / operating elements Display switching status 4 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFC204-01 — 06.10.2014 — IFC204 Inductive sensor IFB3004BBPKG/US-104 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFC204-01 — 06.10.2014 —
IFC204 价格&库存
很抱歉,暂时无法提供与“IFC204”相匹配的价格&库存,您可以联系我们找货
