GI712S
GI712S
    IFM(易福门)
    Cylinder,Threaded-M18
    FAIL-SAFE INDUCTIVE SENSOR; M30
GI712S 数据手册
GI712S Fail-safe inductive sensor GIIA4010-2PS/SIL2/US Product characteristics Electrical design PNP Output function 2 x OSSD (A1 and A2) Enable zone [mm] Housing Dimensions 1...10 threaded type [mm] M30 x 1.5 / L = 70 Application Special feature Gold-plated contacts Type of operation continuous operation (maintenance-free) Safety-related function safe state when undamped Application industrial application Electrical data Operating voltage [V] 19.2...30 DC Rated insulation voltage [V] 30 Current consumption [mA] Protection class III Reverse polarity protection Max. power-on delay time < 30 yes [ms] 1000 Outputs Electrical design PNP Output function 2 x OSSD (A1 and A2) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Output data 2.5; (30 mA) 100 Interface type C class 1 Output voltage at 24 V compatible with EN 61131-2 inputs type 1, 2 Short-circuit protection yes Overload protection no Max. capacitive load CL_max [nF] 20 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — EN-GB — GI712S — 19.05.2016 — GI712S Fail-safe inductive sensor GIIA4010-2PS/SIL2/US Detection zone Enable zone [mm] 1...10 Safe switching-off distance s(ar) [mm] 15 Response time to safety request [ms] 10 Response time when approaching the enable zone [ms] 1 Risk time (response time for safety-related faults) [ms] 30 Response times Operating conditions Applications Ambient temperature class C to EN 60654-1 weatherproof application [°C] -25...70 Note on ambient temperature Ambient temperature operational life ≤ 87600 h [°C] 10...40 Note on ambient temperature operational life ≤ 175200 h Rate of temperature change [K/min] Max. relative air humidity Air pressure Max. height above sea level 0.5 [%] briefly: 5...95 %; permanent: 5...70 % [kPa] 80...106 [m] 2000 Ionising radiation not permissible Salt spray no Protection IP 65; IP 67 Tests / approvals IEC 60947-5-2 IEC 60947-5-3 EN 60947-5-3 EMC EN 61000-4-2 ESD 6 kV CD / 8 kV AD EN 61000-4-3 HF radiated 20 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 61000-4-8 30 A/m EN 55011 class B Shock resistance IEC 60947-5-2 Vibration resistance IEC 60947-5-2 Ta UL approval -25...70 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — EN-GB — GI712S — 19.05.2016 — GI712S Fail-safe inductive sensor GIIA4010-2PS/SIL2/US Safety classification ISO 13849-1 category 2, PL d IEC 61508 SIL 2 IEC 62061 SIL cl 2 Mission time TM [h] ≤ 175200 Mission time TM (additional indication) Safety-related reliability PFHD 20 years [1/h] 1.0E-07 Mechanical data Weight [g] 204.5 Housing threaded type Mounting flush mountable Dimensions [mm] M30 x 1.5 / L = 70 Thread designation M30 x 1.5 Materials brass white bronze coated; PBT Displays / operating elements Display operation 1 x LED, green signal 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Unless stated otherwise, all data refer to the reference target plate to IEC 60947-5-2 over the whole temperature range. Remarks (FE360 = ST37K) 30x30x1 mm Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — EN-GB — GI712S — 19.05.2016 — GI712S Fail-safe inductive sensor GIIA4010-2PS/SIL2/US Connection 1: safety-related logic unit ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — EN-GB — GI712S — 19.05.2016 —
GI712S 价格&库存
很抱歉,暂时无法提供与“GI712S”相匹配的价格&库存,您可以联系我们找货
