I7R215
I7R215
    IFM(易福门)
    Module
    RING SENSOR; 60 X 35 X 20 MM; IN
I7R215 数据手册
I7R215 Inductive ring sensor I7R3025-FPKG/DY/US-100-IPF 1 2 3 sensitivity Output function pulse stretching time Product characteristics Electrical design PNP Output function normally open / normally closed; (selectable) Housing Dimensions circular [mm] 60 x 35 x 20 Application Operating principle dynamic Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...35 DC < 20 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open / normally closed; (selectable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2 200 Short-circuit protection yes Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — I7R215-01 — 09.06.2016 — I7R215 Inductive ring sensor I7R3025-FPKG/DY/US-100-IPF Detection zone Resolution of steel ball (diameter) [mm] 1.2 Max. part speed [m/s] 35 [ms] 0.1...150 Response times Pulse stretching Pulse stretching adjustable yes Max. fall time [ms] 0.2 Response time [ms] < 0.2 Ambient temperature [°C] -25...70 Max. relative air humidity [%] 50; (Ambient temperature 70 °C) Operating conditions Protection IP 67 Tests / approvals MTTF [years] UL approval 556 Ta -25...70 °C Enclosure type Type 4X (indoor use only) / 12 and 13 voltage supply Class 2 File number UL E174191 Mechanical data Weight [g] 52.7 Housing circular Dimensions [mm] 60 x 35 x 20 Inside diameter [mm] 25.1 Materials housing: PA; ring: POM Displays / operating elements Display switching status 1 x LED, yellow Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — I7R215-01 — 09.06.2016 — I7R215 Inductive ring sensor I7R3025-FPKG/DY/US-100-IPF Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — I7R215-01 — 09.06.2016 —
I7R215 价格&库存
很抱歉,暂时无法提供与“I7R215”相匹配的价格&库存,您可以联系我们找货
