IGT203
IGT203
    IFM(易福门)
    Cylinder,Threaded-M18
    INDUCTIVE SENSOR; M18 X 1 / L =
IGT203 数据手册
IGT203 Inductive sensor IGB3008BBPKG/M/V4A/US-104-DPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing Dimensions 8 threaded type [mm] M18 x 1 / L = 46 Application Special feature Gold-plated contacts; Increased sensing range Application regular cleaning processes Electrical data Operating voltage Current consumption [V] 10...36 DC [mA] 10; (24 V) Protection class II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 600 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 8 Operating distance [mm] 0...6.48 Increased sensing range yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT203-01 — 20.04.2009 — IGT203 Inductive sensor IGB3008BBPKG/M/V4A/US-104-DPS Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.4 / copper: 0.3 [% of Sr] 1...20 [°C] 0...100 Operating conditions Ambient temperature Protection IP 68; IP 69K; ("COP") Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] 1727 Ta UL approval 0...40 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 44.7 Housing threaded type Mounting flush mountable Dimensions [mm] M18 x 1 / L = 46 Thread designation Materials M18 x 1 threaded sleeve: stainless steel (1.4404 / 316L); sensing face: PEEK; lock nuts: stainless steel Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT203-01 — 20.04.2009 — IGT203 Inductive sensor IGB3008BBPKG/M/V4A/US-104-DPS Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT203-01 — 20.04.2009 —
IGT203 价格&库存
很抱歉,暂时无法提供与“IGT203”相匹配的价格&库存,您可以联系我们找货
