GG505S
GG505S
    IFM(易福门)
    Cylinder,Threaded-M18
    FAIL-SAFE INDUCTIVE SENSOR; M18
GG505S 数据手册
GG505S Fail-safe inductive sensor GIGA-4015-US /V4A Product characteristics Output function Enable zone clock signal [mm] Housing Dimensions 3...6 threaded type [mm] M18 x 1 / L = 90 Application Special feature Gold-plated contacts Type of operation continuous operation (maintenance-free) Safety-related function safe state when undamped Application industrial application Electrical data Operating voltage Current consumption [V] [mA] Protection class < 15 III Reverse polarity protection Max. power-on delay time 19.2...30 DC yes [ms] 5000 [nF] 2 Inputs Max. input capacitance Ci_max Outputs Output function clock signal Output data Interface type B Short-circuit protection Max. capacitive load CL_max yes [nF] 20 Enable zone [mm] 3...6 Safe switching-off distance s(ar) [mm] 15 Detection zone ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — EN-GB — GG505S — 06.12.2017 — GG505S Fail-safe inductive sensor GIGA-4015-US /V4A Response times Response time to safety request [ms] 20 Response time when approaching the enable zone [ms] 200; (typical 100) Operating conditions Applications Ambient temperature class C to EN 60654-1 weatherproof application [°C] -25...70 Note on ambient temperature Ambient temperature operational life ≤ 87600 h [°C] 10...40 Note on ambient temperature operational life ≤ 175200 h Rate of temperature change [K/min] Max. relative air humidity Air pressure 0.5 [%] briefly: 5...95 %; permanent: 5...70 % [kPa] 80...106 Ionising radiation not permissible Salt spray no Protection IP 68; IP 69K; (to EN 60529) Tests / approvals IEC 60947-5-2 IEC 60947-5-3 EMC EN 61000-4-2 ESD 6 kV CD / 8 kV AD EN 61000-4-3 HF radiated 20 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 61000-4-8 30 A/m EN 55011 class B Shock resistance IEC 60947-5-2 Vibration resistance IEC 60947-5-2 UL approval Ta -25...70 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Safety classification ISO 13849-1 category 3, PL e IEC 61508 Mission time TM SIL 3 [h] Mission time TM (additional indication) Safety-related reliability PFHD ≤ 175200 20 years [1/h] 1E-08 Mechanical data Weight [g] 190 Housing threaded type Mounting non-flush mountable Dimensions Thread designation Materials [mm] M18 x 1 / L = 90 M18 x 1 stainless steel; PBT ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — EN-GB — GG505S — 06.12.2017 — GG505S Fail-safe inductive sensor GIGA-4015-US /V4A Displays / operating elements Display operation 1 x LED, green signal 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Unless stated otherwise, all data refer to the reference target plate to IEC 60947-5-2 over the whole temperature range. Remarks (FE360 = ST37K) 24x24x1 mm Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated Connection 1= safety-related logic unit ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — EN-GB — GG505S — 06.12.2017 —
GG505S 价格&库存
很抱歉,暂时无法提供与“GG505S”相匹配的价格&库存,您可以联系我们找货
