KI0054
KI0054
    IFM(易福门)
    Cylinder,Threaded-M18
    CAPACITIVE SENSOR; M30 X 1.5 / L
KI0054 数据手册
KI0054 Capacitive sensor KI-2200NFBOAP2T/LS100 1 2 LED ring programming buttons Product characteristics Output function Sensing range normally open / normally closed; (selectable) [mm] Housing Dimensions 5...40; (programming buttons) threaded type [mm] M30 x 1.5 / L = 90 Application Installation detection through non-metallic container wall or on bypass pipes Media dry bulk material; liquids Electrical data Frequency AC Operating voltage Protection class Reverse polarity protection Measuring principle [Hz] 47...63 [V] 30...250 AC / 20...250 DC II yes capacitive ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI0054-00 — 05.02.2010 — KI0054 Capacitive sensor KI-2200NFBOAP2T/LS100 Outputs Output function normally open / normally closed; (selectable) Max. voltage drop switching output DC [V] 8 Max. voltage drop switching output AC [V] 10 Max. leakage current [mA] 2.5 (250 V AC) / 1.7 (110 V AC) / 1.5 (24 V DC) Permanent current rating of switching output AC [mA] 100; (150 (...40 °C)) Permanent current rating of switching output DC [mA] 100; (150 (...40 °C)) Short-time current rating of switching output [mA] 1000; (20 ms / 0,5 Hz) Switching frequency AC [Hz] 10 Switching frequency DC [Hz] 10 Short-circuit proof no Overload protection no Detection zone Sensing range [mm] 5...40; (programming buttons) Sensing range adjustable yes Factory setting sensing range [mm] 20 Real sensing range Sr [mm] 20 ± 10 % Accuracy / deviations Correction factor glass: 0.3 / water: 1 / ceramics: 0.2 / PVC: 0.1 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -20...20 [°C] -25...80 Operating conditions Ambient temperature Note on ambient temperature temperature of the sensing face: -25...110 °C Protection IP 65; IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] 321 Mechanical data Weight [g] 109.8 Housing threaded type Mounting non-flush mountable Dimensions [mm] M30 x 1.5 / L = 90 Thread designation Materials M30 x 1.5 housing: PBT; pushbuttons: TPE-U; LED window: PC Displays / operating elements Display switching status 1 x LED ring, yellow plug lights translucently Teach function yes Electronic lock yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI0054-00 — 05.02.2010 — KI0054 Capacitive sensor KI-2200NFBOAP2T/LS100 Electrical connection Required protection miniature fuse to IEC60127-2 sheet 1; ≤ 2 A; fast acting Accessories Items supplied lock nuts: 2 Remarks Note: Remarks Check the safe functioning of the unit after a short circuit. Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x 1/2" Note miniature fuse to IEC60127-2 sheet 1 ≤ 2 A fast acting ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI0054-00 — 05.02.2010 —
KI0054 价格&库存
很抱歉,暂时无法提供与“KI0054”相匹配的价格&库存,您可以联系我们找货
