IER206
IER206
    IFM(易福门)
    Cylinder,Threaded-M8
    INDUCTIVE SENSOR; M8 X 1 / L = 4
IER206 数据手册
IER206 Inductive full-metal sensor IEB2002BARKG/AM/SC/UP/0,3M/US/ Product characteristics Electrical design PNP/NPN Output function normally open Sensing range [mm] Housing Dimensions 2 threaded type [mm] M8 x 1 / L = 45 Application Gold-plated contacts; Increased sensing range; Fullmetal housing; Optical setting aid; anti-spatter Special feature Application Pressure rating Use in welding applications [bar] Note on pressure rating 50 sensing face Electrical data Operating voltage Protection class Reverse polarity protection [V] 10...36 DC III yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IER206-00 — 16.09.2010 — IER206 Inductive full-metal sensor IEB2002BARKG/AM/SC/UP/0,3M/US/ Outputs Electrical design PNP/NPN Output function normally open Max. voltage drop switching output DC [V] 4.5 Minimum load current [mA] 2 Max. leakage current [mA] 0.75 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 150 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 2 Operating distance [mm] 0...1.6 Increased sensing range yes Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.6 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 [% of Sr] 1...20 Operating conditions Ambient temperature [°C] -25...70 Protection IP 67 Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B Impact resistance MTTF 1J [years] 1460 Ta UL approval 0...40 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 35.9 Housing threaded type Mounting flush mountable Dimensions Thread designation Materials Full-metal housing [mm] M8 x 1 / L = 45 M8 x 1 housing: stainless steel (1.4404 / 316L) anti-spatter; sensing face: stainless steel (1.4404 / 316L) anti-spatter; lock nuts: stainless steel (1.4404 / 316L) anti-spatter yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IER206-00 — 16.09.2010 — IER206 Inductive full-metal sensor IEB2002BARKG/AM/SC/UP/0,3M/US/ Displays / operating elements switching status Display 1 x LED, green setting aid Optical setting aid 1 x LED, red yes Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Cable: 0.3 m, PUR; 2 x 0.34 mm² Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IER206-00 — 16.09.2010 —
IER206 价格&库存
很抱歉,暂时无法提供与“IER206”相匹配的价格&库存,您可以联系我们找货
