IGC250
IGC250
    IFM(易福门)
    Cylinder,Threaded-M18
    INDUCTIVE SENSOR; M18 X 1 / L =
IGC250 数据手册
IGC250 Inductive full-metal sensor IGK34,5-APKG/AM/US-104/K0 Product characteristics Electrical design PNP Output function normally closed Sensing range [mm] Housing Dimensions 4.5 threaded type [mm] M18 x 1 / L = 70 Application Special feature Gold-plated contacts; Full-metal housing; Correction factor K = 0 Application Use in machine tools, coolants and lubricants Media ferrous only; aluminium chip immune Pressure rating [bar] Note on pressure rating 100 sensing face Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...36 DC < 20 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally closed Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 100 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGC250-00 — 15.09.2009 — IGC250 Inductive full-metal sensor IGK34,5-APKG/AM/US-104/K0 Detection zone Sensing range [mm] 4.5 Operating distance [mm] 0...3.64 Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.5 [% of Sr] 1...20 Correction factor K = 0 yes Operating conditions Ambient temperature [°C] -25...70 Protection IP 68; ("Coolant") Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B Impact resistance MTTF 1J [years] 1258 Ta UL approval 0...40 °C Enclosure type Type 1 voltage supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 55.3 Housing threaded type Mounting flush mountable Dimensions [mm] M18 x 1 / L = 70 Thread designation Materials M18 x 1 housing: stainless steel (1.4404 / 316L); sensing face: stainless steel (1.4404 / 316L); LED window: PA; lock nuts: stainless steel (1.4404 / 316L) Full-metal housing yes Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGC250-00 — 15.09.2009 — IGC250 Inductive full-metal sensor IGK34,5-APKG/AM/US-104/K0 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGC250-00 — 15.09.2009 —
IGC250 价格&库存
很抱歉,暂时无法提供与“IGC250”相匹配的价格&库存,您可以联系我们找货
