O7E200
O7E200
    IFM(易福门)
    THROUGH-BEAM SENSOR; RED LIGHT;
O7E200 数据手册
O7E200 Through-beam sensor receiver O7E-DPKG/0,20M/AS receiver in upper lens Product characteristics Type of light red light Housing Dimensions rectangular [mm] 20.3 x 15 x 9 Application Function principle Through-beam sensor Electrical data Operating voltage Current consumption [V] 10...30 DC [mA] 10; ((24 V)) Protection class III Reverse polarity protection yes Type of light red light Outputs Electrical design PNP Output function dark-on mode Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 1000 Short-circuit protection yes Type of short-circuit protection pulsed Detection zone Transmitter / receiver Range receiver [m] Range adjustable Light spot dimensions refer to 0...1.5 no at maximum range ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O7E200-00 — 18.08.2009 — O7E200 Through-beam sensor receiver O7E-DPKG/0,20M/AS Operating conditions Ambient temperature [°C] -25...60 Protection IP 65 Tests / approvals EMC EN 60947-5-2 MTTF [years] 1312 [g] 14.5 Mechanical data Weight Housing Dimensions rectangular [mm] 20.3 x 15 x 9 Materials PA Lens material PMMA Lens alignment side lens Displays / operating elements Display switching status 1 x LED, yellow Remarks Remarks Pack quantity operating voltage "supply class 2" according to UL 1 pcs. Electrical connection Cable: 0.2 m, PUR; 3 x 0.14 mm² Connector: 1 x M8; Locking: snap-fit Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O7E200-00 — 18.08.2009 —
O7E200 价格&库存
很抱歉,暂时无法提供与“O7E200”相匹配的价格&库存,您可以联系我们找货
