O6E309
O6E309
    IFM(易福门)
    THROUGH-BEAM SENSOR; RED LIGHT;
O6E309 数据手册
O6E309 Through-beam sensor receiver O6E-FPKG/AS/4P 1: 2: 3: output function switch potentiometer sensitivity Light incidence Product characteristics Type of light red light Communication interface IO-Link Housing Dimensions rectangular [mm] 34.8 x 13 x 21 Application Function principle Through-beam sensor Electrical data Operating voltage Current consumption [V] 10...30 DC [mA] 7; ((24 V)) Protection class III Reverse polarity protection yes Type of light Wave length red light [nm] 633 Outputs Electrical design PNP Output function light-on/dark-on mode; (selectable) Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 1000 Short-circuit protection Type of short-circuit protection yes pulsed ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6E309-00 — 21.01.2021 — O6E309 Through-beam sensor receiver O6E-FPKG/AS/4P Detection zone Transmitter / receiver receiver Range [m] < 10 Range adjustable yes Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Device Identification; Binary Data Channel SIO mode yes Required master port type Min. process cycle time A [ms] IO-Link process data (cyclical) IO-Link functions (acyclical) 2.5 function bit length process value 8 binary switching information 1 application specific tag; operating hours counter; switching cycles counter Supported DeviceIDs Type of operation DeviceID Default 421 Operating conditions Ambient temperature [°C] -25...80 Protection IP 65; IP 67; IP 68; IP 69K Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 716 UL Approval no. E010 Mechanical data Weight [g] 34.1 Housing Dimensions rectangular [mm] Materials 34.8 x 13 x 21 housing: stainless steel (1.4404 / 316L); plastics: PPSU; Sealing: EPDM Lens material PMMA Lens alignment side lens Displays / operating elements Display switching status 1 x LED, yellow operation 1 x LED, green Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. Electrical connection Connector: 1 x M8 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6E309-00 — 21.01.2021 — O6E309 Through-beam sensor receiver O6E-FPKG/AS/4P Connection 4 OUT / IO-Link Diagrams and graphs excess gain graph x: distance [mm] y: excess gain factor ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6E309-00 — 21.01.2021 —
O6E309 价格&库存
很抱歉,暂时无法提供与“O6E309”相匹配的价格&库存,您可以联系我们找货
