HSEC8-170-01-L-DV-A-K-TR
    SAMTEC(申泰)
    SMD,P=0.8mm
HSEC8-170-01-L-DV-A-K-TR 数据手册
HIGH-SPEED EDGE CARD SYSTEMS 0.60 mm, 0.80 mm and 1.00 mm PITCH FEATURES & BENEFITS • 56 Gbps PAM4 performance • PCI Express® 3.0, 4.0 and 5.0 • Edge Rate® contacts optimized for signal integrity performance and cycle life • Up to 200 positions available • Vertical, right-angle, edge mount, pass-through orientations • Power/signal combo, press-fit tails, rugged weld tabs, locks and latches • Mating cable assemblies available Rugged tucked beam technology (HTEC8) KEY SPECIFICATIONS Differential pair for increased speed (HSEC8-DP) Custom designs allow for misalignment in the X-Y axes (HSEC1) SERIES PITCH TOTAL POSITIONS INSULATOR MATERIAL CONTACT MATERIAL OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING LEAD-FREE SOLDERABLE HSEC6 0.60 mm 56-168 Black LCP Copper Alloy -55 ℃ to +125 ℃ 0.8 A (12 pins) 300 VAC Yes HTEC8 0.80 mm 40-200 Black LCP Copper Alloy -55 ℃ to +125 ℃ 3.0 A (2 pins) 215 VAC Yes HSEC8 0.80 mm 18-200 Black LCP BeCu -55 ℃ to +125 ℃ 2.8 A (2 pins) 240 VAC Yes HSEC1 1.00 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.2 A (2 pins) 215 VAC Yes F-221 samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.80 mm) .0315" PITCH • VERTICAL EDGE CARD SOCKET - HSEC8 POSITIONS PER ROW 1 09, 10, 13, 20, 25, 30, 37, 40, 49, 50, 60, 70, 80, 100 (13, 25, 49 only available with -L or -L2 option; 09 only available with -L2 option; 37 only available with -L option) - - CARD THICKNESS –01 - PLATING OPTION - DV - A –L = (1.60 mm) .062" thick card –K = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on tail –03 = (2.36 mm) .093" thick card OTHER OPTIONS = Polyimide Pick & Place Pad –BL = Board Locks; -01 card only (Weld tab standard) –S = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on tail –L = Latching Option; -01 card only (13, 25, 37, 49 only) (Weld tab standard) –L2 = ECDP Latching; -01 card only (09, 13, 25, 49 only) (For use with ECDP) (Weld tab standard) No. of Positions x (0.80) .0315 + (7.80) .307 HSEC8-DV No. of Positions x (0.80) .0315 + (7.80) .307 Card Mates: (1.60 mm) .062" card (2.36 mm) .093" card HSC8 –WT = Weld tab (7.00) .276 –TR (7.00) .276 A B = Tape & Reel (09 - 70 only) A B Cable Mates: ECDP (7.98) .314 (No. of Positions + 6) x (0.80) .0315 + (0.60) .024 (7.98) .314 (1.32) .052 09, 13, 25, 37 & 40 (No. of Positions + 6) xTHRU (0.80) .0315 (0.60) .024 100+POSITIONS No. of Positions x (0.80) .0315 + (4.60) .181 –FR = Full Reel Tape & Reel (must order max. quantities per reel; contact Samtec for quantity breaks) (09-70 only) (1.32) .052 No. of Positions (5.60) .220x (0.80) .0315 + (4.60) .181 (5.60) .220 No. of Positions x (0.80) .0315 + (2.20) .087 No. of Positions x (0.80) .0315 + (2.20) .087 10, 20, & 30 POSITIONS OTHER SOLUTIONS POSITIONS PER ROW A For complete edge card system with cards and sockets, visit samtec.com?RU8. 09*† 13*† 25*† For a card to mate with an HSEC8 socket, visit samte.com?HSC8 10 YEAR MFG EXTENDED LIFE PRODUCT HIGH MATING CYCLES B CABLE CONNECTOR (4.50) .177 (11.80) .465 ECDP-04 HSEC8-109-L2 (6.10) .240 (15.00) .591 ECDP-08 HSEC8-113-L2 (6.10) .240 (24.60) .969 ECDP-16 HSEC8-125-L2 37† (18.10) .713 (34.20) 1.346 ECDP-32 HSEC8-149-L2 40 (18.90) .744 (36.60) 1.441 49*† (22.90) .902 (43.80) 1.724 50 (22.90) .902 (44.60) 1.756 (52.60) 2.071 60 (26.90) 1.059 70† (26.90) 1.059 (60.60) 2.386 80† (26.90) 1.059 (68.60) 2.701 100† (26.90) 1.059 (84.60) 3.331 Positions where no dimensions are given do not have keying feature. * Mates with ECDP Series † Available with -01 Card Only Note: Some sizes, styles and options are non-standard, non-returnable. View complete specifications at: samtec.com?HSEC8-DV samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
HSEC8-170-01-L-DV-A-K-TR 价格&库存
很抱歉,暂时无法提供与“HSEC8-170-01-L-DV-A-K-TR”相匹配的价格&库存,您可以联系我们找货
  • 275+41.63079275+5.36300
  • 825+36.93306825+4.75783
库存:47
  • 1+71.105581+9.16003
  • 10+60.3886810+7.77945
  • 25+56.6031925+7.29179
  • 50+53.8983350+6.94334
  • 100+51.32591100+6.61196
库存:47
    • 25+38.63076
    • 100+30.00987
    • 500+27.96649
    • 1000+22.64645
    • 4700+17.13295
    • 12400+16.25031
    库存:94875
      • 1+54.23760
      • 10+46.26720
      • 30+41.40720
      库存:25
