PPRN214EFCN
PPRN214EFCN
    SULLINS
    CONN HDR 84POS 0.079 GOLD PCB
PPRN214EFCN 数据手册
1 A No. of B C D E WI-0901 SPECIFICATIONS DIMENSIONS Current Rating: Insulator Resistance: 1 Amp 5000 Mega Ohms min. Contact Resistance: 20 milli Ohm Max. Dielectric Withstanding: 500 VAC Operating Temperature: Max. Processing Temp: -40 Degrees C. to +105 Degrees C. 230 Degrees C. for 30~60 seconds (260 Degree C. for 10 seconds) Phosphor Bronze. Contacts A B 24 10.00 12.40 28 12.00 14.40 32 14.00 16.40 36 16.00 18.40 40 18.00 20.40 44 20.00 22.40 48 22.00 24.40 52 24.00 26.40 Contact Material: 56 26.00 28.40 Insulator Material: 60 28.00 30.40 64 30.00 32.40 68 32.00 34.40 72 34.00 36.40 76 36.00 38.40 80 38.00 40.40 84 40.00 42.40 88 42.00 44.40 92 44.00 46.40 96 46.00 48.40 100 48.00 5040 104 50.00 52.40 108 52.00 54.40 112 54.00 56.40 116 56.00 58.40 120 58.00 60.40 Contact Finish: 8.00•+-0.15 Polyester,UL 94V-0 Standard: Nylon-6T Selective Plating, Gold/Tin 1 2.00•+-0.10 A •+-0.10 B •+-0.20 2 2 6.30•+-0.15 2.40•+-0.20 (SOLDER AREA) 0.50•+-0.05 0.40•+-0.03 2.00•+-0.10 3 3 SULLINS 801 E. MISSION RD. SAN MARCOS, CA 92069 GENERAL TOLERANCE XX. •+XXX. •+X. •+- 0.20 .XXX •+.X •+- 0.10 X.ß •+.XX •+- 0.05 A .Xß •+- SCALE UNIT SIZE DRAWN 3:1 mm DATE CHECK DATE APPROVE DATE DWG. NO. T0025 REV. TITLE SHEET PARTS NO. A4 B C PPRNXX4EFCN D E FM-0524
PPRN214EFCN 价格&库存
很抱歉,暂时无法提供与“PPRN214EFCN”相匹配的价格&库存,您可以联系我们找货
