JBXEP2G19FCSDS
JBXEP2G19FCSDS
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT FMALE 19POS GOLD CRIMP
JBXEP2G19FCSDS 数据手册
JBX SERIES Push-Pull Coupling Mechanism Connector Overview JBX Series | Contents Connector 2 contacts ......................................................... 3 contacts ......................................................... 4 contacts ......................................................... 5 contacts ......................................................... 6 contacts ......................................................... 7 contacts ......................................................... 8 contacts ......................................................... 9 contacts ......................................................... 10 contacts ....................................................... 12 contacts ....................................................... 14 contacts ....................................................... 16 contacts ....................................................... 18 contacts ....................................................... 19 contacts ....................................................... 22 contacts ....................................................... 30 contacts ....................................................... 16 36 56 80 96 112 132 158 164 184 194 198 204 214 220 224 Description ....................................................... Packaging ......................................................... Solder Contacts ................................................ Crimp Contacts ................................................ Straight PCB Contacts ...................................... 90° PCB Contacts ............................................. Tooling .............................................................. 230 230 231 232 233 234 235 Contacts 06 07 08 10 12 Technical Information Typical Applications .......................................... Features & Benefits .......................................... Range Overview ............................................... Layouts ............................................................. General Technical Characteristics ..................... Contacts Technical Information Receptacle Assembly Instructions .................... Plug Assembly Instructions ............................... Collets Selection According to Cable Diameters . Rated Current & Working Voltage .................... UL94 + UL1977 ................................................. What is NEMA Rating ? .................................... Ethernet for the Layman ................................... 240 245 251 252 253 257 258 Appendices Glossary of Terms ............................................. 262 Drilling Pattern ................................................. 263 Part Number Index ........................................... 271 Appendices Overview 3 JBX SERIES © 2015 SOURIAU - SOURIAU is a registered trademark JBX Series Overview Typical Applications ................................................................................................. 06 Features & Benefits ................................................................................................. 07 Range Overview ...................................................................................................... 08 Layouts .................................................................................................................... 10 General Technical Characteristics ............................................................................ 12 5 JBX Series | Overview © Olivier Tuffé / Fotolia Instrumentation / Measurement Telecom - Data infrastructure 6 Building Automation & Control © Sergey Milovidov / Fotolia Robotics - Machine tools © krungchingpixs / Fotolia Medical Off road - Mining - Railway © Volodymyr Kyrylyuk / Fotolia © smart.art / Fotolia © Rainer Plendl / Fotolia Typical Applications JBX Series | Overview Features & Benefits IP68 in Mated and Unmated Conditions Ideal for outdoor applications with temporary or continuous water immersion and dust protection. Overview WATER PROOF 360° EMI Shielded Signal integrity Less than 5mΩ: Qualified and Compatible to be used in electromagnetic radiation areas and ensures proper signal integrity and transmission. High Density Layouts Space saving Ideal for compact devices due to small footprint. The use of 0.5mm contacts along with miniature housing makes it suitable for tight applications. Push Pull Locking Mechanism Reliable mating Only requires two fingers to mate/unmate securely with an audible, tactile and visual indicator, capable of mating over 5,000 times. Mixed Power & Signal Layouts Cost savings Power supply and transmission can be combined in a unique interconnection solution to reduce system complexity and minimize component/installation costs. 7 JBX Series | Overview Range JBX IP40 Protective Boot Choice of Contact termination • Crimp • Solder Plug FC: Right Angle Plug FD: Straight Plug FF: Straight Plug no Latch with Black Boot FG: Breakaway Plug FN: Straight Plug with Lanyard FM: Right Angle Plug with Lanyard Receptacle EA: Double Nut Receptacle* ED: Protuding Front Mount EP: Rear Mount Receptacle* ER: Front Mount Receptacle EZ: Rear Mount Receptacle with Mounting Pins PC: In Line Cable Receptacle SA: Rear Mount Cable Receptacle SR: Front Mount Cable Receptacle Choice of Contact termination • Crimp • Straight PCB Tails • Solder • 90° PCB Tails Protective Boot * available with 90° PCB tails 8 JBX Series | Overview Overview JBX IP68 Overview Protective Boot Choice of Contact termination • Crimp • Solder Plug (Available in size 0 and 2) FH: Straight Plug Receptacle (Available in size 0 and 2) HC: Rear Mount Receptacle* Available size 0 HD: Protuding Front Mount Receptacle Available size 0 HH: Front Mount Extended Receptacle Available size 0 & 2 EC: Double Nut, Front or Rear Mount Receptacle * Available size 2 Choice of Contact termination • Crimp • Straight PCB Tails • Solder • 90° PCB Tails Available for JBX IP40 and JBX IP68 + Boot Version Example: JBXFG0G02MCSDSMR Boot = Example: JBX0MPR 9 JBX Series | Overview Layouts Shell size (Electrical parameter according to UL1977) Contact Ø 0.5 Contact Ø 0.7 Contact Ø 0.9 Contact Ø 01.3 6 contacts 4 contacts 2 contacts Page 96 Page 60 Page 20 7 contacts 5 contacts 3 contacts Page 112 Page 80 Page 36 10 contacts 6 contacts 4 contacts 2 contacts Page 164 Page 102 Page 66 Page 26 12 contacts 7 contacts 5 contacts 3 contacts Page 184 Page 118 Page 86 Page 42 2 contacts 2A 500V Page 16 00 4 contacts 2A 500V Page 56 2.5A 320V 2.5A 320V 7A 660V 6.5A 400V 10A 660V 8A 600V 0 8 contacts 2A 190V Page 132 2.5A 300V 2.5A 170V 7A 660V 7A 660V 10A 900V 9A 660V 15A 760V 12A 600V 1 8 contacts 5A 600V Page 138 Note: Contacts are numbered Counterclockwise in the plug and clock wise in the receptacle. 10 Contact Ø 1.6 Contact Ø 2.0 JBX Series | Overview Contact Ø 0.5 mm Ø 0.7 mm Ø 0.9 mm Ø 1.3 mm Ø 1.6 mm Ø 2.0 mm Solder (AWG) 28 and smaller 22 and smaller 22 and smaller 20 and smaller 18 and smaller 16 and smaller Crimp (AWG) Not available 22 - 24 - 26 20 - 22 - 24 18 - 20 - 22 14 - 16 - 18 12 - 14 - 16 Contact Ø 0.7 Contact Ø 0.9 Contact Ø 1.3 Contact Ø 1.6 Contact Ø 2.0 Mixed Contact 12 contacts 8 contacts 4 contacts 3 contacts 2 contacts 8 contacts 7A 830V 10A 830V 15A 1,000V Page 188 Page 142 Page 70 16 contacts 10 contacts 5 contacts 6A 730V 8A 830V 17A 830V Page 46 30A 1,000V 26A 700V 6 x Ø 0.7 2 x Ø 2.0 Overview Shell size Page 30 Page 148 14A 900V 9 contacts 26A 700V 6 x Ø 0.7 3 x Ø 1.3 2 Page 198 Page 168 18 contacts Page 90 6 contacts 5.5A 660V Page 158 12A 900V 10 contacts 17A 700V 8 x Ø 0.7 2 x Ø 1.6 Page 204 Page 106 19 contacts 7 contacts 5A 660V 11A 730V Page 174 Page 214 22 contacts 14 contacts 8 contacts 7 contacts 3 contacts Page 220 Page 194 Page 154 Page 128 Page 52 30 contacts 18 contacts 10 contacts 4 contacts Page 224 Page 210 Page 180 Page 76 5.5A 560V 3 Page 122 3.5A 400V JBX Sealed in Unmated Condition 9A 830V 7A 660V 12A 830V 12A 600V 15A 1,000V 25A 1,600V 25A 1,100V All dimensions are in mm 11 JBX Series | Overview General technical characteristics Materials Environmental Electrical • Outer shell and collet nut: Brass • Operating temperature: from -40°C to +125°C • In accordance with: - UL 1977: Certificate ECBT2 File number: E169916 - CSA C22.2: Certificate ECBT8 File number E169916 • Latching sleeve: Brass • Shielding ring: Brass • Nut: Brass • Half bushes: Brass • Clip: Beryllium copper • Insert: PEEK • Collet: PA 6/6 + MoS2 • Cable seal: Silicon rubber • Contacts: See every layout pages • Halogen free • Flammability rating: UL94 V-0 • Salt spray: per MIL-STD-202 method 101 - 48 h (nickel chrome) - 96 h (black anodized coupling ring) Higher salt spray resistance (200/500 h) upon request • Sealing: - Dynamic IP40 / IP68 in mated condition - Sealed IP68 connectors in unmated condition are marked with the symbol “ ”. Please refer to the connector section. • Fluid resistance: - Gas and oil - Mineral oil - Acid bath - Basic bath • Shielding effectiveness: 55 dB up to 100 MHz • Also see pages 10 & 11 Mechanical • Durability: > 5,000 cycles per IEC 61984 group B • Vibration resistance: 10 - 2,000 Hz, acceleration 15 g, contact Ø 0.7 mm and 0.9 mm 10 - 2,000 Hz, acceleration 20 g, contact Ø 1.3 mm - 1.6 mm and 2 mm Per MIL-STD-1344A method 2005.1 • Thermal shock: 5 cycles 30 min. from -40°C to 105°C Per MIL-STD-202 method 207 • Mechanical shock: 50 g, duration 6 ms ; contact Ø 0.7 mm and 0.9 mm 100 g, duration 6 ms ; contact Ø 1.3 mm 1.6 mm and 2 mm Per MIL-STD-1344A method 20004.1 • Discrimination/Keying: To eliminate mismatching, JBX connectors are offered with discrimination keys to avoid interconnection system errors. Please consult us for more information. 12 Overview JBX Series | Overview 13 JBX SERIES © 2015 SOURIAU - SOURIAU is a registered trademark JBX Series Connector 2 contacts JBX00-02: 2A 500V............................................................... 16 JBX0-02: 10A 660V............................................................... 20 JBX1-02: 15A 760V............................................................... 26 JBX2-02: 30A 1,000V............................................................... 30 3 contacts JBX0-03: 8A 600V............................................................... 36 JBX1-03: 12A 600V............................................................... 42 JBX2-03: 17A 830V............................................................... 46 JBX3-03: 25A 1,600V............................................................... 52 4 contacts JBX00-04: 2A 500V............................................................... 56 JBX0-04: 7A 660V............................................................... 60 JBX1-04: 10A 900V............................................................... 66 JBX2-04: 15A 1,000V............................................................... 70 JBX3-04: 25A 1,100V............................................................... 76 5 contacts JBX0-05: 6.5A 400V............................................................... 80 JBX1-05: 9A 660V............................................................... 86 JBX2-05: 14A 900V............................................................... 90 6 contacts JBX0-06: 2.5A 320V............................................................... 96 JBX1-06: 7A 660V............................................................... 102 JBX2-06: 12A 900V............................................................... 106 7 contacts JBX0-07: 2.5A 320V............................................................... 112 JBX1-07: 7A 660V............................................................... 118 JBX2-07: 11A 730V............................................................... 122 JBX3-07: 15A 1,000V............................................................... 128 8 contacts JBX0-08: 2A 190V............................................................... 132 JBX1-08: 5A 600V............................................................... 138 JBX2-08: 10A 830V............................................................... 142 JBX2-001: 26A 700V............................................................... 148 JBX3-08: 12A 830V............................................................... 154 9 contacts JBX2-002: 26A 700V............................................................... 158 10 contacts JBX1-10: 2.5A 300V............................................................... 164 JBX2-10: 8A 830V............................................................... 168 JBX2-003: 17A 700V............................................................... 174 JBX3-10: 12A 600V............................................................... 180 12 contacts JBX1-12: 2.5A 170V............................................................... 184 JBX2-12: 7A 830V............................................................... 188 14 contacts JBX3-14: 9A 830V............................................................... 194 16 contacts JBX2-16: 6A 730V............................................................... 198 18 contacts JBX2-18: 5.5A 660V............................................................... 204 JBX3-18: 7A 660V............................................................... 210 19 contacts JBX2-19: 5A 660V............................................................... 214 22 contacts JBX3-22: 5.5A 560V............................................................... 220 30 contacts JBX3-30: 3.5A 400V............................................................... 224 Electrical parameters according to UL1977 15 JBX Series | Connector JBX00-02 - IP40 (2 x Ø 0.5mm) FG FD ER Layout WITH Connector IP40 Part Number Contact type Solder contacts see page 19 Part number (1) Connector type Description Male insert Female insert Receptacle Front mount (ER) JBXER00G02MSSDSR JBXER00G02FSSDSR Straight plug (FD) * JBXFD00G02MSSDSR JBXFD00G02FSSDSR Breakaway plug (FG) * JBXFG00G02MSSDSR JBXFG00G02FSSDSR Plug * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 00, 2 solder contacts, male insert = JBXFD00G02MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 00, 2 solder contacts, male insert = JBXFD00G02MSNDSR. 16 2 contacts 2A/500V JBX Series | Connector per UL1977 JBX00-02 - IP40 (2 x Ø 0.5mm) Dimensions (For mated connector lengths see page 19) Front Mount (ER) Straight plug (FD)* Standard version 31.6 Ø7 Ø8 12.7 0.8 34.6 6 Boot version Breakaway Plug (FG)* Panel Cut Out Standard version Connector 31.6 .1 Ø7 Ø7 34.6 6.4 Boot version Note: all dimensions are in mm 17 JBX Series | Connector JBX00-02 - IP40 (2 x Ø 0.5mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR00 JBXBF00 JAXRA00251 Insulating Washer Protective Boot Available only for FD & FG, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions 18 Part number Color Part number JBX00RIA Blue JBX00MPA Blue JBX00RIB White JBX00MPB White JBX00RIG Grey JBX00MPG Grey JBX00RIJ Yellow JBX00MPJ Yellow JBX00RIM Brown JBX00MPM Brown JBX00RIN Black JBX00MPN Black JBX00RIR Red JBX00MPR Red JBX00RIV Green JBX00RIO Orange The overall length is 12 mm longer with the protective boot. Color JBX00MPV Green JBX00MPO Orange Note: The protective boot is not a sealing element. 2 contacts 2A/500V JBX Series | Connector per UL1977 JBX00-02 - IP40 (2 x Ø 0.5mm) Contacts Ø 0.5 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 30 For more information see page 231 Mated Connector Length FD Plug + Receptacle FG Plug + Receptacle 24 24 with ER Connector with ER Electrical Characteristics UL 2A 500V UL94 V-0 Note: all dimensions are in mm 19 JBX Series | Connector JBX0-02 - IP40 (2 x Ø 0.9 mm) - See waterproof IP68 version page 22 FM EZ PC SR FN FC ER FD EP ED EA Layout WITH Connector Part Number Contact type Connector type Description Double nut (EA) Protruding front mount (ED) Receptacle Solder contacts see page 25 Plug Plug Straight PCB contacts see page 25 Receptacle 90° PCB contacts see page 25 Receptacle Female insert JBXEA0G02MSSDS JBXEA0G02FSSDS JBXED0G02MSSDSR JBXED0G02FSSDSR Rear mount (EP) JBXEP0G02MSSDS JBXEP0G02FSSDS JBXER0G02MSSDSR JBXER0G02FSSDSR In line cable (PC) * JBXPC0G02MSSDSR JBXPC0G02FSSDSR Right angle plug (FC) * JBXFC0G02MSSDSR JBXFC0G02FSSDSR Straight plug (FD) * JBXFD0G02MSSDSR JBXFD0G02FSSDSR Right Angle plug with lanyard (FM) * JBXFM0G02MSSDSR JBXFM0G02FSSDSR Straight plug with lanyard (FN) * JBXFN0G02MSSDSR JBXFN0G02FSSDSR JBXEA0G02MCSDS JBXEA0G02FCSDS JBXED0G02MCSDSR JBXED0G02FCSDSR Double nut (EA) Crimp contacts see page 25 Male insert Front mount (ER) Protruding front mount (ED) Receptacle Part number (1) Rear mount (EP) JBXEP0G02MCSDS JBXEP0G02FCSDS Front mount (ER) JBXER0G02MCSDSR JBXER0G02FCSDSR In line cable (PC) * JBXPC0G02MCSDSR JBXPC0G02FCSDSR Front mount cable (SR) * JBXSR0G02MCSDSR JBXSR0G02FCSDSR Right angle plug (FC) * JBXFC0G02MCSDSR JBXFC0G02FCSDSR Straight plug (FD) * JBXFD0G02MCSDSR JBXFD0G02FCSDSR Double nut (EA) - JBXEA0G02FPSDS Rear mount (EP) - JBXEP0G02FPSDS PCB rear mount with mounting pins (EZ) - JBXEZ0G02FPSDSR Double nut (EA) - JBXEA0G02FQSDS Protruding front mount (ED) - JBXED0G02FQSDSR Rear mount (EP) - JBXEP0G02FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 2 solder contacts, male insert = JBXFD0G02MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 2 solder contacts, male insert = JBXFD0G02MSNDSR. 20 : First choice 2 contacts 10A/660V JBX Series | Connector per UL1977 JBX0-02 - IP40 (2 x Ø 0.9 mm) - See waterproof IP68 version page 22 Dimensions (For mated connector lengths see page 25) Rear Mount (EP) Protruding Front Mount (ED) 18.2 14.5 2.5 Ø 12 Ø 12 Ø 10 18.2 1.2 6.7 Front Mount (ER) 3 In Line Cable Receptacle (PC)* Front Mount Cable Receptacle (SR)* Standard version Ø 10 38 Ø 10 Ø 10 1.2 Standard version 38 17 1.2 41.5 8 Boot version Right Angle Plug (FC)* Straight Plug (FD)* Standard version 30.5 20.5 Ø 10 4 29.5 7.6 10 39 Ø 10 19 8 41.5 Boot version PCB Rear Mount with Mounting Pins (EZ) 12.2 4.5 2.5 Connector Double Nut (EA) 1 42.5 Boot version Right Angle Plug with Lanyard (FM)* Straight Plug with Lanyard (FN)* Panel Cut Out 70 39 .1 Ø9 Ø 10 28 Ø 9.3 31 70 8.3 Note: all dimensions are in mm 21 JBX Series | Connector JBX0-02 - IP68 (2 x Ø 0.9 mm) - See non sealed IP40 version page 20 FH HH HD HC Layout WITH Connector Part Number Contact type Solder contacts see page 25 Connector type Straight PCB contacts see page 25 Part number (1) Male insert Female insert Rear mount (HC) JBXHC0G02MSSDSR JBXHC0G02FSSDSR Protruding front mount (HD) JBXHD0G02MSSDSR JBXHD0G02FSSDSR Front mount extended (HH) JBXHH0G02MSSDSR JBXHH0G02FSSDSR Straight plug (FH) * JBXFH0G02MSSDSR JBXFH0G02FSSDSR Protruding front mount (HD) JBXHD0G02MCSDSR JBXHD0G02FCSDSR Front mount extended (HH) JBXHH0G02MCSDSR JBXHH0G02FCSDSR Plug Straight plug (FH) * JBXFH0G02MCSDSR JBXFH0G02FCSDSR Receptacle Rear mount (HC) - JBXHC0G02FPSDSR Receptacle Plug Crimp contacts see page 25 Description Receptacle * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 2 solder contacts, male insert = JBXFH0G02MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 2 solder contacts, male insert = JBXFH0G02MSNDSR. : Sealed in Unmated Condition 22 : First choice 2 contacts 10A/660V JBX Series | Connector per UL1977 JBX0-02 - IP68 (2 x Ø 0.9 mm) - See non sealed IP40 version page 20 Dimensions (For mated connector lengths see page 25) Protruding Front Mount (HD) 11.8 18.6 22 Ø 14 Ø 14 Ø 18 3 4.0 7 4 Straight Plug (FH)* Standard version 38 Front Mount Extended (HH) 8 Panel Cut Out HC Receptacle HD & HH Receptacle Connector Rear Mount (HC) 28 4 Ø 10 Ø1 41.5 12.6 .1 Ø9 8.3 Boot version Note: all dimensions are in mm 23 JBX Series | Connector JBX0-02 - IP40 & IP68 (2 x Ø 0.9 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR0 JBXBF0 JAXRA0251 Insulating Washer Protective Boot Available only for PC - FC - FD - FM - FN - SR - FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX0RIA Blue JBX0MPA Blue JBX0RIB White JBX0MPB White JBX0RIG Grey JBX0MPG Grey JBX0RIJ Yellow JBX0MPJ Yellow JBX0RIM Brown JBX0MPM Brown JBX0RIN Black JBX0MPN Black JBX0RIR Red JBX0MPR Red JBX0RIV Green JBX0RIO Orange Color JBX0MPV The overall length is 17 mm JBX0MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 24 Part number Male Female Part number MIL-22520/7-01 JBX0OUTLP09 JBX0OUTLS09 JBXOUTDC09 2 contacts 10A/660V JBX Series | Connector per UL1977 JBX0-02 - IP40 & IP68 (2 x Ø 0.9 mm) Contacts Ø 0.9 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 24 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 - 22 - 24 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD or FN Plug + Receptacle with EA 30.5 30.7 40.5 with ED with ER with EP 65.3 64.5 46.3 29 with PC Connector 31 with EZ with SR FC or FM Plug + Receptacle 33.4 23.4 with EA with ED 23.4 22 with EP with ER 64.8 with PC 58.3 46.3 22 with SR with EZ FH Plug + Receptacle 27.5 with HC 37 with HD 28.5 with HH Electrical Characteristics UL 10A 660V UL94 V-0 Note: all dimensions are in mm 25 JBX Series | Connector JBX1-02 - IP40 (2 x Ø 1.3 mm) PC FC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 29 Crimp contacts see page 29 Part number (1) Male insert Female insert Double nut (EA) JBXEA1G02MSSDS JBXEA1G02FSSDS Rear mount (EP) JBXEP1G02MSSDS JBXEP1G02FSSDS Front mount (ER) JBXER1G02MSSDSR JBXER1G02FSSDSR In line cable (PC) * JBXPC1G02MSSDSR JBXPC1G02FSSDSR Front mount cable (SR) * JBXSR1G02MSSDSR JBXSR1G02FSSDSR Straight plug (FD) * JBXFD1G02MSSDSR JBXFD1G02FSSDSR Plug Straight plug no latch with black protective boot (FF) JBXFF1G02MSSDSR JBXFF1G02FSSDSR Double nut (EA) JBXEA1G02MCSDS JBXEA1G02FCSDS Receptacle Front mount (ER) JBXER1G02MCSDSR JBXER1G02FCSDSR Plug Straight PCB contacts see page 29 Description Receptacle In line cable (PC) * JBXPC1G02MCSDSR JBXPC1G02FCSDSR Right angle plug (FC) * JBXFC1G02MCSDSR JBXFC1G02FCSDSR Straight plug (FD) * JBXFD1G02MCSDSR JBXFD1G02FCSDSR Double nut (EA) - JBXEA1G02FPSDS Front mount (ER) - JBXER1G02FPSDSR PCB rear mount with mounting pins (EZ) - JBXEZ1G02FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 2 solder contacts, male insert = JBXFD1G02MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 2 solder contacts, male insert = JBXFD1G02MSNDSR. 26 : First choice 2 contacts 15A/760V JBX Series | Connector per UL1977 JBX1-02 - IP40 (2 x Ø 1.3 mm) Dimensions (For mated connector lengths see page 29) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 21 Ø13 12 1.03 1.5 4 7.6 45.6 10 PCB Rear Mount with Mounting Pins (EZ) Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Right Angle Plug (FC)* 36.5 25.5 Standard version 33.5 Ø 12 68 Ø 12 Ø 12 44 47.6 Boot version Panel Cut Out 2.1 Ø1 10.6 Note: all dimensions are in mm 27 JBX Series | Connector JBX1-02 - IP40 (2 x Ø 1.3 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange Color JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 28 Part number Male Female Part number MIL-22520/7-01 JBX1OUTLP13 JBX1OUTLS13 JBXOUTDC13 2 contacts 15A/760V JBX Series | Connector per UL1977 JBX1-02 - IP40 (2 x Ø 1.3 mm) Contacts Ø 1.3 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 - 20 - 22 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle 34 36.8 with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 36 with EZ with SR FC Plug + Receptacle 28.8 with EA with EP 67.4 64.8 27 29 with PC with ER 46.3 27 with SR with EZ FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 15A 760V UL94 V-0 Note: all dimensions are in mm 29 JBX Series | Connector JBX2-02 - IP40 (2 x Ø 2.0 mm) - See waterproof IP67/IP68 version page 32 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 35 Connector type Receptacle Plug Crimp contacts see page 35 Receptacle Plug Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G02MSSDS JBXEA2G02FSSDS Rear mount (EP) JBXEP2G02MSSDS JBXEP2G02FSSDS Front mount (ER) JBXER2G02MSSDSR JBXER2G02FSSDSR In line cable (PC) * JBXPC2G02MSSDSR JBXPC2G02FSSDSR Straight plug (FD) * JBXFD2G02MSSDSR JBXFD2G02FSSDSR Double nut (EA) JBXEA2G02MCSDS JBXEA2G02FCSDS Rear mount (EP) JBXEP2G02MCSDS JBXEP2G02FCSDS Front mount (ER) JBXER2G02MCSDSR JBXER2G02FCSDSR In line cable (PC) * JBXPC2G02MCSDSR JBXPC2G02FCSDSR Rear mount cable (SA) * JBXSA2G02MCSDS JBXSA2G02FCSDS Right angle plug (FC) * JBXFC2G02MCSDSR JBXFC2G02FCSDSR Straight plug (FD) * JBXFD2G02MCSDSR JBXFD2G02FCSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 2 solder contacts, male insert = JBXFD2G02MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 2 solder contacts, male insert = JBXFD2G02MSNDSR. 30 : First choice 2 contacts 30A/1,000V JBX Series | Connector per UL1977 JBX2-02 - IP40 (2 x Ø 2.0 mm) - See waterproof IP67/IP68 version page 32 Dimensions (For mated connector lengths see page 35) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 31 JBX Series | Connector JBX2-02 - IP68 (2 x Ø 2.0 mm) - See non sealed IP40 version page 30 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 35 Receptacle Plug Crimp contacts see page 35 Receptacle Plug Description Part number (1) Male insert Female insert JBXEC2G02MSSDS JBXEC2G02FSSDS Front mount extended (HH) JBXHH2G02MSSDSR JBXHH2G02FSSDSR Straight plug (FH) * JBXFH2G02MSSDSR JBXFH2G02FSSDSR JBXEC2G02MCSDS JBXEC2G02FCSDS Front mount extended (HH) JBXHH2G02MCSDSR JBXHH2G02FCSDSR Straight plug (FH) * JBXFH2G02MCSDSR JBXFH2G02FCSDSR Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 2 solder contacts, male insert = JBXFH2G02MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 2 solder contacts, male insert = JBXFH2G02MSNDSR. : Sealed in Unmated Condition 32 2 contacts 30A/1,000V JBX Series | Connector per UL1977 JBX2-02 - IP67/IP68 (2 x Ø 2.0 mm) - See non sealed IP40 version page 30 Dimensions (For mated connector lengths see page 35) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 33 JBX Series | Connector JBX2-02 - IP40 & IP68 (2 x Ø 2.0 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA - FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling 34 Crimp Tooling Locator Extraction Tool Part number Part number Part number MIL-22520/1-01 JBX2OUTLP20 JBXOUTDC20 2 contacts 30A/1,000V JBX Series | Connector per UL1977 JBX2-02 - IP40 & IP68 (2 x Ø 2.0 mm) Contacts Ø 2.0 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 16 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 12 - 14 - 16 For more information see pages 231 to 232 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with PC with ER with EP 88.3 42 with SA Connector 42 FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with EP with PC with ER 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 30A 1,000V UL94 V-0 Note: all dimensions are in mm 35 JBX Series | Connector JBX0-03 - IP40 (3 x Ø 0.9 mm) - See waterproof IP68 version page 38 FM EZ PC SR FN FC ER FD EP ED EA Layout WITH Connector Part Number Contact type Connector type Description Double nut (EA) Protruding front mount (ED) Receptacle Solder contacts see page 41 Plug Plug Straight PCB contacts see page 41 Receptacle 90° PCB contacts see page 41 Receptacle Female insert JBXEA0G03MSSDS JBXEA0G03FSSDS JBXED0G03MSSDSR JBXED0G03FSSDSR Rear mount (EP) JBXEP0G03MSSDS JBXEP0G03FSSDS JBXER0G03MSSDSR JBXER0G03FSSDSR In line cable (PC) * JBXPC0G03MSSDSR JBXPC0G03FSSDSR Right angle plug (FC) * JBXFC0G03MSSDSR JBXFC0G03FSSDSR Straight plug (FD) * JBXFD0G03MSSDSR JBXFD0G03FSSDSR Right Angle plug with lanyard (FM) * JBXFM0G03MSSDSR JBXFM0G03FSSDSR Straight plug with lanyard (FN) * JBXFN0G03MSSDSR JBXFN0G03FSSDSR JBXEA0G03MCSDS JBXEA0G03FCSDS JBXED0G03MCSDSR JBXED0G03FCSDSR Double nut (EA) Crimp contacts see page 41 Male insert Front mount (ER) Protruding front mount (ED) Receptacle Part number (1) Rear mount (EP) JBXEP0G03MCSDS JBXEP0G03FCSDS Front mount (ER) JBXER0G03MCSDSR JBXER0G03FCSDSR In line cable (PC) * JBXPC0G03MCSDSR JBXPC0G03FCSDSR Front mount cable (SR) * JBXSR0G03MCSDSR JBXSR0G03FCSDSR Right angle plug (FC) * JBXFC0G03MCSDSR JBXFC0G03FCSDSR Straight plug (FD) * JBXFD0G03MCSDSR JBXFD0G03FCSDSR Double nut (EA) - JBXEA0G03FPSDS Rear mount (EP) - JBXEP0G03FPSDS PCB rear mount with mounting pins (EZ) - JBXEZ0G03FPSDSR Double nut (EA) - JBXEA0G03FQSDS Protruding front mount (ED) - JBXED0G03FQSDSR Rear mount (EP) - JBXEP0G03FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 3 solder contacts, male insert = JBXFD0G03MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 3 solder contacts, male insert = JBXFD0G03MSNDSR. 36 : First choice 3 contacts 8A/600V JBX Series | Connector per UL1977 JBX0-03 - IP40 (3 x Ø 0.9 mm) - See waterproof IP68 version page 38 Dimensions (For mated connector lengths see page 41) Rear Mount (EP) Protruding Front Mount (ED) 18.2 14.5 2.5 Ø 12 Ø 12 Ø 10 18.2 1.2 6.7 Front Mount (ER) 3 In Line Cable Receptacle (PC)* Front Mount Cable Receptacle (SR)* Standard version Ø 10 38 Ø 10 Ø 10 1.2 Standard version 38 17 1.2 41.5 8 Boot version Right Angle Plug (FC)* Straight Plug (FD)* Standard version 30.5 20.5 Ø 10 4 29.5 7.6 10 39 Ø 10 19 8 41.5 Boot version PCB Rear Mount with Mounting Pins (EZ) 12.2 4.5 2.5 Connector Double Nut (EA) 1 42.5 Boot version Right Angle Plug with Lanyard (FM) * Straight Plug with Lanyard (FN) * Panel Cut Out 70 39 .1 Ø9 Ø 10 28 Ø 9.3 31 70 8.3 Note: all dimensions are in mm 37 JBX Series | Connector JBX0-03 - IP68 (3 x Ø 0.9 mm) - See non sealed IP40 version page 36 FH HH HD HC Layout WITH Connector Part Number Contact type Solder contacts see page 41 Connector type Straight PCB contacts see page 41 Part number (1) Male insert Female insert Rear mount (HC) JBXHC0G03MSSDSR JBXHC0G03FSSDSR Protruding front mount (HD) JBXHD0G03MSSDSR JBXHD0G03FSSDSR Front mount extended (HH) JBXHH0G03MSSDSR JBXHH0G03FSSDSR Straight plug (FH) * JBXFH0G03MSSDSR JBXFH0G03FSSDSR Protruding front mount (HD) JBXHD0G03MCSDSR JBXHD0G03FCSDSR Front mount extended (HH) JBXHH0G03MCSDSR JBXHH0G03FCSDSR Plug Straight plug (FH) * JBXFH0G03MCSDSR JBXFH0G03FCSDSR Receptacle Rear mount (HC) - JBXHC0G03FPSDSR Receptacle Plug Crimp contacts see page 41 Description Receptacle * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 3 solder contacts, male insert = JBXFH0G03MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 3 solder contacts, male insert = JBXFH0G03MSNDSR. : Sealed in Unmated Condition 38 : First choice 3 contacts 8A/600V JBX Series | Connector per UL1977 JBX0-03 - IP68 (3 x Ø 0.9 mm) - See non sealed IP40 version page 36 Dimensions (For mated connector lengths see page 41) Protruding Front Mount (HD) 11.8 18.6 22 Ø 14 Ø 14 Ø 18 3 4.0 7 4 Straight Plug (FH)* Standard version 38 Front Mount Extended (HH) 8 Panel Cut Out HC Receptacle HD & HH Receptacle Connector Rear Mount (HC) 28 4 Ø 10 Ø1 41.5 12.6 .1 Ø9 8.3 Boot version Note: all dimensions are in mm 39 JBX Series | Connector JBX0-03 - IP40 & IP68 (3 x Ø 0.9 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR0 JBXBF0 JAXRA0251 Insulating Washer Protective Boot Available only for PC - FC - FD - FM - FN - SR - FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX0RIA Blue JBX0MPA Blue JBX0RIB White JBX0MPB White JBX0RIG Grey JBX0MPG Grey JBX0RIJ Yellow JBX0MPJ Yellow JBX0RIM Brown JBX0MPM Brown JBX0RIN Black JBX0MPN Black JBX0RIR Red JBX0MPR Red JBX0RIV Green JBX0RIO Orange Color JBX0MPV The overall length is 17 mm JBX0MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 40 Part number Male Female Part number MIL-22520/7-01 JBX0OUTLP09 JBX0OUTLS09 JBXOUTDC09 3 contacts 8A/600V JBX Series | Connector per UL1977 JBX0-03 - IP40 & IP68 (3 x Ø 0.9 mm) Contacts Ø 0.9 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 24 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 - 22 - 24 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD or FN Plug + Receptacle with EA 30.5 30.7 40.5 with ED with ER with EP 65.3 64.5 46.3 29 with PC Connector 31 with EZ with SR FC or FM Plug + Receptacle 33.4 23.4 with EA with ED 64.8 23.4 22 with EP with ER with PC 58.3 46.3 22 with SR with EZ FH Plug + Receptacle 27.5 with HC 37 with HD 28.5 with HH Electrical Characteristics UL 8A 600V UL94 V-0 Note: all dimensions are in mm 41 JBX Series | Connector JBX1-03 - IP40 (3 x Ø 1.3 mm) PC FC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 45 Crimp contacts see page 45 90° PCB contacts see page 45 Part number (1) Male insert Female insert Double nut (EA) JBXEA1G03MSSDS JBXEA1G03FSSDS Rear mount (EP) JBXEP1G03MSSDS JBXEP1G03FSSDS Front mount (ER) JBXER1G03MSSDSR JBXER1G03FSSDSR In line cable (PC) * JBXPC1G03MSSDSR JBXPC1G03FSSDSR Front mount cable (SR) * JBXSR1G03MSSDSR JBXSR1G03FSSDSR Straight plug (FD) * JBXFD1G03MSSDSR JBXFD1G03FSSDSR Plug Straight plug no latch with black protective boot (FF) JBXFF1G03MSSDSR JBXFF1G03FSSDSR Double nut (EA) JBXEA1G03MCSDS JBXEA1G03FCSDS Receptacle Front mount (ER) JBXER1G03MCSDSR JBXER1G03FCSDSR Plug Straight PCB contacts see page 45 Description Receptacle Receptacle In line cable (PC) * JBXPC1G03MCSDSR JBXPC1G03FCSDSR Right angle plug (FC) * JBXFC1G03MCSDSR JBXFC1G03FCSDSR Straight plug (FD) * JBXFD1G03MCSDSR JBXFD1G03FCSDSR Double nut (EA) - JBXEA1G03FPSDS Front mount (ER) - JBXER1G03FPSDSR PCB rear mount with mounting pins (EZ) - JBXEZ1G03FPSDSR Double nut (EA) - JBXEA1G03FQSDS Rear mount (EP) - JBXEP1G03FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 3 solder contacts, male insert = JBXFD1G03MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 3 solder contacts, male insert = JBXFD1G03MSNDSR. 42 : First choice 3 contacts 12A/600V JBX Series | Connector per UL1977 JBX1-03 - IP40 (3 x Ø 1.3 mm) Dimensions (For mated connector lengths see page 45) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 21 Ø13 12 1.03 1.5 4 7.6 45.6 10 PCB Rear Mount with Mounting Pins (EZ) Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Right Angle Plug (FC)* 36.5 25.5 Standard version 33.5 Ø 12 68 Ø 12 Ø 12 44 47.6 Boot version Panel Cut Out 2.1 Ø1 10.6 Note: all dimensions are in mm 43 JBX Series | Connector JBX1-03 - IP40 (3 x Ø 1.3 mm) Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange Color JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 44 Part number Male Female Part number MIL-22520/7-01 JBX1OUTLP13 JBX1OUTLS13 JBXOUTDC13 3 contacts 12A/600V JBX Series | Connector per UL1977 JBX1-03 - IP40 (3 x Ø 1.3 mm) Contacts Ø 1.3 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 - 20 - 22 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle 34 36.8 with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 36 with EZ with SR FC Plug + Receptacle 28.8 with EA with EP 67.4 64.8 27 29 with SR with PC with ER 46.3 27 with EZ FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 12A 600V UL94 V-0 Note: all dimensions are in mm 45 JBX Series | Connector JBX2-03 - IP40 (3 x Ø 1.6 mm) - See waterproof IP68 version page 48 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 51 Connector type Receptacle Plug Crimp contacts see page 51 Receptacle Plug Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G03MSSDS JBXEA2G03FSSDS Rear mount (EP) JBXEP2G03MSSDS JBXEP2G03FSSDS Front mount (ER) JBXER2G03MSSDSR JBXER2G03FSSDSR In line cable (PC) * JBXPC2G03MSSDSR JBXPC2G03FSSDSR Straight plug (FD) * JBXFD2G03MSSDSR JBXFD2G03FSSDSR Double nut (EA) JBXEA2G03MCSDS JBXEA2G03FCSDS Rear mount (EP) JBXEP2G03MCSDS JBXEP2G03FCSDS Front mount (ER) JBXER2G03MCSDSR JBXER2G03FCSDSR In line cable (PC) * JBXPC2G03MCSDSR JBXPC2G03FCSDSR Rear mount cable (SA) * JBXSA2G03MCSDS JBXSA2G03FCSDS Right angle plug (FC) * JBXFC2G03MCSDSR JBXFC2G03FCSDSR Straight plug (FD) * JBXFD2G03MCSDSR JBXFD2G03FCSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 3 solder contacts, male insert = JBXFD2G03MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 3 solder contacts, male insert = JBXFD2G03MSNDSR. 46 : First choice 3 contacts 17A/830V JBX Series | Connector per UL1977 JBX2-03 - IP40 (3 x Ø 1.6 mm) - See waterproof IP68 version page 48 Dimensions (For mated connector lengths see page 51) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 47 JBX Series | Connector JBX2-03 - IP68 (3 x Ø 1.6 mm) - See non sealed IP40 version page 46 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 51 Receptacle Plug Crimp contacts see page 51 Receptacle Plug Description Part number (1) Male insert Female insert JBXEC2G03MSSDS JBXEC2G03FSSDS Front mount extended (HH) JBXHH2G03MSSDSR JBXHH2G03FSSDSR Straight plug (FH) * JBXFH2G03MSSDSR JBXFH2G03FSSDSR JBXEC2G03MCSDS JBXEC2G03FCSDS Front mount extended (HH) JBXHH2G03MCSDSR JBXHH2G03FCSDSR Straight plug (FH) * JBXFH2G03MCSDSR JBXFH2G03FCSDSR Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 3 solder contacts, male insert = JBXFH2G03MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 3 solder contacts, male insert = JBXFH2G03MSNDSR. : Sealed in Unmated Condition 48 3 contacts 17A/830V JBX Series | Connector per UL1977 JBX2-03 - IP68 (3 x Ø 1.6 mm) - See non sealed IP40 version page 46 Dimensions (For mated connector lengths see page 51) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 49 JBX Series | Connector JBX2-03 - IP40 & IP68 (3 x Ø 1.6 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling 50 Crimp Tooling Locator Extraction Tool Part number Part number Part number MIL-22520/1-01 JBX2OUTLP16 JBXOUTDC16 3 contacts 17A/830V JBX Series | Connector per UL1977 JBX2-03 - IP40 & IP68 (3 x Ø 1.6 mm) Contacts Ø 1.6 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 14 - 16 - 18 For more information see pages 231 to 232 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with PC with ER with EP 88.3 42 with SA Connector 42 FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with EP with PC with ER 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 17A 830V UL94 V-0 Note: all dimensions are in mm 51 JBX Series | Connector JBX3-03 - IP40 (3 x Ø 2.0 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G03MSSDS JBXEA3G03FSSDS Solder contacts see page 55 Receptacle Front mount (ER) JBXER3G03MSSDSR JBXER3G03FSSDSR Front mount cable (SR) * JBXSR3G03MSSDSR JBXSR3G03FSSDSR Straight plug (FD) * Plug Crimp contacts see page 55 Receptacle Plug Male insert Female insert JBXFD3G03MSSDSR JBXFD3G03FSSDSR Double nut (EA) JBXEA3G03MCSDS JBXEA3G03FCSDS Front mount (ER) JBXER3G03MCSDSR JBXER3G03FCSDSR Right angle plug (FC) * JBXFC3G03MCSDSR JBXFC3G03FCSDSR Straight plug (FD) * JBXFD3G03MCSDSR JBXFD3G03FCSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 3 solder contacts, male insert = JBXFD3G03MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 3 solder contacts, male insert = JBXFD3G03MSNDSR. 52 3 contacts 25A/1,600V JBX Series | Connector per UL1977 JBX3-03 - IP40 (3 x Ø 2.0 mm) Dimensions (For mated connector lengths see page 55) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 53 JBX Series | Connector JBX3-03 - IP40 (3 x Ø 2.0 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling 54 Crimp Tooling Locator Extraction Tool Part number Part number Part number MIL-22520/1-01 JBX3OUTLP20 JBXOUTDC20 3 contacts 25A/1,600V JBX Series | Connector per UL1977 JBX3-03 - IP40 (3 x Ø 2.0 mm) Contacts Ø 2.0 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 16 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 12 - 14 - 16 For more information see pages 231 and 232 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER with SR Connector 50.8 FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 25A 1,600V UL94 V-0 Note: all dimensions are in mm 55 JBX Series | Connector JBX00-04 - IP40 (4 x Ø 0.5mm) FG FD ER Layout WITH Connector IP40 Part Number Contact type Solder contacts see page 59 Part number (1) Connector type Description Male insert Female insert Receptacle Front mount (ER) JBXER00G04MSSDSR JBXER00G04FSSDSR Straight plug (FD) * JBXFD00G04MSSDSR JBXFD00G04FSSDSR Breakaway plug (FG) * JBXFG00G04MSSDSR JBXFG00G04FSSDSR Plug * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 00, 4 solder contacts, male insert = JBXFD00G04MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 00, 4 solder contacts, male insert = JBXFD00G04MSNDSR. 56 4 contacts 2A/500V JBX Series | Connector per UL1977 JBX00-04 - IP40 (4 x Ø 0.5mm) Dimensions (For mated connector lengths see page 59) Front Mount (ER) Straight plug (FD)* Standard version 31.6 Ø7 Ø8 12.7 0.8 34.6 6 Boot version Breakaway Plug (FG)* Panel Cut Out Standard version Connector 31.6 .1 Ø7 Ø7 34.6 6.4 Boot version Note: all dimensions are in mm 57 JBX Series | Connector JBX00-04 - IP40 & IP68 (4 x Ø 0.5mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR00 JBXBF00 JAXRA00251 Insulating Washer Protective Boot Available only for FD & FG, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions 58 Part number Color Part number JBX00RIA Blue JBX00MPA Blue JBX00RIB White JBX00MPB White JBX00RIG Grey JBX00MPG Grey JBX00RIJ Yellow JBX00MPJ Yellow JBX00RIM Brown JBX00MPM Brown JBX00RIN Black JBX00MPN Black JBX00RIR Red JBX00MPR Red JBX00RIV Green JBX00RIO Orange JBX00MPV The overall length is 12 mm JBX00MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 4 contacts 2A/500V JBX Series | Connector per UL1977 JBX00-04 - IP40 & IP68 (4 x Ø 0.5mm) Contacts Ø 0.5 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 30 For more information see page 231 Mated Connector Length FD Plug + Receptacle FG Plug + Receptacle 24 24 with ER Connector with ER Electrical Characteristics UL 2A 500V UL94 V-0 Note: all dimensions are in mm 59 JBX Series | Connector JBX0-04 - IP40 (4 x Ø 0.7mm) - See waterproof IP68 version page 62 FM EZ PC SR FN FC ER FD EP ED EA Layout WITH Connector Part Number Contact type Connector type Description Double nut (EA) Protruding front mount (ED) Receptacle Solder contacts see page 65 Plug Plug Straight PCB contacts see page 65 Receptacle 90° PCB contacts see page 65 Receptacle Female insert JBXEA0G04MSSDS JBXEA0G04FSSDS JBXED0G04MSSDSR JBXED0G04FSSDSR Rear mount (EP) JBXEP0G04MSSDS JBXEP0G04FSSDS JBXER0G04MSSDSR JBXER0G04FSSDSR In line cable (PC) * JBXPC0G04MSSDSR JBXPC0G04FSSDSR Right angle plug (FC) * JBXFC0G04MSSDSR JBXFC0G04FSSDSR Straight plug (FD) * JBXFD0G04MSSDSR JBXFD0G04FSSDSR Right Angle plug with lanyard (FM) * JBXFM0G04MSSDSR JBXFM0G04FSSDSR Straight plug with lanyard (FN) * JBXFN0G04MSSDSR JBXFN0G04FSSDSR JBXEA0G04MCSDS JBXEA0G04FCSDS JBXED0G04MCSDSR JBXED0G04FCSDSR Double nut (EA) Crimp contacts see page 65 Male insert Front mount (ER) Protruding front mount (ED) Receptacle Part number (1) Rear mount (EP) JBXEP0G04MCSDS JBXEP0G04FCSDS Front mount (ER) JBXER0G04MCSDSR JBXER0G04FCSDSR In line cable (PC) * JBXPC0G04MCSDSR JBXPC0G04FCSDSR Front mount cable (SR) * JBXSR0G04MCSDSR JBXSR0G04FCSDSR Right angle plug (FC) * JBXFC0G04MCSDSR JBXFC0G04FCSDSR Straight plug (FD) * JBXFD0G04MCSDSR JBXFD0G04FCSDSR Double nut (EA) JBXEA0G04MPSDS JBXEA0G04FPSDS Rear mount (EP) JBXEP0G04MPSDS JBXEP0G04FPSDS PCB rear mount with mounting pins (EZ) JBXEZ0G04MPSDSR JBXEZ0G04FPSDSR Double nut (EA) - JBXEA0G04FQSDS Protruding front mount (ED) - JBXED0G04FQSDSR Rear mount (EP) - JBXEP0G04FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 4 solder contacts, male insert = JBXFD0G04MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 4 solder contacts, male insert = JBXFD0G04MSNDSR. 60 : First choice 4 contacts 7A/660V JBX Series | Connector per UL1977 JBX0-04 - IP40 (4 x Ø 0.7mm) - See waterproof IP68 version page 62 Dimensions (For mated connector lengths see page 65) Rear Mount (EP) Protruding Front Mount (ED) 18.2 14.5 2.5 Ø 12 Ø 12 Ø 10 18.2 1.2 6.7 Front Mount (ER) 3 In Line Cable Receptacle (PC)* Front Mount Cable Receptacle (SR)* Standard version Ø 10 38 Ø 10 Ø 10 1.2 Standard version 38 17 1.2 41.5 8 Boot version Right Angle Plug (FC)* Straight Plug (FD)* Standard version 30.5 20.5 Ø 10 4 29.5 7.6 10 39 Ø 10 19 8 41.5 Boot version PCB Rear Mount with Mounting Pins (EZ) 12.2 4.5 2.5 Connector Double Nut (EA) 1 42.5 Boot version Right Angle Plug with Lanyard (FM) * Straight Plug with Lanyard (FN) * Panel Cut Out 70 39 .1 Ø9 Ø 10 28 Ø 9.3 31 70 8.3 Note: all dimensions are in mm 61 JBX Series | Connector JBX0-04 - IP68 (4 x Ø 0.7mm) - See non sealed IP40 version page 60 FH HH HD HC Layout WITH Connector Part Number Contact type Solder contacts see page 65 Connector type Straight PCB contacts see page 65 Part number (1) Male insert Female insert Rear mount (HC) JBXHC0G04MSSDSR JBXHC0G04FSSDSR Protruding front mount (HD) JBXHD0G04MSSDSR JBXHD0G04FSSDSR Front mount extended (HH) JBXHH0G04MSSDSR JBXHH0G04FSSDSR Straight plug (FH) * JBXFH0G04MSSDSR JBXFH0G04FSSDSR Protruding front mount (HD) JBXHD0G04MCSDSR JBXHD0G04FCSDSR Front mount extended (HH) JBXHH0G04MCSDSR JBXHH0G04FCSDSR Plug Straight plug (FH) * JBXFH0G04MCSDSR JBXFH0G04FCSDSR Receptacle Rear mount (HC) JBXHC0G04MPSDSR JBXHC0G04FPSDSR Receptacle Plug Crimp contacts see page 65 Description Receptacle * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 4 solder contacts, male insert = JBXFH0G04MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 4 solder contacts, male insert = JBXFH0G04MSNDSR. : Sealed in Unmated Condition 62 : First choice 4 contacts 7A/660V JBX Series | Connector per UL1977 JBX0-04 - IP68 (4 x Ø 0.7mm) - See non sealed IP40 version page 60 Dimensions (For mated connector lengths see page 65) Protruding Front Mount (HD) 11.8 18.6 22 Ø 14 Ø 14 Ø 18 3 4.0 7 4 Straight Plug (FH)* Standard version 38 Front Mount Extended (HH) 8 Panel Cut Out HC Receptacle HD & HH Receptacle Connector Rear Mount (HC) 28 4 Ø 10 Ø1 41.5 12.6 .1 Ø9 8.3 Boot version Note: all dimensions are in mm 63 JBX Series | Connector JBX0-04 - IP40 & IP68 (4 x Ø 0.7mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR0 JBXBF0 JAXRA0251 Insulating Washer Protective Boot Available only for PC - FC - FD - FM - FN - SR - FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX0RIA Blue JBX0MPA Blue JBX0RIB White JBX0MPB White JBX0RIG Grey JBX0MPG Grey JBX0RIJ Yellow JBX0MPJ Yellow JBX0RIM Brown JBX0MPM Brown JBX0RIN Black JBX0MPN Black JBX0RIR Red JBX0MPR Red JBX0RIV Green JBX0RIO Orange Color JBX0MPV The overall length is 17 mm JBX0MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 64 Part number Male Female Part number MIL-22520/7-01 JBX0OUTLP07 JBX0OUTLS07 JBXOUTDC07 4 contacts 7A/660V JBX Series | Connector per UL1977 JBX0-04 - IP40 & IP68 (4 x Ø 0.7mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD or FN Plug + Receptacle with EA 30.5 30.7 40.5 with ED with ER with EP 65.3 64.5 46.3 29 with PC Connector 31 with EZ with SR FC or FM Plug + Receptacle 33.4 23.4 with EA with ED 64.8 23.4 22 with EP with ER with PC 58.3 46.3 22 with SR with EZ FH Plug + Receptacle 27.5 with HC 37 with HD 28.5 with HH Electrical Characteristics UL 7A 660V UL94 V-0 Note: all dimensions are in mm 65 JBX Series | Connector JBX1-04 - IP40 (4 x Ø 0.9 mm) PC FC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 69 Crimp contacts see page 69 90° PCB contacts see page 69 Part number (1) Male insert Female insert Double nut (EA) JBXEA1G04MSSDS JBXEA1G04FSSDS Rear mount (EP) JBXEP1G04MSSDS JBXEP1G04FSSDS Front mount (ER) JBXER1G04MSSDSR JBXER1G04FSSDSR In line cable (PC) * JBXPC1G04MSSDSR JBXPC1G04FSSDSR Front mount cable (SR) * JBXSR1G04MSSDSR JBXSR1G04FSSDSR Straight plug (FD) * JBXFD1G04MSSDSR JBXFD1G04FSSDSR Plug Straight plug no latch with black protective boot (FF) JBXFF1G04MSSDSR JBXFF1G04FSSDSR Double nut (EA) JBXEA1G04MCSDS JBXEA1G04FCSDS Receptacle Front mount (ER) JBXER1G04MCSDSR JBXER1G04FCSDSR Plug Straight PCB contacts see page 69 Description Receptacle Receptacle In line cable (PC) * JBXPC1G04MCSDSR JBXPC1G04FCSDSR Right angle plug (FC) * JBXFC1G04MCSDSR JBXFC1G04FCSDSR Straight plug (FD) * JBXFD1G04MCSDSR JBXFD1G04FCSDSR Double nut (EA) - JBXEA1G04FPSDS Front mount (ER) - JBXER1G04FPSDSR PCB rear mount with mounting pins (EZ) - JBXEZ1G04FPSDSR Double nut (EA) - JBXEA1G04FQSDS Rear mount (EP) - JBXEP1G04FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 4 solder contacts, male insert = JBXFD1G04MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 4 solder contacts, male insert = JBXFD1G04MSNDSR. 66 : First choice 4 contacts 10A/900V JBX Series | Connector per UL1977 JBX1-04 - IP40 (4 x Ø 0.9 mm) Dimensions (For mated connector lengths see page 69) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 21 Ø13 12 1.03 1.5 4 7.6 45.6 10 PCB Rear Mount with Mounting Pins (EZ) Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Right Angle Plug (FC)* 36.5 25.5 Standard version 33.5 Ø 12 68 Ø 12 Ø 12 44 47.6 Boot version Panel Cut Out 2.1 Ø1 10.6 67 JBX Series | Connector JBX1-04 - IP40 (4 x Ø 0.9 mm) Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange Color JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 68 Part number Male Female Part number MIL-22520/7-01 JBX1OUTLP09 JBX1OUTLS09 JBXOUTDC09 4 contacts 10A/900V JBX Series | Connector per UL1977 JBX1-04 - IP40 (4 x Ø 0.9 mm) Contacts Ø 0.9 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 24 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 - 22 - 24 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 34 36.8 36 with EZ with SR FC Plug + Receptacle 28.8 with EA with EP 67.4 64.8 27 29 with SR with PC with ER 46.3 27 with EZ FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 10A 900V UL94 V-0 Note: all dimensions are in mm 69 JBX Series | Connector JBX2-04 - IP40 (4 x Ø 1.3 mm) - See waterproof IP68 version page 72 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 75 Connector type Receptacle Plug Crimp contacts see page 75 Receptacle Plug Straight PCB contacts see page 75 Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G04MSSDS JBXEA2G04FSSDS Rear mount (EP) JBXEP2G04MSSDS JBXEP2G04FSSDS Front mount (ER) JBXER2G04MSSDSR JBXER2G04FSSDSR In line cable (PC) * JBXPC2G04MSSDSR JBXPC2G04FSSDSR Straight plug (FD) * JBXFD2G04MSSDSR JBXFD2G04FSSDSR Double nut (EA) JBXEA2G04MCSDS JBXEA2G04FCSDS Rear mount (EP) JBXEP2G04MCSDS JBXEP2G04FCSDS Front mount (ER) JBXER2G04MCSDSR JBXER2G04FCSDSR In line cable (PC) * JBXPC2G04MCSDSR JBXPC2G04FCSDSR Rear mount cable (SA) * JBXSA2G04MCSDS JBXSA2G04FCSDS Right angle plug (FC) * JBXFC2G04MCSDSR JBXFC2G04FCSDSR Straight plug (FD) * JBXFD2G04MCSDSR JBXFD2G04FCSDSR Double nut (EA) JBXEA2G04MPSDS JBXEA2G04FPSDS Rear mount (EP) JBXEP2G04MPSDS JBXEP2G04FPSDS Front mount (ER) JBXER2G04MPSDSR JBXER2G04FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 4 solder contacts, male insert = JBXFD2G04MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 4 solder contacts, male insert = JBXFD2G04MSNDSR. 70 : First choice 4 contacts 15A/1,000V JBX Series | Connector per UL1977 JBX2-04 - IP40 (4 x Ø 1.3 mm) - See waterproof IP68 version page 72 Dimensions (For mated connector lengths see page 75) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 71 JBX Series | Connector JBX2-04 - IP68 (4 x Ø 1.3 mm) - See non sealed IP40 version page 70 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 75 Receptacle Plug Crimp contacts see page 75 Straight PCB contacts see page 75 Receptacle Description Part number (1) Male insert Female insert JBXEC2G04MSSDS JBXEC2G04FSSDS Front mount extended (HH) JBXHH2G04MSSDSR JBXHH2G04FSSDSR Straight plug (FH) * JBXFH2G04MSSDSR JBXFH2G04FSSDSR JBXEC2G04MCSDS JBXEC2G04FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G04MCSDSR JBXHH2G04FCSDSR Plug Straight plug (FH) * JBXFH2G04MCSDSR JBXFH2G04FCSDSR Receptacle Double nut, front or rear mount (EC) JBXEC2G04MPSDS JBXEC2G04FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 4 solder contacts, male insert = JBXFH2G04MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 4 solder contacts, male insert = JBXFH2G04MSNDSR. : Sealed in Unmated Condition 72 : First choice 4 contacts 15A/1,000V JBX Series | Connector per UL1977 JBX2-04 - IP68 (4 x Ø 1.3 mm) - See non sealed IP40 version page 70 Dimensions (For mated connector lengths see page 75) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 73 JBX Series | Connector JBX2-04 - IP40 & IP68 (4 x Ø 1.3 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 74 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP13 JBX2OUTLS13 JBXOUTDC13 4 contacts 15A/1,000V JBX Series | Connector per UL1977 JBX2-04 - IP40 & IP68 (4 x Ø 1.3 mm) Contacts Ø 1.3 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 - 20 - 22 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 15A 1,000V UL94 V-0 Note: all dimensions are in mm 75 JBX Series | Connector JBX3-04 - IP40 (3 x Ø 2.0 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G04MSSDS JBXEA3G04FSSDS Solder contacts see page 79 Receptacle Front mount (ER) JBXER3G04MSSDSR JBXER3G04FSSDSR Front mount cable (SR) * JBXSR3G04MSSDSR JBXSR3G04FSSDSR Straight plug (FD) * Plug Crimp contacts see page 79 Receptacle Plug Male insert Female insert JBXFD3G04MSSDSR JBXFD3G04FSSDSR Double nut (EA) JBXEA3G04MCSDS JBXEA3G04FCSDS Front mount (ER) JBXER3G04MCSDSR JBXER3G04FCSDSR Right angle plug (FC) * JBXFC3G04MCSDSR JBXFC3G04FCSDSR Straight plug (FD) * JBXFD3G04MCSDSR JBXFD3G04FCSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 4 solder contacts, male insert = JBXFD3G04MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 4 solder contacts, male insert = JBXFD3G04MSNDSR. 76 : First choice 4 contacts 25A/1,100V JBX Series | Connector per UL1977 JBX3-04 - IP40 (3 x Ø 2.0 mm) Dimensions (For mated connector lengths see page 79) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 77 JBX Series | Connector JBX3-04 - IP40 (3 x Ø 2.0 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling 78 Crimp Tooling Locator Extraction Tool Part number Part number Part number MIL-22520/1-01 JBX3OUTLP20 JBXOUTDC20 4 contacts 25A/1,100V JBX Series | Connector per UL1977 JBX3-04 - IP40 (3 x Ø 2.0 mm) Contacts Ø 2.0 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 16 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 12 - 14 - 16 For more information see pages 231 and 232 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER with SR Connector 50.8 FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 25A 1,100V UL94 V-0 Note: all dimensions are in mm 79 JBX Series | Connector JBX0-05 - IP40 (5 x Ø 0.7mm) - See waterproof IP68 version page 82 FM EZ PC SR FN FC ER FD EP ED EA Layout WITH Connector Part Number Contact type Connector type Description Double nut (EA) Protruding front mount (ED) Receptacle Solder contacts see page 85 Plug Plug Straight PCB contacts see page 85 Receptacle 90° PCB contacts see page 85 Receptacle Female insert JBXEA0G05MSSDS JBXEA0G05FSSDS JBXED0G05MSSDSR JBXED0G05FSSDSR Rear mount (EP) JBXEP0G05MSSDS JBXEP0G05FSSDS JBXER0G05MSSDSR JBXER0G05FSSDSR In line cable (PC) * JBXPC0G05MSSDSR JBXPC0G05FSSDSR Right angle plug (FC) * JBXFC0G05MSSDSR JBXFC0G05FSSDSR Straight plug (FD) * JBXFD0G05MSSDSR JBXFD0G05FSSDSR Right Angle plug with lanyard (FM) * JBXFM0G05MSSDSR JBXFM0G05FSSDSR Straight plug with lanyard (FN) * JBXFN0G05MSSDSR JBXFN0G05FSSDSR JBXEA0G05MCSDS JBXEA0G05FCSDS JBXED0G05MCSDSR JBXED0G05FCSDSR Double nut (EA) Crimp contacts see page 85 Male insert Front mount (ER) Protruding front mount (ED) Receptacle Part number (1) Rear mount (EP) JBXEP0G05MCSDS JBXEP0G05FCSDS Front mount (ER) JBXER0G05MCSDSR JBXER0G05FCSDSR In line cable (PC) * JBXPC0G05MCSDSR JBXPC0G05FCSDSR Front mount cable (SR) * JBXSR0G05MCSDSR JBXSR0G05FCSDSR Right angle plug (FC) * JBXFC0G05MCSDSR JBXFC0G05FCSDSR Straight plug (FD) * JBXFD0G05MCSDSR JBXFD0G05FCSDSR Double nut (EA) JBXEA0G05MPSDS JBXEA0G05FPSDS Rear mount (EP) JBXEP0G05MPSDS JBXEP0G05FPSDS PCB rear mount with mounting pins (EZ) JBXEZ0G05MPSDSR JBXEZ0G05FPSDSR Double nut (EA) - JBXEA0G05FQSDS Protruding front mount (ED) - JBXED0G05FQSDSR Rear mount (EP) - JBXEP0G05FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 5 solder contacts, male insert = JBXFD0G05MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 5 solder contacts, male insert = JBXFD0G05MSNDSR. 80 : First choice 5 contacts 6.5A/400V JBX Series | Connector per UL1977 JBX0-05 - IP40 (5 x Ø 0.7mm) - See waterproof IP68 version page 82 Dimensions (For mated connector lengths see page 85) Rear Mount (EP) Protruding Front Mount (ED) 18.2 14.5 2.5 Ø 12 Ø 12 Ø 10 18.2 1.2 6.7 Front Mount (ER) 3 In Line Cable Receptacle (PC)* Front Mount Cable Receptacle (SR)* Standard version Ø 10 38 Ø 10 Ø 10 1.2 Standard version 38 17 1.2 41.5 8 Boot version Right Angle Plug (FC)* Straight Plug (FD)* Standard version 30.5 20.5 Ø 10 4 29.5 7.6 10 39 Ø 10 19 8 41.5 Boot version PCB Rear Mount with Mounting Pins (EZ) 12.2 4.5 2.5 Connector Double Nut (EA) 1 42.5 Boot version Right Angle Plug with Lanyard (FM) * Straight Plug with Lanyard (FN) * Panel Cut Out 70 39 .1 Ø9 Ø 10 28 Ø 9.3 31 70 8.3 Note: all dimensions are in mm 81 JBX Series | Connector JBX0-05 - IP68 (5 x Ø 0.7mm) - See non sealed IP40 version page 80 FH HH HD HC Layout WITH Connector Part Number Contact type Solder contacts see page 85 Connector type Straight PCB contacts see page 85 Part number (1) Male insert Female insert Rear mount (HC) JBXHC0G05MSSDSR JBXHC0G05FSSDSR Protruding front mount (HD) JBXHD0G05MSSDSR JBXHD0G05FSSDSR Front mount extended (HH) JBXHH0G05MSSDSR JBXHH0G05FSSDSR Straight plug (FH) * JBXFH0G05MSSDSR JBXFH0G05FSSDSR Protruding front mount (HD) JBXHD0G05MCSDSR JBXHD0G05FCSDSR Front mount extended (HH) JBXHH0G05MCSDSR JBXHH0G05FCSDSR Plug Straight plug (FH) * JBXFH0G05MCSDSR JBXFH0G05FCSDSR Receptacle Rear mount (HC) JBXHC0G05MPSDSR JBXHC0G05FPSDSR Receptacle Plug Crimp contacts see page 85 Description Receptacle * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 5 solder contacts, male insert = JBXFH0G05MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 5 solder contacts, male insert = JBXFH0G05MSNDSR. : Sealed in Unmated Condition 82 : First choice 5 contacts 6.5A/400V JBX Series | Connector per UL1977 JBX0-05 - IP68 (5 x Ø 0.7mm) - See non sealed IP40 version page 80 Dimensions (For mated connector lengths see page 85) Protruding Front Mount (HD) 11.8 18.6 22 Ø 14 Ø 14 Ø 18 3 4.0 7 4 Straight Plug (FH)* Standard version 38 Front Mount Extended (HH) 8 Panel Cut Out HC Receptacle HD & HH Receptacle Connector Rear Mount (HC) 28 4 Ø 10 Ø1 41.5 12.6 .1 Ø9 8.3 Boot version Note: all dimensions are in mm 83 JBX Series | Connector JBX0-05 - IP40 & IP68 (5 x Ø 0.7mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR0 JBXBF0 JAXRA0251 Insulating Washer Protective Boot Available only for PC - FC - FD - FM - FN - SR - FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX0RIA Blue JBX0MPA Blue JBX0RIB White JBX0MPB White JBX0RIG Grey JBX0MPG Grey JBX0RIJ Yellow JBX0MPJ Yellow JBX0RIM Brown JBX0MPM Brown JBX0RIN Black JBX0MPN Black JBX0RIR Red JBX0MPR Red JBX0RIV Green JBX0RIO Orange Color JBX0MPV The overall length is 17 mm JBX0MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 84 Part number Male Female Part number MIL-22520/7-01 JBX0OUTLP07 JBX0OUTLS07 JBXOUTDC07 5 contacts 6.5A/400V JBX Series | Connector per UL1977 JBX0-05 - IP40 & IP68 (5 x Ø 0.7mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD or FN Plug + Receptacle with EA 30.5 30.7 40.5 with ED with ER with EP 65.3 64.5 46.3 29 with PC Connector 31 with EZ with SR FC or FM Plug + Receptacle 33.4 23.4 with EA with ED 23.4 22 with EP with ER 64.8 with PC 58.3 46.3 22 with SR with EZ FH Plug + Receptacle 27.5 with HC 37 with HD 28.5 with HH Electrical Characteristics UL 6.5A 400V UL94 V-0 Note: all dimensions are in mm 85 JBX Series | Connector JBX1-05 - IP40 (5 x Ø 0.9 mm) PC FC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 89 Crimp contacts see page 89 90° PCB contacts see page 89 Part number (1) Male insert Female insert Double nut (EA) JBXEA1G05MSSDS JBXEA1G05FSSDS Rear mount (EP) JBXEP1G05MSSDS JBXEP1G05FSSDS Front mount (ER) JBXER1G05MSSDSR JBXER1G05FSSDSR In line cable (PC) * JBXPC1G05MSSDSR JBXPC1G05FSSDSR Front mount cable (SR) * JBXSR1G05MSSDSR JBXSR1G05FSSDSR Straight plug (FD) * JBXFD1G05MSSDSR JBXFD1G05FSSDSR Plug Straight plug no latch (FF) with black protective boot JBXFF1G05MSSDSR JBXFF1G05FSSDSR Double nut (EA) JBXEA1G05MCSDS JBXEA1G05FCSDS Receptacle Front mount (ER) JBXER1G05MCSDSR JBXER1G05FCSDSR Plug Straight PCB contacts see page 89 Description Receptacle Receptacle In line cable (PC) * JBXPC1G05MCSDSR JBXPC1G05FCSDSR Right angle plug (FC) * JBXFC1G05MCSDSR JBXFC1G05FCSDSR Straight plug (FD) * JBXFD1G05MCSDSR JBXFD1G05FCSDSR Double nut (EA) - JBXEA1G05FPSDS Front mount (ER) - JBXER1G05FPSDSR PCB rear mount with mounting pins (EZ) - JBXEZ1G05FPSDSR Double nut (EA) - JBXEA1G05FQSDS Rear mount (EP) - JBXEP1G05FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 5 solder contacts, male insert = JBXFD1G05MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 5 solder contacts, male insert = JBXFD1G05MSNDSR. 86 : First choice 5 contacts 9A/660V JBX Series | Connector per UL1977 JBX1-05 - IP40 (5 x Ø 0.9 mm) Dimensions (For mated connector lengths see page 89) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 21 Ø13 12 1.03 1.5 4 7.6 45.6 10 PCB Rear Mount with Mounting Pins (EZ) Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Right Angle Plug (FC)* 36.5 25.5 Standard version 33.5 Ø 12 68 Ø 12 Ø 12 44 47.6 Boot version Panel Cut Out 2.1 Ø1 10.6 Note: all dimensions are in mm 87 JBX Series | Connector JBX1-05 - IP40 (5 x Ø 0.9 mm) Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange Color JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 88 Part number Male Female Part number MIL-22520/7-01 JBX1OUTLP09 JBX1OUTLS09 JBXOUTDC09 5 contacts 9A/660V JBX Series | Connector per UL1977 JBX1-05 - IP40 (5 x Ø 0.9 mm) Contacts Ø 0.9 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 24 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 - 22 - 24 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 34 36.8 36 with EZ with SR FC Plug + Receptacle 28.8 with EA with EP 67.4 64.8 27 29 with PC with ER 46.3 27 with SR with EZ FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 9A 660V UL94 V-0 Note: all dimensions are in mm 89 JBX Series | Connector JBX2-05 - IP40 (5 x Ø 1.3 mm) - See waterproof IP68 version page 92 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 95 Connector type Receptacle Plug Crimp contacts see page 95 Receptacle Plug Straight PCB contacts see page 95 Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G05MSSDS JBXEA2G05FSSDS Rear mount (EP) JBXEP2G05MSSDS JBXEP2G05FSSDS Front mount (ER) JBXER2G05MSSDSR JBXER2G05FSSDSR In line cable (PC) * JBXPC2G05MSSDSR JBXPC2G05FSSDSR Straight plug (FD) * JBXFD2G05MSSDSR JBXFD2G05FSSDSR Double nut (EA) JBXEA2G05MCSDS JBXEA2G05FCSDS Rear mount (EP) JBXEP2G05MCSDS JBXEP2G05FCSDS Front mount (ER) JBXER2G05MCSDSR JBXER2G05FCSDSR In line cable (PC) * JBXPC2G05MCSDSR JBXPC2G05FCSDSR Rear mount cable (SA) * JBXSA2G05MCSDS JBXSA2G05FCSDS Right angle plug (FC) * JBXFC2G05MCSDSR JBXFC2G05FCSDSR Straight plug (FD) * JBXFD2G05MCSDSR JBXFD2G05FCSDSR Double nut (EA) JBXEA2G05MPSDS JBXEA2G05FPSDS Rear mount (EP) JBXEP2G05MPSDS JBXEP2G05FPSDS Front mount (ER) JBXER2G05MPSDSR JBXER2G05FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 5 solder contacts, male insert = JBXFD2G05MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 5 solder contacts, male insert = JBXFD2G05MSNDSR. 90 : First choice 5 contacts 14A/900V JBX Series | Connector per UL1977 JBX2-05 - IP40 (5 x Ø 1.3 mm) - See waterproof IP68 version page 92 Dimensions (For mated connector lengths see page 95) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 91 JBX Series | Connector JBX2-05 - IP68 (5 x Ø 1.3 mm) - See non sealed IP40 version page 90 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 95 Receptacle Plug Crimp contacts see page 95 Straight PCB contacts see page 95 Receptacle Description Part number (1) Male insert Female insert JBXEC2G05MSSDS JBXEC2G05FSSDS Front mount extended (HH) JBXHH2G05MSSDSR JBXHH2G05FSSDSR Straight plug (FH) * JBXFH2G05MSSDSR JBXFH2G05FSSDSR JBXEC2G05MCSDS JBXEC2G05FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G05MCSDSR JBXHH2G05FCSDSR Plug Straight plug (FH) * JBXFH2G05MCSDSR JBXFH2G05FCSDSR Receptacle Double nut, front or rear mount (EC) JBXEC2G05MPSDS JBXEC2G05FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 5 solder contacts, male insert = JBXFH2G05MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 5 solder contacts, male insert = JBXFH2G05MSNDSR. : Sealed in Unmated Condition 92 5 contacts 14A/900V JBX Series | Connector per UL1977 JBX2-05 - IP68 (5 x Ø 1.3 mm) - See non sealed IP40 version page 90 Dimensions (For mated connector lengths see page 95) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 93 JBX Series | Connector JBX2-05 - IP40 & IP68 (4 x Ø 1.3 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 94 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP13 JBX2OUTLS13 JBXOUTDC13 5 contacts 14A/900V JBX Series | Connector per UL1977 JBX2-05 - IP40 & IP68 (4 x Ø 1.3 mm) Contacts Ø 1.3 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 - 20 - 22 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 14A 900V UL94 V-0 Note: all dimensions are in mm 95 JBX Series | Connector JBX0-06 - IP40 (6 x Ø 0.5mm) - See waterproof IP68 version page 98 FM EZ PC ER FN FC EP FD ED EA Layout WITH Connector Part Number Contact type Connector type Description Double nut (EA) Protruding front mount (ED) Receptacle Solder contacts see page 101 Plug Straight PCB contacts see page 101 Receptacle Part number (1) Male insert Female insert JBXEA0G06MSSDS JBXEA0G06FSSDS JBXED0G06MSSDSR JBXED0G06FSSDSR Rear mount (EP) JBXEP0G06MSSDS JBXEP0G06FSSDS Front mount (ER) JBXER0G06MSSDSR JBXER0G06FSSDSR In line cable (PC) * JBXPC0G06MSSDSR JBXPC0G06FSSDSR Right angle plug (FC) * JBXFC0G06MSSDSR JBXFC0G06FSSDSR Straight plug (FD) * JBXFD0G06MSSDSR JBXFD0G06FSSDSR Right Angle plug with lanyard (FM) * JBXFM0G06MSSDSR JBXFM0G06FSSDSR Straight plug with lanyard (FN) * JBXFN0G06MSSDSR JBXFN0G06FSSDSR Double nut (EA) JBXEA0G06MPSDS JBXEA0G06FPSDS Rear mount (EP) JBXEP0G06MPSDS JBXEP0G06FPSDS JBXEZ0G06MPSDSR JBXEZ0G06FPSDSR PCB rear mount with mounting pins (EZ) * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 6 solder contacts, male insert = JBXFD0G06MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 6 solder contacts, male insert = JBXFD0G06MSNDSR. 96 : First choice 6 contacts 2.5A/320V JBX Series | Connector per UL1977 JBX0-06 - IP40 (6 x Ø 0.5mm) - See waterproof IP68 version page 98 Dimensions (For mated connector lengths see page 101) Double Nut (EA) Rear Mount (EP) Protruding Front Mount (ED) 18.2 14.5 2.5 Ø 12 Ø 12 Ø 10 18.2 1.2 6.7 Front Mount (ER) 3 In Line Cable Receptacle (PC)* 12.2 4.5 2.5 PCB Rear Mount with Mounting Pins (EZ) 38 41.5 8 1 1.2 4 10 Ø 10 19 7.6 Ø 10 17 Connector Standard version Boot version Right Angle Plug (FC)* Straight Plug (FD)* 70 31 Ø 9.3 39 28 Ø 10 Ø 10 29.5 Right Angle Plug with Lanyard (FM) * Standard version 30.5 20.5 42.5 Boot version Straight Plug with Lanyard (FN) * Panel Cut Out 39 .1 Ø 10 Ø9 70 8.3 Note: all dimensions are in mm 97 JBX Series | Connector JBX0-06 - IP68 (6 x Ø 0.5mm) - See non sealed IP40 version page 96 FH HH HD HC Layout WITH Connector Part Number Contact type Solder contacts see page 101 Straight PCB contacts see page 101 Connector type Description Part number (1) Male insert Female insert Rear mount (HC) JBXHC0G06MSSDSR JBXHC0G06FSSDSR Protruding front mount (HD) JBXHD0G06MSSDSR JBXHD0G06FSSDSR Front mount extended (HH) JBXHH0G06MSSDSR JBXHH0G06FSSDSR Plug Straight plug (FH) * JBXFH0G06MSSDSR JBXFH0G06FSSDSR Receptacle Rear mount (HC) JBXHC0G06MPSDSR JBXHC0G06FPSDSR Receptacle * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 6 solder contacts, male insert = JBXFH0G06MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 6 solder contacts, male insert = JBXFH0G06MSNDSR. : Sealed in Unmated Condition 98 : First choice 6 contacts 2.5A/320V JBX Series | Connector per UL1977 JBX0-06 - IP68 (6 x Ø 0.5mm) - See non sealed IP40 version page 96 Dimensions (For mated connector lengths see page 101) Protruding Front Mount (HD) 11.8 18.6 22 Ø 14 Ø 14 Ø 18 3 4.0 7 4 Straight Plug (FH)* Standard version 38 Front Mount Extended (HH) 8 Panel Cut Out HC Receptacle HD & HH Receptacle Connector Rear Mount (HC) 28 4 Ø 10 Ø1 41.5 12.6 .1 Ø9 8.3 Boot version Note: all dimensions are in mm 99 JBX Series | Connector JBX0-06 - IP40 & IP68 (6 x Ø 0.5mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR0 JBXBF0 JAXRA0251 Insulating Washer Protective Boot Available only for PC - FC - FD - FM - FN - FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions 100 Part number Color Part number JBX0RIA Blue JBX0MPA Blue JBX0RIB White JBX0MPB White JBX0RIG Grey JBX0MPG Grey JBX0RIJ Yellow JBX0MPJ Yellow JBX0RIM Brown JBX0MPM Brown JBX0RIN Black JBX0MPN Black JBX0RIR Red JBX0MPR Red JBX0RIV Green JBX0RIO Orange JBX0MPV The overall length is 17 mm JBX0MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 6 contacts 2.5A/320V JBX Series | Connector per UL1977 JBX0-06 - IP40 & IP68 (6 x Ø 0.5mm) Contacts Ø 0.5 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 28 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 and 233 Mated Connector Length FD or FN Plug + Receptacle 64.5 with ED with ER with EP 46.3 with PC Connector with EA 30.5 30.7 40.5 31 with EZ FC or FM Plug + Receptacle 23.4 with EA 33.4 with ED 23.4 22 with EP with ER 64.8 46.3 with PC with EZ FH Plug + Receptacle 27.5 with HC 37 with HD 28.5 with HH Electrical Characteristics UL 2.5A 320V UL94 V-0 Note: all dimensions are in mm 101 JBX Series | Connector JBX1-06 - IP40 (6 x Ø 0.7mm) PC FC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 105 Crimp contacts see page 105 90° PCB contacts see page 105 Part number (1) Male insert Female insert Double nut (EA) JBXEA1G06MSSDS JBXEA1G06FSSDS Rear mount (EP) JBXEP1G06MSSDS JBXEP1G06FSSDS Front mount (ER) JBXER1G06MSSDSR JBXER1G06FSSDSR In line cable (PC) * JBXPC1G06MSSDSR JBXPC1G06FSSDSR Front mount cable (SR) * JBXSR1G06MSSDSR JBXSR1G06FSSDSR Straight plug (FD) * JBXFD1G06MSSDSR JBXFD1G06FSSDSR Plug Straight plug no latch (FF) with black protective boot JBXFF1G06MSSDSR JBXFF1G06FSSDSR Double nut (EA) JBXEA1G06MCSDS JBXEA1G06FCSDS Receptacle Front mount (ER) JBXER1G06MCSDSR JBXER1G06FCSDSR Plug Straight PCB contacts see page 105 Description Receptacle Receptacle In line cable (PC) * JBXPC1G06MCSDSR JBXPC1G06FCSDSR Right angle plug (FC) * JBXFC1G06MCSDSR JBXFC1G06FCSDSR Straight plug (FD) * JBXFD1G06MCSDSR JBXFD1G06FCSDSR Double nut (EA) JBXEA1G06MPSDS JBXEA1G06FPSDS Front mount (ER) JBXER1G06MPSDSR JBXER1G06FPSDSR PCB rear mount with mounting pins (EZ) JBXEZ1G06MPSDSR JBXEZ1G06FPSDSR Double nut (EA) - JBXEA1G06FQSDS Rear mount (EP) - JBXEP1G06FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 6 solder contacts, male insert = JBXFD1G06MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 6 solder contacts, male insert = JBXFD1G06MSNDSR. 102 : First choice 6 contacts 7A/660V JBX Series | Connector per UL1977 JBX1-06 - IP40 (6 x Ø 0.7mm) Dimensions (For mated connector lengths see page 105) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 21 Ø13 12 1.03 1.5 4 7.6 45.6 10 PCB Rear Mount with Mounting Pins (EZ) Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Right Angle Plug (FC)* 36.5 25.5 Standard version 33.5 Ø 12 68 Ø 12 Ø 12 44 47.6 Boot version Panel Cut Out 2.1 Ø1 10.6 Note: all dimensions are in mm 103 JBX Series | Connector JBX1-06 - IP40 (6 x Ø 0.7mm) Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange Color JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 104 Part number Male Female Part number MIL-22520/7-01 JBX1OUTLP07 JBX1OUTLS07 JBXOUTDC07 6 contacts 7A/660V JBX Series | Connector per UL1977 JBX1-06 - IP40 (6 x Ø 0.7mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 34 36.8 36 with EZ with SR FC Plug + Receptacle 28.8 with EA with EP 67.4 64.8 27 29 with PC with ER 46.3 27 with SR with EZ FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 7A 660V UL94 V-0 Note: all dimensions are in mm 105 JBX Series | Connector JBX2-06 - IP40 (6 x Ø 1.3 mm) - See waterproof IP68 version page 108 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 110 Connector type Receptacle Plug Crimp contacts see page 110 Receptacle Plug Straight PCB contacts see page 110 Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G06MSSDS JBXEA2G06FSSDS Rear mount (EP) JBXEP2G06MSSDS JBXEP2G06FSSDS Front mount (ER) JBXER2G06MSSDSR JBXER2G06FSSDSR In line cable (PC) * JBXPC2G06MSSDSR JBXPC2G06FSSDSR Straight plug (FD) * JBXFD2G06MSSDSR JBXFD2G06FSSDSR Double nut (EA) JBXEA2G06MCSDS JBXEA2G06FCSDS Rear mount (EP) JBXEP2G06MCSDS JBXEP2G06FCSDS Front mount (ER) JBXER2G06MCSDSR JBXER2G06FCSDSR In line cable (PC) * JBXPC2G06MCSDSR JBXPC2G06FCSDSR Rear mount cable (SA) * JBXSA2G06MCSDS JBXSA2G06FCSDS Right angle plug (FC) * JBXFC2G06MCSDSR JBXFC2G06FCSDSR Straight plug (FD) * JBXFD2G06MCSDSR JBXFD2G06FCSDSR Double nut (EA) JBXEA2G06MPSDS JBXEA2G06FPSDS Rear mount (EP) JBXEP2G06MPSDS JBXEP2G06FPSDS Front mount (ER) JBXER2G06MPSDSR JBXER2G06FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 6 solder contacts, male insert = JBXFD2G06MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 6 solder contacts, male insert = JBXFD2G06MSNDSR. 106 : First choice 6 contacts 12A/900V JBX Series | Connector per UL1977 JBX2-06 - IP40 (6 x Ø 1.3 mm) - See waterproof IP68 version page 108 Dimensions (For mated connector lengths see page 110) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 107 JBX Series | Connector JBX2-06 - IP68 (6 x Ø 1.3 mm) - See non sealed IP40 version page 106 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 110 Receptacle Plug Crimp contacts see page 110 Straight PCB contacts see page 110 Receptacle Description Part number (1) Male insert Female insert JBXEC2G06MSSDS JBXEC2G06FSSDS Front mount extended (HH) JBXHH2G06MSSDSR JBXHH2G06FSSDSR Straight plug (FH) * JBXFH2G06MSSDSR JBXFH2G06FSSDSR JBXEC2G06MCSDS JBXEC2G06FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G06MCSDSR JBXHH2G06FCSDSR Plug Straight plug (FH) * JBXFH2G06MCSDSR JBXFH2G06FCSDSR Receptacle Double nut, front or rear mount (EC) JBXEC2G06MPSDS JBXEC2G06FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 6 solder contacts, male insert = JBXFH2G06MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 6 solder contacts, male insert = JBXFH2G06MSNDSR. : Sealed in Unmated Condition 108 6 contacts 12A/900V JBX Series | Connector per UL1977 JBX2-06 - IP68 (6 x Ø 1.3 mm) - See non sealed IP40 version page 106 Dimensions (For mated connector lengths see page 110) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 109 JBX Series | Connector JBX2-06 - IP40 & IP68 (6 x Ø 1.3 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 110 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP13 JBX2OUTLS13 JBXOUTDC13 6 contacts 12A/900V JBX Series | Connector per UL1977 JBX2-06 - IP40 & IP68 (6 x Ø 1.3 mm) Contacts Ø 1.3 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 - 20 - 22 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 12A 900V UL94 V-0 Note: all dimensions are in mm 111 JBX Series | Connector JBX0-07 - IP40 (7 x Ø 0.5mm) - See waterproof IP68 version page 114 FM EZ PC ER FN FC EP FD ED EA Layout WITH Connector Part Number Contact type Connector type Description Double nut (EA) Protruding front mount (ED) Receptacle Solder contacts see page 117 Plug Straight PCB contacts see page 117 Receptacle Part number (1) Male insert Female insert JBXEA0G07MSSDS JBXEA0G07FSSDS JBXED0G07MSSDSR JBXED0G07FSSDSR Rear mount (EP) JBXEP0G07MSSDS JBXEP0G07FSSDS Front mount (ER) JBXER0G07MSSDSR JBXER0G07FSSDSR In line cable (PC) * JBXPC0G07MSSDSR JBXPC0G07FSSDSR Right angle plug (FC) * JBXFC0G07MSSDSR JBXFC0G07FSSDSR Straight plug (FD) * JBXFD0G07MSSDSR JBXFD0G07FSSDSR Right Angle plug with lanyard (FM) * JBXFM0G07MSSDSR JBXFM0G07FSSDSR Straight plug with lanyard (FN) * JBXFN0G07MSSDSR JBXFN0G07FSSDSR Double nut (EA) JBXEA0G07MPSDS JBXEA0G07FPSDS Rear mount (EP) JBXEP0G07MPSDS JBXEP0G07FPSDS JBXEZ0G07MPSDSR JBXEZ0G07FPSDSR PCB rear mount with mounting pins (EZ) * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 7 solder contacts, male insert = JBXFD0G07MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 7 solder contacts, male insert = JBXFD0G07MSNDSR. 112 : First choice 7 contacts 2.5A/320V JBX Series | Connector per UL1977 JBX0-07 - IP40 (7 x Ø 0.5mm) - See waterproof IP68 version page 114 Dimensions (For mated connector lengths see page 117) Double Nut (EA) Rear Mount (EP) Protruding Front Mount (ED) 18.2 14.5 2.5 Ø 12 Ø 12 Ø 10 18.2 1.2 6.7 Front Mount (ER) 3 In Line Cable Receptacle (PC)* 12.2 4.5 2.5 PCB Rear Mount with Mounting Pins (EZ) 38 41.5 8 1 1.2 4 10 Ø 10 19 7.6 Ø 10 17 Connector Standard version Boot version Right Angle Plug (FC)* Straight Plug (FD)* 70 31 Ø 9.3 39 28 Ø 10 Ø 10 29.5 Right Angle Plug with Lanyard (FM) * Standard version 30.5 20.5 42.5 Boot version Straight Plug with Lanyard (FN) * Panel Cut Out 39 .1 Ø 10 Ø9 70 8.3 Note: all dimensions are in mm 113 JBX Series | Connector JBX0-07 - IP68 (7 x Ø 0.5mm) - See non sealed IP40 version page 112 FH HH HD HC Layout WITH Connector Part Number Contact type Solder contacts see page 117 Straight PCB contacts see page 117 Connector type Description Part number (1) Male insert Female insert Rear mount (HC) JBXHC0G07MSSDSR JBXHC0G07FSSDSR Protruding front mount (HD) JBXHD0G07MSSDSR JBXHD0G07FSSDSR Front mount extended (HH) JBXHH0G07MSSDSR JBXHH0G07FSSDSR Plug Straight plug (FH) * JBXFH0G07MSSDSR JBXFH0G07FSSDSR Receptacle Rear mount (HC) JBXHC0G07MPSDSR JBXHC0G07FPSDSR Receptacle * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 7 solder contacts, male insert = JBXFH0G07MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 7 solder contacts, male insert = JBXFH0G07MSNDSR. : Sealed in Unmated Condition 114 : First choice 7 contacts 2.5A/320V JBX Series | Connector per UL1977 JBX0-07 - IP68 (7 x Ø 0.5mm) - See non sealed IP40 version page 112 Dimensions (For mated connector lengths see page 117) Protruding Front Mount (HD) 11.8 18.6 22 Ø 14 Ø 14 Ø 18 3 4.0 7 4 Straight Plug (FH)* Standard version 38 Front Mount Extended (HH) 8 Panel Cut Out HC Receptacle HD & HH Receptacle Connector Rear Mount (HC) 28 4 Ø 10 Ø1 41.5 12.6 .1 Ø9 8.3 Boot version Note: all dimensions are in mm 115 JBX Series | Connector JBX0-07 - IP40 & IP68 (7 x Ø 0.5mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR0 JBXBF0 JAXRA0251 Insulating Washer Protective Boot Available only for PC - FC - FD - FM - FN - FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions 116 Part number Color Part number JBX0RIA Blue JBX0MPA Blue JBX0RIB White JBX0MPB White JBX0RIG Grey JBX0MPG Grey JBX0RIJ Yellow JBX0MPJ Yellow JBX0RIM Brown JBX0MPM Brown JBX0RIN Black JBX0MPN Black JBX0RIR Red JBX0MPR Red JBX0RIV Green JBX0RIO Orange JBX0MPV The overall length is 17 mm JBX0MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 7 contacts 2.5A/320V JBX Series | Connector per UL1977 JBX0-07 - IP40 & IP68 (7 x Ø 0.5mm) Contacts Ø 0.5 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 28 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 and 233 Mated Connector Length FD or FN Plug + Receptacle 64.5 with ED with ER with EP 46.3 with PC Connector with EA 30.5 30.7 40.5 31 with EZ FC or FM Plug + Receptacle 23.4 with EA 33.4 with ED 23.4 22 with EP with ER 64.8 46.3 with PC with EZ FH Plug + Receptacle 27.5 with HC 37 with HD 28.5 with HH Electrical Characteristics UL 2.5A 320V UL94 V-0 Note: all dimensions are in mm 117 JBX Series | Connector JBX1-07 - IP40 (7 x Ø 0.7mm) PC FC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 121 Crimp contacts see page 121 90° PCB contacts see page 121 Part number (1) Male insert Female insert Double nut (EA) JBXEA1G07MSSDS JBXEA1G07FSSDS Rear mount (EP) JBXEP1G07MSSDS JBXEP1G07FSSDS Front mount (ER) JBXER1G07MSSDSR JBXER1G07FSSDSR In line cable (PC) * JBXPC1G07MSSDSR JBXPC1G07FSSDSR Front mount cable (SR) * JBXSR1G07MSSDSR JBXSR1G07FSSDSR Straight plug (FD) * JBXFD1G07MSSDSR JBXFD1G07FSSDSR Plug Straight plug no latch (FF) with black protective boot JBXFF1G07MSSDSR JBXFF1G07FSSDSR Double nut (EA) JBXEA1G07MCSDS JBXEA1G07FCSDS Receptacle Front mount (ER) JBXER1G07MCSDSR JBXER1G07FCSDSR Plug Straight PCB contacts see page 121 Description Receptacle Receptacle In line cable (PC) * JBXPC1G07MCSDSR JBXPC1G07FCSDSR Right angle plug (FC) * JBXFC1G07MCSDSR JBXFC1G07FCSDSR Straight plug (FD) * JBXFD1G07MCSDSR JBXFD1G07FCSDSR Double nut (EA) JBXEA1G07MPSDS JBXEA1G07FPSDS Front mount (ER) JBXER1G07MPSDSR JBXER1G07FPSDSR PCB rear mount with mounting pins (EZ) JBXEZ1G07MPSDSR JBXEZ1G07FPSDSR Double nut (EA) - JBXEA1G07FQSDS Rear mount (EP) - JBXEP1G07FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 7 solder contacts, male insert = JBXFD1G07MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 7 solder contacts, male insert = JBXFD1G07MSNDSR. 118 : First choice 7 contacts 7A/660V JBX Series | Connector per UL1977 JBX1-07 - IP40 (7 x Ø 0.7mm) Dimensions (For mated connector lengths see page 121) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 21 Ø13 12 1.03 1.5 4 7.6 45.6 10 PCB Rear Mount with Mounting Pins (EZ) Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Right Angle Plug (FC)* 36.5 25.5 Standard version 33.5 Ø 12 68 Ø 12 Ø 12 44 47.6 Boot version Panel Cut Out 2.1 Ø1 10.6 Note: all dimensions are in mm 119 JBX Series | Connector JBX1-07 - IP40 (7 x Ø 0.7mm) Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange Color JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 120 Part number Male Female Part number MIL-22520/7-01 JBX1OUTLP07 JBX1OUTLS07 JBXOUTDC07 7 contacts 7A/660V JBX Series | Connector per UL1977 JBX1-07 - IP40 (7 x Ø 0.7mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 34 36.8 36 with EZ with SR FC Plug + Receptacle 28.8 with EA with EP 67.4 64.8 27 29 with PC with ER 46.3 27 with SR with EZ FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 7A 660V UL94 V-0 Note: all dimensions are in mm 121 JBX Series | Connector JBX2-07 - IP40 (7 x Ø 1.3 mm) - See waterproof IP68 version page 124 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 127 Connector type Receptacle Plug Crimp contacts see page 127 Receptacle Plug Straight PCB contacts see page 127 Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G07MSSDS JBXEA2G07FSSDS Rear mount (EP) JBXEP2G07MSSDS JBXEP2G07FSSDS Front mount (ER) JBXER2G07MSSDSR JBXER2G07FSSDSR In line cable (PC) * JBXPC2G07MSSDSR JBXPC2G07FSSDSR Straight plug (FD) * JBXFD2G07MSSDSR JBXFD2G07FSSDSR Double nut (EA) JBXEA2G07MCSDS JBXEA2G07FCSDS Rear mount (EP) JBXEP2G07MCSDS JBXEP2G07FCSDS Front mount (ER) JBXER2G07MCSDSR JBXER2G07FCSDSR In line cable (PC) * JBXPC2G07MCSDSR JBXPC2G07FCSDSR Rear mount cable (SA) * JBXSA2G07MCSDS JBXSA2G07FCSDS Right angle plug (FC) * JBXFC2G07MCSDSR JBXFC2G07FCSDSR Straight plug (FD) * JBXFD2G07MCSDSR JBXFD2G07FCSDSR Double nut (EA) JBXEA2G07MPSDS JBXEA2G07FPSDS Rear mount (EP) JBXEP2G07MPSDS JBXEP2G07FPSDS Front mount (ER) JBXER2G07MPSDSR JBXER2G07FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 7 solder contacts, male insert = JBXFD2G07MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 7 solder contacts, male insert = JBXFD2G07MSNDSR. 122 : First choice 7 contacts 11A/730V JBX Series | Connector per UL1977 JBX2-07 - IP40 (7 x Ø 1.3 mm) - See waterproof IP68 version page 124 Dimensions (For mated connector lengths see page 127) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 123 JBX Series | Connector JBX2-07 - IP68 (7 x Ø 1.3 mm) - See non sealed IP40 version page 122 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 127 Receptacle Plug Crimp contacts see page 127 Straight PCB contacts see page 127 Receptacle Description Part number (1) Male insert Female insert JBXEC2G07MSSDS JBXEC2G07FSSDS Front mount extended (HH) JBXHH2G07MSSDSR JBXHH2G07FSSDSR Straight plug (FH) * JBXFH2G07MSSDSR JBXFH2G07FSSDSR JBXEC2G07MCSDS JBXEC2G07FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G07MCSDSR JBXHH2G07FCSDSR Plug Straight plug (FH) * JBXFH2G07MCSDSR JBXFH2G07FCSDSR Receptacle Double nut, front or rear mount (EC) JBXEC2G07MPSDS JBXEC2G07FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 7 solder contacts, male insert = JBXFH2G07MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 7 solder contacts, male insert = JBXFH2G07MSNDSR. : Sealed in Unmated Condition 124 7 contacts 11A/730V JBX Series | Connector per UL1977 JBX2-07 - IP68 (7 x Ø 1.3 mm) - See non sealed IP40 version page 122 Dimensions (For mated connector lengths see page 127) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 125 JBX Series | Connector JBX2-07 - IP40 & IP68 (7 x Ø 1.3 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 126 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP13 JBX2OUTLS13 JBXOUTDC13 7 contacts 11A/730V JBX Series | Connector per UL1977 JBX2-07 - IP40 & IP68 (7 x Ø 1.3 mm) Contacts Ø 1.3 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 - 20 - 22 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 11A 730V UL94 V-0 Note: all dimensions are in mm 127 JBX Series | Connector JBX3-07 - IP40 (7 x Ø 1.6 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G07MSSDS JBXEA3G07FSSDS Solder contacts see page 131 Receptacle Front mount (ER) JBXER3G07MSSDSR JBXER3G07FSSDSR Front mount cable (SR) * JBXSR3G07MSSDSR JBXSR3G07FSSDSR Straight plug (FD) * Plug Crimp contacts see page 131 Receptacle Plug Male insert Female insert JBXFD3G07MSSDSR JBXFD3G07FSSDSR Double nut (EA) JBXEA3G07MCSDS JBXEA3G07FCSDS Front mount (ER) JBXER3G07MCSDSR JBXER3G07FCSDSR Right angle plug (FC) * JBXFC3G07MCSDSR JBXFC3G07FCSDSR Straight plug (FD) * JBXFD3G07MCSDSR JBXFD3G07FCSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 7 solder contacts, male insert = JBXFD3G07MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 7 solder contacts, male insert = JBXFD3G07MSNDSR. 128 : First choice 7 contacts 15A/1,000V JBX Series | Connector per UL1977 JBX3-07 - IP40 (7 x Ø 1.6 mm) Dimensions (For mated connector lengths see page 131) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 129 JBX Series | Connector JBX3-07 - IP40 (7 x Ø 1.6 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling 130 Crimp Tooling Locator Extraction Tool Part number Part number Part number MIL-22520/1-01 JBX3OUTLP16 JBXOUTDC16 7 contacts 15A/1,000V JBX Series | Connector per UL1977 JBX3-07 - IP40 (7 x Ø 1.6 mm) Contacts Ø 1.6 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 14 - 16 - 18 For more information see pages 231 and 232 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER with SR Connector 50.8 FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 15A 1,000V UL94 V-0 Note: all dimensions are in mm 131 JBX Series | Connector JBX0-08 - IP40 (8 x Ø 0.5mm) - See waterproof IP68 version page 134 FM EZ PC ER FN FC EP FD ED EA Layout WITH Connector Part Number Contact type Connector type Description Double nut (EA) Protruding front mount (ED) Receptacle Solder contacts see page 137 Plug Straight PCB contacts see page 137 Receptacle Part number (1) Male insert Female insert JBXEA0G08MSSDS JBXEA0G08FSSDS JBXED0G08MSSDSR JBXED0G08FSSDSR Rear mount (EP) JBXEP0G08MSSDS JBXEP0G08FSSDS Front mount (ER) JBXER0G08MSSDSR JBXER0G08FSSDSR In line cable (PC) * JBXPC0G08MSSDSR JBXPC0G08FSSDSR Right angle plug (FC) * JBXFC0G08MSSDSR JBXFC0G08FSSDSR Straight plug (FD) * JBXFD0G08MSSDSR JBXFD0G08FSSDSR Right Angle plug with lanyard (FM) * JBXFM0G08MSSDSR JBXFM0G08FSSDSR Straight plug with lanyard (FN) * JBXFN0G08MSSDSR JBXFN0G08FSSDSR Double nut (EA) JBXEA0G08MPSDS JBXEA0G08FPSDS Rear mount (EP) JBXEP0G08MPSDS JBXEP0G08FPSDS JBXEZ0G08MPSDSR JBXEZ0G08FPSDSR PCB rear mount with mounting pins (EZ) * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 8 solder contacts, male insert = JBXFD0G08MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 8 solder contacts, male insert = JBXFD0G08MSNDSR. 132 : First choice 8 contacts 2A/190V JBX Series | Connector per UL1977 JBX0-08 - IP40 (8 x Ø 0.5mm) - See waterproof IP68 version page 134 Dimensions (For mated connector lengths see page 137) Double Nut (EA) Rear Mount (EP) Protruding Front Mount (ED) 18.2 14.5 2.5 Ø 12 Ø 12 Ø 10 18.2 1.2 6.7 Front Mount (ER) 3 In Line Cable Receptacle (PC)* 12.2 4.5 2.5 PCB Rear Mount with Mounting Pins (EZ) 38 41.5 8 1 1.2 4 10 Ø 10 19 7.6 Ø 10 17 Connector Standard version Boot version Right Angle Plug (FC)* Straight Plug (FD)* 70 31 Ø 9.3 39 28 Ø 10 Ø 10 29.5 Right Angle Plug with Lanyard (FM) * Standard version 30.5 20.5 42.5 Boot version Straight Plug with Lanyard (FN) * Panel Cut Out 39 .1 Ø 10 Ø9 70 8.3 Note: all dimensions are in mm 133 JBX Series | Connector JBX0-08 - IP68 (8 x Ø 0.5mm) - See non sealed IP40 version page 132 FH HH HD HC Layout WITH Connector Part Number Contact type Solder contacts see page 137 Straight PCB contacts see page 137 Connector type Description Part number (1) Male insert Female insert Rear mount (HC) JBXHC0G08MSSDSR JBXHC0G08FSSDSR Protruding front mount (HD) JBXHD0G08MSSDSR JBXHD0G08FSSDSR Front mount extended (HH) JBXHH0G08MSSDSR JBXHH0G08FSSDSR Plug Straight plug (FH) * JBXFH0G08MSSDSR JBXFH0G08FSSDSR Receptacle Rear mount (HC) JBXHC0G08MPSDSR JBXHC0G08FPSDSR Receptacle * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 0, 8 solder contacts, male insert = JBXFH0G08MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 0, 8 solder contacts, male insert = JBXFH0G08MSNDSR. : Sealed in Unmated Condition 134 : First choice 8 contacts 2A/190V JBX Series | Connector per UL1977 JBX0-08 - IP68 (8 x Ø 0.5mm) - See non sealed IP40 version page 132 Dimensions (For mated connector lengths see page 137) Protruding Front Mount (HD) 11.8 18.6 22 Ø 14 Ø 14 Ø 18 3 4.0 7 4 Straight Plug (FH)* Standard version 38 Front Mount Extended (HH) 8 Panel Cut Out HC Receptacle HD & HH Receptacle Connector Rear Mount (HC) 28 4 Ø 10 Ø1 41.5 12.6 .1 Ø9 8.3 Boot version Note: all dimensions are in mm 135 JBX Series | Connector JBX0-08 - IP40 & IP68 (8 x Ø 0.5mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR0 JBXBF0 JAXRA0251 Insulating Washer Protective Boot Available only for PC - FC - FD - FM - FN - FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions 136 Part number Color Part number JBX0RIA Blue JBX0MPA Blue JBX0RIB White JBX0MPB White JBX0RIG Grey JBX0MPG Grey JBX0RIJ Yellow JBX0MPJ Yellow JBX0RIM Brown JBX0MPM Brown JBX0RIN Black JBX0MPN Black JBX0RIR Red JBX0MPR Red JBX0RIV Green JBX0RIO Orange JBX0MPV The overall length is 17 mm JBX0MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 8 contacts 2A/190V JBX Series | Connector per UL1977 JBX0-08 - IP40 & IP68 (8 x Ø 0.5mm) Contacts Ø 0.5 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 28 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 and 233 Mated Connector Length FD or FN Plug + Receptacle 64.5 with ED with ER with EP 46.3 with PC Connector with EA 30.5 30.7 40.5 31 with EZ FC or FM Plug + Receptacle 23.4 with EA 33.4 with ED 23.4 22 with EP with ER 64.8 46.3 with PC with EZ FH Plug + Receptacle 27.5 with HC 37 with HD 28.5 with HH Electrical Characteristics UL 2A 190V UL94 V-0 Note: all dimensions are in mm 137 JBX Series | Connector JBX1-08 - IP40 (8 x Ø 0.7mm) PC FC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 141 Crimp contacts see page 141 90° PCB contacts see page 141 Part number (1) Male insert Female insert Double nut (EA) JBXEA1G08MSSDS JBXEA1G08FSSDS Rear mount (EP) JBXEP1G08MSSDS JBXEP1G08FSSDS Front mount (ER) JBXER1G08MSSDSR JBXER1G08FSSDSR In line cable (PC) * JBXPC1G08MSSDSR JBXPC1G08FSSDSR Front mount cable (SR) * JBXSR1G08MSSDSR JBXSR1G08FSSDSR Straight plug (FD) * JBXFD1G08MSSDSR JBXFD1G08FSSDSR Plug Straight plug no latch (FF) with black protective boot JBXFF1G08MSSDSR JBXFF1G08FSSDSR Double nut (EA) JBXEA1G08MCSDS JBXEA1G08FCSDS Receptacle Front mount (ER) JBXER1G08MCSDSR JBXER1G08FCSDSR Plug Straight PCB contacts see page 141 Description Receptacle Receptacle In line cable (PC) * JBXPC1G08MCSDSR JBXPC1G08FCSDSR Right angle plug (FC) * JBXFC1G08MCSDSR JBXFC1G08FCSDSR Straight plug (FD) * JBXFD1G08MCSDSR JBXFD1G08FCSDSR Double nut (EA) JBXEA1G08MPSDS JBXEA1G08FPSDS Front mount (ER) JBXER1G08MPSDSR JBXER1G08FPSDSR PCB rear mount with mounting pins (EZ) JBXEZ1G08MPSDSR JBXEZ1G08FPSDSR Double nut (EA) - JBXEA1G08FQSDS Rear mount (EP) - JBXEP1G08FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 8 solder contacts, male insert = JBXFD1G08MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 8 solder contacts, male insert = JBXFD1G08MSNDSR. 138 : First choice 8 contacts 5A/600V JBX Series | Connector per UL1977 JBX1-08 - IP40 (8 x Ø 0.7mm) Dimensions (For mated connector lengths see page 141) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 21 Ø13 12 1.03 1.5 4 7.6 45.6 10 PCB Rear Mount with Mounting Pins (EZ) Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Right Angle Plug (FC)* 36.5 25.5 Standard version 33.5 Ø 12 68 Ø 12 Ø 12 44 47.6 Boot version Panel Cut Out 2.1 Ø1 10.6 Note: all dimensions are in mm 139 JBX Series | Connector JBX1-08 - IP40 (8 x Ø 0.7mm) Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange Color JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 140 Part number Male Female Part number MIL-22520/7-01 JBX1OUTLP07 JBX1OUTLS07 JBXOUTDC07 8 contacts 5A/600V JBX Series | Connector per UL1977 JBX1-08 - IP40 (8 x Ø 0.7mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 34 36.8 36 with EZ with SR FC Plug + Receptacle 28.8 with EA with EP 67.4 64.8 27 29 with PC with ER 46.3 27 with SR with EZ FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 5A 600V UL94 V-0 Note: all dimensions are in mm 141 JBX Series | Connector JBX2-08 - IP40 (8 x Ø 0.9 mm) - See waterproof IP68 version page 144 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 147 Connector type Receptacle Plug Crimp contacts see page 147 Receptacle Plug Straight PCB contacts see page 147 90° PCB contacts see page 147 Receptacle Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G08MSSDS JBXEA2G08FSSDS Rear mount (EP) JBXEP2G08MSSDS JBXEP2G08FSSDS Front mount (ER) JBXER2G08MSSDSR JBXER2G08FSSDSR In line cable (PC) * JBXPC2G08MSSDSR JBXPC2G08FSSDSR Straight plug (FD) * JBXFD2G08MSSDSR JBXFD2G08FSSDSR Double nut (EA) JBXEA2G08MCSDS JBXEA2G08FCSDS Rear mount (EP) JBXEP2G08MCSDS JBXEP2G08FCSDS Front mount (ER) JBXER2G08MCSDSR JBXER2G08FCSDSR In line cable (PC) * JBXPC2G08MCSDSR JBXPC2G08FCSDSR Rear mount cable (SA) * JBXSA2G08MCSDS JBXSA2G08FCSDS Right angle plug (FC) * JBXFC2G08MCSDSR JBXFC2G08FCSDSR Straight plug (FD) * JBXFD2G08MCSDSR JBXFD2G08FCSDSR Double nut (EA) - JBXEA2G08FPSDS Rear mount (EP) - JBXEP2G08FPSDS Front mount (ER) - JBXER2G08FPSDSR Double nut (EA) - JBXEA2G08FQSDS Rear mount (EP) - JBXEP2G08FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 8 solder contacts, male insert = JBXFD2G08MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 8 solder contacts, male insert = JBXFD2G08MSNDSR. 142 : First choice 8 contacts 10A/830V JBX Series | Connector per UL1977 JBX2-08 - IP40 (8 x Ø 0.9 mm) - See waterproof IP68 version page 144 Dimensions (For mated connector lengths see page 147) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 143 JBX Series | Connector JBX2-08 - IP68 (7 x Ø 0.9 mm) - See non sealed IP40 version page 142 FH EC HH Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 147 Receptacle Plug Crimp contacts see page 147 Straight PCB contacts see page 147 Receptacle Description Part number (1) Male insert Female insert JBXEC2G08MSSDS JBXEC2G08FSSDS Front mount extended (HH) JBXHH2G08MSSDSR JBXHH2G08FSSDSR Straight plug (FH) * JBXFH2G08MSSDSR JBXFH2G08FSSDSR JBXEC2G08MCSDS JBXEC2G08FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G08MCSDSR JBXHH2G08FCSDSR Plug Straight plug (FH) * JBXFH2G08MCSDSR JBXFH2G08FCSDSR Receptacle Double nut, front or rear mount (EC) - JBXEC2G08FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 8 solder contacts, male insert = JBXFH2G08MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 8 solder contacts, male insert = JBXFH2G08MSNDSR. : Sealed in Unmated Condition 144 8 contacts 10A/830V JBX Series | Connector per UL1977 JBX2-08 - IP68 (7 x Ø 0.9 mm) - See non sealed IP40 version page 142 Dimensions (For mated connector lengths see page 147) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 145 JBX Series | Connector JBX2-08 - IP40 & IP68 (8 x Ø 0.9 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 146 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP09 JBX2OUTLS09 JBXOUTDC09 8 contacts 10A/830V JBX Series | Connector per UL1977 JBX2-08 - IP40 & IP68 (8 x Ø 0.9 mm) Contacts Ø 0.9 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 24 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 - 22 - 24 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 10A 830V UL94 V-0 Note: all dimensions are in mm 147 JBX Series | Connector JBX2-001 - IP40 (6 x Ø 0.7 mm + 2 x Ø 2.0 mm) - See waterproof IP68 version page 150 FD PC ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 153 Connector type Receptacle Plug Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G001MSSDS JBXEA2G001FSSDS Rear mount (EP) JBXEP2G001MSSDS JBXEP2G001FSSDS Front mount (ER) JBXER2G001MSSDSR JBXER2G001FSSDSR In line cable (PC) * JBXPC2G001MSSDSR JBXPC2G001FSSDSR Straight plug (FD) * JBXFD2G001MSSDSR JBXFD2G001FSSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 8 solder contacts, male insert = JBXFD2G001MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 8 solder contacts, male insert = JBXFD2G001MSNDSR. 148 8 contacts 26A/700V JBX Series | Connector per UL1977 JBX2-001 - IP40 (6 x Ø 0.7 mm + 2 x Ø 2.0 mm) - See waterproof IP68 version page 150 Dimensions (For mated connector lengths see page 153) Rear Mount (EP) 22.2 18.5 20.4 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Straight Plug (FD)* Standard version Panel Cut Out 52 5.1 Ø1 Ø 15 Ø 16 Boot version 10 Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) 18.5 Ø 20 Ø 20 Double Nut (EA) 56.8 13.6 Boot version Note: all dimensions are in mm 149 JBX Series | Connector JBX2-001 - IP68 (6 x Ø 0.7 mm + 2 x Ø 2.0 mm) - See non sealed IP40 version page 148 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 153 Receptacle Plug Description Part number (1) Male insert Female insert JBXEC2G001MSSDS JBXEC2G001FSSDS Front mount extended (HH) JBXHH2G001MSSDSR JBXHH2G001FSSDSR Straight plug (FH) * JBXFH2G001MSSDSR JBXFH2G001FSSDSR Double nut, front or rear mount (EC) * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 8 solder contacts, male insert = JBXFH2G001MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 8 solder contacts, male insert = JBXFH2G001MSNDSR. : Sealed in Unmated Condition 150 8 contacts 26A/700V JBX Series | Connector per UL1977 JBX2-001 - IP68 (6 x Ø 0.7 mm + 2 x Ø 2.0 mm) - See non sealed IP40 version page 148 Dimensions (For mated connector lengths see page 153) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 151 JBX Series | Connector JBX2-001 - IP40 & IP68 (6 x Ø 0.7 mm + 2 x Ø 2.0 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FD , FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Tooling Extraction Tools 152 Part number Ø 0.7 Contacts Ø 2.0 JBXOUTDC07 JBXOUTDC20 JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 8 contacts 26A/700V JBX Series | Connector per UL1977 JBX2-001 - IP40 & IP68 (6 x Ø 0.7 mm + 2 x Ø 2.0 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 Ø 2.0 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 16 For more information see page 231 Mated Connector Length FD Plug + Receptacle with EA 40 43 with ER with EP 87.8 Connector 42 with PC FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 26A 700V UL94 V-0 Note: all dimensions are in mm 153 JBX Series | Connector JBX3-08 - IP40 (8 x Ø 1.3 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G08MSSDS JBXEA3G08FSSDS Solder contacts see page 157 Receptacle Front mount (ER) JBXER3G08MSSDSR JBXER3G08FSSDSR Front mount cable (SR) * JBXSR3G08MSSDSR JBXSR3G08FSSDSR Straight plug (FD) * Plug Crimp contacts see page 157 Receptacle Plug Male insert Female insert JBXFD3G08MSSDSR JBXFD3G08FSSDSR Double nut (EA) JBXEA3G08MCSDS JBXEA3G08FCSDS Front mount (ER) JBXER3G08MCSDSR JBXER3G08FCSDSR Right angle plug (FC) * JBXFC3G08MCSDSR JBXFC3G08FCSDSR Straight plug (FD) * JBXFD3G08MCSDSR JBXFD3G08FCSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 8 solder contacts, male insert = JBXFD3G08MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 8 solder contacts, male insert = JBXFD3G08MSNDSR. 154 8 contacts 12A/830V JBX Series | Connector per UL1977 JBX3-08 - IP40 (8 x Ø 1.3 mm) Dimensions (For mated connector lengths see page 157) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 155 JBX Series | Connector JBX3-08 - IP40 (8 x Ø 1.3 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 156 Part number Male Female Part number MIL-22520/7-01 JBX3OUTLP13 JBX3OUTLS13 JBXOUTDC13 8 contacts 12A/830V JBX Series | Connector per UL1977 JBX3-08 - IP40 (8 x Ø 1.3 mm) Contacts Ø 1.3 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 - 20 - 22 For more information see pages 231 and 232 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER with SR Connector 50.8 FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 12A 830V UL94 V-0 Note: all dimensions are in mm 157 JBX Series | Connector JBX2-002 - IP40 (6 x Ø 0.7 mm + 3 x Ø 1.3 mm) - See waterproof IP68 version page 160 FD PC ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 163 Connector type Receptacle Plug Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G002MSSDS JBXEA2G002FSSDS Rear mount (EP) JBXEP2G002MSSDS JBXEP2G002FSSDS Front mount (ER) JBXER2G002MSSDSR JBXER2G002FSSDSR In line cable (PC) * JBXPC2G002MSSDSR JBXPC2G002FSSDSR Straight plug (FD) * JBXFD2G002MSSDSR JBXFD2G002FSSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 9 solder contacts, male insert = JBXFD2G002MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 9 solder contacts, male insert = JBXFD2G002MSNDSR. 158 9 contacts 26A/700V JBX Series | Connector per UL1977 JBX2-002 - IP40 (6 x Ø 0.7 mm + 3 x Ø 1.3 mm) - See waterproof IP68 version page 160 Dimensions (For mated connector lengths see page 163) Rear Mount (EP) 22.2 18.5 20.4 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Straight Plug (FD)* Standard version Panel Cut Out 52 5.1 Ø1 Ø 15 Ø 16 Boot version 10 Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) 18.5 Ø 20 Ø 20 Double Nut (EA) 56.8 13.6 Boot version Note: all dimensions are in mm 159 JBX Series | Connector JBX2-002 - IP68 (6 x Ø 0.7 mm + 3 x Ø 1.3 mm) - See non sealed IP40 version page 158 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 163 Receptacle Plug Description Part number (1) Male insert Female insert JBXEC2G002MSSDS JBXEC2G002FSSDS Front mount extended (HH) JBXHH2G002MSSDSR JBXHH2G002FSSDSR Straight plug (FH) * JBXFH2G002MSSDSR JBXFH2G002FSSDSR Double nut, front or rear mount (EC) * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 9 solder contacts, male insert = JBXFH2G002MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 9 solder contacts, male insert = JBXFH2G002MSNDSR. : Sealed in Unmated Condition 160 9 contacts 26A/700V JBX Series | Connector per UL1977 JBX2-002 - IP68 (6 x Ø 0.7 mm + 3 x Ø 1.3 mm) - See non sealed IP40 version page 158 Dimensions (For mated connector lengths see page 163) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 161 JBX Series | Connector JBX2-002 - P40 & IP68 (6 x Ø 0.7 mm + 3 x Ø 1.3 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FD , FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Tooling Extraction Tools 162 Part number Ø 0.7 Part number Ø 1.3 JBXOUTDC07 JBXOUTDC13 JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 9 contacts 26A/700V JBX Series | Connector JBX2-002 - P40 & IP68 per UL1977 (6 x Ø 0.7 mm + 3 x Ø 1.3 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 Ø 1.3 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 For more information see page 231 Mated Connector Length FD Plug + Receptacle with EA 40 43 with ER with EP 87.8 Connector 42 with PC FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 26A 700V UL94 V-0 Note: all dimensions are in mm 163 JBX Series | Connector JBX1-10 - IP40 (10 x Ø 0.5mm) PC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 167 Straight PCB contacts see page 167 Description Part number (1) Male insert Female insert Double nut (EA) JBXEA1G10MSSDS JBXEA1G10FSSDS Rear mount (EP) JBXEP1G10MSSDS JBXEP1G10FSSDS Front mount (ER) JBXER1G10MSSDSR JBXER1G10FSSDSR In line cable (PC) * JBXPC1G10MSSDSR JBXPC1G10FSSDSR Front mount cable (SR) * JBXSR1G10MSSDSR JBXSR1G10FSSDSR Straight plug (FD) * JBXFD1G10MSSDSR JBXFD1G10FSSDSR Plug Straight plug no latch (FF) with black protective boot JBXFF1G10MSSDSR JBXFF1G10FSSDSR Double nut (EA) - JBXEA1G10FPSDS Receptacle Front mount (ER) - JBXER1G10FPSDSR PCB rear mount with mounting pins (EZ) - JBXEZ1G10FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 10 solder contacts, male insert = JBXFD1G10MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 10 solder contacts, male insert = JBXFD1G10MSNDSR. 164 : First choice 10 contacts 2.5A/300V JBX Series | Connector per UL1977 JBX1-10 - IP40 (10 x Ø 0.5mm) Dimensions (For mated connector lengths see page 167) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 1.5 21 4 12 Ø13 PCB Rear Mount with Mounting Pins (EZ) 1.03 45.6 10 7.6 Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Panel Cut Out Standard version 68 Ø 12 Ø 12 44 47.6 2.1 Ø1 10.6 Boot version Note: all dimensions are in mm 165 JBX Series | Connector JBX1-10 - IP40 (10 x Ø 0.5mm) Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions 166 Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 10 contacts 2.5A/300V JBX Series | Connector per UL1977 JBX1-10 - IP40 (10 x Ø 0.5mm) Contacts Ø 0.5 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 28 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 and 233 Mated Connector Length FD Plug + Receptacle with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 34 36.8 36 with EZ with SR FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 2.5A 300V UL94 V-0 Note: all dimensions are in mm 167 JBX Series | Connector JBX2-10 - IP40 (10 x Ø 0.9 mm) - See waterproof IP68 version page 170 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 173 Connector type Receptacle Plug Crimp contacts see page 173 Receptacle Plug Straight PCB contacts see page 173 90° PCB contacts see page 173 Receptacle Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G10MSSDS JBXEA2G10FSSDS Rear mount (EP) JBXEP2G10MSSDS JBXEP2G10FSSDS Front mount (ER) JBXER2G10MSSDSR JBXER2G10FSSDSR In line cable (PC) * JBXPC2G10MSSDSR JBXPC2G10FSSDSR Straight plug (FD) * JBXFD2G10MSSDSR JBXFD2G10FSSDSR Double nut (EA) JBXEA2G10MCSDS JBXEA2G10FCSDS Rear mount (EP) JBXEP2G10MCSDS JBXEP2G10FCSDS Front mount (ER) JBXER2G10MCSDSR JBXER2G10FCSDSR In line cable (PC) * JBXPC2G10MCSDSR JBXPC2G10FCSDSR Rear mount cable (SA) * JBXSA2G10MCSDS JBXSA2G10FCSDS Right angle plug (FC) * JBXFC2G10MCSDSR JBXFC2G10FCSDSR Straight plug (FD) * JBXFD2G10MCSDSR JBXFD2G10FCSDSR Double nut (EA) - JBXEA2G10FPSDS Rear mount (EP) - JBXEP2G10FPSDS Front mount (ER) - JBXER2G10FPSDSR Double nut (EA) - JBXEA2G10FQSDS Rear mount (EP) - JBXEP2G10FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 10 solder contacts, male insert = JBXFD2G10MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 10 solder contacts, male insert = JBXFD2G10MSNDSR. 168 : First choice 10 contacts 8A/830V JBX Series | Connector per UL1977 JBX2-10 - IP40 (10 x Ø 0.9 mm) - See waterproof IP68 version page 170 Dimensions (For mated connector lengths see page 173) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 169 JBX Series | Connector JBX2-10 - IP68 (10 x Ø 0.9 mm) - See non sealed IP40 version page 168 FH EC HH Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 173 Receptacle Plug Crimp contacts see page 173 Straight PCB contacts see page 173 Receptacle Description Part number (1) Male insert Female insert JBXEC2G10MSSDS JBXEC2G10FSSDS Front mount extended (HH) JBXHH2G10MSSDSR JBXHH2G10FSSDSR Straight plug (FH) * JBXFH2G10MSSDSR JBXFH2G10FSSDSR JBXEC2G10MCSDS JBXEC2G10FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G10MCSDSR JBXHH2G10FCSDSR Plug Straight plug (FH) * JBXFH2G10MCSDSR JBXFH2G10FCSDSR Receptacle Double nut, front or rear mount (EC) - JBXEC2G10FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 10 solder contacts, male insert = JBXFH2G10MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 10 solder contacts, male insert = JBXFH2G10MSNDSR. : Sealed in Unmated Condition 170 10 contacts 8A/830V JBX Series | Connector per UL1977 JBX2-10 - IP68 (10 x Ø 0.9 mm) - See non sealed IP40 version page 168 Dimensions (For mated connector lengths see page 173) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 171 JBX Series | Connector JBX2-10 - IP40 & IP68 (10 x Ø 0.9 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 172 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP09 JBX2OUTLS09 JBXOUTDC09 10 contacts 8A/830V JBX Series | Connector per UL1977 JBX2-10 - IP40 & IP68 (10 x Ø 0.9 mm) Contacts Ø 0.9 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 24 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 - 22 - 24 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 8A 830V UL94 V-0 Note: all dimensions are in mm 173 JBX Series | Connector JBX2-003 - IP40 (8 x Ø 0.7 mm + 2 x Ø 1.6 mm) - See waterproof IP68 version page 176 FD PC ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 179 Connector type Receptacle Plug Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G003MSSDS JBXEA2G003FSSDS Rear mount (EP) JBXEP2G003MSSDS JBXEP2G003FSSDS Front mount (ER) JBXER2G003MSSDSR JBXER2G003FSSDSR In line cable (PC) * JBXPC2G003MSSDSR JBXPC2G003FSSDSR Straight plug (FD) * JBXFD2G003MSSDSR JBXFD2G003FSSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 10 solder contacts, male insert = JBXFD2G003MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 10 solder contacts, male insert = JBXFD2G003MSNDSR. 174 10 contacts 17A/700V JBX Series | Connector per UL1977 JBX2-003 - IP40 (8 x Ø 0.7 mm + 2 x Ø 1.6 mm) - See waterproof IP68 version page 176 Dimensions (For mated connector lengths see page 179) Rear Mount (EP) 22.2 18.5 20.4 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Straight Plug (FD)* Standard version Panel Cut Out 52 5.1 Ø1 Ø 15 Ø 16 Boot version 10 Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) 18.5 Ø 20 Ø 20 Double Nut (EA) 56.8 13.6 Boot version Note: all dimensions are in mm 175 JBX Series | Connector JBX2-003 - IP68 (8 x Ø 0.7 mm + 2 x Ø 1.6 mm) - See non sealed IP40 version page 174 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 179 Receptacle Plug Description Part number (1) Male insert Female insert JBXEC2G003MSSDS JBXEC2G003FSSDS Front mount extended (HH) JBXHH2G003MSSDSR JBXHH2G003FSSDSR Straight plug (FH) * JBXFH2G003MSSDSR JBXFH2G003FSSDSR Double nut, front or rear mount (EC) * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 10 solder contacts, male insert = JBXFH2G003MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 10 solder contacts, male insert = JBXFH2G003MSNDSR. : Sealed in Unmated Condition 176 10 contacts 17A/700V JBX Series | Connector per UL1977 JBX2-003 - IP68 (8 x Ø 0.7 mm + 2 x Ø 1.6 mm) - See non sealed IP40 version page 174 Dimensions (For mated connector lengths see page 179) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 177 JBX Series | Connector JBX2-003 - IP40 & IP68 (8 x Ø 0.7 mm + 2 x Ø 1.6 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FD , FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Tooling Extraction Tools 178 Part number Ø 0.7 Part number Ø 1.6 JBXOUTDC07 JBXOUTDC16 JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 10 contacts 17A/700V JBX Series | Connector per UL1977 JBX2-003 - IP40 & IP68 (8 x Ø 0.7 mm + 2 x Ø 1.6 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 Ø 1.6 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 For more information see page 231 Mated Connector Length FD Plug + Receptacle with EA 40 43 with ER with EP 87.8 Connector 42 with PC FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 17A 700V UL94 V-0 Note: all dimensions are in mm 179 JBX Series | Connector JBX3-10 - IP40 (10 x Ø 1.3 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G10MSSDS JBXEA3G10FSSDS Solder contacts see page 183 Receptacle Front mount (ER) JBXER3G10MSSDSR JBXER3G10FSSDSR Front mount cable (SR) * JBXSR3G10MSSDSR JBXSR3G10FSSDSR Straight plug (FD) * Plug Crimp contacts see page 183 Straight PCB contacts see page 183 Receptacle Plug Receptacle Male insert Female insert JBXFD3G10MSSDSR JBXFD3G10FSSDSR Double nut (EA) JBXEA3G10MCSDS JBXEA3G10FCSDS Front mount (ER) JBXER3G10MCSDSR JBXER3G10FCSDSR Right angle plug (FC) * JBXFC3G10MCSDSR JBXFC3G10FCSDSR Straight plug (FD) * JBXFD3G10MCSDSR JBXFD3G10FCSDSR Double nut (EA) - JBXEA3G10FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 10 solder contacts, male insert = JBXFD3G10MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 10 solder contacts, male insert = JBXFD3G10MSNDSR. 180 10 contacts 12A/600V JBX Series | Connector per UL1977 JBX3-10 - IP40 (10 x Ø 1.3 mm) Dimensions (For mated connector lengths see page 183) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 181 JBX Series | Connector JBX3-10 - IP40 (10 x Ø 1.3 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 182 Part number Male Female Part number MIL-22520/7-01 JBX3OUTLP13 JBX3OUTLS13 JBXOUTDC13 10 contacts 12A/600V JBX Series | Connector per UL1977 JBX3-10 - IP40 (10 x Ø 1.3 mm) Contacts Ø 1.3 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 18 - 20 - 22 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER Connector 50.8 with SR FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 12A 600V UL94 V-0 Note: all dimensions are in mm 183 JBX Series | Connector JBX1-12 - IP40 (12 x Ø 0.5mm) PC FF FD SR EZ ER EP EA Layout WITH Connector Part Number Contact type Connector type Receptacle Solder contacts see page 187 Straight PCB contacts see page 187 Description Part number (1) Male insert Female insert Double nut (EA) JBXEA1G12MSSDS JBXEA1G12FSSDS Rear mount (EP) JBXEP1G12MSSDS JBXEP1G12FSSDS Front mount (ER) JBXER1G12MSSDSR JBXER1G12FSSDSR In line cable (PC) * JBXPC1G12MSSDSR JBXPC1G12FSSDSR Front mount cable (SR) * JBXSR1G12MSSDSR JBXSR1G12FSSDSR Straight plug (FD) * JBXFD1G12MSSDSR JBXFD1G12FSSDSR Plug Straight plug no latch (FF) with black protective boot JBXFF1G12MSSDSR JBXFF1G12FSSDSR Double nut (EA) - JBXEA1G12FPSDS Receptacle Front mount (ER) - JBXER1G12FPSDSR PCB rear mount with mounting pins (EZ) - JBXEZ1G12FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 1, 12 solder contacts, male insert = JBXFD1G12MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 1, 12 solder contacts, male insert = JBXFD1G12MSNDSR. 184 : First choice 12 contacts 2.5A/170V JBX Series | Connector per UL1977 JBX1-12 - IP40 (12 x Ø 0.5mm) Dimensions (For mated connector lengths see page 187) Rear Mount (EP) 17.2 Ø 16 Ø 14 16.5 Ø 16 20.2 Front Mount (ER) 3.2 8.3 In Line Cable (PC)* 9.2 6 3.2 Front Mount Cable (SR)* Standard version 42 42 1.5 21 4 12 Ø13 PCB Rear Mount with Mounting Pins (EZ) 1.03 45.6 10 7.6 Ø 14 Standard version 1.5 Connector Double Nut (EA) 10 45.6 Boot version Boot version Straight Plug (FD)* Straight Plug (FF) Panel Cut Out Standard version 68 Ø 12 Ø 12 44 47.6 2.1 Ø1 10.6 Boot version Note: all dimensions are in mm 185 JBX Series | Connector JBX1-12 - IP40 (12 x Ø 0.5mm) Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR1 JBXBF1 JAXRA1251 Insulating Washer Protective Boot Available only for PC - FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions 186 Part number Color Part number JBX1RIA Blue JBX1MPA Blue JBX1RIB White JBX1MPB White JBX1RIG Grey JBX1MPG Grey JBX1RIJ Yellow JBX1MPJ Yellow JBX1RIM Brown JBX1MPM Brown JBX1RIN Black JBX1MPN Black JBX1RIR Red JBX1MPR Red JBX1RIV Green JBX1RIO Orange JBX1MPV The overall length is 21 mm JBX1MPO longer with the protective boot. Note: The protective boot is not a sealing element. Color Green Orange 12 contacts 2.5A/170V JBX Series | Connector per UL1977 JBX1-12 - IP40 (12 x Ø 0.5mm) Contacts Ø 0.5 mm Contact type Plating Contact locking type AWG - Wire max. Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 28 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 and 233 Mated Connector Length FD Plug + Receptacle with EA with EP 74.8 with ER 74.5 53.3 34 with PC Connector 34 36.8 36 with EZ with SR FF Plug + Receptacle 59 61 60.8 with EA with EP 99.5 with PC 99.5 59 with SR with ER 78 with EZ Electrical Characteristics UL 2.5A 170V UL94 V-0 Note: all dimensions are in mm 187 JBX Series | Connector JBX2-12 - IP40 (12 x Ø 0.7 mm) - See waterproof IP68 version page 190 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 193 Connector type Receptacle Plug Crimp contacts see page 193 Receptacle Plug Straight PCB contacts see page 193 90° PCB contacts see page 193 Receptacle Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G12MSSDS JBXEA2G12FSSDS Rear mount (EP) JBXEP2G12MSSDS JBXEP2G12FSSDS Front mount (ER) JBXER2G12MSSDSR JBXER2G12FSSDSR In line cable (PC) * JBXPC2G12MSSDSR JBXPC2G12FSSDSR Straight plug (FD) * JBXFD2G12MSSDSR JBXFD2G12FSSDSR Double nut (EA) JBXEA2G12MCSDS JBXEA2G12FCSDS Rear mount (EP) JBXEP2G12MCSDS JBXEP2G12FCSDS Front mount (ER) JBXER2G12MCSDSR JBXER2G12FCSDSR In line cable (PC) * JBXPC2G12MCSDSR JBXPC2G12FCSDSR Rear mount cable (SA) * JBXSA2G12MCSDS JBXSA2G12FCSDS Right angle plug (FC) * JBXFC2G12MCSDSR JBXFC2G12FCSDSR Straight plug (FD) * JBXFD2G12MCSDSR JBXFD2G12FCSDSR Double nut (EA) JBXEA2G12MPSDS JBXEA2G12FPSDS Rear mount (EP) JBXEP2G12MPSDS JBXEP2G12FPSDS Front mount (ER) JBXER2G12MPSDSR JBXER2G12FPSDSR Double nut (EA) - JBXEA2G12FQSDS Rear mount (EP) - JBXEP2G12FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 12 solder contacts, male insert = JBXFD2G12MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 12 solder contacts, male insert = JBXFD2G12MSNDSR. 188 : First choice 12 contacts 7A/830V JBX Series | Connector per UL1977 JBX2-12 - IP40 (12 x Ø 0.7 mm) - See waterproof IP68 version page 190 Dimensions (For mated connector lengths see page 193) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 189 JBX Series | Connector JBX2-12 - IP68 (12 x Ø 0.7 mm) - See non sealed IP40 version page 188 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 193 Receptacle Plug Crimp contacts see page 193 Straight PCB contacts see page 193 Receptacle Description Part number (1) Male insert Female insert JBXEC2G12MSSDS JBXEC2G12FSSDS Front mount extended (HH) JBXHH2G12MSSDSR JBXHH2G12FSSDSR Straight plug (FH) * JBXFH2G12MSSDSR JBXFH2G12FSSDSR JBXEC2G12MCSDS JBXEC2G12FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G12MCSDSR JBXHH2G12FCSDSR Plug Straight plug (FH) * JBXFH2G12MCSDSR JBXFH2G12FCSDSR Receptacle Double nut, front or rear mount (EC) JBXEC2G12MPSDS JBXEC2G12FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 12 solder contacts, male insert = JBXFH2G12MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 12 solder contacts, male insert = JBXFH2G12MSNDSR. : Sealed in Unmated Condition 190 12 contacts 7A/830V JBX Series | Connector per UL1977 JBX2-12 - IP68 (12 x Ø 0.7 mm) - See non sealed IP40 version page 188 Dimensions (For mated connector lengths see page 193) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 191 JBX Series | Connector JBX2-12 - IP40 & IP68 (12 x Ø 0.7 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 192 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP07 JBX2OUTLS07 JBXOUTDC07 12 contacts 7A/830V JBX Series | Connector per UL1977 JBX2-12 - IP40 & IP68 (12 x Ø 0.7 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 7A 830V UL94 V-0 Note: all dimensions are in mm 193 JBX Series | Connector JBX3-14 - IP40 (14 x Ø 0.9 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G14MSSDS JBXEA3G14FSSDS Solder contacts see page 197 Receptacle Front mount (ER) JBXER3G14MSSDSR JBXER3G14FSSDSR Front mount cable (SR) * JBXSR3G14MSSDSR JBXSR3G14FSSDSR Straight plug (FD) * Plug Crimp contacts see page 197 Straight PCB contacts see page 197 Receptacle Plug Receptacle Male insert Female insert JBXFD3G14MSSDSR JBXFD3G14FSSDSR Double nut (EA) JBXEA3G14MCSDS JBXEA3G14FCSDS Front mount (ER) JBXER3G14MCSDSR JBXER3G14FCSDSR Right angle plug (FC) * JBXFC3G14MCSDSR JBXFC3G14FCSDSR Straight plug (FD) * JBXFD3G14MCSDSR JBXFD3G14FCSDSR Double nut (EA) - JBXEA3G14FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 14 solder contacts, male insert = JBXFD3G14MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 14 solder contacts, male insert = JBXFD3G14MSNDSR. 194 : First choice 14 contacts 9A/830V JBX Series | Connector per UL1977 JBX3-14 - IP40 (14 x Ø 0.9 mm) Dimensions (For mated connector lengths see page 197) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 195 JBX Series | Connector JBX3-14 - IP40 (10 x Ø 0.9 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 196 Part number Male Female Part number MIL-22520/7-01 JBX3OUTLP09 JBX3OUTLS09 JBXOUTDC09 14 contacts 9A/830V JBX Series | Connector per UL1977 JBX3-14 - IP40 (10 x Ø 0.9 mm) Contacts Ø 0.9 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 24 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 - 22 - 24 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER Connector 50.8 with SR FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 9A 830V UL94 V-0 Note: all dimensions are in mm 197 JBX Series | Connector JBX2-16 - IP40 (16 x Ø 0.7 mm) - See waterproof IP68 version page 200 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 203 Connector type Receptacle Plug Crimp contacts see page 203 Receptacle Plug Straight PCB contacts see page 203 90° PCB contacts see page 203 Receptacle Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G16MSSDS JBXEA2G16FSSDS Rear mount (EP) JBXEP2G16MSSDS JBXEP2G16FSSDS Front mount (ER) JBXER2G16MSSDSR JBXER2G16FSSDSR In line cable (PC) * JBXPC2G16MSSDSR JBXPC2G16FSSDSR Straight plug (FD) * JBXFD2G16MSSDSR JBXFD2G16FSSDSR Double nut (EA) JBXEA2G16MCSDS JBXEA2G16FCSDS Rear mount (EP) JBXEP2G16MCSDS JBXEP2G16FCSDS Front mount (ER) JBXER2G16MCSDSR JBXER2G16FCSDSR In line cable (PC) * JBXPC2G16MCSDSR JBXPC2G16FCSDSR Rear mount cable (SA) * JBXSA2G16MCSDS JBXSA2G16FCSDS Right angle plug (FC) * JBXFC2G16MCSDSR JBXFC2G16FCSDSR Straight plug (FD) * JBXFD2G16MCSDSR JBXFD2G16FCSDSR Double nut (EA) JBXEA2G16MPSDS JBXEA2G16FPSDS Rear mount (EP) JBXEP2G16MPSDS JBXEP2G16FPSDS Front mount (ER) JBXER2G16MPSDSR JBXER2G16FPSDSR Double nut (EA) - JBXEA2G16FQSDS Rear mount (EP) - JBXEP2G16FQSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 16 solder contacts, male insert = JBXFD2G16MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 16 solder contacts, male insert = JBXFD2G16MSNDSR. 198 : First choice 16 contacts 6A/730V JBX Series | Connector per UL1977 JBX2-16 - IP40 (16 x Ø 0.7 mm) - See waterproof IP68 version page 200 Dimensions (For mated connector lengths see page 203) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 199 JBX Series | Connector JBX2-16 - IP68 (16 x Ø 0.7 mm) - See non sealed IP40 version page 198 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 203 Receptacle Plug Crimp contacts see page 203 Straight PCB contacts see page 203 Receptacle Description Part number (1) Male insert Female insert JBXEC2G16MSSDS JBXEC2G16FSSDS Front mount extended (HH) JBXHH2G16MSSDSR JBXHH2G16FSSDSR Straight plug (FH) * JBXFH2G16MSSDSR JBXFH2G16FSSDSR JBXEC2G16MCSDS JBXEC2G16FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G16MCSDSR JBXHH2G16FCSDSR Plug Straight plug (FH) * JBXFH2G16MCSDSR JBXFH2G16FCSDSR Receptacle Double nut, front or rear mount (EC) JBXEC2G16MPSDS JBXEC2G16FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 16 solder contacts, male insert = JBXFH2G16MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 16 solder contacts, male insert = JBXFH2G16MSNDSR. : Sealed in Unmated Condition 200 : First choice 16 contacts 6A/730V JBX Series | Connector per UL1977 JBX2-16 - IP68 (16 x Ø 0.7 mm) - See non sealed IP40 version page 198 Dimensions (For mated connector lengths see page 203) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 201 JBX Series | Connector JBX2-16 - IP40 & IP68 (16 x Ø 0.7 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 202 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP07 JBX2OUTLS07 JBXOUTDC07 16 contacts 6A/730V JBX Series | Connector per UL1977 JBX2-16 - IP40 & IP68 (16 x Ø 0.7 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - 90° PCB Machined 0.5 μm gold over 3 to 5 μm Ni Removable - For more information see pages 231 to 234 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 6A 730V UL94 V-0 Note: all dimensions are in mm 203 JBX Series | Connector JBX2-18 - IP40 (18 x Ø 0.7 mm) - See waterproof IP68 version page 206 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 209 Connector type Receptacle Plug Crimp contacts see page 209 Receptacle Plug Straight PCB contacts see page 209 Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G18MSSDS JBXEA2G18FSSDS Rear mount (EP) JBXEP2G18MSSDS JBXEP2G18FSSDS Front mount (ER) JBXER2G18MSSDSR JBXER2G18FSSDSR In line cable (PC) * JBXPC2G18MSSDSR JBXPC2G18FSSDSR Straight plug (FD) * JBXFD2G18MSSDSR JBXFD2G18FSSDSR Double nut (EA) JBXEA2G18MCSDS JBXEA2G18FCSDS Rear mount (EP) JBXEP2G18MCSDS JBXEP2G18FCSDS Front mount (ER) JBXER2G18MCSDSR JBXER2G18FCSDSR In line cable (PC) * JBXPC2G18MCSDSR JBXPC2G18FCSDSR Rear mount cable (SA) * JBXSA2G18MCSDS JBXSA2G18FCSDS Right angle plug (FC) * JBXFC2G18MCSDSR JBXFC2G18FCSDSR Straight plug (FD) * JBXFD2G18MCSDSR JBXFD2G18FCSDSR Double nut (EA) JBXEA2G18MPSDS JBXEA2G18FPSDS Rear mount (EP) JBXEP2G18MPSDS JBXEP2G18FPSDS Front mount (ER) JBXER2G18MPSDSR JBXER2G18FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 18 solder contacts, male insert = JBXFD2G18MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 18 solder contacts, male insert = JBXFD2G18MSNDSR. 204 : First choice 18 contacts 5.5A/660V JBX Series | Connector per UL1977 JBX2-18 - IP40 (18 x Ø 0.7 mm) - See waterproof IP68 version page 206 Dimensions (For mated connector lengths see page 209) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 205 JBX Series | Connector JBX2-18 - IP68 (18 x Ø 0.7 mm) - See non sealed IP40 version page 204 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 209 Receptacle Plug Crimp contacts see page 209 Straight PCB contacts see page 209 Receptacle Description Part number (1) Male insert Female insert JBXEC2G18MSSDS JBXEC2G18FSSDS Front mount extended (HH) JBXHH2G18MSSDSR JBXHH2G18FSSDSR Straight plug (FH) * JBXFH2G18MSSDSR JBXFH2G18FSSDSR JBXEC2G18MCSDS JBXEC2G18FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G18MCSDSR JBXHH2G18FCSDSR Plug Straight plug (FH) * JBXFH2G18MCSDSR JBXFH2G18FCSDSR Receptacle Double nut, front or rear mount (EC) JBXEC2G18MPSDS JBXEC2G18FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 18 solder contacts, male insert = JBXFH2G18MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 18 solder contacts, male insert = JBXFH2G18MSNDSR. : Sealed in Unmated Condition 206 18 contacts 5.5A/660V JBX Series | Connector per UL1977 JBX2-18 - IP68 (18 x Ø 0.7 mm) - See non sealed IP40 version page 204 Dimensions (For mated connector lengths see page 209) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 207 JBX Series | Connector JBX2-18 - IP40 & IP68 (18 x Ø 0.7 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 208 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP07 JBX2OUTLS07 JBXOUTDC07 18 contacts 5.5A/660V JBX Series | Connector per UL1977 JBX2-18 - IP40 & IP68 (18 x Ø 0.7 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 5.5A 660V UL94 V-0 Note: all dimensions are in mm 209 JBX Series | Connector JBX3-18 - IP40 (18 x Ø 0.9 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G18MSSDS JBXEA3G18FSSDS Solder contacts see page 213 Receptacle Front mount (ER) JBXER3G18MSSDSR JBXER3G18FSSDSR Front mount cable (SR) * JBXSR3G18MSSDSR JBXSR3G18FSSDSR Straight plug (FD) * Plug Crimp contacts see page 213 Straight PCB contacts see page 213 Receptacle Plug Receptacle Male insert Female insert JBXFD3G18MSSDSR JBXFD3G18FSSDSR Double nut (EA) JBXEA3G18MCSDS JBXEA3G18FCSDS Front mount (ER) JBXER3G18MCSDSR JBXER3G18FCSDSR Right angle plug (FC) * JBXFC3G18MCSDSR JBXFC3G18FCSDSR Straight plug (FD) * JBXFD3G18MCSDSR JBXFD3G18FCSDSR Double nut (EA) - JBXEA3G18FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 18 solder contacts, male insert = JBXFD3G18MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 18 solder contacts, male insert = JBXFD3G18MSNDSR. 210 : First choice 18 contacts 7A/660V JBX Series | Connector per UL1977 JBX3-18 - IP40 (18 x Ø 0.9 mm) Dimensions (For mated connector lengths see page 213) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 211 JBX Series | Connector JBX3-18 - IP40 (18 x Ø 0.9 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 212 Part number Male Female Part number MIL-22520/7-01 JBX3OUTLP09 JBX3OUTLS09 JBXOUTDC09 18 contacts 7A/660V JBX Series | Connector per UL1977 JBX3-18 - IP40 (18 x Ø 0.9 mm) Contacts Ø 0.9 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Removable 24 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 20 - 22 - 24 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER Connector 50.8 with SR FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 7A 660V UL94 V-0 Note: all dimensions are in mm 213 JBX Series | Connector JBX2-19 - IP40 (19 x Ø 0.7 mm) - See waterproof IP68 version page 216 PC FD FC SA ER EP EA Layout WITH Connector Part Number Contact type Solder contacts see page 219 Connector type Receptacle Plug Crimp contacts see page 219 Receptacle Plug Straight PCB contacts see page 219 Receptacle Description Part number (1) Male insert Female insert Double nut (EA) JBXEA2G19MSSDS JBXEA2G19FSSDS Rear mount (EP) JBXEP2G19MSSDS JBXEP2G19FSSDS Front mount (ER) JBXER2G19MSSDSR JBXER2G19FSSDSR In line cable (PC) * JBXPC2G19MSSDSR JBXPC2G19FSSDSR Straight plug (FD) * JBXFD2G19MSSDSR JBXFD2G19FSSDSR Double nut (EA) JBXEA2G19MCSDS JBXEA2G19FCSDS Rear mount (EP) JBXEP2G19MCSDS JBXEP2G19FCSDS Front mount (ER) JBXER2G19MCSDSR JBXER2G19FCSDSR In line cable (PC) * JBXPC2G19MCSDSR JBXPC2G19FCSDSR Rear mount cable (SA) * JBXSA2G19MCSDS JBXSA2G19FCSDS Right angle plug (FC) * JBXFC2G19MCSDSR JBXFC2G19FCSDSR Straight plug (FD) * JBXFD2G19MCSDSR JBXFD2G19FCSDSR Double nut (EA) JBXEA2G19MPSDS JBXEA2G19FPSDS Rear mount (EP) JBXEP2G19MPSDS JBXEP2G19FPSDS Front mount (ER) JBXER2G19MPSDSR JBXER2G19FPSDSR * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 19 solder contacts, male insert = JBXFD2G19MSSDSMR. The protective boot need to be ordered separately, see page accessories. (1): In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 19 solder contacts, male insert = JBXFD2G19MSNDSR. 214 : First choice 19 contacts 5A/660V JBX Series | Connector per UL1977 JBX2-19 - IP40 (19 x Ø 0.7 mm) - See waterproof IP68 version page 216 Dimensions (For mated connector lengths see page 219) Rear Mount (EP) 22.2 18.5 20.4 18.5 8 Ø 18 11.7 6.5 3.8 In Line Cable (PC)* Rear Mount Cable (SA)* Standard version Right Angle Plug (FC)* 52 Ø 15 Ø 20 Ø 16 Boot version Standard version 50 3.8 10 Straight Plug (FD)* Standard version 50 54.8 1.8 Connector 3.8 Front Mount (ER) Ø 20 Ø 20 Double Nut (EA) 56.8 6.5 54.8 Boot version Boot version Panel Cut Out 5.1 Ø1 36.5 Ø 15 42.5 30.5 13.6 Note: all dimensions are in mm 215 JBX Series | Connector JBX2-19 - IP68 (19 x Ø 0.7 mm) - See non sealed IP40 version page 214 FH HH EC Layout WITH Connector Part Number Contact type Connector type Solder contacts see page 219 Receptacle Plug Crimp contacts see page 219 Straight PCB contacts see page 219 Receptacle Description Part number (1) Male insert Female insert JBXEC2G19MSSDS JBXEC2G19FSSDS Front mount extended (HH) JBXHH2G19MSSDSR JBXHH2G19FSSDSR Straight plug (FH) * JBXFH2G19MSSDSR JBXFH2G19FSSDSR JBXEC2G19MCSDS JBXEC2G19FCSDS Double nut, front or rear mount (EC) Double nut, front or rear mount (EC) Front mount extended (HH) JBXHH2G19MCSDSR JBXHH2G19FCSDSR Plug Straight plug (FH) * JBXFH2G19MCSDSR JBXFH2G19FCSDSR Receptacle Double nut, front or rear mount (EC) JBXEC2G19MPSDS JBXEC2G19FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 2, 19 solder contacts, male insert = JBXFH2G19MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 2, 19 solder contacts, male insert = JBXFH2G19MSNDSR. : Sealed in Unmated Condition 216 19 contacts 5A/660V JBX Series | Connector per UL1977 JBX2-19 - IP68 (19 x Ø 0.7 mm) - See non sealed IP40 version page 214 Dimensions (For mated connector lengths see page 219) Double Nut (EC) Straight Plug (FH)* Front Mount Extended (HH) Standard version 24.5 52 Ø 16 Ø 20 Ø 20 20 56.8 6.5 10 5 10 Boot version Connector Panel Cut Out 5.1 Ø1 13.6 Note: all dimensions are in mm 217 JBX Series | Connector JBX2-19 - IP40 & IP68 (19 x Ø 0.7 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR2 JBXBF2 JAXRA2252 Insulating Washer Protective Boot Available only for PC - FC - FD - SA, FH, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX2RIA Blue JBX2MPA Blue JBX2RIB White JBX2MPB White JBX2RIG Grey JBX2MPG Grey JBX2RIJ Yellow JBX2MPJ Yellow JBX2RIM Brown JBX2MPM Brown JBX2RIN Black JBX2MPN Black JBX2RIR Red JBX2MPR Red JBX2RIV Green JBX2RIO Orange Color JBX2MPV The overall length is 25 mm JBX2MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 218 Part number Male Female Part number MIL-22520/7-01 JBX2OUTLP07 JBX2OUTLS07 JBXOUTDC07 19 contacts 5A/660V JBX Series | Connector per UL1977 JBX2-19 - IP40 & IP68 (19 x Ø 0.7 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 87.8 40 43 with ER with EP 88.3 42 with PC Connector 42 with SA FC Plug + Receptacle 34.5 with EA 80.3 32.6 35 with ER with EP with PC 80.3 34 with SA FH Plug + Receptacle 40.5 39 with EC with HH Electrical Characteristics UL 5A 660V UL94 V-0 Note: all dimensions are in mm 219 JBX Series | Connector JBX3-22 - IP40 (22 x Ø 0.7 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G22MSSDS JBXEA3G22FSSDS Solder contacts see page 223 Receptacle Front mount (ER) JBXER3G22MSSDSR JBXER3G22FSSDSR Front mount cable (SR) * JBXSR3G22MSSDSR JBXSR3G22FSSDSR Straight plug (FD) * Plug Crimp contacts see page 223 Straight PCB contacts see page 223 Receptacle Plug Receptacle Male insert Female insert JBXFD3G22MSSDSR JBXFD3G22FSSDSR Double nut (EA) JBXEA3G22MCSDS JBXEA3G22FCSDS Front mount (ER) JBXER3G22MCSDSR JBXER3G22FCSDSR Right angle plug (FC) * JBXFC3G22MCSDSR JBXFC3G22FCSDSR Straight plug (FD) * JBXFD3G22MCSDSR JBXFD3G22FCSDSR Double nut (EA) - JBXEA3G22FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 22 solder contacts, male insert = JBXFD3G22MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 22 solder contacts, male insert = JBXFD3G22MSNDSR. 220 : First choice 22 contacts 5.5A/560V JBX Series | Connector per UL1977 JBX3-22 - IP40 (22 x Ø 0.7 mm) Dimensions (For mated connector lengths see page 223) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 221 JBX Series | Connector JBX3-22 - IP40 (22 x Ø 0.7 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 222 Part number Male Female Part number MIL-22520/7-01 JBX3OUTLP07 JBX3OUTLS07 JBXOUTDC07 22 contacts 5.5A/560V JBX Series | Connector per UL1977 JBX3-22 - IP40 (22 x Ø 0.7 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER Connector 50.8 with SR FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 5.5A 560V UL94 V-0 Note: all dimensions are in mm 223 JBX Series | Connector JBX3-30 - IP40 (30 x Ø 0.7 mm) SR FD ER EA FC Layout WITH Connector Part Number Part number (1) Contact type Connector type Description Double nut (EA) JBXEA3G30MSSDS JBXEA3G30FSSDS Solder contacts see page 227 Receptacle Front mount (ER) JBXER3G30MSSDSR JBXER3G30FSSDSR Front mount cable (SR) * JBXSR3G30MSSDSR JBXSR3G30FSSDSR Straight plug (FD) * Plug Crimp contacts see page 227 Straight PCB contacts see page 227 Receptacle Plug Receptacle Male insert Female insert JBXFD3G30MSSDSR JBXFD3G30FSSDSR Double nut (EA) JBXEA3G30MCSDS JBXEA3G30FCSDS Front mount (ER) JBXER3G30MCSDSR JBXER3G30FCSDSR Right angle plug (FC) * JBXFC3G30MCSDSR JBXFC3G30FCSDSR Straight plug (FD) * JBXFD3G30MCSDSR JBXFD3G30FCSDSR Double nut (EA) - JBXEA3G30FPSDS * In order to get the back nut for protective boot please add «M» after the last «S». Example: JBX Straight Plug, size 3, 30 solder contacts, male insert = JBXFD3G30MSSDSMR. The protective boot need to be ordered separately, see page accessories. 1: In order to get a black Chrome over Nickel please replace «S» before the «D» by one «N». Example: JBX Straight Plug, size 3, 30 solder contacts, male insert = JBXFD3G30MSNDSR. 224 : First choice 30 contacts 3.5A/400V JBX Series | Connector per UL1977 JBX3-30 - IP40 (30 x Ø 0.7 mm) Dimensions (For mated connector lengths see page 227) Double Nut (EA) Front Mount (ER) Front Mount Cable Receptacle (SR)* Standard version 22.5 4.5 2 9.5 59 Ø 22 Ø 24 Ø 22 27.2 2 12 12 64 Boot version Right Angle Plug (FC)* Panel Cut Out 50.5 35.5 Standard version 8.1 Ø1 45 Ø 16 Ø 18 61 Connector Straight Plug (FD)* 67 16.6 Boot version Note: all dimensions are in mm 225 JBX Series | Connector JBX3-30 - IP40 (30 x Ø 0.7 mm) Accessories Receptacle Dust Cap Plug Dust Cap Grounding Washer Part number Part number Part number JBXBR3 JBXBF3 JAXRA3252 Insulating Washer Protective Boot Available only for FC - FD - SR, with back nut protective boot Note : Insulating washers are not compatible with the IP68 versions Part number Color Part number JBX3RIA Blue JBX3MPA Blue JBX3RIB White JBX3MPB White JBX3RIG Grey JBX3MPG Grey JBX3RIJ Yellow JBX3MPJ Yellow JBX3RIM Brown JBX3MPM Brown JBX3RIN Black JBX3MPN Black JBX3RIR Red JBX3MPR Red JBX3RIV Green JBX3RIO Orange Color JBX3MPV The overall length is 28.5 mm JBX3MPO longer with the protective boot. Note: The protective boot is not a sealing element. Green Orange Tooling Crimp Tooling Locator Extraction Tool Part number 226 Part number Male Female Part number MIL-22520/7-01 JBX3OUTLP07 JBX3OUTLS07 JBXOUTDC07 30 contacts 3.5A/400V JBX Series | Connector per UL1977 JBX3-30 - IP40 (30 x Ø 0.7 mm) Contacts Ø 0.7 mm Contact type Plating Contact locking type AWG Solder Machined 0.5 μm gold over 3 to 5 μm Ni Fixed 22 Crimp Machined 0.5 μm gold over 3 to 5 μm Ni Removable 22 - 24 - 26 Straight PCB Machined 0.5 μm gold over 3 to 5 μm Ni Fixed - For more information see pages 231 to 233 Mated Connector Length FD Plug + Receptacle with EA 48 105 48 with ER Connector 50.8 with SR FC Plug + Receptacle 40.8 38 with EA with ER 94.8 38 with SR Electrical Characteristics UL 3.5A 400V UL94 V-0 Note: all dimensions are in mm 227 JBX SERIES © 2015 SOURIAU - SOURIAU is a registered trademark JBX Series Contacts Description ................................................................................................................ 230 Packaging .................................................................................................................. 230 Solder Contacts ......................................................................................................... 231 Crimp Contacts ......................................................................................................... 232 Straight PCB Contacts ............................................................................................... 233 90° PCB Contacts ...................................................................................................... 234 Tooling ....................................................................................................................... 235 229 JBX Series | Contacts Contacts Description The JBX series is delivered with contacts and offers the unique feature to use the same style contact in any layout with the same active part size (i.e. #25, #22, #20, #18 mm, #16 or #14). This provides our customers with an easy solution to buy only one type of contact to equip all their connectors even if housings/shell sizes are different. This provides the benefit of standardization and subsequent reduced inventory costs. In addition, it eliminates the need for added tooling and simplifies the assembly process. Souriau contacts are designed for simple snap-in installation and further eliminate the need for insertion tooling. In addition to the below “crimp” or "solder" style contact options, the JBX series can also be equipped with straight or 90° PCB contacts. • Solder • Crimp • Straight PCB Packaging for contacts #22 to #14 Due to the wide variety of applications, contact packaging is offered in bulk package. • 100 pieces loose package 230 • 90° PCB JBX Series | Contacts Solder Contacts ØC ØF L T C ØC Contact size ØC #25 Ø 0.5 mm #22 Ø 0.7 mm #20 Ø 0.9 mm #18 Ø 1.3 mm #16 Ø 1.6 mm #14 Ø 2.0 mm Shell size ØF ØF Wire size (Stranded) AWG (Maxi) mm² (Maxi) 00 0.40 30 0.05 0 0.50 28 0.09 1 0.50 28 0.09 0 0.80 22 0.34 1 0.80 22 0.34 2 0.80 22 0.34 3 0.80 22 0.34 0 0.80 22 0.34 1 0.80 22 0.34 2 0.80 22 0.34 3 0.80 22 0.34 1 1.10 20 0.50 2 1.10 20 0.50 3 1.10 20 0.50 2 1.50 18 1.00 3 1.50 18 1.00 2 1.90 16 1.50 3 1.90 16 1.50 Part number* Male Female JBX0CTMS09 JBX1CTMS09 JBX2CTMS09 JBX3CTMS09 JBX1CTMS13 JBX2CTMS13 JBX3CTMS13 JBX2CTMS16 JBX3CTMS16 JBX2CTMS20 JBX3CTMS20 JBX0CTFS09 JBX1CTFS09 JBX2CTFS09 JBX3CTFS09 JBX1CTFS13 JBX2CTFS13 JBX3CTFS13 JBX2CTFS16 JBX3CTFS16 JBX2CTFS20 JBX3CTFS20 Max current rating (A) Contact resistance (mΩ) 5 10 5 10 5 10 7 5 7 5 7 5 7 5 10 3.5 10 3.5 10 3.5 10 3.5 15 3 15 3 15 3 17 2.5 17 2.5 30 2.5 30 2.5 * Part numbers for removal contacts only Stripping for FD, SR, PC connectors Stripping for FC connector Shell size Contact size L C T L C 00 0.5 9 2 4 - - - 0.5 11 2 7 16 2 7 0.7 12 3 7 16 3 7 0.9 12 3 7 16 3 7 0.5 12 2 8 19 2 8 0.7 13 3 8 19 3 8 0.9 13 3 8 19 3 8 1.3 13 3.5 8 19 3.5 8 0 1 2 3 Contacts Wire Stripping Instructions T 0.7 16 3 9 25 3 9 0.9 16 3 9 25 3 9 1.3 16 3.5 9 25 3 9 1.6 18 4 9 25 4 9 2.0 18 4 9 25 4 9 0.7 20 3 10 30 3 10 0.9 20 3 10 30 3 10 1.3 20 3.5 10 30 3.5 10 1.6 22 4 10 30 4 10 2.0 22 4 10 30 4 10 Note: all dimensions are in mm 231 JBX Series | Contacts Crimp Contacts L C Wire size Part number* Contact size Shell type 0 #22 Ø 0.7 mm 1 2 22 - 24 - 26 0.129-0.326 3 22 - 24 - 26 0.129-0.326 0 20 - 22 - 24 0.205-0.518 1 20 - 22 - 24 0.205-0.518 2 20 - 22 - 24 0.205-0.518 3 20 - 22 - 24 0.205-0.518 1 18 - 20 - 22 0.326-0.823 2 18 - 20 - 22 0.326-0.823 3 18 - 20 - 22 0.326-0.823 #20 Ø 0.9 mm #18 Ø 1.3 mm #16 Ø 1.6 mm #14 Ø 2.0 mm AWG T ØI mm² Male Female 22 - 24 - 26 0.129-0.326 22 - 24 - 26 0.129-0.326 JBX0CTMC07 JBX1CTMC07 JBX2CTMC07 JBX3CTMC07 JBX0CTMC09 JBX1CTMC09 JBX2CTMC09 JBX3CTMC09 JBX1CTMC13 JBX2CTMC13 JBX3CTMC13 JBX2CTMC16 JBX3CTMC16 JBX2CTMC20 JBX3CTMC20 JBX0CTFC07 JBX1CTFC07 JBX2CTFC07 JBX3CTFC07 JBX0CTFC09 JBX1CTFC09 JBX2CTFC09 JBX3CTFC09 JBX1CTFC13 JBX2CTFC13 JBX3CTFC13 JBX2CTFC16 JBX3CTFC16 JBX2CTFC20 JBX3CTFC20 2 14 - 16 - 18 0.823-2.081 3 14 - 16 - 18 0.823-2.081 2 12 - 14 - 16 1.309-3.309 3 12 - 14 - 16 1.309-3.309 Max current rating (A) Contact resistance (mΩ) 7 5 7 5 7 5 7 5 10 3.5 10 3.5 10 3.5 10 3.5 15 3 15 3 15 3 17 2.5 17 2.5 30 2.5 30 2.5 * Part numbers for removal contacts only Wire Stripping Instructions Shell size Contact size 0.7 0 0.9 0.7 1 0.9 1.3 0.7 0.9 2 1.3 1.6 2.0 0.7 0.9 3 1.3 1.6 2.0 Note: all dimensions are in mm 232 ØI (diameter over insulation) Stripping for FD, SR, PC connectors ≤ 1.35 4 > 1.35 ≤ 1.60 > 1.60 ≤ 1.35 > 1.35 ≤ 1.60 > 1.60 ≤ 2.10 > 2.10 ≤ 1.35 > 1.35 ≤ 1.60 > 1.60 ≤ 2.10 > 2.10 ≤ 2.60 > 2.60 ≤ 3.20 > 3.20 ≤ 1.35 > 1.35 ≤ 1.60 > 1.60 ≤ 2.10 > 2.10 ≤ 2.60 > 2.60 ≤ 3.20 > 3.20 L 15 15 16 16 16 19 19 19 21 21 25 25 25 27 27 C 5.5 4 5.5 4 5.5 4 5.5 4 5.5 4 5.5 4 5.5 4 5.5 5.5 7 5.5 7 4 7 4 7 4 7 5..5 8.5 5..5 8.5 T 7 7 8 Stripping for FC connector L 19 19 22 8 22 8 22 9 28 9 28 9 28 9 28 9 28 10 35 10 10 35 35 10 35 10 35 C 4 5.5 4 5.5 4 5.5 4 5.5 4 5.5 4 5.5 4 5.5 4 5.5 5.5 7 5.5 7 4 7 4 7 4 7 5.5 8.5 5.5 8.5 T 7 7 8 8 8 9 9 9 9 9 10 10 10 10 10 JBX Series | Contacts Straight PCB Contacts A C B D Shell size Contact size #25 Ø 0.5 mm 0 1 Female contact Yes Yes 2 Contact resistance (mΩ) A B C D 10 21.6 5.4 21.6 5.4 07 Yes Yes 2.5 10 21.6 5.4 21.6 5.5 08 Yes Yes 2.5 10 21.6 5.4 21.6 5.4 05 Yes Yes 6.5 5 24.3 5.9 21.8 3.4 04 Yes Yes 7 5 24.3 5.9 21.8 3.4 #20 Ø 0.9 mm 03 No Yes 10 3.5 - - 21.8 3.4 02 No Yes 10 3.5 - - 21.8 3.4 #25 Ø 0.5 mm 12 No Yes 5 10 - - 24.0 5.1 10 No Yes 5 10 - - 24.0 5.1 #22 Ø 0.7 mm #17 Ø 1.3 mm #22 Ø 0.7 mm #20 Ø 0.9 mm #17 Ø 1.3 mm #22 Ø 0.7 mm 3 06 Male contact Max current rating (A) Contact range #22 Ø 0.7 mm #20 Ø 0.9 mm 2 Layout Female Insulator #20 Ø 0.9 mm #17 Ø 1.3 mm 08 Yes Yes 7 5 26.3 5.9 24.3 3.9 07 Yes Yes 7 5 26.3 5.9 24.3 3.9 06 Yes Yes 7 5 26.3 5.9 24.3 3.9 05 No Yes 10 3.5 - - 24.3 3.9 04 No Yes 10 3.5 - - 24.3 3.9 03 No Yes 15 3 - - 24.3 3.9 02 No Yes 15 3 - - 24.3 3.9 19 Yes Yes 7 5 25.7 3.3 28.3 5.9 18 Yes Yes 7 5 25.7 3.3 28.3 5.9 16 Yes Yes 7 5 25.7 3.3 28.3 5.9 12 Yes Yes 7 5 25.7 3.3 28.3 5.9 10 No Yes 10 3.5 - - 28.3 5.9 08 No Yes 10 3.5 - - 28.3 5.9 07 Yes Yes 15 3 30.5 8.1 28.3 5.9 06 Yes Yes 15 3 30.5 8.1 28.3 5.9 05 Yes Yes 15 3 30.5 8.1 28.3 5.9 04 Yes Yes 15 3 30.5 8.1 28.3 5.9 30 No Yes 7 5 - - 33.2 5.8 22 No Yes 7 5 - - 33.2 5.8 18 No Yes 10 3.5 - - 33.2 5.8 14 No Yes 10 3.5 - - 33.2 5.8 10 No Yes 15 3.5 - - 33.2 5.8 Note: all dimensions are in mm 233 Contacts Male Insulator JBX Series | Contacts 90° PCB Contacts B A Female Insulator Shell size 0 Contact size Layout #22 Ø 0.7 mm 05 #20 Ø 0.9 mm #22 Ø 0.7 mm 1 #20 Ø 0.9 mm #17 Ø 1.3 mm 2 Contact resistance (mΩ) A B Yes 7 5 25.2 31.9 04 Yes 7 5 22.7 31.7 03 Yes 10 3.5 22.7 31.4 02 Yes 10 3.5 22.7 31.9 08 Yes 7 5 27.6 32.5 07 Yes 7 5 27.6 32.4 06 Yes 7 5 27.6 32.4 05 Yes 10 3.5 27.6 32.1 04 Yes 10 3.5 25.0 31.8 03 Yes 15 3 25.0 31.5 #22 Ø 0.7 mm 16 Yes 7 5 34.7 34 12 Yes 7 5 32.1 33.7 #20 Ø 0.9 mm 10 Yes 10 3.5 32.1 33.6 08 Yes 10 3.5 29.6 33.8 Note: all dimensions are in mm 234 Female contact Max current rating (A) Contact range JBX Series | Contacts Tooling Crimp Tool Table Crimp contacts Contact size Shell type 0 #22 Ø 0.7 mm 1 2 3 0 #20 Ø 0.9 mm 1 2 3 #18 Ø 1.3 mm 1 2 3 2 #16 Ø 1.6 mm 3 #14 Ø 2.0 mm 3 2 Part number* Male Female JBX0CTMC07 JBX1CTMC07 JBX2CTMC07 JBX3CTMC07 JBX0CTMC09 JBX1CTMC09 JBX2CTMC09 JBX3CTMC09 JBX1CTMC13 JBX2CTMC13 JBX3CTMC13 JBX2CTMC16 JBX3CTMC16 JBX2CTMC20 JBX3CTMC20 JBX0CTFC07 JBX1CTFC07 JBX2CTFC07 JBX3CTFC07 JBX0CTFC09 JBX1CTFC09 JBX2CTFC09 JBX3CTFC09 JBX1CTFC13 JBX2CTFC13 JBX3CTFC13 JBX2CTFC16 JBX3CTFC16 JBX2CTFC20 JBX3CTFC20 Crimp tooling MIL‐22520/7‐01 MIL‐22520/7‐01 MIL‐22520/7‐01 MIL‐22520/1‐01 MIL‐22520/1‐01 Locator Male Female JBX0OUTLP07 JBX0OUTLS07 JBX1OUTLP07 JBX1OUTLS07 JBX2OUTLP07 JBX2OUTLS07 JBX3OUTLP07 JBX3OUTLS07 JBX0OUTLP09 JBX0OUTLS09 JBX1OUTLP09 JBX1OUTLS09 JBX2OUTLP09 JBX2OUTLS09 JBX3OUTLP09 JBX3OUTLS09 JBX1OUTLP13 JBX1OUTLS13 JBX2OUTLP13 JBX2OUTLS13 JBX3OUTLP13 JBX3OUTLS13 JBX2OUTLT16 JBX3OUTLT16 JBX2OUTLT20 JBX3OUTLT20 Extraction tools JBXOUTDC07 JBXOUTDC09 JBXOUTDC13 JBXOUTDC16 JBXOUTDC20 * Part numbers for removal contacts only Contact extraction instruction Contacts • Place the tool into the cavity from front face of the insulator • Push on the handle • Remove the contact. 235 JBX Series | Contacts Notes 236 JBX Series | Contacts Contacts Notes 237 JBX SERIES © 2015 SOURIAU - SOURIAU is a registered trademark JBX Series Technical Information Receptacle Assembly Instructions ........................................................................... 240 Plug Assembly Instructions ...................................................................................... 245 Collets Selection According to Cable Diameters .................................................... 251 Rated Current & Working Voltage ........................................................................... 252 UL94 + UL1977 ........................................................................................................ 253 What is NEMA Rating ? ........................................................................................... 257 Ethernet for the Layman .......................................................................................... 258 239 JBX Series | Technical Information JBX Receptacle Assembly Instructions JBXEA or JBXEC Assembly (Mounting Suggestion) • Solder or crimp contacts (see pages 231 & 232) • Slide the lock washer and the hex nut onto the cable • Apply thread lock to panel nut prior to assembly. • Place the receptacle in the panel cut-out • Insert contacts manually in the cavities for removable contacts versions • Insert the lock washer and tighten the panel nut hand tight • Screw the hex nut to the bulkhead • Use two wrenches to finalize the screwing: - Maintain the panel nut wrench fixed - Screw the hex nut • Recommended tightening torques are shown in the table below. Front mounting with fitted contacts 1 Rear mounting with separate contacts 1 Hex nut Hex nut Panel nut Lock washer Crimp contacts Solder contacts Lock washer Panel nut 2 2 Hex nut Crimp contacts Panel nut Panel nut Solder contacts Lock washer 3 3 Hex nut wrench Panel nut wrench Hex nut wrench Panel nut wrench x E ma x E ma Shell size 0 1 2 3 Wrench size 11 14 17 21 Tightening torque (Nm) 0.7 1.3 1.7 2 E - Panel max. thicknesses (mm) 6.7 8.3 8 9.5 Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 240 JBX Series | Technical Information JBXED Assembly (Mounting Suggestion) • • • • • Solder or crimp contacts (see pages 231 & 232) Slide the lock washer and the hex nut onto the cable Apply thread lock to the receptacle prior to assembly. Place the receptacle in the panel cut-out Insert contacts manually in the cavities for removable contacts versions • Insert the lock washer and tighten the panel nut hand tight • Screw the hex nut to the bulkhead with a wrench • Recommended tightening torques are shown in the table below. Shell size Tightening torque (Nm) max. Wrench size E Panel max. thicknesses (mm) 0 0.7 11 3.0 1 1.3 14 4.5 2 1.7 17 6.3 1 Lock washer Red band Hex nut ax Em 2 JBXEP Assembly (Mounting Suggestion) Solder or crimp contacts (see pages 231 & 232) Place the receptacle in the panel cut-out Insert the washer and tighten the panel nut hand tight Insert contacts manually in the cavities for removable contacts versions • Use two wrenches to finalize the screwing: - Maintain the receptacle with nut wrench fixed - Screw the panel nut • Recommended tightening torques are shown in the table below. 1 Shell Technical Information • • • • Panel nut ax Em Lock washer Wrench size Tightening torque (Nm) max. A B E Panel max. thicknesses (mm) 0 0.7 10 11 4.5 1 1.3 13 14 6.0 2 1.7 17 17 6.5 Shell size 2 B Shell wrench A Panel nut wrench Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 241 JBX Series | Technical Information JBX Receptacle Assembly Instructions (Continued) JBXER Assembly (Mounting Suggestion) • • • • Solder or crimp contacts (see pages 231 & 232) Slide the lock washer and the hex nut onto the cable Place the receptacle in the panel cut-out Insert contacts manually in the cavities for removable contacts versions • Screw the hex nut to the bulkhead with a wrench • Recommended tightening torques are shown in the table below. 1 Lock washer Red band Hex nut ax Em Shell size Tightening torque (Nm) max. Wrench size E Panel max. thicknesses (mm) 00 0 0.7 7 6.0 0.7 11 8.0 1 1.3 14 10.0 2 1.7 17 10.0 3 2 21 12.0 2 JBXEZ Assembly (Mounting Suggestion) • Please refer to the customer drawing for the PCB drilling holes. 1 Computer cards (PCB) Red point Mounting pin 2 Mounting pin Computer cards (PCB) Note: all dimensions are in mm 242 Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B JBX Series | Technical Information JBXHC Assembly (Mounting Suggestion) • • • • • Solder or crimp contacts (see pages 231 & 232) Place the receptacle in the panel cut-out Apply thread lock to panel nut prior to assembly. Tighten the panel nut hand tight Insert contacts manually in the cavities for removable contacts versions • Screw the hex nut if needed • Screw the panel nut with a wrench • Recommended tightening torques are shown in the table below. 1 O-ring Hex nut Panel nut E max Shell size 0 Tightening torque (Nm) max. Wrench size A B A B 1.7 0.7 16 11 E Panel max. thicknesses (mm) 2 B Hex nut wrench 4.0 A Panel nut wrench JBXHD Assembly (Mounting Suggestion) Solder or crimp contacts (see pages 231 & 232) Slide the lock washer and the hex nut onto the cable Place the receptacle in the panel cut-out Insert contacts manually in the cavities for removable contacts versions • Screw the hex nut to the bulkhead with a wrench • Recommended tightening torques are shown in the table below. 1 O-ring Hex nut Technical Information • • • • Lock washer Shell size Tightening torque (Nm) max. Wrench size E Panel max. thicknesses (mm) 0 1.3 11 7.0 E max 2 Hex nut wrench Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B Note: all dimensions are in mm 243 JBX Series | Technical Information JBX Receptacle Assembly Instructions (Continued) JBXHH Assembly (Mounting Suggestion) • • • • • • Solder or crimp contacts (see pages 231 & 232) Slide the lock washer and the hex nut onto the cable Place the receptacle in the panel cut-out Insert contacts manually in the cavities for removable contacts versions Screw the hex nut to the bulkhead with a wrench Recommended tightening torques are shown in the table below. Shell size Tightening torque (Nm) max. Wrench size 0 0.7 11 8.0 2 1.7 17 10.0 1 Lock washer O-ring Hex nut E Panel max. thicknesses (mm) E max 2 Hex nut wrench Note: all dimensions are in mm 244 Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B JBX Series | Technical Information JBX Plug Assembly Instructions (Continued) JBXPC Assembly (Mounting Suggestion) Protective boot 1 Back nut boot Half bushing with window Collet Red dot Shell Insulator Back nut standard Half bushing without window Shell size Tightening torque (Nm) max. B C 2 Window 3 3A Wrench size B Braid covering the collet C 0 0.8 0.8 9 8 1 1.0 1.0 11 10 2 1.5 1.5 14 13 Technical Information • Slide the Protective boot/Back nut boot or the Back nut standard onto the cable • Select the proper Collet according to the cable diameter specification (see page 251) and slide it onto the cable • Strip external cable jacket and wire (see dimension pages 231 & 232) • Solder or crimp contacts (see pages 231 & 232) • Place the two half bushes on the insert making sure that the insert keyway appears through the window of the half bushing (fig. 2) • Place the collet and the half bushes while maintaining the screen. Half bush keys must be seated in the collet keyway (fig. 3) • If the cable has shielding, fold back the braid so that it is covering the outside diameter of the collet. Braid must be between the collet and half bushes (fig 3A) • Place all the sub-assembly in the connector housing making sure to keep sub-assembly aligned (fig. 3). Respect the red dot and window alignment • Install the back nut or the back nut boot and screw it on to the threads • Use two wrenches to finalize the screwing • Recommended tightening torques are shown in the table below. 4 Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B B Shell wrench C Back nut wrench Note: all dimensions are in mm 245 JBX Series | Technical Information JBX Plug Assembly Instructions (Continued) JBXSA Assembly (Mounting Suggestion) Protective boot 1 Back nut boot Lock washer Half bushing with window Hexagonal nut Collet Insulator Back nut standard Panel nut Shell Half bushing without window • Slide the Protective boot/Back nut boot or the Back nut standard onto the cable • Select the proper Collet according to the cable diameter specification (see page 251) and slide it onto the cable • Strip external cable jacket and wire (see dimension pages 231 & 232) • Solder or crimp contacts (see pages 231 & 232) • Place the two half bushes on the insert making sure that the insert keyway appears through the window of the half bushing (fig. 2) • Place the collet and the half bushes while maintaining the screen. Half bush keys must be seated in the collet keyway (fig. 3) • If the cable has shielding, fold back the braid so that it is covering the outside diameter of the collet. Braid must be between the collet and half bushes (fig 3A) • Place all the sub-assembly in the connector housing making sure to keep sub-assembly aligned (fig. 3). • Install the back nut or the back nut boot and screw it on to the threads • Tighten the panel nut hand tight (fig. 4) • Use two wrenches to finalize the screwing (fig. 5 & 6) • Recommended tightening torques are shown in the table below. 2 3 Window 3A Braid covering the collet Lock washer Hex nut 4 Back nut Panel nut Shell size 2 Tightening torque (Nm) max. Wrench size B C B C 1.7 1.5 17 13 x E ma E Panel max. thicknesses (mm) 6.5 5 B Hex nut wrench C Back nut wrench 6 B Hex nut wrench Note: all dimensions are in mm 246 Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B JBX Series | Technical Information JBXSR Assembly (Mounting Suggestion) Protective boot 1 Back nut boot Half bushing with window Hexagonal nut Lock washer Collet Insulator Back nut standard Shell Half bushing without window • Slide the Protective boot/Back nut boot or the Back nut standard onto the cable • Select the proper Collet according to the cable diameter specification (see page 251) and slide it onto the cable • Strip external cable jacket and wire (see dimension pages 231 & 232) • Solder or crimp contacts (see pages 231 & 232) • Place the two half bushes on the insert making sure that the insert keyway appears through the window of the half bushing (fig. 2) • Place the collet and the half bushes while maintaining the screen. Half bush keys must be seated in the collet keyway (fig. 3) • If the cable has shielding, fold back the braid so that it is covering the outside diameter of the collet. Braid must be between the collet and half bushes (fig 3) • Insert the receptacle in the panel cut out, respect the orientation (fig. 4) • Place all the sub-assembly in the connector housing making sure to keep sub-assembly aligned (fig. 4). Respect the red dot and window alignment. • Install the back nut or the back nut boot and screw it on to the threads • Screw the hex nut with a wrench (fig. 5) • Use two wrenches to finalize the screwing (fig. 6) • Recommended tightening torques are shown in the table below. Shell size Tightening torque (Nm) max. Wrench size C E Panel max. thicknesses (mm) B C B 0 0.7 0.8 11 8 8.0 1 1.3 1.0 14 10 10.0 2 1.7 1.5 17 13 10.0 3 2.0 2.0 21 15 12.0 2 3 Window 3A Braid covering the collet 4 Lock washer Hex nut Back nut Technical Information Sleeve x E ma 5 Panel wrench Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B B Hex nut wrench 6 C Back nut wrench B Hex nut wrench Note: all dimensions are in mm 247 JBX Series | Technical Information JBX Plug Assembly Instructions (Continued) JBXFC & JBXFM Assembly (Mounting Suggestion) • Slide the Protective boot/Back nut boot or the Back nut standard onto the cable • Select the proper Collet according to the cable diameter specification (see page 251) and slide it onto the cable (fig. 2) • Slide the Elbow backshell onto the cable (fig. 2) • If the cable has shielding, fold back the braid so that it is covering the outside diameter of the collet. Braid must be between the collet and half bushes (fig 2A) • Strip external cable jacket and wire (see dimension pages 231 & 232) • Solder or crimp contacts (see pages 231 & 232) • Place the cabling spacer onto the cables • Insert the contacts into the insulator. • Slide the Cabling spacer on the Insulator (fig. 3) • Slide the Retaining ring on the Insulator (fig. 3) • Position the wires at 90° then place the assembly (Elbow backshell + Cabling spacer + Insulator) inside the sleeve (fig. 3) • Ensure that the milled flat of the elbow outlet is facing to the rear of the plug housing (fig. 4) • Tighten the retaining nut with a wrench (fig. 5) • Install the back nut or the back nut boot and screw it on to the thread • Use two wrenches to finalize the screwing (fig. 6) • Recommended tightening torques are shown in the table below. Shell size Tightening torque (Nm) max. 1 Cabling spacer Retaining ring Insulator Sleeve Elbow backshell Retaining nut Collet Back nut boot Back nut standard Wrench size Protective boot A B C A B C 0 0.4 - 0.8 10 8 8 1 0.4 - 1.0 12 10 10 2 0.5 - 1.5 15 13 13 3 0.5 - 2.0 17 15 15 2 2A Braid covering the collet 3 Milled flat 4 Milled flat 5 A Retaining nut wrench 6 4 B Elbow wrench C Back nut wrench Note: all dimensions are in mm 248 Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B JBX Series | Technical Information JBXFD, JBXFG, JBXFN & JBXFH Assembly (Mounting Suggestion) Protective boot 1 Back nut boot Half bushing with window Collet Red dot Shell Insulator Back nut standard Half bushing without window • Slide the Protective boot/Back nut boot or the Back nut standard onto the cable • Select the proper Collet according to the cable diameter specification (see page 251) and slide it onto the cable • Strip external cable jacket and wire (see dimension pages 231 & 232) • Solder or crimp contacts (see pages 231 & 232) • Place the two half bushes on the insert making sure that the insert keyway appears through the window of the half bushing (fig. 2) • Place the collet and the half bushes while maintaining the screen. Half bush keys must be seated in the collet keyway (fig. 3) • If the cable has shielding, fold back the braid so that it is covering the outside diameter of the collet. Braid must be between the collet and half bushes (fig 3A) • Place all the sub-assembly in the connector housing making sure to keep sub-assembly aligned (fig. 3). Respect the red dot and window alignment • Install the back nut or the back nut boot and screw it • Use two wrenches to finalyze the screwing • Recommended tightening torques are shown in the table below. 2 Window 3 Collet Shell Shell size Tightening torque (Nm) max. Technical Information 3A Wrench size B C B C 00 - 0.7 6 6 0 - 0.8 9 8 1 - 1.0 11 10 2 - 1.5 14 13 3 - 2.0 16 15 Braid covering the collet 4 Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B B Shell wrench C Back nut wrench Note: all dimensions are in mm 249 JBX Series | Technical Information JBX Plug Assembly Instructions (Continued) JBXFF Assembly (Mounting Suggestion) 1 Back nut boot Half bushing with window Collet Red dot Insulator Protective boot Half bushing without window Shell • Slide the Protective boot/Back nut boot or the Back nut standard onto the cable • Select the proper Collet according to the cable diameter specification (see page 251) and slide it onto the cable • Strip external cable jacket and wire (see dimension pages 231 & 232) • Solder or crimp contacts (see pages 231 & 232) • Place the two half bushes on the insert making sure that the insert keyway appears through the window of the half bushing (fig. 2) • Place the collet and the half bushes while maintaining the screen. Half bush keys must be seated in the collet keyway (fig. 3) • If the cable has shielding, fold back the braid so that it is covering the outside diameter of the collet. Braid must be between the collet and half bushes (fig 3A) • Place all the sub-assembly in the connector housing making sure to keep sub-assembly aligned (fig. 3). Respect the red dot and window alignment • Install the back nut or the back nut boot and screw it • Use two wrenches to finalyze the screwing • Recommended tightening torques are shown in the table below. 2 Window 3 Collet Shell 3A Shell size 1 Shell wrench Back nut wrench Size Torque (Nm) Size Torque (Nm) 10 - 10 1.0 Braid covering the collet 4 Note: all dimensions are in mm 250 B Shell wrench C Back nut wrench Note : Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B JBX Series | Technical Information Collets Selection According to Cable Diameters Collet number 1 Cable diameter (mm) Shell size 00 Shell size 0 Shell size 1 Shell size 2 Shell size 3 1.1 to 1.9 1.5 to 2.5 2.0 to 2.5 3.5 to 4.7 4.9 to 6.0 2 2.0 to 2.8 2.6 to 3.5 2.6 to 3.5 4.8 to 5.7 6.1 to 7.2 3 2.9 to 3.5 3.6 to 4.5 3.6 to 4.5 5.8 to 6.7 7.3 to 8.4 - 4.6 to 5.5 4.6 to 5.5 6.8 to 7.7 8.5 to 9.6 - - 5.6 to 6.6 7.8 to 8.7 9.7 to 10.8 6 - - 6.7 to 7.5 8.8 to 9.7 10.9 to 12.0 Technical Information 4 5 Note: all dimensions are in mm 251 JBX Series | Technical Information Rated Current & Working Voltage Current Carrying Capacity The current carrying capacity of a connector is limited by the thermal properties of materials used in its construction. The amount of current that can be handled depends on the size of cable used, the ambient temperature and the heat that is generated inside the connector. Part 3 of the IEC 60512 standard determines through a derating curve, the maximum current permissible, which varies from one layout to another (Fig.1 & Fig.2). Wire size plays an important role in dissipating heat and avoid overheating (Fig.1 & Fig.3). Please note that the curve should be adjusted when dealing with potential hot spots, which can occur as a result of unequal loading of current across a number of contacts. As a general rule, it is best to avoid placing power handling contacts in the middle of the connector; try to locate them towards the edge where heat can be dissipated more effectively. Eventually you should find a level which represents the permissible operating range: 140 Fig.1: JBX2-001 (Power Derating curve - Signal Contact Fixed at 2A) Temperature (°C) 120 Max. temp. use Recommended use 100 80 Connector rating: • Power Contact : 26A at 30˚C T-Rise • Signal Contact : 2A 8 contacts 2A 700V 6 x Ø 1.3 2 x Ø 2.0 Signal Contact (cable awg 26) is powered at 2A Power Contact (cable awg 16): 0 to 35 A 60 40 20 0 0 5 10 15 20 25 30 35 40 45 Current for Power contact (A) Fig.2: JBX2-001(Power Derating curve - Signal Contact Fixed at 2A) 140 Max. temp. use Recommended use Temperature (°C) 120 Connector rating: • Power Contact: 17A at 30˚C T-Rise • Signal Contact: 2A 100 80 9 contacts 2A 700V 6 x Ø 0.7 3 x Ø 1.3 Signal Contact (cable awg 26) is powered at 2A, Power Contact (cable awg 20): 0 to 25 A 60 40 20 0 0 5 10 15 20 25 30 35 40 45 Current for Power contact (A) Fig.3: JBX2-001(Power Derating curve - Signal Contact Fixed at 2A) 140 Max. temp. use Recommended use Temperature (°C) 120 Connector rating: • Power Contact: 26A at 30˚C T-Rise • Signal Contact: 2A 100 80 10 contacts 2A 700V 8 x Ø 0.7 2 x Ø 1.6 Signal Contact (cable awg 26) is powered at 2A, Power Contact (cable awg 18): 0 to 40 A 60 40 20 0 0 5 10 15 20 25 30 35 40 45 Current for Power contact (A) The rated current is defined as uninterrupted continuous current that a connector can take when all contacts are energized simultaneously without exceeding the maximum limit of temperature. The earth contact is never loaded. 252 JBX Series | Technical Information Shielding Effectiveness/Corrosion Shielding Effectiveness EMC (Electro-Magnetic Compatibility) means a device (e.g. a connector) can tolerate interferences and continue to work properly. It's generally measured via the shielding effectiveness. This value is a ratio between the power radiated inside to the maximum power interferences outside. (dB)=10Log Pin Pout Pin: Power in Pout: Power out 48 Hrs 96 Hrs 500 Hrs 253 Technical Information 0 Outdoor application with corrosive atmospheres (Salt Spray and 4 Corrosive Gases) Over the years, many different test methods have been developed but never really captured the exact equivalence between testing scenarios and real electronic device exposure to corrosive environments. Souriau has been developing, manufacturing and testing connector solutions for more than 90 years and has developed a unique corrosion test based on Salt Spray exposure combined with four additional corrosive gases. Typical industrial applications may involve exposure to corrosive atmospheres equivalent to 48 or 96 hours. Souriau’s JBX product series has been validated to withstand corrosive agent exposure at these timeframes. In addition, we can offer different solutions and plating options to withstand longer corrosion exposure times and test up to 500 hours. Indoor application Tempory outdoor exposure Control of corrosion impact on electronic devices is an important expertise. Metal connectors suitable for outdoor and indoor use should be able to withstand climate ingress, exposure to salt spray and corrosive gases while still maintaining mechanical and electrical functionality. Outdoor application Corrosion Resistance JBX Series | Technical Information UL94 + UL1977 Underwriter Laboratories There are two main standards for industrial connectors: UL94 & UL1977 UL94 This standard is dedicated to plastics flammability. It characterizes how the material burns in various orientation and thicknesses. The JBX series has been rated at V-0 & HB. Procedure: A specimen is supported in a vertical or horizontal position and a flame is applied to the bottom of the specimen. The flame is applied for ten seconds and then removed until flaming stops, at which time the flame is reapplied for another ten seconds and then removed. Two sets of five specimens are tested. V-0 Vertical burning: • Specimens must not burn with flaming combustion for more than 10 seconds after each test flame application • Total flaming combustion time must not exceed 50 seconds for each set of 5 specimens • Specimens must not burn with flaming or glowing combustion up to the specimen holding clamp • Specimens must not drip flaming particles that ignite the cotton • No specimen can have glowing combustion remain for longer than 30 seconds after removal of the test flame. Material 13±0.5mm 125±1mm 45° 300±1mm ~ ~ Cotton 100±1mm HB Horizontal burning: • A material classified HB shall not have a burning rate exceeding 40 mm per minute over a 75 mm span for specimens having a thickness of 3.0 to 13 mm • A material classified HB shall not have a burning rate exceeding 75 mm per minute over a 75 mm span for specimens having a thickness less than 3.0 mm • A material classified HB shall cease to burn before the 100 mm reference mark. 254 25±1mm Material 13±0.5mm 45° Wire gauze 45° 10±1mm Wire gauze JBX Series | Technical Information Underwriter Laboratories UL1977 There are several standards which deal with plug and receptacle. Each of them is only for a small area of applications. It could be telecommunication, etc. The UL 1977 covers single and multipole connectors intended for factory assembly. Requirements apply to devices taking into account intensity and voltage. The categories are as follows: 30 V (42 V peak) 0 600 V 0 Type 0 Type 1A 8.3 A Type 2 31 A Tybe 1B Type 3 200 A Type 4 1000 A According to above table, the level of performance that has to be reached could be different. Most of them are explained in the following page. Insulating materials: • Minimum ratings for polymeric materials Type Flame rating Relative thermal index (RTI) Electrical/mechanical w/o impact */** 0 - 50/50 1A HB 50/50 1B HB 50/50 2 HB 50/50 3 HB 50/50 4 HB 50/50 * The RTI of the material shall not be lower than the temperature measured during the Temperature Test. ** For a thickness less than that for which a value has been established, the RTI of the minimum thickness with an established value shall be used. Assembly: Connector has to be keyed to prevent any mismating that can damage the machine or hurt the user. In the same way, plugs and sockets have to be equipped to protect persons against contact with live parts. Finally the identified grounding contact shall be located so that the corresponding electrical continuity has to be completed before any other contact. 255 Technical Information Material uses for electrical insulation, as a minimum, have to comply with the characteristics shown below: JBX Series | Technical Information UL94 + UL1977 (Continued) Underwriter Laboratories UL1977 Spacing: For a 250V max connector, distance through air or over material shall be 1.2mm whereas from 250V to 600V connector the spacing is 3.2mm minimum. These distances have to be taken between uninsulated live parts as shown in the matrix below: • Applicability of spacing requirements Type Uninsulated live part - uninsulated live part of opposite polarity Uninsulated live part - uninsulated grounded metal part Uninsulated live part - exposed dead metal part 0 No No No 1A Yes Yes Yes 1B Yes Yes No 2 Yes Yes Yes 3 Yes Yes Yes 4 Yes Yes Yes An alternative way to determine voltage rating is with the Dielectric-Withstand test. If during one minute there is no arc-over or breakdown the rated voltage is given as shown below: a) 500 volts for a type 1B device b) 1000 volts plus twice rated voltage for types 1A, 2, 3 and 4 devices. Marking: A device shall be legibly marked with the manufacturer's trade name, trade mark, or other descriptive marking by which the organization responsible for the product may be identified. (Exception: If the device is too small, or where the legibility would be difficult to attain, the manufacturer’s name, trademark, or other descriptive marking may appear on the smallest unit container or carton) The following shall be marked on the device or on the smallest unit container or carton or on a stuffer sheet in the smallest unit container or carton: a) The catalog number or an equivalent designation b) The electrical rating in both volts and amperes, if assigned c) Whether ac or dc, if restricted d) Flammability class, if identified Example - Marking for the arrangement 10-3: 256 10A 500V UL94 V-0 JBX Series | Technical Information What is NEMA Rating ? • NEMA ratings vs IP ratings Whereas IP ratings only consider protection against ingress of foreign bodies (first digit) and ingress of water (second digit), NEMA ratings consider these but also verify protection from external ice, corrosive materials, oil immersion, etc. The correlation between NEMA & IP being limited only to dust and water, we can state that a NEMA type is equivalent to an IP rating but it is not possible to say the contrary. Below a list of some NEMA standards: Enclosure rating IP20 Type 1 • IP22 IP55 IP65 IP66 IP67 • Type 3 Type 3R IP64 • • Type 3S Type 4 • Type 4X • • Type 6 • Type 12 • Type 13 • indicates compliance 6 IP67 Enclosures constructed for either indoor or outdoor use to provide a degree of protection to personnel against incidental contact with the enclosed equipment, falling dirt, hose-directed water, the entry of water during occasional temporary submersion at a limited depth and damage from external ice formation. 6P IP67 Enclosures constructed for either indoor or outdoor use to provide a degree of protection to personnel against incidental contact with the enclosed equipment, falling dirt, hose-directed water, the entry of water during prolonged submersion at a limited depth and damage from external ice formation. Technical Information Type 6 rating can be either Type 6 or Type 6P - please see below: 257 JBX Series | Technical Information Ethernet for the Layman In order to explain basic Ethernet theory, we can use a functional comparison to a busy city with highways, buildings and cars. To illustrate this, the table below provides correlation between the different components/pieces/links that encompass Ethernet network connectivity, and the larger scale infrastructure of a metropolitan city. • City: • Buildings: • Roads: • Cars: • Tolls: • Bridges: • Traffic laws: The network itself End equipment, PC, server, etc. Ethernet cabling Data packets, datagrams, bits, bytes, etc. Firewalls Connectors Protocol/communication specifications Ethernet Basics Ethernet is a widely used communications protocol that is used to transmit data packets (datagrams) between network devices. Imagine a highway in a large metropolitan area six lanes wide at rush hour. The vehicles on the highway need rules to follow so that they get to their destination without crashing into each other. In an Ethernet network link, there could be 100 million bits of information transmitted in one second. In the Ethernet standard, there exist rules to govern packet structure, transmission requirements, error correction, communication with end equipment, etc. Examining the differences between 100Mhz, 100 Base TX, Cat5e/Cat6. What does it all mean? When discussing connectors and Ethernet, there are a few key details to be aware of: • 100Mhz is a measurement of Frequency for the signal - Comparable to the Speed Limit of a highway • 100BaseTX (or Fast Ethernet) is an Ethernet link standard and identifies available link bandwidth. The bandwidth is measured in units of MBits/S (megabits per second) - Comparable to the number of cars that pass a point in one second • Cat5e/Cat6 are an EIA/TIA standard for performance and physical characteristics for cables and connectors - Comparable to performance specifications of the car and highway. In connectors and cables, Fast Ethernet uses 2 pairs. One for transmit and one for receive. This way data traffic can flow in both directions simultaneously. 258 JBX Series | Technical Information Souriau offering: Standard solutions. JBX size 2, 16 contacts - Cat5e Twisted pairs 1 1 (Pair 1) ‹ 1 &11 2 (Pair 1) ‹ 9 & 8 3 (Pair 2) ‹ 5 & 6 4 (Pair 2) ‹ 12 & 13 2 13 3 14 4 5 JBX size 2, 18 contacts - Cat5e Twisted pairs 11 10 12 16 6 9 15 8 7 JBX2-16 16 Ø 7mm Shielding continuity shall be done in cavities 10, 16, 15, 7, 14, 4, 3 and 2 1 (Pair 1) ‹ 1 &2 2 (Pair 1) ‹ 10 & 11 3 (Pair 2) ‹ 4 & 5 4 (Pair 2) ‹ 7 & 8 12 1 2 3 14 15 4 5 6 13 18 16 11 10 17 7 9 8 JBX2-18 18 Ø 7mm Shielding continuity shall be done in cavities 3, 6, 9 and 12 Conclusion Technical Information To carry 100Mb/s data signal, 100BaseTX or Fast Ethernet recommends the use of Cat5e connectors as well as Cat5e cable with the support of a 100MHz signal. Nevertheless, a 100Mb/s signal can be transmitted in certain conditions (short distance, only one connector, lower frequency but a different code) thru many other connection materials - not necessarily Cat5e rated. 259 JBX SERIES © 2015 SOURIAU - SOURIAU is a registered trademark JBX Series Appendices Glossary of Terms .................................................................................................... 262 Drilling Pattern ........................................................................................................ 263 Part Number Index .................................................................................................. 271 261 JBX Series | Appendices Glossary of Terms • Clearance Per the IEC 60664-1 it is the shortest distance between two conductive parts even over the air. • Creepage distance Per the IEC 60664-1 it represents the shortest distance along the surface of the insulating material between two conductive parts. • CTI (Comparative Tracking Index) The CTI value is commonly used to characterize the electrical breakdown properties of an insulating material. It allows users to know the tendency to create creepage paths. This value represents the maximum voltage after 50 drops of ammonium chloride solution without any breakdown. Air gap Creepage distance • Working voltage Per the IEC 60664-1 it is the highest r.m.s. value of A.C. or D.C. voltage across any particular insulation which can occur when the equipment is supplied at rated voltage. • Rated impulse voltage Impulse withstands voltage value assigned by the manufacturer to the equipment or to a part of it characterizing the specified withstand capability of its insulation against transient overvoltage. • Working current It is the maximum continuous and not interrupted current able to be carried by all contacts without exceeding the maximum temperature of the insulating material. • Transient voltage Extract from the IEC 60664-1: Short duration overvoltage of a few millisecond or less, oscillatory or non-oscillatory, usually highly damped. 262 • RTI (Relative temperature Index): Extract from ULs website: Maximum service temperature for a material, where a class of critical property will not be unacceptably compromised through chemical thermal degradation, over the reasonable life of an electrical product, relative to a reference material having a confirmed, acceptable corresponding performance defined RTI. - RTI Elec: Electrical RTI, associated with critical electrical insulating properties. - RTI Mech Imp: Mechanical Impact RTI, associated with critical impact resistance, resilience and flexibility properties. - RTI Mech Str: Mechanical Strength (Mechanical without Impact) RTI, associated with critical mechanical strength where impact resistance, resilience and flexibility are not essential. JBX Series | Appendices Drilling Pattern - Female Insulator Shell Size Dimensions (mm) Straight PCB Contacts JBX0-02 JBX0-03 JBX0-04 45° R 1.25 R 1.1 R 1.15 3x120° 4x90° Ø 0.95 Ø 0.95 Ø 0.75 JBX0-05 JBX0-06 JBX0-07 30° 30° 5x72° R 1.375 R 1.5 Ø 0.75 R 1.5 6x60° Ø 0.75 6x60° Ø 0.75 JBX0-08 0 90° PCB Contacts 7x51°25' R 1.53 JBX0-03 JBX0-02 2.54 2.54 2.54 Ø 0.95 Ø 0.75 Ø 0.95 Mounting Pins 7.62 JBX0-04 JBX0-05 2.54 2.54 Ø 1.2 Ø 0.75 Appendices 1.27 2.54 2.54 7.62 Insulator 2.54 Ø 0.75 263 JBX Series | Appendices Drilling Pattern - Female Insulator (Continued) Shell Size Dimensions (mm) Straight PCB Contacts JBX1-02 JBX1-03 JBX1-04 45° R 1.55 R 1.5 R 1.4 3x120° 4x90° Ø 0.95 Ø 0.95 Ø 0.95 JBX1-05 JBX1-06 JBX1-07 30° 30° 5x72° R 1.7 R 1.85 R 1.85 6x60° 6x60° 1 Ø 0.95 Ø 0.75 JBX1-08 Ø 0.75 JBX1-12 JBX1-10 20° 22.5° R 1.85 8x45° 7x51°25' R 2.13 9x40° R2 3x120° Ø 0.75 264 R 0.7 Ø 0.75 Ø 0.75 R 0.82 JBX Series | Appendices Shell Size Dimensions (mm) 90° PCB Contacts 2.54 2.54 Ø 0.83 Ø 0.83 Ø 0.83 JBX1-06 JBX1-07 2.54 2.54 2.54 2.54 2.54 2.54 Ø 0.83 Ø 0.83 Mounting Pins JBX1-08 7.62 2.54 3.17 7.62 Insulator Appendices 2.54 1.84 1 2.54 2.54 2.54 2.54 2.54 2.54 2.54 JBX1-05 2.54 JBX1-04 2.54 JBX1-03 Ø 1.2 Ø 0.83 265 JBX Series | Appendices Drilling Pattern - Female Insulator (Continued) Shell Size Dimensions (mm) Straight PCB Contacts JBX2-04 JBX2-05 45° R 2.45 5x72° R 2.55 4x90° Ø 0.95 Ø 0.95 JBX2-07 JBX2-06 36° 30° R 2.88 R 2.75 6x60° 5x72° Ø 0.95 Ø 0.95 2 JBX2-08 JBX2-10 22.5° 8x45° R 3.15 R 3.15 8x45° Ø 0.95 Ø 0.95 JBX2-12 45° R 3.23 22.5° 8x45° 4x90° Ø 0.75 266 R 1.40 R 1.10 JBX Series | Appendices Shell Size Dimensions (mm) Straight PCB Contacts JBX2-16 Y -X X -Y Rep 1 2 3 4 5 6 7 8 0 1.77 2.98 3.24 2.48 0.92 0 -1.36 -2.76 -3.28 -2.76 -1.36 0.47 2.15 3.14 1.55 X -0.92 -2.48 -3.24 -2.98 -1.77 Y 3.14 2.15 0.48 9 10 11 12 13 14 -1.47 -0.91 0.48 15 16 0.91 1.47 -1.25 -1.25 0.48 JBX2-18 Y 2 -X X -Y Rep 1 2 3 4 5 6 7 8 9 10 11 12 13 0 14 15 -1.49 -1.49 16 0 17 18 X -0.86 -2.35 -3.21 -3.21 -2.35 -0.86 0.86 2.35 3.21 3.21 2.35 0.86 Y 3.21 2.35 0.86 -0.86 -2.35 -3.21 -3.21 -2.35 -0.86 0.86 2.35 3.21 1.73 0.86 -0.86 -1.73 -0.86 0.86 1.49 1.49 JBX2-19 Y -X X Rep 1 2 3 4 5 6 7 8 9 10 11 12 13 0 14 15 -1.49 -1.49 16 0 17 18 Appendices -Y 19 X -0.86 -2.35 -3.21 -3.21 -2.35 -0.86 0.86 2.35 3.21 3.21 2.35 0.86 1.49 1.49 0 Y 3.21 2.35 0.86 -0.86 -2.35 -3.21 -3.21 -2.35 -0.86 0.86 2.35 3.21 1.73 0.86 -0.86 -1.73 -0.86 0.86 0 267 JBX Series | Appendices Drilling Pattern - Female Insulator (Continued) Shell Size Dimensions (mm) 90° PCB Contacts JBX2-08 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 JBX2-10 Ø 0.83 JBX2-12 2.54 2.54 2.54 2.54 Ø 0.83 268 2.54 1.27 2.54 2.54 2.54 2.54 2.54 2.54 2.54 1.27 2.54 JBX2-16 2.54 2 Ø 0.83 Ø 0.83 2.54 JBX Series | Appendices Shell Size Dimensions (mm) Straight PCB Contacts JBX3-08 JBX3-10 22.5° R 3.75 8x45° Ø 0.95 3 8x45° R 3.90 R 1.40 Ø 0.95 JBX3-14 JBX3-18 15° 12x30° 18° 10x36° R 4.05 R 4.15 6x60° 4x90° R 2.15 Ø 0.95 Appendices Ø 0.95 R 1.70 269 JBX Series | Appendices Drilling Pattern - Female Insulator (Continued) Shell Size Dimensions (mm) Straight PCB Contacts JBX3-22 JBX3-30 Y Y X -X X -X -Y -Y Rep 3 270 X Y Rep X Y -0.87 4.38 -2.48 3.72 1 -0.97 4.24 1 2 -2.71 3.40 2 3 -3.92 1.89 3 -3.72 2.48 4 -4.35 0 4 -4.38 0.87 5 -3.92 -1.89 6 -2.71 -3.40 7 -0.97 -4.24 8 0.97 -4.24 9 2.71 -3.40 10 3.92 -1.89 11 4.35 0 12 3.92 1.89 13 2.71 3.40 14 0.97 4.24 15 -0.96 2.31 16 -2.31 0.96 17 -2.31 -0.96 18 -0.96 -2.31 19 -2.66 0.87 19 0.96 -2.31 20 -2.66 -0.87 20 2.31 -0.96 21 -1.62 -2.22 21 2.31 0.96 22 0 -2.80 22 0.96 2.31 23 1.62 -2.22 24 2.66 -0.87 25 2.66 0.87 26 1.62 2.22 27 0 1.10 28 -1.25 0 29 0 -1.10 30 1.25 0 5 -4.38 -0.87 6 -3.72 -2.48 7 -2.48 -3.72 8 -0.87 -4.38 9 0.87 4.38 10 2.48 -3.72 11 3.72 -2.48 12 4.38 -0.87 13 4.38 0.87 14 3.72 2.48 15 2.48 3.72 16 0.87 4.38 17 0 2.80 18 -1.62 2.22 JBX Series | Appendices Connectors JBXEA0G02FCNDS................ JBXEA0G02FCSDS................ JBXEA0G02FPNDS................ JBXEA0G02FPSDS................ JBXEA0G02FQNDS................ JBXEA0G02FQSDS................ JBXEA0G02FSNDS................ JBXEA0G02FSSDS................ JBXEA0G02MCNDS................ JBXEA0G02MCSDS................ JBXEA0G02MSNDS................ JBXEA0G02MSSDS................ JBXEA0G03FCNDS................ JBXEA0G03FCSDS................ JBXEA0G03FPNDS................ JBXEA0G03FPSDS................ JBXEA0G03FQNDS................ JBXEA0G03FQSDS................ JBXEA0G03FSNDS................ JBXEA0G03FSSDS................ JBXEA0G03MCNDS................ JBXEA0G03MCSDS................ JBXEA0G03MSNDS................ JBXEA0G03MSSDS................ JBXEA0G04FCNDS................ JBXEA0G04FCSDS................ JBXEA0G04FPNDS................ JBXEA0G04FPSDS................ JBXEA0G04FQNDS................ JBXEA0G04FQSDS................ JBXEA0G04FSNDS................ JBXEA0G04FSSDS................ JBXEA0G04MCNDS................ JBXEA0G04MCSDS................ JBXEA0G04MPNDS................ JBXEA0G04MPSDS................ JBXEA0G04MSNDS................ JBXEA0G04MSSDS................ JBXEA0G05FCNDS................ JBXEA0G05FCSDS................ JBXEA0G05FPNDS................ JBXEA0G05FPSDS................ JBXEA0G05FQNDS................ JBXEA0G05FQSDS................ JBXEA0G05FSNDS................ JBXEA0G05FSSDS................ JBXEA0G05MCNDS................ JBXEA0G05MCSDS................ JBXEA0G05MPNDS................ JBXEA0G05MPSDS................ JBXEA0G05MSNDS................ JBXEA0G05MSSDS................ JBXEA0G06FPNDS................ JBXEA0G06FPSDS................ JBXEA0G06FSNDS................ JBXEA0G06FSSDS................ JBXEA0G06MPNDS................ JBXEA0G06MPSDS................ JBXEA0G06MSNDS................ JBXEA0G06MSSDS................ JBXEA0G07FPNDS................ JBXEA0G07FPSDS................ P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.112 P.112 JBXEA0G07FSNDS................ JBXEA0G07FSSDS................ JBXEA0G07MPNDS................ JBXEA0G07MPSDS................ JBXEA0G07MSNDS................ JBXEA0G07MSSDS................ JBXEA0G08FPNDS................ JBXEA0G08FPSDS................ JBXEA0G08FSNDS................ JBXEA0G08FSSDS................ JBXEA0G08MPNDS................ JBXEA0G08MPSDS................ JBXEA0G08MSNDS................ JBXEA0G08MSSDS................ JBXEA1G02FCNDS................ JBXEA1G02FCSDS................ JBXEA1G02FPNDS................ JBXEA1G02FPSDS................ JBXEA1G02FSNDS................ JBXEA1G02FSSDS................ JBXEA1G02MCNDS................ JBXEA1G02MCSDS................ JBXEA1G02MSNDS................ JBXEA1G02MSSDS................ JBXEA1G03FCNDS................ JBXEA1G03FCSDS................ JBXEA1G03FPNDS................ JBXEA1G03FPSDS................ JBXEA1G03FQNDS................ JBXEA1G03FQSDS................ JBXEA1G03FSNDS................ JBXEA1G03FSSDS................ JBXEA1G03MCNDS................ JBXEA1G03MCSDS................ JBXEA1G03MSNDS................ JBXEA1G03MSSDS................ JBXEA1G04FCNDS................ JBXEA1G04FCSDS................ JBXEA1G04FPNDS................ JBXEA1G04FPSDS................ JBXEA1G04FQNDS................ JBXEA1G04FQSDS................ JBXEA1G04FSNDS................ JBXEA1G04FSSDS................ JBXEA1G04MCNDS................ JBXEA1G04MCSDS................ JBXEA1G04MSNDS................ JBXEA1G04MSSDS................ JBXEA1G05FCNDS................ JBXEA1G05FCSDS................ JBXEA1G05FPNDS................ JBXEA1G05FPSDS................ JBXEA1G05FQNDS................ JBXEA1G05FQSDS................ JBXEA1G05FSNDS................ JBXEA1G05FSSDS................ JBXEA1G05MCNDS................ JBXEA1G05MCSDS................ JBXEA1G05MSNDS................ JBXEA1G05MSSDS................ JBXEA1G06FCNDS................ JBXEA1G06FCSDS................ JBXEA1G06FPNDS................ JBXEA1G06FPSDS................ P.112 P.112 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.102 P.102 P.102 P.102 JBXEA1G06FQNDS................ JBXEA1G06FQSDS................ JBXEA1G06FSNDS................ JBXEA1G06FSSDS................ JBXEA1G06MCNDS................ JBXEA1G06MCSDS................ JBXEA1G06MPNDS................ JBXEA1G06MPSDS................ JBXEA1G06MSNDS................ JBXEA1G06MSSDS................ JBXEA1G07FCNDS................ JBXEA1G07FCSDS................ JBXEA1G07FPNDS................ JBXEA1G07FPSDS................ JBXEA1G07FQNDS................ JBXEA1G07FQSDS................ JBXEA1G07FSNDS................ JBXEA1G07FSSDS................ JBXEA1G07MCNDS................ JBXEA1G07MCSDS................ JBXEA1G07MPNDS................ JBXEA1G07MPSDS................ JBXEA1G07MSNDS................ JBXEA1G07MSSDS................ JBXEA1G08FCNDS................ JBXEA1G08FCSDS................ JBXEA1G08FPNDS................ JBXEA1G08FPSDS................ JBXEA1G08FQNDS................ JBXEA1G08FQSDS................ JBXEA1G08FSNDS................ JBXEA1G08FSSDS................ JBXEA1G08MCNDS................ JBXEA1G08MCSDS................ JBXEA1G08MPNDS................ JBXEA1G08MPSDS................ JBXEA1G08MSNDS................ JBXEA1G08MSSDS................ JBXEA1G10FPNDS................ JBXEA1G10FPSDS................ JBXEA1G10FSNDS................ JBXEA1G10FSSDS................ JBXEA1G10MSNDS................ JBXEA1G10MSSDS................ JBXEA1G12FPNDS................ JBXEA1G12FPSDS................ JBXEA1G12FSNDS................ JBXEA1G12FSSDS................ JBXEA1G12MSNDS................ JBXEA1G12MSSDS................ JBXEA2G001FSNDS............... JBXEA2G001FSSDS............... JBXEA2G001MSNDS............... JBXEA2G001MSSDS............... JBXEA2G002FSNDS............... JBXEA2G002FSSDS............... JBXEA2G002MSNDS............... JBXEA2G002MSSDS............... JBXEA2G003FSNDS............... JBXEA2G003FSSDS............... JBXEA2G003MSNDS............... JBXEA2G003MSSDS............... JBXEA2G02FCNDS................ JBXEA2G02FCSDS................ P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.164 P.164 P.164 P.164 P.164 P.164 P.184 P.184 P.184 P.184 P.184 P.184 P.148 P.148 P.148 P.148 P.158 P.158 P.158 P.158 P.174 P.174 P.174 P.174 P.30 P.30 271 Appendices Part Number Index JBX Series | Appendices Part Number Index (Continued) JBXEA2G02FSNDS................ JBXEA2G02FSSDS................ JBXEA2G02MCNDS................ JBXEA2G02MCSDS................ JBXEA2G02MSNDS................ JBXEA2G02MSSDS................ JBXEA2G03FCNDS................ JBXEA2G03FCSDS................ JBXEA2G03FSNDS................ JBXEA2G03FSSDS................ JBXEA2G03MCNDS................ JBXEA2G03MCSDS................ JBXEA2G03MSNDS................ JBXEA2G03MSSDS................ JBXEA2G04FCNDS................ JBXEA2G04FCSDS................ JBXEA2G04FPNDS................ JBXEA2G04FPSDS................ JBXEA2G04FSNDS................ JBXEA2G04FSSDS................ JBXEA2G04MCNDS................ JBXEA2G04MCSDS................ JBXEA2G04MPNDS................ JBXEA2G04MPSDS................ JBXEA2G04MSNDS................ JBXEA2G04MSSDS................ JBXEA2G05FCNDS................ JBXEA2G05FCSDS................ JBXEA2G05FPNDS................ JBXEA2G05FPSDS................ JBXEA2G05FSNDS................ JBXEA2G05FSSDS................ JBXEA2G05MCNDS................ JBXEA2G05MCSDS................ JBXEA2G05MPNDS................ JBXEA2G05MPSDS................ JBXEA2G05MSNDS................ JBXEA2G05MSSDS................ JBXEA2G06FCNDS................ JBXEA2G06FCSDS................ JBXEA2G06FPNDS................ JBXEA2G06FPSDS................ JBXEA2G06FSNDS................ JBXEA2G06FSSDS................ JBXEA2G06MCNDS................ JBXEA2G06MCSDS................ JBXEA2G06MPNDS................ JBXEA2G06MPSDS................ JBXEA2G06MSNDS................ JBXEA2G06MSSDS................ JBXEA2G07FCNDS................ JBXEA2G07FCSDS................ JBXEA2G07FPNDS................ JBXEA2G07FPSDS................ JBXEA2G07FSNDS................ JBXEA2G07FSSDS................ JBXEA2G07MCNDS................ JBXEA2G07MCSDS................ JBXEA2G07MPNDS................ JBXEA2G07MPSDS................ JBXEA2G07MSNDS................ JBXEA2G07MSSDS................ JBXEA2G08FCNDS................ JBXEA2G08FCSDS................ 272 P.30 P.30 P.30 P.30 P.30 P.30 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.142 P.142 JBXEA2G08FPNDS................ JBXEA2G08FPSDS................ JBXEA2G08FQNDS................ JBXEA2G08FQSDS................ JBXEA2G08FSNDS................ JBXEA2G08FSSDS................ JBXEA2G08MCNDS................ JBXEA2G08MCSDS................ JBXEA2G08MSNDS................ JBXEA2G08MSSDS................ JBXEA2G10FCNDS................ JBXEA2G10FCSDS................ JBXEA2G10FPNDS................ JBXEA2G10FPSDS................ JBXEA2G10FQNDS................ JBXEA2G10FQSDS................ JBXEA2G10FSNDS................ JBXEA2G10FSSDS................ JBXEA2G10MCNDS................ JBXEA2G10MCSDS................ JBXEA2G10MSNDS................ JBXEA2G10MSSDS................ JBXEA2G12FCNDS................ JBXEA2G12FCSDS................ JBXEA2G12FPNDS................ JBXEA2G12FPSDS................ JBXEA2G12FQNDS................ JBXEA2G12FQSDS................ JBXEA2G12FSNDS................ JBXEA2G12FSSDS................ JBXEA2G12MCNDS................ JBXEA2G12MCSDS................ JBXEA2G12MPNDS................ JBXEA2G12MPSDS................ JBXEA2G12MSNDS................ JBXEA2G12MSSDS................ JBXEA2G16FCNDS................ JBXEA2G16FCSDS................ JBXEA2G16FPNDS................ JBXEA2G16FPSDS................ JBXEA2G16FQNDS................ JBXEA2G16FQSDS................ JBXEA2G16FSNDS................ JBXEA2G16FSSDS................ JBXEA2G16MCNDS................ JBXEA2G16MCSDS................ JBXEA2G16MPNDS................ JBXEA2G16MPSDS................ JBXEA2G16MSNDS................ JBXEA2G16MSSDS................ JBXEA2G18FCNDS................ JBXEA2G18FCSDS................ JBXEA2G18FPNDS................ JBXEA2G18FPSDS................ JBXEA2G18FSNDS................ JBXEA2G18FSSDS................ JBXEA2G18MCNDS................ JBXEA2G18MCSDS................ JBXEA2G18MPNDS................ JBXEA2G18MPSDS................ JBXEA2G18MSNDS................ JBXEA2G18MSSDS................ JBXEA2G19FCNDS................ JBXEA2G19FCSDS................ P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.214 P.214 JBXEA2G19FPNDS................ JBXEA2G19FPSDS................ JBXEA2G19FSNDS................ JBXEA2G19FSSDS................ JBXEA2G19MCNDS................ JBXEA2G19MCSDS................ JBXEA2G19MPNDS................ JBXEA2G19MPSDS................ JBXEA2G19MSNDS................ JBXEA2G19MSSDS................ JBXEA3G03FCNDS................ JBXEA3G03FCSDS................ JBXEA3G03FSNDS................ JBXEA3G03FSSDS................ JBXEA3G03MCNDS................ JBXEA3G03MCSDS................ JBXEA3G03MSNDS................ JBXEA3G03MSSDS................ JBXEA3G04FCNDS................ JBXEA3G04FCSDS................ JBXEA3G04FSNDS................ JBXEA3G04FSSDS................ JBXEA3G04MCNDS................ JBXEA3G04MCSDS................ JBXEA3G04MSNDS................ JBXEA3G04MSSDS................ JBXEA3G07FCNDS................ JBXEA3G07FCSDS................ JBXEA3G07FSNDS................ JBXEA3G07FSSDS................ JBXEA3G07MCNDS................ JBXEA3G07MCSDS................ JBXEA3G07MSNDS................ JBXEA3G07MSSDS................ JBXEA3G08FCNDS................ JBXEA3G08FCSDS................ JBXEA3G08FSNDS................ JBXEA3G08FSSDS................ JBXEA3G08MCNDS................ JBXEA3G08MCSDS................ JBXEA3G08MSNDS................ JBXEA3G08MSSDS................ JBXEA3G10FCNDS................ JBXEA3G10FCSDS................ JBXEA3G10FPNDS................ JBXEA3G10FPSDS................ JBXEA3G10FSNDS................ JBXEA3G10FSSDS................ JBXEA3G10MCNDS................ JBXEA3G10MCSDS................ JBXEA3G10MSNDS................ JBXEA3G10MSSDS................ JBXEA3G14FCNDS................ JBXEA3G14FCSDS................ JBXEA3G14FPNDS................ JBXEA3G14FPSDS................ JBXEA3G14FSNDS................ JBXEA3G14FSSDS................ JBXEA3G14MCNDS................ JBXEA3G14MCSDS................ JBXEA3G14MSNDS................ JBXEA3G14MSSDS................ JBXEA3G18FCNDS................ JBXEA3G18FCSDS................ P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.210 P.210 JBXEA3G18FPNDS................ JBXEA3G18FPSDS................ JBXEA3G18FSNDS................ JBXEA3G18FSSDS................ JBXEA3G18MCNDS................ JBXEA3G18MCSDS................ JBXEA3G18MSNDS................ JBXEA3G18MSSDS................ JBXEA3G22FCNDS................ JBXEA3G22FCSDS................ JBXEA3G22FPNDS................ JBXEA3G22FPSDS................ JBXEA3G22FSNDS................ JBXEA3G22FSSDS................ JBXEA3G22MCNDS................ JBXEA3G22MCSDS................ JBXEA3G22MSNDS................ JBXEA3G22MSSDS................ JBXEA3G30FCNDS................ JBXEA3G30FCSDS................ JBXEA3G30FPNDS................ JBXEA3G30FPSDS................ JBXEA3G30FSNDS................ JBXEA3G30FSSDS................ JBXEA3G30MCNDS................ JBXEA3G30MCSDS................ JBXEA3G30MSNDS................ JBXEA3G30MSSDS................ JBXEC2G001FSNDS............... JBXEC2G001FSSDS............... JBXEC2G001MSNDS............... JBXEC2G001MSSDS............... JBXEC2G002FSNDS............... JBXEC2G002FSSDS............... JBXEC2G002MSNDS............... JBXEC2G002MSSDS............... JBXEC2G003FSNDS............... JBXEC2G003FSSDS............... JBXEC2G003MSNDS............... JBXEC2G003MSSDS............... JBXEC2G02FCNDS................ JBXEC2G02FCSDS................ JBXEC2G02FSNDS................ JBXEC2G02FSSDS................ JBXEC2G02MCNDS................ JBXEC2G02MCSDS................ JBXEC2G02MSNDS................ JBXEC2G02MSSDS................ JBXEC2G03FCNDS................ JBXEC2G03FCSDS................ JBXEC2G03FSNDS................ JBXEC2G03FSSDS................ JBXEC2G03MCNDS................ JBXEC2G03MCSDS................ JBXEC2G03MSNDS................ JBXEC2G03MSSDS................ JBXEC2G04FCNDS................ JBXEC2G04FCSDS................ JBXEC2G04FPNDS................ JBXEC2G04FPSDS................ JBXEC2G04FSNDS................ JBXEC2G04FSSDS................ JBXEC2G04MCNDS................ JBXEC2G04MCSDS................ P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.150 P.150 P.150 P.150 P.160 P.160 P.160 P.160 P.176 P.176 P.176 P.176 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.72 P.72 P.72 P.72 P.72 P.72 P.72 P.72 JBXEC2G04MPNDS................ JBXEC2G04MPSDS................ JBXEC2G04MSNDS................ JBXEC2G04MSSDS................ JBXEC2G05FCNDS................ JBXEC2G05FCSDS................ JBXEC2G05FPNDS................ JBXEC2G05FPSDS................ JBXEC2G05FSNDS................ JBXEC2G05FSSDS................ JBXEC2G05MCNDS................ JBXEC2G05MCSDS................ JBXEC2G05MPNDS................ JBXEC2G05MPSDS................ JBXEC2G05MSNDS................ JBXEC2G05MSSDS................ JBXEC2G06FCNDS................ JBXEC2G06FCSDS................ JBXEC2G06FPNDS................ JBXEC2G06FPSDS................ JBXEC2G06FSNDS................ JBXEC2G06FSSDS................ JBXEC2G06MCNDS................ JBXEC2G06MCSDS................ JBXEC2G06MPNDS................ JBXEC2G06MPSDS................ JBXEC2G06MSNDS................ JBXEC2G06MSSDS................ JBXEC2G07FCNDS................ JBXEC2G07FCSDS................ JBXEC2G07FPNDS................ JBXEC2G07FPSDS................ JBXEC2G07FSNDS................ JBXEC2G07FSSDS................ JBXEC2G07MCNDS................ JBXEC2G07MCSDS................ JBXEC2G07MPNDS................ JBXEC2G07MPSDS................ JBXEC2G07MSNDS................ JBXEC2G07MSSDS................ JBXEC2G08FCNDS................ JBXEC2G08FCSDS................ JBXEC2G08FPNDS................ JBXEC2G08FPSDS................ JBXEC2G08FSNDS................ JBXEC2G08FSSDS................ JBXEC2G08MCNDS................ JBXEC2G08MCSDS................ JBXEC2G08MSNDS................ JBXEC2G08MSSDS................ JBXEC2G10FCNDS................ JBXEC2G10FCSDS................ JBXEC2G10FPNDS................ JBXEC2G10FPSDS................ JBXEC2G10FSNDS................ JBXEC2G10FSSDS................ JBXEC2G10MCNDS................ JBXEC2G10MCSDS................ JBXEC2G10MSNDS................ JBXEC2G10MSSDS................ JBXEC2G12FCNDS................ JBXEC2G12FCSDS................ JBXEC2G12FPNDS................ JBXEC2G12FPSDS................ P.72 P.72 P.72 P.72 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.190 P.190 P.190 P.190 JBXEC2G12FSNDS................ JBXEC2G12FSSDS................ JBXEC2G12MCNDS................ JBXEC2G12MCSDS................ JBXEC2G12MPNDS................ JBXEC2G12MPSDS................ JBXEC2G12MSNDS................ JBXEC2G12MSSDS................ JBXEC2G16FCNDS................ JBXEC2G16FCSDS................ JBXEC2G16FPNDS................ JBXEC2G16FPSDS................ JBXEC2G16FSNDS................ JBXEC2G16FSSDS................ JBXEC2G16MCNDS................ JBXEC2G16MCSDS................ JBXEC2G16MPNDS................ JBXEC2G16MPSDS................ JBXEC2G16MSNDS................ JBXEC2G16MSSDS................ JBXEC2G18FCNDS................ JBXEC2G18FCSDS................ JBXEC2G18FPNDS................ JBXEC2G18FPSDS................ JBXEC2G18FSNDS................ JBXEC2G18FSSDS................ JBXEC2G18MCNDS................ JBXEC2G18MCSDS................ JBXEC2G18MPNDS................ JBXEC2G18MPSDS................ JBXEC2G18MSNDS................ JBXEC2G18MSSDS................ JBXEC2G19FCNDS................ JBXEC2G19FCSDS................ JBXEC2G19FPNDS................ JBXEC2G19FPSDS................ JBXEC2G19FSNDS................ JBXEC2G19FSSDS................ JBXEC2G19MCNDS................ JBXEC2G19MCSDS................ JBXEC2G19MPNDS................ JBXEC2G19MPSDS................ JBXEC2G19MSNDS................ JBXEC2G19MSSDS................ JBXED0G02FCNDSR............... JBXED0G02FCSDSR............... JBXED0G02FQNDSR............... JBXED0G02FQSDSR............... JBXED0G02FSNDSR............... JBXED0G02FSSDSR............... JBXED0G02MCNDSR............... JBXED0G02MCSDSR............... JBXED0G02MSNDSR............... JBXED0G02MSSDSR............... JBXED0G03FCNDSR............... JBXED0G03FCSDSR............... JBXED0G03FQNDSR............... JBXED0G03FQSDSR............... JBXED0G03FSNDSR............... JBXED0G03FSSDSR............... JBXED0G03MCNDSR............... JBXED0G03MCSDSR............... JBXED0G03MSNDSR............... JBXED0G03MSSDSR............... P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 273 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) JBXED0G04FCNDSR............... JBXED0G04FCSDSR............... JBXED0G04FQNDSR............... JBXED0G04FQSDSR............... JBXED0G04FSNDSR............... JBXED0G04FSSDSR............... JBXED0G04MCNDSR............... JBXED0G04MCSDSR............... JBXED0G04MSNDSR............... JBXED0G04MSSDSR............... JBXED0G05FCNDSR............... JBXED0G05FCSDSR............... JBXED0G05FQNDSR............... JBXED0G05FQSDSR............... JBXED0G05FSNDSR............... JBXED0G05FSSDSR............... JBXED0G05MCNDSR............... JBXED0G05MCSDSR............... JBXED0G05MSNDSR............... JBXED0G05MSSDSR............... JBXED0G06FSNDSR............... JBXED0G06FSSDSR............... JBXED0G06MSNDSR............... JBXED0G06MSSDSR............... JBXED0G07FSNDSR............... JBXED0G07FSSDSR............... JBXED0G07MSNDSR............... JBXED0G07MSSDSR............... JBXED0G08FSNDSR............... JBXED0G08FSSDSR............... JBXED0G08MSNDSR............... JBXED0G08MSSDSR............... JBXEP0G02FCNDS................ JBXEP0G02FCSDS................ JBXEP0G02FPNDS................ JBXEP0G02FPSDS................ JBXEP0G02FQNDS................ JBXEP0G02FQSDS................ JBXEP0G02FSNDS................ JBXEP0G02FSSDS................ JBXEP0G02MCNDS................ JBXEP0G02MCSDS................ JBXEP0G02MSNDS................ JBXEP0G02MSSDS................ JBXEP0G03FCNDS................ JBXEP0G03FCSDS................ JBXEP0G03FPNDS................ JBXEP0G03FPSDS................ JBXEP0G03FQNDS................ JBXEP0G03FQSDS................ JBXEP0G03FSNDS................ JBXEP0G03FSSDS................ JBXEP0G03MCNDS................ JBXEP0G03MCSDS................ JBXEP0G03MSNDS................ JBXEP0G03MSSDS................ JBXEP0G04FCNDS................ JBXEP0G04FCSDS................ JBXEP0G04FPNDS................ JBXEP0G04FPSDS................ JBXEP0G04FQNDS................ JBXEP0G04FQSDS................ JBXEP0G04FSNDS................ JBXEP0G04FSSDS................ 274 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 JBXEP0G04MCNDS................ JBXEP0G04MCSDS................ JBXEP0G04MPNDS................ JBXEP0G04MPSDS................ JBXEP0G04MSNDS................ JBXEP0G04MSSDS................ JBXEP0G05FCNDS................ JBXEP0G05FCSDS................ JBXEP0G05FPNDS................ JBXEP0G05FPSDS................ JBXEP0G05FQNDS................ JBXEP0G05FQSDS................ JBXEP0G05FSNDS................ JBXEP0G05FSSDS................ JBXEP0G05MCNDS................ JBXEP0G05MCSDS................ JBXEP0G05MPNDS................ JBXEP0G05MPSDS................ JBXEP0G05MSNDS................ JBXEP0G05MSSDS................ JBXEP0G06FPNDS................ JBXEP0G06FPSDS................ JBXEP0G06FSNDS................ JBXEP0G06FSSDS................ JBXEP0G06MPNDS................ JBXEP0G06MPSDS................ JBXEP0G06MSNDS................ JBXEP0G06MSSDS................ JBXEP0G07FPNDS................ JBXEP0G07FPSDS................ JBXEP0G07FSNDS................ JBXEP0G07FSSDS................ JBXEP0G07MPNDS................ JBXEP0G07MPSDS................ JBXEP0G07MSNDS................ JBXEP0G07MSSDS................ JBXEP0G08FPNDS................ JBXEP0G08FPSDS................ JBXEP0G08FSNDS................ JBXEP0G08FSSDS................ JBXEP0G08MPNDS................ JBXEP0G08MPSDS................ JBXEP0G08MSNDS................ JBXEP0G08MSSDS................ JBXEP1G02FSNDS................ JBXEP1G02FSSDS................ JBXEP1G02MSNDS................ JBXEP1G02MSSDS................ JBXEP1G03FQNDS................ JBXEP1G03FQSDS................ JBXEP1G03FSNDS................ JBXEP1G03FSSDS................ JBXEP1G03MSNDS................ JBXEP1G03MSSDS................ JBXEP1G04FQNDS................ JBXEP1G04FQSDS................ JBXEP1G04FSNDS................ JBXEP1G04FSSDS................ JBXEP1G04MSNDS................ JBXEP1G04MSSDS................ JBXEP1G05FQNDS................ JBXEP1G05FQSDS................ JBXEP1G05FSNDS................ JBXEP1G05FSSDS................ P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.26 P.26 P.26 P.26 P.42 P.42 P.42 P.42 P.42 P.42 P.66 P.66 P.66 P.66 P.66 P.66 P.86 P.86 P.86 P.86 JBXEP1G05MSNDS................ JBXEP1G05MSSDS................ JBXEP1G06FQNDS................ JBXEP1G06FQSDS................ JBXEP1G06FSNDS................ JBXEP1G06FSSDS................ JBXEP1G06MSNDS................ JBXEP1G06MSSDS................ JBXEP1G07FQNDS................ JBXEP1G07FQSDS................ JBXEP1G07FSNDS................ JBXEP1G07FSSDS................ JBXEP1G07MSNDS................ JBXEP1G07MSSDS................ JBXEP1G08FQNDS................ JBXEP1G08FQSDS................ JBXEP1G08FSNDS................ JBXEP1G08FSSDS................ JBXEP1G08MSNDS................ JBXEP1G08MSSDS................ JBXEP1G10FSNDS................ JBXEP1G10FSSDS................ JBXEP1G10MSNDS................ JBXEP1G10MSSDS................ JBXEP1G12FSNDS................ JBXEP1G12FSSDS................ JBXEP1G12MSNDS................ JBXEP1G12MSSDS................ JBXEP2G001FSNDS............... JBXEP2G001FSSDS............... JBXEP2G001MSNDS............... JBXEP2G001MSSDS............... JBXEP2G002FSNDS............... JBXEP2G002FSSDS............... JBXEP2G002MSNDS............... JBXEP2G002MSSDS............... JBXEP2G003FSNDS............... JBXEP2G003FSSDS............... JBXEP2G003MSNDS............... JBXEP2G003MSSDS............... JBXEP2G02FCNDS................ JBXEP2G02FCSDS................ JBXEP2G02FSNDS................ JBXEP2G02FSSDS................ JBXEP2G02MCNDS................ JBXEP2G02MCSDS................ JBXEP2G02MSNDS................ JBXEP2G02MSSDS................ JBXEP2G03FCNDS................ JBXEP2G03FCSDS................ JBXEP2G03FSNDS................ JBXEP2G03FSSDS................ JBXEP2G03MCNDS................ JBXEP2G03MCSDS................ JBXEP2G03MSNDS................ JBXEP2G03MSSDS................ JBXEP2G04FCNDS................ JBXEP2G04FCSDS................ JBXEP2G04FPNDS................ JBXEP2G04FPSDS................ JBXEP2G04FSNDS................ JBXEP2G04FSSDS................ JBXEP2G04MCNDS................ JBXEP2G04MCSDS................ P.86 P.86 P.102 P.102 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 P.118 P.118 P.138 P.138 P.138 P.138 P.138 P.138 P.164 P.164 P.164 P.164 P.184 P.184 P.184 P.184 P.148 P.148 P.148 P.148 P.158 P.158 P.158 P.158 P.174 P.174 P.174 P.174 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 JBXEP2G04MPNDS................ JBXEP2G04MPSDS................ JBXEP2G04MSNDS................ JBXEP2G04MSSDS................ JBXEP2G05FCNDS................ JBXEP2G05FCSDS................ JBXEP2G05FPNDS................ JBXEP2G05FPSDS................ JBXEP2G05FSNDS................ JBXEP2G05FSSDS................ JBXEP2G05MCNDS................ JBXEP2G05MCSDS................ JBXEP2G05MPNDS................ JBXEP2G05MPSDS................ JBXEP2G05MSNDS................ JBXEP2G05MSSDS................ JBXEP2G06FCNDS................ JBXEP2G06FCSDS................ JBXEP2G06FPNDS................ JBXEP2G06FPSDS................ JBXEP2G06FSNDS................ JBXEP2G06FSSDS................ JBXEP2G06MCNDS................ JBXEP2G06MCSDS................ JBXEP2G06MPNDS................ JBXEP2G06MPSDS................ JBXEP2G06MSNDS................ JBXEP2G06MSSDS................ JBXEP2G07FCNDS................ JBXEP2G07FCSDS................ JBXEP2G07FPNDS................ JBXEP2G07FPSDS................ JBXEP2G07FSNDS................ JBXEP2G07FSSDS................ JBXEP2G07MCNDS................ JBXEP2G07MCSDS................ JBXEP2G07MPNDS................ JBXEP2G07MPSDS................ JBXEP2G07MSNDS................ JBXEP2G07MSSDS................ JBXEP2G08FCNDS................ JBXEP2G08FCSDS................ JBXEP2G08FPNDS................ JBXEP2G08FPSDS................ JBXEP2G08FQNDS................ JBXEP2G08FQSDS................ JBXEP2G08FSNDS................ JBXEP2G08FSSDS................ JBXEP2G08MCNDS................ JBXEP2G08MCSDS................ JBXEP2G08MSNDS................ JBXEP2G08MSSDS................ JBXEP2G10FCNDS................ JBXEP2G10FCSDS................ JBXEP2G10FPNDS................ JBXEP2G10FPSDS................ JBXEP2G10FQNDS................ JBXEP2G10FQSDS................ JBXEP2G10FSNDS................ JBXEP2G10FSSDS................ JBXEP2G10MCNDS................ JBXEP2G10MCSDS................ JBXEP2G10MSNDS................ JBXEP2G10MSSDS................ P.70 P.70 P.70 P.70 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 JBXEP2G12FCNDS................ JBXEP2G12FCSDS................ JBXEP2G12FPNDS................ JBXEP2G12FPSDS................ JBXEP2G12FQNDS................ JBXEP2G12FQSDS................ JBXEP2G12FSNDS................ JBXEP2G12FSSDS................ JBXEP2G12MCNDS................ JBXEP2G12MCSDS................ JBXEP2G12MPNDS................ JBXEP2G12MPSDS................ JBXEP2G12MSNDS................ JBXEP2G12MSSDS................ JBXEP2G16FCNDS................ JBXEP2G16FCSDS................ JBXEP2G16FPNDS................ JBXEP2G16FPSDS................ JBXEP2G16FQNDS................ JBXEP2G16FQSDS................ JBXEP2G16FSNDS................ JBXEP2G16FSSDS................ JBXEP2G16MCNDS................ JBXEP2G16MCSDS................ JBXEP2G16MPNDS................ JBXEP2G16MPSDS................ JBXEP2G16MSNDS................ JBXEP2G16MSSDS................ JBXEP2G18FCNDS................ JBXEP2G18FCSDS................ JBXEP2G18FPNDS................ JBXEP2G18FPSDS................ JBXEP2G18FSNDS................ JBXEP2G18FSSDS................ JBXEP2G18MCNDS................ JBXEP2G18MCSDS................ JBXEP2G18MPNDS................ JBXEP2G18MPSDS................ JBXEP2G18MSNDS................ JBXEP2G18MSSDS................ JBXEP2G19FCNDS................ JBXEP2G19FCSDS................ JBXEP2G19FPNDS................ JBXEP2G19FPSDS................ JBXEP2G19FSNDS................ JBXEP2G19FSSDS................ JBXEP2G19MCNDS................ JBXEP2G19MCSDS................ JBXEP2G19MPNDS................ JBXEP2G19MPSDS................ JBXEP2G19MSNDS................ JBXEP2G19MSSDS................ JBXER00G02FSNDSR.............. JBXER00G02FSSDSR.............. JBXER00G02MSNDSR.............. JBXER00G02MSSDSR.............. JBXER00G04FSNDSR.............. JBXER00G04FSSDSR.............. JBXER00G04MSNDSR.............. JBXER00G04MSSDSR.............. JBXER0G02FCNDSR............... JBXER0G02FCSDSR............... JBXER0G02FSNDSR............... JBXER0G02FSSDSR............... P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.16 P.16 P.16 P.16 P.56 P.56 P.56 P.56 P.20 P.20 P.20 P.20 JBXER0G02MCNDSR............... JBXER0G02MCSDSR............... JBXER0G02MSNDSR............... JBXER0G02MSSDSR............... JBXER0G03FCNDSR............... JBXER0G03FCSDSR............... JBXER0G03FSNDSR............... JBXER0G03FSSDSR............... JBXER0G03MCNDSR............... JBXER0G03MCSDSR............... JBXER0G03MSNDSR............... JBXER0G03MSSDSR............... JBXER0G04FCNDSR............... JBXER0G04FCSDSR............... JBXER0G04FSNDSR............... JBXER0G04FSSDSR............... JBXER0G04MCNDSR............... JBXER0G04MCSDSR............... JBXER0G04MSNDSR............... JBXER0G04MSSDSR............... JBXER0G05FCNDSR............... JBXER0G05FCSDSR............... JBXER0G05FSNDSR............... JBXER0G05FSSDSR............... JBXER0G05MCNDSR............... JBXER0G05MCSDSR............... JBXER0G05MSNDSR............... JBXER0G05MSSDSR............... JBXER0G06FSNDSR............... JBXER0G06FSSDSR............... JBXER0G06MSNDSR............... JBXER0G06MSSDSR............... JBXER0G07FSNDSR............... JBXER0G07FSSDSR............... JBXER0G07MSNDSR............... JBXER0G07MSSDSR............... JBXER0G08FSNDSR............... JBXER0G08FSSDSR............... JBXER0G08MSNDSR............... JBXER0G08MSSDSR............... JBXER1G02FCNDSR............... JBXER1G02FCSDSR............... JBXER1G02FPNDSR............... JBXER1G02FPSDSR............... JBXER1G02FSNDSR............... JBXER1G02FSSDSR............... JBXER1G02MCNDSR............... JBXER1G02MCSDSR............... JBXER1G02MSNDSR............... JBXER1G02MSSDSR............... JBXER1G03FCNDSR............... JBXER1G03FCSDSR............... JBXER1G03FPNDSR............... JBXER1G03FPSDSR............... JBXER1G03FSNDSR............... JBXER1G03FSSDSR............... JBXER1G03MCNDSR............... JBXER1G03MCSDSR............... JBXER1G03MSNDSR............... JBXER1G03MSSDSR............... JBXER1G04FCNDSR............... JBXER1G04FCSDSR............... JBXER1G04FPNDSR............... JBXER1G04FPSDSR............... P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.66 P.66 P.66 P.66 275 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) JBXER1G04FSNDSR............... JBXER1G04FSSDSR............... JBXER1G04MCNDSR............... JBXER1G04MCSDSR............... JBXER1G04MSNDSR............... JBXER1G04MSSDSR............... JBXER1G05FCNDSR............... JBXER1G05FCSDSR............... JBXER1G05FPNDSR............... JBXER1G05FPSDSR............... JBXER1G05FSNDSR............... JBXER1G05FSSDSR............... JBXER1G05MCNDSR............... JBXER1G05MCSDSR............... JBXER1G05MSNDSR............... JBXER1G05MSSDSR............... JBXER1G06FCNDSR............... JBXER1G06FCSDSR............... JBXER1G06FPNDSR............... JBXER1G06FPSDSR............... JBXER1G06FSNDSR............... JBXER1G06FSSDSR............... JBXER1G06MCNDSR............... JBXER1G06MCSDSR............... JBXER1G06MPNDSR............... JBXER1G06MPSDSR............... JBXER1G06MSNDSR............... JBXER1G06MSSDSR............... JBXER1G07FCNDSR............... JBXER1G07FCSDSR............... JBXER1G07FPNDSR............... JBXER1G07FPSDSR............... JBXER1G07FSNDSR............... JBXER1G07FSSDSR............... JBXER1G07MCNDSR............... JBXER1G07MCSDSR............... JBXER1G07MPNDSR............... JBXER1G07MPSDSR............... JBXER1G07MSNDSR............... JBXER1G07MSSDSR............... JBXER1G08FCNDSR............... JBXER1G08FCSDSR............... JBXER1G08FPNDSR............... JBXER1G08FPSDSR............... JBXER1G08FSNDSR............... JBXER1G08FSSDSR............... JBXER1G08MCNDSR............... JBXER1G08MCSDSR............... JBXER1G08MPNDSR............... JBXER1G08MPSDSR............... JBXER1G08MSNDSR............... JBXER1G08MSSDSR............... JBXER1G10FPNDSR............... JBXER1G10FPSDSR............... JBXER1G10FSNDSR............... JBXER1G10FSSDSR............... JBXER1G10MSNDSR............... JBXER1G10MSSDSR............... JBXER1G12FPNDSR............... JBXER1G12FPSDSR............... JBXER1G12FSNDSR............... JBXER1G12FSSDSR............... JBXER1G12MSNDSR............... JBXER1G12MSSDSR............... 276 P.66 P.66 P.66 P.66 P.66 P.66 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.164 P.164 P.164 P.164 P.164 P.164 P.184 P.184 P.184 P.184 P.184 P.184 JBXER2G001FSNDSR.............. JBXER2G001FSSDSR.............. JBXER2G001MSNDSR.............. JBXER2G001MSSDSR.............. JBXER2G002FSNDSR.............. JBXER2G002FSSDSR.............. JBXER2G002MSNDSR.............. JBXER2G002MSSDSR.............. JBXER2G003FSNDSR.............. JBXER2G003FSSDSR.............. JBXER2G003MSNDSR.............. JBXER2G003MSSDSR.............. JBXER2G02FCNDSR............... JBXER2G02FCSDSR............... JBXER2G02FSNDSR............... JBXER2G02FSSDSR............... JBXER2G02MCNDSR............... JBXER2G02MCSDSR............... JBXER2G02MSNDSR............... JBXER2G02MSSDSR............... JBXER2G03FCNDSR............... JBXER2G03FCSDSR............... JBXER2G03FSNDSR............... JBXER2G03FSSDSR............... JBXER2G03MCNDSR............... JBXER2G03MCSDSR............... JBXER2G03MSNDSR............... JBXER2G03MSSDSR............... JBXER2G04FCNDSR............... JBXER2G04FCSDSR............... JBXER2G04FPNDSR............... JBXER2G04FPSDSR............... JBXER2G04FSNDSR............... JBXER2G04FSSDSR............... JBXER2G04MCNDSR............... JBXER2G04MCSDSR............... JBXER2G04MPNDSR............... JBXER2G04MPSDSR............... JBXER2G04MSNDSR............... JBXER2G04MSSDSR............... JBXER2G05FCNDSR............... JBXER2G05FCSDSR............... JBXER2G05FPNDSR............... JBXER2G05FPSDSR............... JBXER2G05FSNDSR............... JBXER2G05FSSDSR............... JBXER2G05MCNDSR............... JBXER2G05MCSDSR............... JBXER2G05MPNDSR............... JBXER2G05MPSDSR............... JBXER2G05MSNDSR............... JBXER2G05MSSDSR............... JBXER2G06FCNDSR............... JBXER2G06FCSDSR............... JBXER2G06FPNDSR............... JBXER2G06FPSDSR............... JBXER2G06FSNDSR............... JBXER2G06FSSDSR............... JBXER2G06MCNDSR............... JBXER2G06MCSDSR............... JBXER2G06MPNDSR............... JBXER2G06MPSDSR............... JBXER2G06MSNDSR............... JBXER2G06MSSDSR............... P.148 P.148 P.148 P.148 P.158 P.158 P.158 P.158 P.174 P.174 P.174 P.174 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 JBXER2G07FCNDSR............... JBXER2G07FCSDSR............... JBXER2G07FPNDSR............... JBXER2G07FPSDSR............... JBXER2G07FSNDSR............... JBXER2G07FSSDSR............... JBXER2G07MCNDSR............... JBXER2G07MCSDSR............... JBXER2G07MPNDSR............... JBXER2G07MPSDSR............... JBXER2G07MSNDSR............... JBXER2G07MSSDSR............... JBXER2G08FCNDSR............... JBXER2G08FCSDSR............... JBXER2G08FPNDSR............... JBXER2G08FPSDSR............... JBXER2G08FSNDSR............... JBXER2G08FSSDSR............... JBXER2G08MCNDSR............... JBXER2G08MCSDSR............... JBXER2G08MSNDSR............... JBXER2G08MSSDSR............... JBXER2G10FCNDSR............... JBXER2G10FCSDSR............... JBXER2G10FPNDSR............... JBXER2G10FPSDSR............... JBXER2G10FSNDSR............... JBXER2G10FSSDSR............... JBXER2G10MCNDSR............... JBXER2G10MCSDSR............... JBXER2G10MSNDSR............... JBXER2G10MSSDSR............... JBXER2G12FCNDSR............... JBXER2G12FCSDSR............... JBXER2G12FPNDSR............... JBXER2G12FPSDSR............... JBXER2G12FSNDSR............... JBXER2G12FSSDSR............... JBXER2G12MCNDSR............... JBXER2G12MCSDSR............... JBXER2G12MPNDSR............... JBXER2G12MPSDSR............... JBXER2G12MSNDSR............... JBXER2G12MSSDSR............... JBXER2G16FCNDSR............... JBXER2G16FCSDSR............... JBXER2G16FPNDSR............... JBXER2G16FPSDSR............... JBXER2G16FSNDSR............... JBXER2G16FSSDSR............... JBXER2G16MCNDSR............... JBXER2G16MCSDSR............... JBXER2G16MPNDSR............... JBXER2G16MPSDSR............... JBXER2G16MSNDSR............... JBXER2G16MSSDSR............... JBXER2G18FCNDSR............... JBXER2G18FCSDSR............... JBXER2G18FPNDSR............... JBXER2G18FPSDSR............... JBXER2G18FSNDSR............... JBXER2G18FSSDSR............... JBXER2G18MCNDSR............... JBXER2G18MCSDSR............... P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 JBXER2G18MPNDSR............... JBXER2G18MPSDSR............... JBXER2G18MSNDSR............... JBXER2G18MSSDSR............... JBXER2G19FCNDSR............... JBXER2G19FCSDSR............... JBXER2G19FPNDSR............... JBXER2G19FPSDSR............... JBXER2G19FSNDSR............... JBXER2G19FSSDSR............... JBXER2G19MCNDSR............... JBXER2G19MCSDSR............... JBXER2G19MPNDSR............... JBXER2G19MPSDSR............... JBXER2G19MSNDSR............... JBXER2G19MSSDSR............... JBXER3G03FCNDSR............... JBXER3G03FCSDSR............... JBXER3G03FSNDSR............... JBXER3G03FSSDSR............... JBXER3G03MCNDSR............... JBXER3G03MCSDSR............... JBXER3G03MSNDSR............... JBXER3G03MSSDSR............... JBXER3G04FCNDSR............... JBXER3G04FCSDSR............... JBXER3G04FSNDSR............... JBXER3G04FSSDSR............... JBXER3G04MCNDSR............... JBXER3G04MCSDSR............... JBXER3G04MSNDSR............... JBXER3G04MSSDSR............... JBXER3G07FCNDSR............... JBXER3G07FCSDSR............... JBXER3G07FSNDSR............... JBXER3G07FSSDSR............... JBXER3G07MCNDSR............... JBXER3G07MCSDSR............... JBXER3G07MSNDSR............... JBXER3G07MSSDSR............... JBXER3G08FCNDSR............... JBXER3G08FCSDSR............... JBXER3G08FSNDSR............... JBXER3G08FSSDSR............... JBXER3G08MCNDSR............... JBXER3G08MCSDSR............... JBXER3G08MSNDSR............... JBXER3G08MSSDSR............... JBXER3G10FCNDSR............... JBXER3G10FCSDSR............... JBXER3G10FSNDSR............... JBXER3G10FSSDSR............... JBXER3G10MCNDSR............... JBXER3G10MCSDSR............... JBXER3G10MSNDSR............... JBXER3G10MSSDSR............... JBXER3G14FCNDSR............... JBXER3G14FCSDSR............... JBXER3G14FSNDSR............... JBXER3G14FSSDSR............... JBXER3G14MCNDSR............... JBXER3G14MCSDSR............... JBXER3G14MSNDSR............... JBXER3G14MSSDSR............... P.204 P.204 P.204 P.204 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 JBXER3G18FCNDSR............... JBXER3G18FCSDSR............... JBXER3G18FSNDSR............... JBXER3G18FSSDSR............... JBXER3G18MCNDSR............... JBXER3G18MCSDSR............... JBXER3G18MSNDSR............... JBXER3G18MSSDSR............... JBXER3G22FCNDSR............... JBXER3G22FCSDSR............... JBXER3G22FSNDSR............... JBXER3G22FSSDSR............... JBXER3G22MCNDSR............... JBXER3G22MCSDSR............... JBXER3G22MSNDSR............... JBXER3G22MSSDSR............... JBXER3G30FCNDSR............... JBXER3G30FCSDSR............... JBXER3G30FSNDSR............... JBXER3G30FSSDSR............... JBXER3G30MCNDSR............... JBXER3G30MCSDSR............... JBXER3G30MSNDSR............... JBXER3G30MSSDSR............... JBXEZ0G02FPNDSR............... JBXEZ0G02FPSDSR............... JBXEZ0G03FPNDSR............... JBXEZ0G03FPSDSR............... JBXEZ0G04FPNDSR............... JBXEZ0G04FPSDSR............... JBXEZ0G04MPNDSR............... JBXEZ0G04MPSDSR............... JBXEZ0G05FPNDSR............... JBXEZ0G05FPSDSR............... JBXEZ0G05MPNDSR............... JBXEZ0G05MPSDSR............... JBXEZ0G06FPNDSR............... JBXEZ0G06FPSDSR............... JBXEZ0G06MPNDSR............... JBXEZ0G06MPSDSR............... JBXEZ0G07FPNDSR............... JBXEZ0G07FPSDSR............... JBXEZ0G07MPNDSR............... JBXEZ0G07MPSDSR............... JBXEZ0G08FPNDSR............... JBXEZ0G08FPSDSR............... JBXEZ0G08MPNDSR............... JBXEZ0G08MPSDSR............... JBXEZ1G02FPNDSR............... JBXEZ1G02FPSDSR............... JBXEZ1G03FPNDSR............... JBXEZ1G03FPSDSR............... JBXEZ1G04FPNDSR............... JBXEZ1G04FPSDSR............... JBXEZ1G05FPNDSR............... JBXEZ1G05FPSDSR............... JBXEZ1G06FPNDSR............... JBXEZ1G06FPSDSR............... JBXEZ1G06MPNDSR............... JBXEZ1G06MPSDSR............... JBXEZ1G07FPNDSR............... JBXEZ1G07FPSDSR............... JBXEZ1G07MPNDSR............... JBXEZ1G07MPSDSR............... P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.20 P.20 P.36 P.36 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.26 P.26 P.42 P.42 P.66 P.66 P.86 P.86 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 JBXEZ1G08FPNDSR............... JBXEZ1G08FPSDSR............... JBXEZ1G08MPNDSR............... JBXEZ1G08MPSDSR............... JBXEZ1G10FPNDSR............... JBXEZ1G10FPSDSR............... JBXEZ1G12FPNDSR............... JBXEZ1G12FPSDSR............... JBXFC0G02FCNDSMR.............. JBXFC0G02FCNDSR............... JBXFC0G02FCSDSMR.............. JBXFC0G02FCSDSR............... JBXFC0G02FSNDSMR.............. JBXFC0G02FSNDSR............... JBXFC0G02FSSDSMR.............. JBXFC0G02FSSDSR............... JBXFC0G02MCNDSMR.............. JBXFC0G02MCNDSR............... JBXFC0G02MCSDSMR.............. JBXFC0G02MCSDSR............... JBXFC0G02MSNDSMR.............. JBXFC0G02MSNDSR............... JBXFC0G02MSSDSMR.............. JBXFC0G02MSSDSR............... JBXFC0G03FCNDSMR.............. JBXFC0G03FCNDSR............... JBXFC0G03FCSDSMR.............. JBXFC0G03FCSDSR............... JBXFC0G03FSNDSMR.............. JBXFC0G03FSNDSR............... JBXFC0G03FSSDSMR.............. JBXFC0G03FSSDSR............... JBXFC0G03MCNDSMR.............. JBXFC0G03MCNDSR............... JBXFC0G03MCSDSMR.............. JBXFC0G03MCSDSR............... JBXFC0G03MSNDSMR.............. JBXFC0G03MSNDSR............... JBXFC0G03MSSDSMR.............. JBXFC0G03MSSDSR............... JBXFC0G04FCNDSMR.............. JBXFC0G04FCNDSR............... JBXFC0G04FCSDSMR.............. JBXFC0G04FCSDSR............... JBXFC0G04FSNDSMR.............. JBXFC0G04FSNDSR............... JBXFC0G04FSSDSMR.............. JBXFC0G04FSSDSR............... JBXFC0G04MCNDSMR.............. JBXFC0G04MCNDSR............... JBXFC0G04MCSDSMR.............. JBXFC0G04MCSDSR............... JBXFC0G04MSNDSMR.............. JBXFC0G04MSNDSR............... JBXFC0G04MSSDSMR.............. JBXFC0G04MSSDSR............... JBXFC0G05FCNDSMR.............. JBXFC0G05FCNDSR............... JBXFC0G05FCSDSMR.............. JBXFC0G05FCSDSR............... JBXFC0G05FSNDSMR.............. JBXFC0G05FSNDSR............... JBXFC0G05FSSDSMR.............. JBXFC0G05FSSDSR............... P.138 P.138 P.138 P.138 P.164 P.164 P.184 P.184 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 277 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) JBXFC0G05MCNDSMR.............. JBXFC0G05MCNDSR............... JBXFC0G05MCSDSMR.............. JBXFC0G05MCSDSR............... JBXFC0G05MSNDSMR.............. JBXFC0G05MSNDSR............... JBXFC0G05MSSDSMR.............. JBXFC0G05MSSDSR............... JBXFC0G06FSNDSMR.............. JBXFC0G06FSNDSR............... JBXFC0G06FSSDSMR.............. JBXFC0G06FSSDSR............... JBXFC0G06MSNDSMR.............. JBXFC0G06MSNDSR............... JBXFC0G06MSSDSMR.............. JBXFC0G06MSSDSR............... JBXFC0G07FSNDSMR.............. JBXFC0G07FSNDSR............... JBXFC0G07FSSDSMR.............. JBXFC0G07FSSDSR............... JBXFC0G07MSNDSMR.............. JBXFC0G07MSNDSR............... JBXFC0G07MSSDSMR.............. JBXFC0G07MSSDSR............... JBXFC0G08FSNDSMR.............. JBXFC0G08FSNDSR............... JBXFC0G08FSSDSMR.............. JBXFC0G08FSSDSR............... JBXFC0G08MSNDSMR.............. JBXFC0G08MSNDSR............... JBXFC0G08MSSDSMR.............. JBXFC0G08MSSDSR............... JBXFC1G02FCNDSMR.............. JBXFC1G02FCNDSR............... JBXFC1G02FCSDSMR.............. JBXFC1G02FCSDSR............... JBXFC1G02MCNDSMR.............. JBXFC1G02MCNDSR............... JBXFC1G02MCSDSMR.............. JBXFC1G02MCSDSR............... JBXFC1G03FCNDSMR.............. JBXFC1G03FCNDSR............... JBXFC1G03FCSDSMR.............. JBXFC1G03FCSDSR............... JBXFC1G03MCNDSMR.............. JBXFC1G03MCNDSR............... JBXFC1G03MCSDSMR.............. JBXFC1G03MCSDSR............... JBXFC1G04FCNDSMR.............. JBXFC1G04FCNDSR............... JBXFC1G04FCSDSMR.............. JBXFC1G04FCSDSR............... JBXFC1G04MCNDSMR.............. JBXFC1G04MCNDSR............... JBXFC1G04MCSDSMR.............. JBXFC1G04MCSDSR............... JBXFC1G05FCNDSMR.............. JBXFC1G05FCNDSR............... JBXFC1G05FCSDSMR.............. JBXFC1G05FCSDSR............... JBXFC1G05MCNDSMR.............. JBXFC1G05MCNDSR............... JBXFC1G05MCSDSMR.............. JBXFC1G05MCSDSR............... 278 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 JBXFC1G06FCNDSMR.............. JBXFC1G06FCNDSR............... JBXFC1G06FCSDSMR.............. JBXFC1G06FCSDSR............... JBXFC1G06MCNDSMR.............. JBXFC1G06MCNDSR............... JBXFC1G06MCSDSMR.............. JBXFC1G06MCSDSR............... JBXFC1G07FCNDSMR.............. JBXFC1G07FCNDSR............... JBXFC1G07FCSDSMR.............. JBXFC1G07FCSDSR............... JBXFC1G07MCNDSMR.............. JBXFC1G07MCNDSR............... JBXFC1G07MCSDSMR.............. JBXFC1G07MCSDSR............... JBXFC1G08FCNDSMR.............. JBXFC1G08FCNDSR............... JBXFC1G08FCSDSMR.............. JBXFC1G08FCSDSR............... JBXFC1G08MCNDSMR.............. JBXFC1G08MCNDSR............... JBXFC1G08MCSDSMR.............. JBXFC1G08MCSDSR............... JBXFC2G02FCNDSMR.............. JBXFC2G02FCNDSR............... JBXFC2G02FCSDSMR.............. JBXFC2G02FCSDSR............... JBXFC2G02MCNDSMR.............. JBXFC2G02MCNDSR............... JBXFC2G02MCSDSMR.............. JBXFC2G02MCSDSR............... JBXFC2G03FCNDSMR.............. JBXFC2G03FCNDSR............... JBXFC2G03FCSDSMR.............. JBXFC2G03FCSDSR............... JBXFC2G03MCNDSMR.............. JBXFC2G03MCNDSR............... JBXFC2G03MCSDSMR.............. JBXFC2G03MCSDSR............... JBXFC2G04FCNDSMR.............. JBXFC2G04FCNDSR............... JBXFC2G04FCSDSMR.............. JBXFC2G04FCSDSR............... JBXFC2G04MCNDSMR.............. JBXFC2G04MCNDSR............... JBXFC2G04MCSDSMR.............. JBXFC2G04MCSDSR............... JBXFC2G05FCNDSMR.............. JBXFC2G05FCNDSR............... JBXFC2G05FCSDSMR.............. JBXFC2G05FCSDSR............... JBXFC2G05MCNDSMR.............. JBXFC2G05MCNDSR............... JBXFC2G05MCSDSMR.............. JBXFC2G05MCSDSR............... JBXFC2G06FCNDSMR.............. JBXFC2G06FCNDSR............... JBXFC2G06FCSDSMR.............. JBXFC2G06FCSDSR............... JBXFC2G06MCNDSMR.............. JBXFC2G06MCNDSR............... JBXFC2G06MCSDSMR.............. JBXFC2G06MCSDSR............... P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 JBXFC2G07FCNDSMR.............. JBXFC2G07FCNDSR............... JBXFC2G07FCSDSMR.............. JBXFC2G07FCSDSR............... JBXFC2G07MCNDSMR.............. JBXFC2G07MCNDSR............... JBXFC2G07MCSDSMR.............. JBXFC2G07MCSDSR............... JBXFC2G08FCNDSMR.............. JBXFC2G08FCNDSR............... JBXFC2G08FCSDSMR.............. JBXFC2G08FCSDSR............... JBXFC2G08MCNDSMR.............. JBXFC2G08MCNDSR............... JBXFC2G08MCSDSMR.............. JBXFC2G08MCSDSR............... JBXFC2G10FCNDSMR.............. JBXFC2G10FCNDSR............... JBXFC2G10FCSDSMR.............. JBXFC2G10FCSDSR............... JBXFC2G10MCNDSMR.............. JBXFC2G10MCNDSR............... JBXFC2G10MCSDSMR.............. JBXFC2G10MCSDSR............... JBXFC2G12FCNDSMR.............. JBXFC2G12FCNDSR............... JBXFC2G12FCSDSMR.............. JBXFC2G12FCSDSR............... JBXFC2G12MCNDSMR.............. JBXFC2G12MCNDSR............... JBXFC2G12MCSDSMR.............. JBXFC2G12MCSDSR............... JBXFC2G16FCNDSMR.............. JBXFC2G16FCNDSR............... JBXFC2G16FCSDSMR.............. JBXFC2G16FCSDSR............... JBXFC2G16MCNDSMR.............. JBXFC2G16MCNDSR............... JBXFC2G16MCSDSMR.............. JBXFC2G16MCSDSR............... JBXFC2G18FCNDSMR.............. JBXFC2G18FCNDSR............... JBXFC2G18FCSDSMR.............. JBXFC2G18FCSDSR............... JBXFC2G18MCNDSMR.............. JBXFC2G18MCNDSR............... JBXFC2G18MCSDSMR.............. JBXFC2G18MCSDSR............... JBXFC2G19FCNDSMR.............. JBXFC2G19FCNDSR............... JBXFC2G19FCSDSMR.............. JBXFC2G19FCSDSR............... JBXFC2G19MCNDSMR.............. JBXFC2G19MCNDSR............... JBXFC2G19MCSDSMR.............. JBXFC2G19MCSDSR............... JBXFC3G03FCNDSMR.............. JBXFC3G03FCNDSR............... JBXFC3G03FCSDSMR.............. JBXFC3G03FCSDSR............... JBXFC3G03MCNDSMR.............. JBXFC3G03MCNDSR............... JBXFC3G03MCSDSMR.............. JBXFC3G03MCSDSR............... P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 JBXFC3G04FCNDSMR.............. JBXFC3G04FCNDSR............... JBXFC3G04FCSDSMR.............. JBXFC3G04FCSDSR............... JBXFC3G04MCNDSMR.............. JBXFC3G04MCNDSR............... JBXFC3G04MCSDSMR.............. JBXFC3G04MCSDSR............... JBXFC3G07FCNDSMR.............. JBXFC3G07FCNDSR............... JBXFC3G07FCSDSMR.............. JBXFC3G07FCSDSR............... JBXFC3G07MCNDSMR.............. JBXFC3G07MCNDSR............... JBXFC3G07MCSDSMR.............. JBXFC3G07MCSDSR............... JBXFC3G08FCNDSMR.............. JBXFC3G08FCNDSR............... JBXFC3G08FCSDSMR.............. JBXFC3G08FCSDSR............... JBXFC3G08MCNDSMR.............. JBXFC3G08MCNDSR............... JBXFC3G08MCSDSMR.............. JBXFC3G08MCSDSR............... JBXFC3G10FCNDSMR.............. JBXFC3G10FCNDSR............... JBXFC3G10FCSDSMR.............. JBXFC3G10FCSDSR............... JBXFC3G10MCNDSMR.............. JBXFC3G10MCNDSR............... JBXFC3G10MCSDSMR.............. JBXFC3G10MCSDSR............... JBXFC3G14FCNDSMR.............. JBXFC3G14FCNDSR............... JBXFC3G14FCSDSMR.............. JBXFC3G14FCSDSR............... JBXFC3G14MCNDSMR.............. JBXFC3G14MCNDSR............... JBXFC3G14MCSDSMR.............. JBXFC3G14MCSDSR............... JBXFC3G18FCNDSMR.............. JBXFC3G18FCNDSR............... JBXFC3G18FCSDSMR.............. JBXFC3G18FCSDSR............... JBXFC3G18MCNDSMR.............. JBXFC3G18MCNDSR............... JBXFC3G18MCSDSMR.............. JBXFC3G18MCSDSR............... JBXFC3G22FCNDSMR.............. JBXFC3G22FCNDSR............... JBXFC3G22FCSDSMR.............. JBXFC3G22FCSDSR............... JBXFC3G22MCNDSMR.............. JBXFC3G22MCNDSR............... JBXFC3G22MCSDSMR.............. JBXFC3G22MCSDSR............... JBXFC3G30FCNDSMR.............. JBXFC3G30FCNDSR............... JBXFC3G30FCSDSMR.............. JBXFC3G30FCSDSR............... JBXFC3G30MCNDSMR.............. JBXFC3G30MCNDSR............... JBXFC3G30MCSDSMR.............. JBXFC3G30MCSDSR............... P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 JBXFD00G02FSNDSMR............. JBXFD00G02FSNDSR.............. JBXFD00G02FSSDSMR............. JBXFD00G02FSSDSR.............. JBXFD00G02MSNDSMR............. JBXFD00G02MSNDSR.............. JBXFD00G02MSSDSMR............. JBXFD00G02MSSDSR.............. JBXFD00G04FSNDSMR............. JBXFD00G04FSNDSR.............. JBXFD00G04FSSDSMR............. JBXFD00G04FSSDSR.............. JBXFD00G04MSNDSMR............. JBXFD00G04MSNDSR.............. JBXFD00G04MSSDSMR............. JBXFD00G04MSSDSR.............. JBXFD0G02FCNDSMR.............. JBXFD0G02FCNDSR............... JBXFD0G02FCSDSMR.............. JBXFD0G02FCSDSR............... JBXFD0G02FSNDSMR.............. JBXFD0G02FSNDSR............... JBXFD0G02FSSDSMR.............. JBXFD0G02FSSDSR............... JBXFD0G02MCNDSMR.............. JBXFD0G02MCNDSR............... JBXFD0G02MCSDSMR.............. JBXFD0G02MCSDSR............... JBXFD0G02MSNDSMR.............. JBXFD0G02MSNDSR............... JBXFD0G02MSSDSMR.............. JBXFD0G02MSSDSR............... JBXFD0G03FCNDSMR.............. JBXFD0G03FCNDSR............... JBXFD0G03FCSDSMR.............. JBXFD0G03FCSDSR............... JBXFD0G03FSNDSMR.............. JBXFD0G03FSNDSR............... JBXFD0G03FSSDSMR.............. JBXFD0G03FSSDSR............... JBXFD0G03MCNDSMR.............. JBXFD0G03MCNDSR............... JBXFD0G03MCSDSMR.............. JBXFD0G03MCSDSR............... JBXFD0G03MSNDSMR.............. JBXFD0G03MSNDSR............... JBXFD0G03MSSDSMR.............. JBXFD0G03MSSDSR............... JBXFD0G04FCNDSMR.............. JBXFD0G04FCNDSR............... JBXFD0G04FCSDSMR.............. JBXFD0G04FCSDSR............... JBXFD0G04FSNDSMR.............. JBXFD0G04FSNDSR............... JBXFD0G04FSSDSMR.............. JBXFD0G04FSSDSR............... JBXFD0G04MCNDSMR.............. JBXFD0G04MCNDSR............... JBXFD0G04MCSDSMR.............. JBXFD0G04MCSDSR............... JBXFD0G04MSNDSMR.............. JBXFD0G04MSNDSR............... JBXFD0G04MSSDSMR.............. JBXFD0G04MSSDSR............... P.16 P.16 P.16 P.16 P.16 P.16 P.16 P.16 P.56 P.56 P.56 P.56 P.56 P.56 P.56 P.56 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 JBXFD0G05FCNDSMR.............. JBXFD0G05FCNDSR............... JBXFD0G05FCSDSMR.............. JBXFD0G05FCSDSR............... JBXFD0G05FSNDSMR.............. JBXFD0G05FSNDSR............... JBXFD0G05FSSDSMR.............. JBXFD0G05FSSDSR............... JBXFD0G05MCNDSMR.............. JBXFD0G05MCNDSR............... JBXFD0G05MCSDSMR.............. JBXFD0G05MCSDSR............... JBXFD0G05MSNDSMR.............. JBXFD0G05MSNDSR............... JBXFD0G05MSSDSMR.............. JBXFD0G05MSSDSR............... JBXFD0G06FSNDSMR.............. JBXFD0G06FSNDSR............... JBXFD0G06FSSDSMR.............. JBXFD0G06FSSDSR............... JBXFD0G06MSNDSMR.............. JBXFD0G06MSNDSR............... JBXFD0G06MSSDSMR.............. JBXFD0G06MSSDSR............... JBXFD0G07FSNDSMR.............. JBXFD0G07FSNDSR............... JBXFD0G07FSSDSMR.............. JBXFD0G07FSSDSR............... JBXFD0G07MSNDSMR.............. JBXFD0G07MSNDSR............... JBXFD0G07MSSDSMR.............. JBXFD0G07MSSDSR............... JBXFD0G08FSNDSMR.............. JBXFD0G08FSNDSR............... JBXFD0G08FSSDSMR.............. JBXFD0G08FSSDSR............... JBXFD0G08MSNDSMR.............. JBXFD0G08MSNDSR............... JBXFD0G08MSSDSMR.............. JBXFD0G08MSSDSR............... JBXFD1G02FCNDSMR.............. JBXFD1G02FCNDSR............... JBXFD1G02FCSDSMR.............. JBXFD1G02FCSDSR............... JBXFD1G02FSNDSMR.............. JBXFD1G02FSNDSR............... JBXFD1G02FSSDSMR.............. JBXFD1G02FSSDSR............... JBXFD1G02MCNDSMR.............. JBXFD1G02MCNDSR............... JBXFD1G02MCSDSMR.............. JBXFD1G02MCSDSR............... JBXFD1G02MSNDSMR.............. JBXFD1G02MSNDSR............... JBXFD1G02MSSDSMR.............. JBXFD1G02MSSDSR............... JBXFD1G03FCNDSMR.............. JBXFD1G03FCNDSR............... JBXFD1G03FCSDSMR.............. JBXFD1G03FCSDSR............... JBXFD1G03FSNDSMR.............. JBXFD1G03FSNDSR............... JBXFD1G03FSSDSMR.............. JBXFD1G03FSSDSR............... P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 279 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) JBXFD1G03MCNDSMR.............. JBXFD1G03MCNDSR............... JBXFD1G03MCSDSMR.............. JBXFD1G03MCSDSR............... JBXFD1G03MSNDSMR.............. JBXFD1G03MSNDSR............... JBXFD1G03MSSDSMR.............. JBXFD1G03MSSDSR............... JBXFD1G04FCNDSMR.............. JBXFD1G04FCNDSR............... JBXFD1G04FCSDSMR.............. JBXFD1G04FCSDSR............... JBXFD1G04FSNDSMR.............. JBXFD1G04FSNDSR............... JBXFD1G04FSSDSMR.............. JBXFD1G04FSSDSR............... JBXFD1G04MCNDSMR.............. JBXFD1G04MCNDSR............... JBXFD1G04MCSDSMR.............. JBXFD1G04MCSDSR............... JBXFD1G04MSNDSMR.............. JBXFD1G04MSNDSR............... JBXFD1G04MSSDSMR.............. JBXFD1G04MSSDSR............... JBXFD1G05FCNDSMR.............. JBXFD1G05FCNDSR............... JBXFD1G05FCSDSMR.............. JBXFD1G05FCSDSR............... JBXFD1G05FSNDSMR.............. JBXFD1G05FSNDSR............... JBXFD1G05FSSDSMR.............. JBXFD1G05FSSDSR............... JBXFD1G05MCNDSMR.............. JBXFD1G05MCNDSR............... JBXFD1G05MCSDSMR.............. JBXFD1G05MCSDSR............... JBXFD1G05MSNDSMR.............. JBXFD1G05MSNDSR............... JBXFD1G05MSSDSMR.............. JBXFD1G05MSSDSR............... JBXFD1G06FCNDSMR.............. JBXFD1G06FCNDSR............... JBXFD1G06FCSDSMR.............. JBXFD1G06FCSDSR............... JBXFD1G06FSNDSMR.............. JBXFD1G06FSNDSR............... JBXFD1G06FSSDSMR.............. JBXFD1G06FSSDSR............... JBXFD1G06MCNDSMR.............. JBXFD1G06MCNDSR............... JBXFD1G06MCSDSMR.............. JBXFD1G06MCSDSR............... JBXFD1G06MSNDSMR.............. JBXFD1G06MSNDSR............... JBXFD1G06MSSDSMR.............. JBXFD1G06MSSDSR............... JBXFD1G07FCNDSMR.............. JBXFD1G07FCNDSR............... JBXFD1G07FCSDSMR.............. JBXFD1G07FCSDSR............... JBXFD1G07FSNDSMR.............. JBXFD1G07FSNDSR............... JBXFD1G07FSSDSMR.............. JBXFD1G07FSSDSR............... 280 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 JBXFD1G07MCNDSMR.............. JBXFD1G07MCNDSR............... JBXFD1G07MCSDSMR.............. JBXFD1G07MCSDSR............... JBXFD1G07MSNDSMR.............. JBXFD1G07MSNDSR............... JBXFD1G07MSSDSMR.............. JBXFD1G07MSSDSR............... JBXFD1G08FCNDSMR.............. JBXFD1G08FCNDSR............... JBXFD1G08FCSDSMR.............. JBXFD1G08FCSDSR............... JBXFD1G08FSNDSMR.............. JBXFD1G08FSNDSR............... JBXFD1G08FSSDSMR.............. JBXFD1G08FSSDSR............... JBXFD1G08MCNDSMR.............. JBXFD1G08MCNDSR............... JBXFD1G08MCSDSMR.............. JBXFD1G08MCSDSR............... JBXFD1G08MSNDSMR.............. JBXFD1G08MSNDSR............... JBXFD1G08MSSDSMR.............. JBXFD1G08MSSDSR............... JBXFD1G10FSNDSMR.............. JBXFD1G10FSNDSR............... JBXFD1G10FSSDSMR.............. JBXFD1G10FSSDSR............... JBXFD1G10MSNDSMR.............. JBXFD1G10MSNDSR............... JBXFD1G10MSSDSMR.............. JBXFD1G10MSSDSR............... JBXFD1G12FSNDSMR.............. JBXFD1G12FSNDSR............... JBXFD1G12FSSDSMR.............. JBXFD1G12FSSDSR............... JBXFD1G12MSNDSMR.............. JBXFD1G12MSNDSR............... JBXFD1G12MSSDSMR.............. JBXFD1G12MSSDSR............... JBXFD2G001FSNDSMR............. JBXFD2G001FSNDSR.............. JBXFD2G001FSSDSMR............. JBXFD2G001FSSDSR.............. JBXFD2G001MSNDSMR............. JBXFD2G001MSNDSR.............. JBXFD2G001MSSDSMR............. JBXFD2G001MSSDSR.............. JBXFD2G002FSNDSMR............. JBXFD2G002FSNDSR.............. JBXFD2G002FSSDSMR............. JBXFD2G002FSSDSR.............. JBXFD2G002MSNDSMR............. JBXFD2G002MSNDSR.............. JBXFD2G002MSSDSMR............. JBXFD2G002MSSDSR.............. JBXFD2G003FSNDSMR............. JBXFD2G003FSNDSR.............. JBXFD2G003FSSDSMR............. JBXFD2G003FSSDSR.............. JBXFD2G003MSNDSMR............. JBXFD2G003MSNDSR.............. JBXFD2G003MSSDSMR............. JBXFD2G003MSSDSR.............. P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.164 P.164 P.164 P.164 P.164 P.164 P.164 P.164 P.184 P.184 P.184 P.184 P.184 P.184 P.184 P.184 P.148 P.148 P.148 P.148 P.148 P.148 P.148 P.148 P.158 P.158 P.158 P.158 P.158 P.158 P.158 P.158 P.174 P.174 P.174 P.174 P.174 P.174 P.174 P.174 JBXFD2G02FCNDSMR.............. JBXFD2G02FCNDSR............... JBXFD2G02FCSDSMR.............. JBXFD2G02FCSDSR............... JBXFD2G02FSNDSMR.............. JBXFD2G02FSNDSR............... JBXFD2G02FSSDSMR.............. JBXFD2G02FSSDSR............... JBXFD2G02MCNDSMR.............. JBXFD2G02MCNDSR............... JBXFD2G02MCSDSMR.............. JBXFD2G02MCSDSR............... JBXFD2G02MSNDSMR.............. JBXFD2G02MSNDSR............... JBXFD2G02MSSDSMR.............. JBXFD2G02MSSDSR............... JBXFD2G03FCNDSMR.............. JBXFD2G03FCNDSR............... JBXFD2G03FCSDSMR.............. JBXFD2G03FCSDSR............... JBXFD2G03FSNDSMR.............. JBXFD2G03FSNDSR............... JBXFD2G03FSSDSMR.............. JBXFD2G03FSSDSR............... JBXFD2G03MCNDSMR.............. JBXFD2G03MCNDSR............... JBXFD2G03MCSDSMR.............. JBXFD2G03MCSDSR............... JBXFD2G03MSNDSMR.............. JBXFD2G03MSNDSR............... JBXFD2G03MSSDSMR.............. JBXFD2G03MSSDSR............... JBXFD2G04FCNDSMR.............. JBXFD2G04FCNDSR............... JBXFD2G04FCSDSMR.............. JBXFD2G04FCSDSR............... JBXFD2G04FSNDSMR.............. JBXFD2G04FSNDSR............... JBXFD2G04FSSDSMR.............. JBXFD2G04FSSDSR............... JBXFD2G04MCNDSMR.............. JBXFD2G04MCNDSR............... JBXFD2G04MCSDSMR.............. JBXFD2G04MCSDSR............... JBXFD2G04MSNDSMR.............. JBXFD2G04MSNDSR............... JBXFD2G04MSSDSMR.............. JBXFD2G04MSSDSR............... JBXFD2G05FCNDSMR.............. JBXFD2G05FCNDSR............... JBXFD2G05FCSDSMR.............. JBXFD2G05FCSDSR............... JBXFD2G05FSNDSMR.............. JBXFD2G05FSNDSR............... JBXFD2G05FSSDSMR.............. JBXFD2G05FSSDSR............... JBXFD2G05MCNDSMR.............. JBXFD2G05MCNDSR............... JBXFD2G05MCSDSMR.............. JBXFD2G05MCSDSR............... JBXFD2G05MSNDSMR.............. JBXFD2G05MSNDSR............... JBXFD2G05MSSDSMR.............. JBXFD2G05MSSDSR............... P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 JBXFD2G06FCNDSMR.............. JBXFD2G06FCNDSR............... JBXFD2G06FCSDSMR.............. JBXFD2G06FCSDSR............... JBXFD2G06FSNDSMR.............. JBXFD2G06FSNDSR............... JBXFD2G06FSSDSMR.............. JBXFD2G06FSSDSR............... JBXFD2G06MCNDSMR.............. JBXFD2G06MCNDSR............... JBXFD2G06MCSDSMR.............. JBXFD2G06MCSDSR............... JBXFD2G06MSNDSMR.............. JBXFD2G06MSNDSR............... JBXFD2G06MSSDSMR.............. JBXFD2G06MSSDSR............... JBXFD2G07FCNDSMR.............. JBXFD2G07FCNDSR............... JBXFD2G07FCSDSMR.............. JBXFD2G07FCSDSR............... JBXFD2G07FSNDSMR.............. JBXFD2G07FSNDSR............... JBXFD2G07FSSDSMR.............. JBXFD2G07FSSDSR............... JBXFD2G07MCNDSMR.............. JBXFD2G07MCNDSR............... JBXFD2G07MCSDSMR.............. JBXFD2G07MCSDSR............... JBXFD2G07MSNDSMR.............. JBXFD2G07MSNDSR............... JBXFD2G07MSSDSMR.............. JBXFD2G07MSSDSR............... JBXFD2G08FCNDSMR.............. JBXFD2G08FCNDSR............... JBXFD2G08FCSDSMR.............. JBXFD2G08FCSDSR............... JBXFD2G08FSNDSMR.............. JBXFD2G08FSNDSR............... JBXFD2G08FSSDSMR.............. JBXFD2G08FSSDSR............... JBXFD2G08MCNDSMR.............. JBXFD2G08MCNDSR............... JBXFD2G08MCSDSMR.............. JBXFD2G08MCSDSR............... JBXFD2G08MSNDSMR.............. JBXFD2G08MSNDSR............... JBXFD2G08MSSDSMR.............. JBXFD2G08MSSDSR............... JBXFD2G10FCNDSMR.............. JBXFD2G10FCNDSR............... JBXFD2G10FCSDSMR.............. JBXFD2G10FCSDSR............... JBXFD2G10FSNDSMR.............. JBXFD2G10FSNDSR............... JBXFD2G10FSSDSMR.............. JBXFD2G10FSSDSR............... JBXFD2G10MCNDSMR.............. JBXFD2G10MCNDSR............... JBXFD2G10MCSDSMR.............. JBXFD2G10MCSDSR............... JBXFD2G10MSNDSMR.............. JBXFD2G10MSNDSR............... JBXFD2G10MSSDSMR.............. JBXFD2G10MSSDSR............... P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 JBXFD2G12FCNDSMR.............. JBXFD2G12FCNDSR............... JBXFD2G12FCSDSMR.............. JBXFD2G12FCSDSR............... JBXFD2G12FSNDSMR.............. JBXFD2G12FSNDSR............... JBXFD2G12FSSDSMR.............. JBXFD2G12FSSDSR............... JBXFD2G12MCNDSMR.............. JBXFD2G12MCNDSR............... JBXFD2G12MCSDSMR.............. JBXFD2G12MCSDSR............... JBXFD2G12MSNDSMR.............. JBXFD2G12MSNDSR............... JBXFD2G12MSSDSMR.............. JBXFD2G12MSSDSR............... JBXFD2G16FCNDSMR.............. JBXFD2G16FCNDSR............... JBXFD2G16FCSDSMR.............. JBXFD2G16FCSDSR............... JBXFD2G16FSNDSMR.............. JBXFD2G16FSNDSR............... JBXFD2G16FSSDSMR.............. JBXFD2G16FSSDSR............... JBXFD2G16MCNDSMR.............. JBXFD2G16MCNDSR............... JBXFD2G16MCSDSMR.............. JBXFD2G16MCSDSR............... JBXFD2G16MSNDSMR.............. JBXFD2G16MSNDSR............... JBXFD2G16MSSDSMR.............. JBXFD2G16MSSDSR............... JBXFD2G18FCNDSMR.............. JBXFD2G18FCNDSR............... JBXFD2G18FCSDSMR.............. JBXFD2G18FCSDSR............... JBXFD2G18FSNDSMR.............. JBXFD2G18FSNDSR............... JBXFD2G18FSSDSMR.............. JBXFD2G18FSSDSR............... JBXFD2G18MCNDSMR.............. JBXFD2G18MCNDSR............... JBXFD2G18MCSDSMR.............. JBXFD2G18MCSDSR............... JBXFD2G18MSNDSMR.............. JBXFD2G18MSNDSR............... JBXFD2G18MSSDSMR.............. JBXFD2G18MSSDSR............... JBXFD2G19FCNDSMR.............. JBXFD2G19FCNDSR............... JBXFD2G19FCSDSMR.............. JBXFD2G19FCSDSR............... JBXFD2G19FSNDSMR.............. JBXFD2G19FSNDSR............... JBXFD2G19FSSDSMR.............. JBXFD2G19FSSDSR............... JBXFD2G19MCNDSMR.............. JBXFD2G19MCNDSR............... JBXFD2G19MCSDSMR.............. JBXFD2G19MCSDSR............... JBXFD2G19MSNDSMR.............. JBXFD2G19MSNDSR............... JBXFD2G19MSSDSMR.............. JBXFD2G19MSSDSR............... P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 JBXFD3G03FCNDSMR.............. JBXFD3G03FCNDSR............... JBXFD3G03FCSDSMR.............. JBXFD3G03FCSDSR............... JBXFD3G03FSNDSMR.............. JBXFD3G03FSNDSR............... JBXFD3G03FSSDSMR.............. JBXFD3G03FSSDSR............... JBXFD3G03MCNDSMR.............. JBXFD3G03MCNDSR............... JBXFD3G03MCSDSMR.............. JBXFD3G03MCSDSR............... JBXFD3G03MSNDSMR.............. JBXFD3G03MSNDSR............... JBXFD3G03MSSDSMR.............. JBXFD3G03MSSDSR............... JBXFD3G04FCNDSMR.............. JBXFD3G04FCNDSR............... JBXFD3G04FCSDSMR.............. JBXFD3G04FCSDSR............... JBXFD3G04FSNDSMR.............. JBXFD3G04FSNDSR............... JBXFD3G04FSSDSMR.............. JBXFD3G04FSSDSR............... JBXFD3G04MCNDSMR.............. JBXFD3G04MCNDSR............... JBXFD3G04MCSDSMR.............. JBXFD3G04MCSDSR............... JBXFD3G04MSNDSMR.............. JBXFD3G04MSNDSR............... JBXFD3G04MSSDSMR.............. JBXFD3G04MSSDSR............... JBXFD3G07FCNDSMR.............. JBXFD3G07FCNDSR............... JBXFD3G07FCSDSMR.............. JBXFD3G07FCSDSR............... JBXFD3G07FSNDSMR.............. JBXFD3G07FSNDSR............... JBXFD3G07FSSDSMR.............. JBXFD3G07FSSDSR............... JBXFD3G07MCNDSMR.............. JBXFD3G07MCNDSR............... JBXFD3G07MCSDSMR.............. JBXFD3G07MCSDSR............... JBXFD3G07MSNDSMR.............. JBXFD3G07MSNDSR............... JBXFD3G07MSSDSMR.............. JBXFD3G07MSSDSR............... JBXFD3G08FCNDSMR.............. JBXFD3G08FCNDSR............... JBXFD3G08FCSDSMR.............. JBXFD3G08FCSDSR............... JBXFD3G08FSNDSMR.............. JBXFD3G08FSNDSR............... JBXFD3G08FSSDSMR.............. JBXFD3G08FSSDSR............... JBXFD3G08MCNDSMR.............. JBXFD3G08MCNDSR............... JBXFD3G08MCSDSMR.............. JBXFD3G08MCSDSR............... JBXFD3G08MSNDSMR.............. JBXFD3G08MSNDSR............... JBXFD3G08MSSDSMR.............. JBXFD3G08MSSDSR............... P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 281 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) JBXFD3G10FCNDSMR.............. JBXFD3G10FCNDSR............... JBXFD3G10FCSDSMR.............. JBXFD3G10FCSDSR............... JBXFD3G10FSNDSMR.............. JBXFD3G10FSNDSR............... JBXFD3G10FSSDSMR.............. JBXFD3G10FSSDSR............... JBXFD3G10MCNDSMR.............. JBXFD3G10MCNDSR............... JBXFD3G10MCSDSMR.............. JBXFD3G10MCSDSR............... JBXFD3G10MSNDSMR.............. JBXFD3G10MSNDSR............... JBXFD3G10MSSDSMR.............. JBXFD3G10MSSDSR............... JBXFD3G14FCNDSMR.............. JBXFD3G14FCNDSR............... JBXFD3G14FCSDSMR.............. JBXFD3G14FCSDSR............... JBXFD3G14FSNDSMR.............. JBXFD3G14FSNDSR............... JBXFD3G14FSSDSMR.............. JBXFD3G14FSSDSR............... JBXFD3G14MCNDSMR.............. JBXFD3G14MCNDSR............... JBXFD3G14MCSDSMR.............. JBXFD3G14MCSDSR............... JBXFD3G14MSNDSMR.............. JBXFD3G14MSNDSR............... JBXFD3G14MSSDSMR.............. JBXFD3G14MSSDSR............... JBXFD3G18FCNDSMR.............. JBXFD3G18FCNDSR............... JBXFD3G18FCSDSMR.............. JBXFD3G18FCSDSR............... JBXFD3G18FSNDSMR.............. JBXFD3G18FSNDSR............... JBXFD3G18FSSDSMR.............. JBXFD3G18FSSDSR............... JBXFD3G18MCNDSMR.............. JBXFD3G18MCNDSR............... JBXFD3G18MCSDSMR.............. JBXFD3G18MCSDSR............... JBXFD3G18MSNDSMR.............. JBXFD3G18MSNDSR............... JBXFD3G18MSSDSMR.............. JBXFD3G18MSSDSR............... JBXFD3G22FCNDSMR.............. JBXFD3G22FCNDSR............... JBXFD3G22FCSDSMR.............. JBXFD3G22FCSDSR............... JBXFD3G22FSNDSMR.............. JBXFD3G22FSNDSR............... JBXFD3G22FSSDSMR.............. JBXFD3G22FSSDSR............... JBXFD3G22MCNDSMR.............. JBXFD3G22MCNDSR............... JBXFD3G22MCSDSMR.............. JBXFD3G22MCSDSR............... JBXFD3G22MSNDSMR.............. JBXFD3G22MSNDSR............... JBXFD3G22MSSDSMR.............. JBXFD3G22MSSDSR............... 282 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 JBXFD3G30FCNDSMR.............. JBXFD3G30FCNDSR............... JBXFD3G30FCSDSMR.............. JBXFD3G30FCSDSR............... JBXFD3G30FSNDSMR.............. JBXFD3G30FSNDSR............... JBXFD3G30FSSDSMR.............. JBXFD3G30FSSDSR............... JBXFD3G30MCNDSMR.............. JBXFD3G30MCNDSR............... JBXFD3G30MCSDSMR.............. JBXFD3G30MCSDSR............... JBXFD3G30MSNDSMR.............. JBXFD3G30MSNDSR............... JBXFD3G30MSSDSMR.............. JBXFD3G30MSSDSR............... JBXFF1G02FSNDSMR.............. JBXFF1G02FSNDSR............... JBXFF1G02FSSDSMR.............. JBXFF1G02FSSDSR............... JBXFF1G02MSNDSMR.............. JBXFF1G02MSNDSR............... JBXFF1G02MSSDSMR.............. JBXFF1G02MSSDSR............... JBXFF1G03FSNDSMR.............. JBXFF1G03FSNDSR............... JBXFF1G03FSSDSMR.............. JBXFF1G03FSSDSR............... JBXFF1G03MSNDSMR.............. JBXFF1G03MSNDSR............... JBXFF1G03MSSDSMR.............. JBXFF1G03MSSDSR............... JBXFF1G04FSNDSMR.............. JBXFF1G04FSNDSR............... JBXFF1G04FSSDSMR.............. JBXFF1G04FSSDSR............... JBXFF1G04MSNDSMR.............. JBXFF1G04MSNDSR............... JBXFF1G04MSSDSMR.............. JBXFF1G04MSSDSR............... JBXFF1G05FSNDSMR.............. JBXFF1G05FSNDSR............... JBXFF1G05FSSDSMR.............. JBXFF1G05FSSDSR............... JBXFF1G05MSNDSMR.............. JBXFF1G05MSNDSR............... JBXFF1G05MSSDSMR.............. JBXFF1G05MSSDSR............... JBXFF1G06FSNDSMR.............. JBXFF1G06FSNDSR............... JBXFF1G06FSSDSMR.............. JBXFF1G06FSSDSR............... JBXFF1G06MSNDSMR.............. JBXFF1G06MSNDSR............... JBXFF1G06MSSDSMR.............. JBXFF1G06MSSDSR............... JBXFF1G07FSNDSMR.............. JBXFF1G07FSNDSR............... JBXFF1G07FSSDSMR.............. JBXFF1G07FSSDSR............... JBXFF1G07MSNDSMR.............. JBXFF1G07MSNDSR............... JBXFF1G07MSSDSMR.............. JBXFF1G07MSSDSR............... P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 JBXFF1G08FSNDSMR.............. JBXFF1G08FSNDSR............... JBXFF1G08FSSDSMR.............. JBXFF1G08FSSDSR............... JBXFF1G08MSNDSMR.............. JBXFF1G08MSNDSR............... JBXFF1G08MSSDSMR.............. JBXFF1G08MSSDSR............... JBXFF1G10FSNDSMR.............. JBXFF1G10FSNDSR............... JBXFF1G10FSSDSMR.............. JBXFF1G10FSSDSR............... JBXFF1G10MSNDSMR.............. JBXFF1G10MSNDSR............... JBXFF1G10MSSDSMR.............. JBXFF1G10MSSDSR............... JBXFF1G12FSNDSMR.............. JBXFF1G12FSNDSR............... JBXFF1G12FSSDSMR.............. JBXFF1G12FSSDSR............... JBXFF1G12MSNDSMR.............. JBXFF1G12MSNDSR............... JBXFF1G12MSSDSMR.............. JBXFF1G12MSSDSR............... JBXFG00G02FSNDSMR............. JBXFG00G02FSNDSR.............. JBXFG00G02FSSDSMR............. JBXFG00G02FSSDSR.............. JBXFG00G02MSNDSMR............. JBXFG00G02MSNDSR.............. JBXFG00G02MSSDSMR............. JBXFG00G02MSSDSR.............. JBXFG00G04FSNDSMR............. JBXFG00G04FSNDSR.............. JBXFG00G04FSSDSMR............. JBXFG00G04FSSDSR.............. JBXFG00G04MSNDSMR............. JBXFG00G04MSNDSR.............. JBXFG00G04MSSDSMR............. JBXFG00G04MSSDSR.............. JBXFH0G02FCNDSMR.............. JBXFH0G02FCNDSR............... JBXFH0G02FCSDSMR.............. JBXFH0G02FCSDSR............... JBXFH0G02FSNDSMR.............. JBXFH0G02FSNDSR............... JBXFH0G02FSSDSMR.............. JBXFH0G02FSSDSR............... JBXFH0G02MCNDSMR.............. JBXFH0G02MCNDSR............... JBXFH0G02MCSDSMR.............. JBXFH0G02MCSDSR............... JBXFH0G02MSNDSMR.............. JBXFH0G02MSNDSR............... JBXFH0G02MSSDSMR.............. JBXFH0G02MSSDSR............... JBXFH0G03FCNDSMR.............. JBXFH0G03FCNDSR............... JBXFH0G03FCSDSMR.............. JBXFH0G03FCSDSR............... JBXFH0G03FSNDSMR.............. JBXFH0G03FSNDSR............... JBXFH0G03FSSDSMR.............. JBXFH0G03FSSDSR............... P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.164 P.164 P.164 P.164 P.164 P.164 P.164 P.164 P.184 P.184 P.184 P.184 P.184 P.184 P.184 P.184 P.16 P.16 P.16 P.16 P.16 P.16 P.16 P.16 P.56 P.56 P.56 P.56 P.56 P.56 P.56 P.56 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.38 P.38 P.38 P.38 P.38 P.38 P.38 P.38 JBXFH0G03MCNDSMR.............. JBXFH0G03MCNDSR............... JBXFH0G03MCSDSMR.............. JBXFH0G03MCSDSR............... JBXFH0G03MSNDSMR.............. JBXFH0G03MSNDSR............... JBXFH0G03MSSDSMR.............. JBXFH0G03MSSDSR............... JBXFH0G04FCNDSMR.............. JBXFH0G04FCNDSR............... JBXFH0G04FCSDSMR.............. JBXFH0G04FCSDSR............... JBXFH0G04FSNDSMR.............. JBXFH0G04FSNDSR............... JBXFH0G04FSSDSMR.............. JBXFH0G04FSSDSR............... JBXFH0G04MCNDSMR.............. JBXFH0G04MCNDSR............... JBXFH0G04MCSDSMR.............. JBXFH0G04MCSDSR............... JBXFH0G04MSNDSMR.............. JBXFH0G04MSNDSR............... JBXFH0G04MSSDSMR.............. JBXFH0G04MSSDSR............... JBXFH0G05FCNDSMR.............. JBXFH0G05FCNDSR............... JBXFH0G05FCSDSMR.............. JBXFH0G05FCSDSR............... JBXFH0G05FSNDSMR.............. JBXFH0G05FSNDSR............... JBXFH0G05FSSDSMR.............. JBXFH0G05FSSDSR............... JBXFH0G05MCNDSMR.............. JBXFH0G05MCNDSR............... JBXFH0G05MCSDSMR.............. JBXFH0G05MCSDSR............... JBXFH0G05MSNDSMR.............. JBXFH0G05MSNDSR............... JBXFH0G05MSSDSMR.............. JBXFH0G05MSSDSR............... JBXFH0G06FSNDSMR.............. JBXFH0G06FSNDSR............... JBXFH0G06FSSDSMR.............. JBXFH0G06FSSDSR............... JBXFH0G06MSNDSMR.............. JBXFH0G06MSNDSR............... JBXFH0G06MSSDSMR.............. JBXFH0G06MSSDSR............... JBXFH0G07FSNDSMR.............. JBXFH0G07FSNDSR............... JBXFH0G07FSSDSMR.............. JBXFH0G07FSSDSR............... JBXFH0G07MSNDSMR.............. JBXFH0G07MSNDSR............... JBXFH0G07MSSDSMR.............. JBXFH0G07MSSDSR............... JBXFH0G08FSNDSMR.............. JBXFH0G08FSNDSR............... JBXFH0G08FSSDSMR.............. JBXFH0G08FSSDSR............... JBXFH0G08MSNDSMR.............. JBXFH0G08MSNDSR............... JBXFH0G08MSSDSMR.............. JBXFH0G08MSSDSR............... P.38 P.38 P.38 P.38 P.38 P.38 P.38 P.38 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.98 P.98 P.98 P.98 P.98 P.98 P.98 P.98 P.114 P.114 P.114 P.114 P.114 P.114 P.114 P.114 P.134 P.134 P.134 P.134 P.134 P.134 P.134 P.134 JBXFH2G001FSNDSMR............. JBXFH2G001FSNDSR.............. JBXFH2G001FSSDSMR............. JBXFH2G001FSSDSR.............. JBXFH2G001MSNDSMR............. JBXFH2G001MSNDSR.............. JBXFH2G001MSSDSMR............. JBXFH2G001MSSDSR.............. JBXFH2G002FSNDSMR............. JBXFH2G002FSNDSR.............. JBXFH2G002FSSDSMR............. JBXFH2G002FSSDSR.............. JBXFH2G002MSNDSMR............. JBXFH2G002MSNDSR.............. JBXFH2G002MSSDSMR............. JBXFH2G002MSSDSR.............. JBXFH2G003FSNDSMR............. JBXFH2G003FSNDSR.............. JBXFH2G003FSSDSMR............. JBXFH2G003FSSDSR.............. JBXFH2G003MSNDSMR............. JBXFH2G003MSNDSR.............. JBXFH2G003MSSDSMR............. JBXFH2G003MSSDSR.............. JBXFH2G02FCNDSMR.............. JBXFH2G02FCNDSR............... JBXFH2G02FCSDSMR.............. JBXFH2G02FCSDSR............... JBXFH2G02FSNDSMR.............. JBXFH2G02FSNDSR............... JBXFH2G02FSSDSMR.............. JBXFH2G02FSSDSR............... JBXFH2G02MCNDSMR.............. JBXFH2G02MCNDSR............... JBXFH2G02MCSDSMR.............. JBXFH2G02MCSDSR............... JBXFH2G02MSNDSMR.............. JBXFH2G02MSNDSR............... JBXFH2G02MSSDSMR.............. JBXFH2G02MSSDSR............... JBXFH2G03FCNDSMR.............. JBXFH2G03FCNDSR............... JBXFH2G03FCSDSMR.............. JBXFH2G03FCSDSR............... JBXFH2G03FSNDSMR.............. JBXFH2G03FSNDSR............... JBXFH2G03FSSDSMR.............. JBXFH2G03FSSDSR............... JBXFH2G03MCNDSMR.............. JBXFH2G03MCNDSR............... JBXFH2G03MCSDSMR.............. JBXFH2G03MCSDSR............... JBXFH2G03MSNDSMR.............. JBXFH2G03MSNDSR............... JBXFH2G03MSSDSMR.............. JBXFH2G03MSSDSR............... JBXFH2G04FCNDSMR.............. JBXFH2G04FCNDSR............... JBXFH2G04FCSDSMR.............. JBXFH2G04FCSDSR............... JBXFH2G04FSNDSMR.............. JBXFH2G04FSNDSR............... JBXFH2G04FSSDSMR.............. JBXFH2G04FSSDSR............... P.150 P.150 P.150 P.150 P.150 P.150 P.150 P.150 P.160 P.160 P.160 P.160 P.160 P.160 P.160 P.160 P.176 P.176 P.176 P.176 P.176 P.176 P.176 P.176 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.72 P.72 P.72 P.72 P.72 P.72 P.72 P.72 JBXFH2G04MCNDSMR.............. JBXFH2G04MCNDSR............... JBXFH2G04MCSDSMR.............. JBXFH2G04MCSDSR............... JBXFH2G04MSNDSMR.............. JBXFH2G04MSNDSR............... JBXFH2G04MSSDSMR.............. JBXFH2G04MSSDSR............... JBXFH2G05FCNDSMR.............. JBXFH2G05FCNDSR............... JBXFH2G05FCSDSMR.............. JBXFH2G05FCSDSR............... JBXFH2G05FSNDSMR.............. JBXFH2G05FSNDSR............... JBXFH2G05FSSDSMR.............. JBXFH2G05FSSDSR............... JBXFH2G05MCNDSMR.............. JBXFH2G05MCNDSR............... JBXFH2G05MCSDSMR.............. JBXFH2G05MCSDSR............... JBXFH2G05MSNDSMR.............. JBXFH2G05MSNDSR............... JBXFH2G05MSSDSMR.............. JBXFH2G05MSSDSR............... JBXFH2G06FCNDSMR.............. JBXFH2G06FCNDSR............... JBXFH2G06FCSDSMR.............. JBXFH2G06FCSDSR............... JBXFH2G06FSNDSMR.............. JBXFH2G06FSNDSR............... JBXFH2G06FSSDSMR.............. JBXFH2G06FSSDSR............... JBXFH2G06MCNDSMR.............. JBXFH2G06MCNDSR............... JBXFH2G06MCSDSMR.............. JBXFH2G06MCSDSR............... JBXFH2G06MSNDSMR.............. JBXFH2G06MSNDSR............... JBXFH2G06MSSDSMR.............. JBXFH2G06MSSDSR............... JBXFH2G07FCNDSMR.............. JBXFH2G07FCNDSR............... JBXFH2G07FCSDSMR.............. JBXFH2G07FCSDSR............... JBXFH2G07FSNDSMR.............. JBXFH2G07FSNDSR............... JBXFH2G07FSSDSMR.............. JBXFH2G07FSSDSR............... JBXFH2G07MCNDSMR.............. JBXFH2G07MCNDSR............... JBXFH2G07MCSDSMR.............. JBXFH2G07MCSDSR............... JBXFH2G07MSNDSMR.............. JBXFH2G07MSNDSR............... JBXFH2G07MSSDSMR.............. JBXFH2G07MSSDSR............... JBXFH2G08FCNDSMR.............. JBXFH2G08FCNDSR............... JBXFH2G08FCSDSMR.............. JBXFH2G08FCSDSR............... JBXFH2G08FSNDSMR.............. JBXFH2G08FSNDSR............... JBXFH2G08FSSDSMR.............. JBXFH2G08FSSDSR............... P.72 P.72 P.72 P.72 P.72 P.72 P.72 P.72 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.144 283 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) JBXFH2G08MCNDSMR.............. JBXFH2G08MCNDSR............... JBXFH2G08MCSDSMR.............. JBXFH2G08MCSDSR............... JBXFH2G08MSNDSMR.............. JBXFH2G08MSNDSR............... JBXFH2G08MSSDSMR.............. JBXFH2G08MSSDSR............... JBXFH2G10FCNDSMR.............. JBXFH2G10FCNDSR............... JBXFH2G10FCSDSMR.............. JBXFH2G10FCSDSR............... JBXFH2G10FSNDSMR.............. JBXFH2G10FSNDSR............... JBXFH2G10FSSDSMR.............. JBXFH2G10FSSDSR............... JBXFH2G10MCNDSMR.............. JBXFH2G10MCNDSR............... JBXFH2G10MCSDSMR.............. JBXFH2G10MCSDSR............... JBXFH2G10MSNDSMR.............. JBXFH2G10MSNDSR............... JBXFH2G10MSSDSMR.............. JBXFH2G10MSSDSR............... JBXFH2G12FCNDSMR.............. JBXFH2G12FCNDSR............... JBXFH2G12FCSDSMR.............. JBXFH2G12FCSDSR............... JBXFH2G12FSNDSMR.............. JBXFH2G12FSNDSR............... JBXFH2G12FSSDSMR.............. JBXFH2G12FSSDSR............... JBXFH2G12MCNDSMR.............. JBXFH2G12MCNDSR............... JBXFH2G12MCSDSMR.............. JBXFH2G12MCSDSR............... JBXFH2G12MSNDSMR.............. JBXFH2G12MSNDSR............... JBXFH2G12MSSDSMR.............. JBXFH2G12MSSDSR............... JBXFH2G16FCNDSMR.............. JBXFH2G16FCNDSR............... JBXFH2G16FCSDSMR.............. JBXFH2G16FCSDSR............... JBXFH2G16FSNDSMR.............. JBXFH2G16FSNDSR............... JBXFH2G16FSSDSMR.............. JBXFH2G16FSSDSR............... JBXFH2G16MCNDSMR.............. JBXFH2G16MCNDSR............... JBXFH2G16MCSDSMR.............. JBXFH2G16MCSDSR............... JBXFH2G16MSNDSMR.............. JBXFH2G16MSNDSR............... JBXFH2G16MSSDSMR.............. JBXFH2G16MSSDSR............... JBXFH2G18FCNDSMR.............. JBXFH2G18FCNDSR............... JBXFH2G18FCSDSMR.............. JBXFH2G18FCSDSR............... JBXFH2G18FSNDSMR.............. JBXFH2G18FSNDSR............... JBXFH2G18FSSDSMR.............. JBXFH2G18FSSDSR............... 284 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.206 JBXFH2G18MCNDSMR.............. JBXFH2G18MCNDSR............... JBXFH2G18MCSDSMR.............. JBXFH2G18MCSDSR............... JBXFH2G18MSNDSMR.............. JBXFH2G18MSNDSR............... JBXFH2G18MSSDSMR.............. JBXFH2G18MSSDSR............... JBXFH2G19FCNDSMR.............. JBXFH2G19FCNDSR............... JBXFH2G19FCSDSMR.............. JBXFH2G19FCSDSR............... JBXFH2G19FSNDSMR.............. JBXFH2G19FSNDSR............... JBXFH2G19FSSDSMR.............. JBXFH2G19FSSDSR............... JBXFH2G19MCNDSMR.............. JBXFH2G19MCNDSR............... JBXFH2G19MCSDSMR.............. JBXFH2G19MCSDSR............... JBXFH2G19MSNDSMR.............. JBXFH2G19MSNDSR............... JBXFH2G19MSSDSMR.............. JBXFH2G19MSSDSR............... JBXFM0G02FSNDSMR.............. JBXFM0G02FSNDSR............... JBXFM0G02FSSDSMR.............. JBXFM0G02FSSDSR............... JBXFM0G02MSNDSMR.............. JBXFM0G02MSNDSR............... JBXFM0G02MSSDSMR.............. JBXFM0G02MSSDSR............... JBXFM0G03FSNDSMR.............. JBXFM0G03FSNDSR............... JBXFM0G03FSSDSMR.............. JBXFM0G03FSSDSR............... JBXFM0G03MSNDSMR.............. JBXFM0G03MSNDSR............... JBXFM0G03MSSDSMR.............. JBXFM0G03MSSDSR............... JBXFM0G04FSNDSMR.............. JBXFM0G04FSNDSR............... JBXFM0G04FSSDSMR.............. JBXFM0G04FSSDSR............... JBXFM0G04MSNDSMR.............. JBXFM0G04MSNDSR............... JBXFM0G04MSSDSMR.............. JBXFM0G04MSSDSR............... JBXFM0G05FSNDSMR.............. JBXFM0G05FSNDSR............... JBXFM0G05FSSDSMR.............. JBXFM0G05FSSDSR............... JBXFM0G05MSNDSMR.............. JBXFM0G05MSNDSR............... JBXFM0G05MSSDSMR.............. JBXFM0G05MSSDSR............... JBXFM0G06FSNDSMR.............. JBXFM0G06FSNDSR............... JBXFM0G06FSSDSMR.............. JBXFM0G06FSSDSR............... JBXFM0G06MSNDSMR.............. JBXFM0G06MSNDSR............... JBXFM0G06MSSDSMR.............. JBXFM0G06MSSDSR............... P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.96 JBXFM0G07FSNDSMR.............. JBXFM0G07FSNDSR............... JBXFM0G07FSSDSMR.............. JBXFM0G07FSSDSR............... JBXFM0G07MSNDSMR.............. JBXFM0G07MSNDSR............... JBXFM0G07MSSDSMR.............. JBXFM0G07MSSDSR............... JBXFM0G08FSNDSMR.............. JBXFM0G08FSNDSR............... JBXFM0G08FSSDSMR.............. JBXFM0G08FSSDSR............... JBXFM0G08MSNDSMR.............. JBXFM0G08MSNDSR............... JBXFM0G08MSSDSMR.............. JBXFM0G08MSSDSR............... JBXFN0G02FSNDSMR.............. JBXFN0G02FSNDSR............... JBXFN0G02FSSDSMR.............. JBXFN0G02FSSDSR............... JBXFN0G02MSNDSMR.............. JBXFN0G02MSNDSR............... JBXFN0G02MSSDSMR.............. JBXFN0G02MSSDSR............... JBXFN0G03FSNDSMR.............. JBXFN0G03FSNDSR............... JBXFN0G03FSSDSMR.............. JBXFN0G03FSSDSR............... JBXFN0G03MSNDSMR.............. JBXFN0G03MSNDSR............... JBXFN0G03MSSDSMR.............. JBXFN0G03MSSDSR............... JBXFN0G04FSNDSMR.............. JBXFN0G04FSNDSR............... JBXFN0G04FSSDSMR.............. JBXFN0G04FSSDSR............... JBXFN0G04MSNDSMR.............. JBXFN0G04MSNDSR............... JBXFN0G04MSSDSMR.............. JBXFN0G04MSSDSR............... JBXFN0G05FSNDSMR.............. JBXFN0G05FSNDSR............... JBXFN0G05FSSDSMR.............. JBXFN0G05FSSDSR............... JBXFN0G05MSNDSMR.............. JBXFN0G05MSNDSR............... JBXFN0G05MSSDSMR.............. JBXFN0G05MSSDSR............... JBXFN0G06FSNDSMR.............. JBXFN0G06FSNDSR............... JBXFN0G06FSSDSMR.............. JBXFN0G06FSSDSR............... JBXFN0G06MSNDSMR.............. JBXFN0G06MSNDSR............... JBXFN0G06MSSDSMR.............. JBXFN0G06MSSDSR............... JBXFN0G07FSNDSMR.............. JBXFN0G07FSNDSR............... JBXFN0G07FSSDSMR.............. JBXFN0G07FSSDSR............... JBXFN0G07MSNDSMR.............. JBXFN0G07MSNDSR............... JBXFN0G07MSSDSMR.............. JBXFN0G07MSSDSR............... P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.112 JBXFN0G08FSNDSMR.............. JBXFN0G08FSNDSR............... JBXFN0G08FSSDSMR.............. JBXFN0G08FSSDSR............... JBXFN0G08MSNDSMR.............. JBXFN0G08MSNDSR............... JBXFN0G08MSSDSMR.............. JBXFN0G08MSSDSR............... JBXHC0G02FPNDSR............... JBXHC0G02FPSDSR............... JBXHC0G02FSNDSR............... JBXHC0G02FSSDSR............... JBXHC0G02MSNDSR............... JBXHC0G02MSSDSR............... JBXHC0G03FPNDSR............... JBXHC0G03FPSDSR............... JBXHC0G03FSNDSR............... JBXHC0G03FSSDSR............... JBXHC0G03MSNDSR............... JBXHC0G03MSSDSR............... JBXHC0G04FPNDSR............... JBXHC0G04FPSDSR............... JBXHC0G04FSNDSR............... JBXHC0G04FSSDSR............... JBXHC0G04MPNDSR............... JBXHC0G04MPSDSR............... JBXHC0G04MSNDSR............... JBXHC0G04MSSDSR............... JBXHC0G05FPNDSR............... JBXHC0G05FPSDSR............... JBXHC0G05FSNDSR............... JBXHC0G05FSSDSR............... JBXHC0G05MPNDSR............... JBXHC0G05MPSDSR............... JBXHC0G05MSNDSR............... JBXHC0G05MSSDSR............... JBXHC0G06FPNDSR............... JBXHC0G06FPSDSR............... JBXHC0G06FSNDSR............... JBXHC0G06FSSDSR............... JBXHC0G06MPNDSR............... JBXHC0G06MPSDSR............... JBXHC0G06MSNDSR............... JBXHC0G06MSSDSR............... JBXHC0G07FPNDSR............... JBXHC0G07FPSDSR............... JBXHC0G07FSNDSR............... JBXHC0G07FSSDSR............... JBXHC0G07MPNDSR............... JBXHC0G07MPSDSR............... JBXHC0G07MSNDSR............... JBXHC0G07MSSDSR............... JBXHC0G08FPNDSR............... JBXHC0G08FPSDSR............... JBXHC0G08FSNDSR............... JBXHC0G08FSSDSR............... JBXHC0G08MPNDSR............... JBXHC0G08MPSDSR............... JBXHC0G08MSNDSR............... JBXHC0G08MSSDSR............... JBXHD0G02FCNDSR............... JBXHD0G02FCSDSR............... JBXHD0G02FSNDSR............... JBXHD0G02FSSDSR............... P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.22 P.22 P.22 P.22 P.22 P.22 P.38 P.38 P.38 P.38 P.38 P.38 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.98 P.98 P.98 P.98 P.98 P.98 P.98 P.98 P.114 P.114 P.114 P.114 P.114 P.114 P.114 P.114 P.134 P.134 P.134 P.134 P.134 P.134 P.134 P.134 P.22 P.22 P.22 P.22 JBXHD0G02MCNDSR............... JBXHD0G02MCSDSR............... JBXHD0G02MSNDSR............... JBXHD0G02MSSDSR............... JBXHD0G03FCNDSR............... JBXHD0G03FCSDSR............... JBXHD0G03FSNDSR............... JBXHD0G03FSSDSR............... JBXHD0G03MCNDSR............... JBXHD0G03MCSDSR............... JBXHD0G03MSNDSR............... JBXHD0G03MSSDSR............... JBXHD0G04FCNDSR............... JBXHD0G04FCSDSR............... JBXHD0G04FSNDSR............... JBXHD0G04FSSDSR............... JBXHD0G04MCNDSR............... JBXHD0G04MCSDSR............... JBXHD0G04MSNDSR............... JBXHD0G04MSSDSR............... JBXHD0G05FCNDSR............... JBXHD0G05FCSDSR............... JBXHD0G05FSNDSR............... JBXHD0G05FSSDSR............... JBXHD0G05MCNDSR............... JBXHD0G05MCSDSR............... JBXHD0G05MSNDSR............... JBXHD0G05MSSDSR............... JBXHD0G06FSNDSR............... JBXHD0G06FSSDSR............... JBXHD0G06MSNDSR............... JBXHD0G06MSSDSR............... JBXHD0G07FSNDSR............... JBXHD0G07FSSDSR............... JBXHD0G07MSNDSR............... JBXHD0G07MSSDSR............... JBXHD0G08FSNDSR............... JBXHD0G08FSSDSR............... JBXHD0G08MSNDSR............... JBXHD0G08MSSDSR............... JBXHH0G02FCNDSR............... JBXHH0G02FCSDSR............... JBXHH0G02FSNDSR............... JBXHH0G02FSSDSR............... JBXHH0G02MCNDSR............... JBXHH0G02MCSDSR............... JBXHH0G02MSNDSR............... JBXHH0G02MSSDSR............... JBXHH0G03FCNDSR............... JBXHH0G03FCSDSR............... JBXHH0G03FSNDSR............... JBXHH0G03FSSDSR............... JBXHH0G03MCNDSR............... JBXHH0G03MCSDSR............... JBXHH0G03MSNDSR............... JBXHH0G03MSSDSR............... JBXHH0G04FCNDSR............... JBXHH0G04FCSDSR............... JBXHH0G04FSNDSR............... JBXHH0G04FSSDSR............... JBXHH0G04MCNDSR............... JBXHH0G04MCSDSR............... JBXHH0G04MSNDSR............... JBXHH0G04MSSDSR............... P.22 P.22 P.22 P.22 P.38 P.38 P.38 P.38 P.38 P.38 P.38 P.38 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.98 P.98 P.98 P.98 P.114 P.114 P.114 P.114 P.134 P.134 P.134 P.134 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.22 P.38 P.38 P.38 P.38 P.38 P.38 P.38 P.38 P.62 P.62 P.62 P.62 P.62 P.62 P.62 P.62 JBXHH0G05FCNDSR............... JBXHH0G05FCSDSR............... JBXHH0G05FSNDSR............... JBXHH0G05FSSDSR............... JBXHH0G05MCNDSR............... JBXHH0G05MCSDSR............... JBXHH0G05MSNDSR............... JBXHH0G05MSSDSR............... JBXHH0G06FSNDSR............... JBXHH0G06FSSDSR............... JBXHH0G06MSNDSR............... JBXHH0G06MSSDSR............... JBXHH0G07FSNDSR............... JBXHH0G07FSSDSR............... JBXHH0G07MSNDSR............... JBXHH0G07MSSDSR............... JBXHH0G08FSNDSR............... JBXHH0G08FSSDSR............... JBXHH0G08MSNDSR............... JBXHH0G08MSSDSR............... JBXHH2G001FSNDSR.............. JBXHH2G001FSSDSR.............. JBXHH2G001MSNDSR.............. JBXHH2G001MSSDSR.............. JBXHH2G002FSNDSR.............. JBXHH2G002FSSDSR.............. JBXHH2G002MSNDSR.............. JBXHH2G002MSSDSR.............. JBXHH2G003FSNDSR.............. JBXHH2G003FSSDSR.............. JBXHH2G003MSNDSR.............. JBXHH2G003MSSDSR.............. JBXHH2G02FCNDSR............... JBXHH2G02FCSDSR............... JBXHH2G02FSNDSR............... JBXHH2G02FSSDSR............... JBXHH2G02MCNDSR............... JBXHH2G02MCSDSR............... JBXHH2G02MSNDSR............... JBXHH2G02MSSDSR............... JBXHH2G03FCNDSR............... JBXHH2G03FCSDSR............... JBXHH2G03FSNDSR............... JBXHH2G03FSSDSR............... JBXHH2G03MCNDSR............... JBXHH2G03MCSDSR............... JBXHH2G03MSNDSR............... JBXHH2G03MSSDSR............... JBXHH2G04FCNDSR............... JBXHH2G04FCSDSR............... JBXHH2G04FSNDSR............... JBXHH2G04FSSDSR............... JBXHH2G04MCNDSR............... JBXHH2G04MCSDSR............... JBXHH2G04MSNDSR............... JBXHH2G04MSSDSR............... JBXHH2G05FCNDSR............... JBXHH2G05FCSDSR............... JBXHH2G05FSNDSR............... JBXHH2G05FSSDSR............... JBXHH2G05MCNDSR............... JBXHH2G05MCSDSR............... JBXHH2G05MSNDSR............... JBXHH2G05MSSDSR............... P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.82 P.98 P.98 P.98 P.98 P.114 P.114 P.114 P.114 P.134 P.134 P.134 P.134 P.150 P.150 P.150 P.150 P.160 P.160 P.160 P.160 P.176 P.176 P.176 P.176 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.32 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.48 P.72 P.72 P.72 P.72 P.72 P.72 P.72 P.72 P.92 P.92 P.92 P.92 P.92 P.92 P.92 P.92 285 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) JBXHH2G06FCNDSR............... JBXHH2G06FCSDSR............... JBXHH2G06FSNDSR............... JBXHH2G06FSSDSR............... JBXHH2G06MCNDSR............... JBXHH2G06MCSDSR............... JBXHH2G06MSNDSR............... JBXHH2G06MSSDSR............... JBXHH2G07FCNDSR............... JBXHH2G07FCSDSR............... JBXHH2G07FSNDSR............... JBXHH2G07FSSDSR............... JBXHH2G07MCNDSR............... JBXHH2G07MCSDSR............... JBXHH2G07MSNDSR............... JBXHH2G07MSSDSR............... JBXHH2G08FCNDSR............... JBXHH2G08FCSDSR............... JBXHH2G08FSNDSR............... JBXHH2G08FSSDSR............... JBXHH2G08MCNDSR............... JBXHH2G08MCSDSR............... JBXHH2G08MSNDSR............... JBXHH2G08MSSDSR............... JBXHH2G10FCNDSR............... JBXHH2G10FCSDSR............... JBXHH2G10FSNDSR............... JBXHH2G10FSSDSR............... JBXHH2G10MCNDSR............... JBXHH2G10MCSDSR............... JBXHH2G10MSNDSR............... JBXHH2G10MSSDSR............... JBXHH2G12FCNDSR............... JBXHH2G12FCSDSR............... JBXHH2G12FSNDSR............... JBXHH2G12FSSDSR............... JBXHH2G12MCNDSR............... JBXHH2G12MCSDSR............... JBXHH2G12MSNDSR............... JBXHH2G12MSSDSR............... JBXHH2G16FCNDSR............... JBXHH2G16FCSDSR............... JBXHH2G16FSNDSR............... JBXHH2G16FSSDSR............... JBXHH2G16MCNDSR............... JBXHH2G16MCSDSR............... JBXHH2G16MSNDSR............... JBXHH2G16MSSDSR............... JBXHH2G18FCNDSR............... JBXHH2G18FCSDSR............... JBXHH2G18FSNDSR............... JBXHH2G18FSSDSR............... JBXHH2G18MCNDSR............... JBXHH2G18MCSDSR............... JBXHH2G18MSNDSR............... JBXHH2G18MSSDSR............... JBXHH2G19FCNDSR............... JBXHH2G19FCSDSR............... JBXHH2G19FSNDSR............... JBXHH2G19FSSDSR............... JBXHH2G19MCNDSR............... JBXHH2G19MCSDSR............... JBXHH2G19MSNDSR............... JBXHH2G19MSSDSR............... 286 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.108 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.124 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.144 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.170 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.190 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.200 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.206 P.216 P.216 P.216 P.216 P.216 P.216 P.216 P.216 JBXPC0G02FCNDSMR.............. JBXPC0G02FCNDSR............... JBXPC0G02FCSDSMR.............. JBXPC0G02FCSDSR............... JBXPC0G02FSNDSMR.............. JBXPC0G02FSNDSR............... JBXPC0G02FSSDSMR.............. JBXPC0G02FSSDSR............... JBXPC0G02MCNDSMR.............. JBXPC0G02MCNDSR............... JBXPC0G02MCSDSMR.............. JBXPC0G02MCSDSR............... JBXPC0G02MSNDSMR.............. JBXPC0G02MSNDSR............... JBXPC0G02MSSDSMR.............. JBXPC0G02MSSDSR............... JBXPC0G03FCNDSMR.............. JBXPC0G03FCNDSR............... JBXPC0G03FCSDSMR.............. JBXPC0G03FCSDSR............... JBXPC0G03FSNDSMR.............. JBXPC0G03FSNDSR............... JBXPC0G03FSSDSMR.............. JBXPC0G03FSSDSR............... JBXPC0G03MCNDSMR.............. JBXPC0G03MCNDSR............... JBXPC0G03MCSDSMR.............. JBXPC0G03MCSDSR............... JBXPC0G03MSNDSMR.............. JBXPC0G03MSNDSR............... JBXPC0G03MSSDSMR.............. JBXPC0G03MSSDSR............... JBXPC0G04FCNDSMR.............. JBXPC0G04FCNDSR............... JBXPC0G04FCSDSMR.............. JBXPC0G04FCSDSR............... JBXPC0G04FSNDSMR.............. JBXPC0G04FSNDSR............... JBXPC0G04FSSDSMR.............. JBXPC0G04FSSDSR............... JBXPC0G04MCNDSMR.............. JBXPC0G04MCNDSR............... JBXPC0G04MCSDSMR.............. JBXPC0G04MCSDSR............... JBXPC0G04MSNDSMR.............. JBXPC0G04MSNDSR............... JBXPC0G04MSSDSMR.............. JBXPC0G04MSSDSR............... JBXPC0G05FCNDSMR.............. JBXPC0G05FCNDSR............... JBXPC0G05FCSDSMR.............. JBXPC0G05FCSDSR............... JBXPC0G05FSNDSMR.............. JBXPC0G05FSNDSR............... JBXPC0G05FSSDSMR.............. JBXPC0G05FSSDSR............... JBXPC0G05MCNDSMR.............. JBXPC0G05MCNDSR............... JBXPC0G05MCSDSMR.............. JBXPC0G05MCSDSR............... JBXPC0G05MSNDSMR.............. JBXPC0G05MSNDSR............... JBXPC0G05MSSDSMR.............. JBXPC0G05MSSDSR............... P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 JBXPC0G06FSNDSMR.............. JBXPC0G06FSNDSR............... JBXPC0G06FSSDSMR.............. JBXPC0G06FSSDSR............... JBXPC0G06MSNDSMR.............. JBXPC0G06MSNDSR............... JBXPC0G06MSSDSMR.............. JBXPC0G06MSSDSR............... JBXPC0G07FSNDSMR.............. JBXPC0G07FSNDSR............... JBXPC0G07FSSDSMR.............. JBXPC0G07FSSDSR............... JBXPC0G07MSNDSMR.............. JBXPC0G07MSNDSR............... JBXPC0G07MSSDSMR.............. JBXPC0G07MSSDSR............... JBXPC0G08FSNDSMR.............. JBXPC0G08FSNDSR............... JBXPC0G08FSSDSMR.............. JBXPC0G08FSSDSR............... JBXPC0G08MSNDSMR.............. JBXPC0G08MSNDSR............... JBXPC0G08MSSDSMR.............. JBXPC0G08MSSDSR............... JBXPC1G02FCNDSMR.............. JBXPC1G02FCNDSR............... JBXPC1G02FCSDSMR.............. JBXPC1G02FCSDSR............... JBXPC1G02FSNDSMR.............. JBXPC1G02FSNDSR............... JBXPC1G02FSSDSMR.............. JBXPC1G02FSSDSR............... JBXPC1G02MCNDSMR.............. JBXPC1G02MCNDSR............... JBXPC1G02MCSDSMR.............. JBXPC1G02MCSDSR............... JBXPC1G02MSNDSMR.............. JBXPC1G02MSNDSR............... JBXPC1G02MSSDSMR.............. JBXPC1G02MSSDSR............... JBXPC1G03FCNDSMR.............. JBXPC1G03FCNDSR............... JBXPC1G03FCSDSMR.............. JBXPC1G03FCSDSR............... JBXPC1G03FSNDSMR.............. JBXPC1G03FSNDSR............... JBXPC1G03FSSDSMR.............. JBXPC1G03FSSDSR............... JBXPC1G03MCNDSMR.............. JBXPC1G03MCNDSR............... JBXPC1G03MCSDSMR.............. JBXPC1G03MCSDSR............... JBXPC1G03MSNDSMR.............. JBXPC1G03MSNDSR............... JBXPC1G03MSSDSMR.............. JBXPC1G03MSSDSR............... JBXPC1G04FCNDSMR.............. JBXPC1G04FCNDSR............... JBXPC1G04FCSDSMR.............. JBXPC1G04FCSDSR............... JBXPC1G04FSNDSMR.............. JBXPC1G04FSNDSR............... JBXPC1G04FSSDSMR.............. JBXPC1G04FSSDSR............... P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.96 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.112 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.132 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 JBXPC1G04MCNDSMR.............. JBXPC1G04MCNDSR............... JBXPC1G04MCSDSMR.............. JBXPC1G04MCSDSR............... JBXPC1G04MSNDSMR.............. JBXPC1G04MSNDSR............... JBXPC1G04MSSDSMR.............. JBXPC1G04MSSDSR............... JBXPC1G05FCNDSMR.............. JBXPC1G05FCNDSR............... JBXPC1G05FCSDSMR.............. JBXPC1G05FCSDSR............... JBXPC1G05FSNDSMR.............. JBXPC1G05FSNDSR............... JBXPC1G05FSSDSMR.............. JBXPC1G05FSSDSR............... JBXPC1G05MCNDSMR.............. JBXPC1G05MCNDSR............... JBXPC1G05MCSDSMR.............. JBXPC1G05MCSDSR............... JBXPC1G05MSNDSMR.............. JBXPC1G05MSNDSR............... JBXPC1G05MSSDSMR.............. JBXPC1G05MSSDSR............... JBXPC1G06FCNDSMR.............. JBXPC1G06FCNDSR............... JBXPC1G06FCSDSMR.............. JBXPC1G06FCSDSR............... JBXPC1G06FSNDSMR.............. JBXPC1G06FSNDSR............... JBXPC1G06FSSDSMR.............. JBXPC1G06FSSDSR............... JBXPC1G06MCNDSMR.............. JBXPC1G06MCNDSR............... JBXPC1G06MCSDSMR.............. JBXPC1G06MCSDSR............... JBXPC1G06MSNDSMR.............. JBXPC1G06MSNDSR............... JBXPC1G06MSSDSMR.............. JBXPC1G06MSSDSR............... JBXPC1G07FCNDSMR.............. JBXPC1G07FCNDSR............... JBXPC1G07FCSDSMR.............. JBXPC1G07FCSDSR............... JBXPC1G07FSNDSMR.............. JBXPC1G07FSNDSR............... JBXPC1G07FSSDSMR.............. JBXPC1G07FSSDSR............... JBXPC1G07MCNDSMR.............. JBXPC1G07MCNDSR............... JBXPC1G07MCSDSMR.............. JBXPC1G07MCSDSR............... JBXPC1G07MSNDSMR.............. JBXPC1G07MSNDSR............... JBXPC1G07MSSDSMR.............. JBXPC1G07MSSDSR............... JBXPC1G08FCNDSMR.............. JBXPC1G08FCNDSR............... JBXPC1G08FCSDSMR.............. JBXPC1G08FCSDSR............... JBXPC1G08FSNDSMR.............. JBXPC1G08FSNDSR............... JBXPC1G08FSSDSMR.............. JBXPC1G08FSSDSR............... P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 JBXPC1G08MCNDSMR.............. JBXPC1G08MCNDSR............... JBXPC1G08MCSDSMR.............. JBXPC1G08MCSDSR............... JBXPC1G08MSNDSMR.............. JBXPC1G08MSNDSR............... JBXPC1G08MSSDSMR.............. JBXPC1G08MSSDSR............... JBXPC1G10FSNDSMR.............. JBXPC1G10FSNDSR............... JBXPC1G10FSSDSMR.............. JBXPC1G10FSSDSR............... JBXPC1G10MSNDSMR.............. JBXPC1G10MSNDSR............... JBXPC1G10MSSDSMR.............. JBXPC1G10MSSDSR............... JBXPC1G12FSNDSMR.............. JBXPC1G12FSNDSR............... JBXPC1G12FSSDSMR.............. JBXPC1G12FSSDSR............... JBXPC1G12MSNDSMR.............. JBXPC1G12MSNDSR............... JBXPC1G12MSSDSMR.............. JBXPC1G12MSSDSR............... JBXPC2G001FSNDSMR............. JBXPC2G001FSNDSR.............. JBXPC2G001FSSDSMR............. JBXPC2G001FSSDSR.............. JBXPC2G001MSNDSMR............. JBXPC2G001MSNDSR.............. JBXPC2G001MSSDSMR............. JBXPC2G001MSSDSR.............. JBXPC2G002FSNDSMR............. JBXPC2G002FSNDSR.............. JBXPC2G002FSSDSMR............. JBXPC2G002FSSDSR.............. JBXPC2G002MSNDSMR............. JBXPC2G002MSNDSR.............. JBXPC2G002MSSDSMR............. JBXPC2G002MSSDSR.............. JBXPC2G003FSNDSMR............. JBXPC2G003FSNDSR.............. JBXPC2G003FSSDSMR............. JBXPC2G003FSSDSR.............. JBXPC2G003MSNDSMR............. JBXPC2G003MSNDSR.............. JBXPC2G003MSSDSMR............. JBXPC2G003MSSDSR.............. JBXPC2G02FCNDSMR.............. JBXPC2G02FCNDSR............... JBXPC2G02FCSDSMR.............. JBXPC2G02FCSDSR............... JBXPC2G02FSNDSMR.............. JBXPC2G02FSNDSR............... JBXPC2G02FSSDSMR.............. JBXPC2G02FSSDSR............... JBXPC2G02MCNDSMR.............. JBXPC2G02MCNDSR............... JBXPC2G02MCSDSMR.............. JBXPC2G02MCSDSR............... JBXPC2G02MSNDSMR.............. JBXPC2G02MSNDSR............... JBXPC2G02MSSDSMR.............. JBXPC2G02MSSDSR............... P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.164 P.164 P.164 P.164 P.164 P.164 P.164 P.164 P.184 P.184 P.184 P.184 P.184 P.184 P.184 P.184 P.148 P.148 P.148 P.148 P.148 P.148 P.148 P.148 P.158 P.158 P.158 P.158 P.158 P.158 P.158 P.158 P.174 P.174 P.174 P.174 P.174 P.174 P.174 P.174 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 JBXPC2G03FCNDSMR.............. JBXPC2G03FCNDSR............... JBXPC2G03FCSDSMR.............. JBXPC2G03FCSDSR............... JBXPC2G03FSNDSMR.............. JBXPC2G03FSNDSR............... JBXPC2G03FSSDSMR.............. JBXPC2G03FSSDSR............... JBXPC2G03MCNDSMR.............. JBXPC2G03MCNDSR............... JBXPC2G03MCSDSMR.............. JBXPC2G03MCSDSR............... JBXPC2G03MSNDSMR.............. JBXPC2G03MSNDSR............... JBXPC2G03MSSDSMR.............. JBXPC2G03MSSDSR............... JBXPC2G04FCNDSMR.............. JBXPC2G04FCNDSR............... JBXPC2G04FCSDSMR.............. JBXPC2G04FCSDSR............... JBXPC2G04FSNDSMR.............. JBXPC2G04FSNDSR............... JBXPC2G04FSSDSMR.............. JBXPC2G04FSSDSR............... JBXPC2G04MCNDSMR.............. JBXPC2G04MCNDSR............... JBXPC2G04MCSDSMR.............. JBXPC2G04MCSDSR............... JBXPC2G04MSNDSMR.............. JBXPC2G04MSNDSR............... JBXPC2G04MSSDSMR.............. JBXPC2G04MSSDSR............... JBXPC2G05FCNDSMR.............. JBXPC2G05FCNDSR............... JBXPC2G05FCSDSMR.............. JBXPC2G05FCSDSR............... JBXPC2G05FSNDSMR.............. JBXPC2G05FSNDSR............... JBXPC2G05FSSDSMR.............. JBXPC2G05FSSDSR............... JBXPC2G05MCNDSMR.............. JBXPC2G05MCNDSR............... JBXPC2G05MCSDSMR.............. JBXPC2G05MCSDSR............... JBXPC2G05MSNDSMR.............. JBXPC2G05MSNDSR............... JBXPC2G05MSSDSMR.............. JBXPC2G05MSSDSR............... JBXPC2G06FCNDSMR.............. JBXPC2G06FCNDSR............... JBXPC2G06FCSDSMR.............. JBXPC2G06FCSDSR............... JBXPC2G06FSNDSMR.............. JBXPC2G06FSNDSR............... JBXPC2G06FSSDSMR.............. JBXPC2G06FSSDSR............... JBXPC2G06MCNDSMR.............. JBXPC2G06MCNDSR............... JBXPC2G06MCSDSMR.............. JBXPC2G06MCSDSR............... JBXPC2G06MSNDSMR.............. JBXPC2G06MSNDSR............... JBXPC2G06MSSDSMR.............. JBXPC2G06MSSDSR............... P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 287 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) JBXPC2G07FCNDSMR.............. JBXPC2G07FCNDSR............... JBXPC2G07FCSDSMR.............. JBXPC2G07FCSDSR............... JBXPC2G07FSNDSMR.............. JBXPC2G07FSNDSR............... JBXPC2G07FSSDSMR.............. JBXPC2G07FSSDSR............... JBXPC2G07MCNDSMR.............. JBXPC2G07MCNDSR............... JBXPC2G07MCSDSMR.............. JBXPC2G07MCSDSR............... JBXPC2G07MSNDSMR.............. JBXPC2G07MSNDSR............... JBXPC2G07MSSDSMR.............. JBXPC2G07MSSDSR............... JBXPC2G08FCNDSMR.............. JBXPC2G08FCNDSR............... JBXPC2G08FCSDSMR.............. JBXPC2G08FCSDSR............... JBXPC2G08FSNDSMR.............. JBXPC2G08FSNDSR............... JBXPC2G08FSSDSMR.............. JBXPC2G08FSSDSR............... JBXPC2G08MCNDSMR.............. JBXPC2G08MCNDSR............... JBXPC2G08MCSDSMR.............. JBXPC2G08MCSDSR............... JBXPC2G08MSNDSMR.............. JBXPC2G08MSNDSR............... JBXPC2G08MSSDSMR.............. JBXPC2G08MSSDSR............... JBXPC2G10FCNDSMR.............. JBXPC2G10FCNDSR............... JBXPC2G10FCSDSMR.............. JBXPC2G10FCSDSR............... JBXPC2G10FSNDSMR.............. JBXPC2G10FSNDSR............... JBXPC2G10FSSDSMR.............. JBXPC2G10FSSDSR............... JBXPC2G10MCNDSMR.............. JBXPC2G10MCNDSR............... JBXPC2G10MCSDSMR.............. JBXPC2G10MCSDSR............... JBXPC2G10MSNDSMR.............. JBXPC2G10MSNDSR............... JBXPC2G10MSSDSMR.............. JBXPC2G10MSSDSR............... JBXPC2G12FCNDSMR.............. JBXPC2G12FCNDSR............... JBXPC2G12FCSDSMR.............. JBXPC2G12FCSDSR............... JBXPC2G12FSNDSMR.............. JBXPC2G12FSNDSR............... JBXPC2G12FSSDSMR.............. JBXPC2G12FSSDSR............... JBXPC2G12MCNDSMR.............. JBXPC2G12MCNDSR............... JBXPC2G12MCSDSMR.............. JBXPC2G12MCSDSR............... JBXPC2G12MSNDSMR.............. JBXPC2G12MSNDSR............... JBXPC2G12MSSDSMR.............. JBXPC2G12MSSDSR............... 288 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 JBXPC2G16FCNDSMR.............. JBXPC2G16FCNDSR............... JBXPC2G16FCSDSMR.............. JBXPC2G16FCSDSR............... JBXPC2G16FSNDSMR.............. JBXPC2G16FSNDSR............... JBXPC2G16FSSDSMR.............. JBXPC2G16FSSDSR............... JBXPC2G16MCNDSMR.............. JBXPC2G16MCNDSR............... JBXPC2G16MCSDSMR.............. JBXPC2G16MCSDSR............... JBXPC2G16MSNDSMR.............. JBXPC2G16MSNDSR............... JBXPC2G16MSSDSMR.............. JBXPC2G16MSSDSR............... JBXPC2G18FCNDSMR.............. JBXPC2G18FCNDSR............... JBXPC2G18FCSDSMR.............. JBXPC2G18FCSDSR............... JBXPC2G18FSNDSMR.............. JBXPC2G18FSNDSR............... JBXPC2G18FSSDSMR.............. JBXPC2G18FSSDSR............... JBXPC2G18MCNDSMR.............. JBXPC2G18MCNDSR............... JBXPC2G18MCSDSMR.............. JBXPC2G18MCSDSR............... JBXPC2G18MSNDSMR.............. JBXPC2G18MSNDSR............... JBXPC2G18MSSDSMR.............. JBXPC2G18MSSDSR............... JBXPC2G19FCNDSMR.............. JBXPC2G19FCNDSR............... JBXPC2G19FCSDSMR.............. JBXPC2G19FCSDSR............... JBXPC2G19FSNDSMR.............. JBXPC2G19FSNDSR............... JBXPC2G19FSSDSMR.............. JBXPC2G19FSSDSR............... JBXPC2G19MCNDSMR.............. JBXPC2G19MCNDSR............... JBXPC2G19MCSDSMR.............. JBXPC2G19MCSDSR............... JBXPC2G19MSNDSMR.............. JBXPC2G19MSNDSR............... JBXPC2G19MSSDSMR.............. JBXPC2G19MSSDSR............... JBXSA2G02FCNDS................ JBXSA2G02FCNDSM............... JBXSA2G02FCSDS................ JBXSA2G02FCSDSM............... JBXSA2G02MCNDS................ JBXSA2G02MCNDSM............... JBXSA2G02MCSDS................ JBXSA2G02MCSDSM............... JBXSA2G03FCNDS................ JBXSA2G03FCNDSM............... JBXSA2G03FCSDS................ JBXSA2G03FCSDSM............... JBXSA2G03MCNDS................ JBXSA2G03MCNDSM............... JBXSA2G03MCSDS................ JBXSA2G03MCSDSM............... P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.30 P.46 P.46 P.46 P.46 P.46 P.46 P.46 P.46 JBXSA2G04FCNDS................ JBXSA2G04FCNDSM............... JBXSA2G04FCSDS................ JBXSA2G04FCSDSM............... JBXSA2G04MCNDS................ JBXSA2G04MCNDSM............... JBXSA2G04MCSDS................ JBXSA2G04MCSDSM............... JBXSA2G05FCNDS................ JBXSA2G05FCNDSM............... JBXSA2G05FCSDS................ JBXSA2G05FCSDSM............... JBXSA2G05MCNDS................ JBXSA2G05MCNDSM............... JBXSA2G05MCSDS................ JBXSA2G05MCSDSM............... JBXSA2G06FCNDS................ JBXSA2G06FCNDSM............... JBXSA2G06FCSDS................ JBXSA2G06FCSDSM............... JBXSA2G06MCNDS................ JBXSA2G06MCNDSM............... JBXSA2G06MCSDS................ JBXSA2G06MCSDSM............... JBXSA2G07FCNDS................ JBXSA2G07FCNDSM............... JBXSA2G07FCSDS................ JBXSA2G07FCSDSM............... JBXSA2G07MCNDS................ JBXSA2G07MCNDSM............... JBXSA2G07MCSDS................ JBXSA2G07MCSDSM............... JBXSA2G08FCNDS................ JBXSA2G08FCNDSM............... JBXSA2G08FCSDS................ JBXSA2G08FCSDSM............... JBXSA2G08MCNDS................ JBXSA2G08MCNDSM............... JBXSA2G08MCSDS................ JBXSA2G08MCSDSM............... JBXSA2G10FCNDS................ JBXSA2G10FCNDSM............... JBXSA2G10FCSDS................ JBXSA2G10FCSDSM............... JBXSA2G10MCNDS................ JBXSA2G10MCNDSM............... JBXSA2G10MCSDS................ JBXSA2G10MCSDSM............... JBXSA2G12FCNDS................ JBXSA2G12FCNDSM............... JBXSA2G12FCSDS................ JBXSA2G12FCSDSM............... JBXSA2G12MCNDS................ JBXSA2G12MCNDSM............... JBXSA2G12MCSDS................ JBXSA2G12MCSDSM............... JBXSA2G16FCNDS................ JBXSA2G16FCNDSM............... JBXSA2G16FCSDS................ JBXSA2G16FCSDSM............... JBXSA2G16MCNDS................ JBXSA2G16MCNDSM............... JBXSA2G16MCSDS................ JBXSA2G16MCSDSM............... P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.70 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.90 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.106 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.122 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.142 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.168 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.188 P.198 P.198 P.198 P.198 P.198 P.198 P.198 P.198 JBXSA2G18FCNDS................ JBXSA2G18FCNDSM............... JBXSA2G18FCSDS................ JBXSA2G18FCSDSM............... JBXSA2G18MCNDS................ JBXSA2G18MCNDSM............... JBXSA2G18MCSDS................ JBXSA2G18MCSDSM............... JBXSA2G19FCNDS................ JBXSA2G19FCNDSM............... JBXSA2G19FCSDS................ JBXSA2G19FCSDSM............... JBXSA2G19MCNDS................ JBXSA2G19MCNDSM............... JBXSA2G19MCSDS................ JBXSA2G19MCSDSM............... JBXSR0G02FCNDSMR.............. JBXSR0G02FCNDSR............... JBXSR0G02FCSDSMR.............. JBXSR0G02FCSDSR............... JBXSR0G02MCNDSMR.............. JBXSR0G02MCNDSR............... JBXSR0G02MCSDSMR.............. JBXSR0G02MCSDSR............... JBXSR0G03FCNDSMR.............. JBXSR0G03FCNDSR............... JBXSR0G03FCSDSMR.............. JBXSR0G03FCSDSR............... JBXSR0G03MCNDSMR.............. JBXSR0G03MCNDSR............... JBXSR0G03MCSDSMR.............. JBXSR0G03MCSDSR............... JBXSR0G04FCNDSMR.............. JBXSR0G04FCNDSR............... JBXSR0G04FCSDSMR.............. JBXSR0G04FCSDSR............... JBXSR0G04MCNDSMR.............. JBXSR0G04MCNDSR............... JBXSR0G04MCSDSMR.............. JBXSR0G04MCSDSR............... JBXSR0G05FCNDSMR.............. JBXSR0G05FCNDSR............... JBXSR0G05FCSDSMR.............. JBXSR0G05FCSDSR............... JBXSR0G05MCNDSMR.............. JBXSR0G05MCNDSR............... JBXSR0G05MCSDSMR.............. JBXSR0G05MCSDSR............... JBXSR1G02FSNDSMR.............. JBXSR1G02FSNDSR............... JBXSR1G02FSSDSMR.............. JBXSR1G02FSSDSR............... JBXSR1G02MSNDSMR.............. JBXSR1G02MSNDSR............... JBXSR1G02MSSDSMR.............. JBXSR1G02MSSDSR............... JBXSR1G03FSNDSMR.............. JBXSR1G03FSNDSR............... JBXSR1G03FSSDSMR.............. JBXSR1G03FSSDSR............... JBXSR1G03MSNDSMR.............. JBXSR1G03MSNDSR............... JBXSR1G03MSSDSMR.............. JBXSR1G03MSSDSR............... P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.204 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.214 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.20 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.36 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.60 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.80 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.26 P.42 P.42 P.42 P.42 P.42 P.42 P.42 P.42 JBXSR1G04FSNDSMR.............. JBXSR1G04FSNDSR............... JBXSR1G04FSSDSMR.............. JBXSR1G04FSSDSR............... JBXSR1G04MSNDSMR.............. JBXSR1G04MSNDSR............... JBXSR1G04MSSDSMR.............. JBXSR1G04MSSDSR............... JBXSR1G05FSNDSMR.............. JBXSR1G05FSNDSR............... JBXSR1G05FSSDSMR.............. JBXSR1G05FSSDSR............... JBXSR1G05MSNDSMR.............. JBXSR1G05MSNDSR............... JBXSR1G05MSSDSMR.............. JBXSR1G05MSSDSR............... JBXSR1G06FSNDSMR.............. JBXSR1G06FSNDSR............... JBXSR1G06FSSDSMR.............. JBXSR1G06FSSDSR............... JBXSR1G06MSNDSMR.............. JBXSR1G06MSNDSR............... JBXSR1G06MSSDSMR.............. JBXSR1G06MSSDSR............... JBXSR1G07FSNDSMR.............. JBXSR1G07FSNDSR............... JBXSR1G07FSSDSMR.............. JBXSR1G07FSSDSR............... JBXSR1G07MSNDSMR.............. JBXSR1G07MSNDSR............... JBXSR1G07MSSDSMR.............. JBXSR1G07MSSDSR............... JBXSR1G08FSNDSMR.............. JBXSR1G08FSNDSR............... JBXSR1G08FSSDSMR.............. JBXSR1G08FSSDSR............... JBXSR1G08MSNDSMR.............. JBXSR1G08MSNDSR............... JBXSR1G08MSSDSMR.............. JBXSR1G08MSSDSR............... JBXSR1G10FSNDSMR.............. JBXSR1G10FSNDSR............... JBXSR1G10FSSDSMR.............. JBXSR1G10FSSDSR............... JBXSR1G10MSNDSMR.............. JBXSR1G10MSNDSR............... JBXSR1G10MSSDSMR.............. JBXSR1G10MSSDSR............... JBXSR1G12FSNDSMR.............. JBXSR1G12FSNDSR............... JBXSR1G12FSSDSMR.............. JBXSR1G12FSSDSR............... JBXSR1G12MSNDSMR.............. JBXSR1G12MSNDSR............... JBXSR1G12MSSDSMR.............. JBXSR1G12MSSDSR............... JBXSR3G03FSNDSMR.............. JBXSR3G03FSNDSR............... JBXSR3G03FSSDSMR.............. JBXSR3G03FSSDSR............... JBXSR3G03MSNDSMR.............. JBXSR3G03MSNDSR............... JBXSR3G03MSSDSMR.............. JBXSR3G03MSSDSR............... P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.66 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.86 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.102 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.118 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.138 P.164 P.164 P.164 P.164 P.164 P.164 P.164 P.164 P.184 P.184 P.184 P.184 P.184 P.184 P.184 P.184 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 JBXSR3G04FSNDSMR.............. JBXSR3G04FSNDSR............... JBXSR3G04FSSDSMR.............. JBXSR3G04FSSDSR............... JBXSR3G04MSNDSMR.............. JBXSR3G04MSNDSR............... JBXSR3G04MSSDSMR.............. JBXSR3G04MSSDSR............... JBXSR3G07FSNDSMR.............. JBXSR3G07FSNDSR............... JBXSR3G07FSSDSMR.............. JBXSR3G07FSSDSR............... JBXSR3G07MSNDSMR.............. JBXSR3G07MSNDSR............... JBXSR3G07MSSDSMR.............. JBXSR3G07MSSDSR............... JBXSR3G08FSNDSMR.............. JBXSR3G08FSNDSR............... JBXSR3G08FSSDSMR.............. JBXSR3G08FSSDSR............... JBXSR3G08MSNDSMR.............. JBXSR3G08MSNDSR............... JBXSR3G08MSSDSMR.............. JBXSR3G08MSSDSR............... JBXSR3G10FSNDSMR.............. JBXSR3G10FSNDSR............... JBXSR3G10FSSDSMR.............. JBXSR3G10FSSDSR............... JBXSR3G10MSNDSMR.............. JBXSR3G10MSNDSR............... JBXSR3G10MSSDSMR.............. JBXSR3G10MSSDSR............... JBXSR3G14FSNDSMR.............. JBXSR3G14FSNDSR............... JBXSR3G14FSSDSMR.............. JBXSR3G14FSSDSR............... JBXSR3G14MSNDSMR.............. JBXSR3G14MSNDSR............... JBXSR3G14MSSDSMR.............. JBXSR3G14MSSDSR............... JBXSR3G18FSNDSMR.............. JBXSR3G18FSNDSR............... JBXSR3G18FSSDSMR.............. JBXSR3G18FSSDSR............... JBXSR3G18MSNDSMR.............. JBXSR3G18MSNDSR............... JBXSR3G18MSSDSMR.............. JBXSR3G18MSSDSR............... JBXSR3G22FSNDSMR.............. JBXSR3G22FSNDSR............... JBXSR3G22FSSDSMR.............. JBXSR3G22FSSDSR............... JBXSR3G22MSNDSMR.............. JBXSR3G22MSNDSR............... JBXSR3G22MSSDSMR.............. JBXSR3G22MSSDSR............... JBXSR3G30FSNDSMR.............. JBXSR3G30FSNDSR............... JBXSR3G30FSSDSMR.............. JBXSR3G30FSSDSR............... JBXSR3G30MSNDSMR.............. JBXSR3G30MSNDSR............... JBXSR3G30MSSDSMR.............. JBXSR3G30MSSDSR............... P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.76 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.128 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.154 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.180 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.194 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.210 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.220 P.224 P.224 P.224 P.224 P.224 P.224 P.224 P.224 289 Appendices JBX Series | Appendices JBX Series | Appendices Part Number Index (Continued) Accessories JAXRA00251.................... JBX00MPA...................... JBX00MPB...................... JBX00MPG...................... JBX00MPJ...................... JBX00MPM...................... JBX00MPN...................... JBX00MPO...................... JBX00MPR...................... JBX00MPV...................... JBX00RIA...................... JBX00RIB...................... JBX00RIG...................... JBX00RIJ...................... JBX00RIM...................... JBX00RIN...................... JBX00RIO...................... JBX00RIR...................... JBX00RIV...................... JBXBF00....................... JBXBR00....................... JAXRA0251..................... JBX0MPA....................... JBX0MPB....................... JBX0MPG....................... JBX0MPJ....................... JBX0MPM....................... JBX0MPN....................... JBX0MPO....................... JBX0MPR....................... JBX0MPV....................... JBX0RIA....................... JBX0RIB....................... JBX0RIG....................... JBX0RIJ....................... JBX0RIM....................... JBX0RIN....................... JBX0RIO....................... JBX0RIR....................... JBX0RIV....................... JBXBF0........................ JBXBR0........................ JAXRA1251..................... JBX1MPA....................... JBX1MPB....................... JBX1MPG....................... JBX1MPJ....................... JBX1MPM....................... JBX1MPN....................... JBX1MPO....................... JBX1MPR....................... JBX1MPV....................... JBX1RIA....................... JBX1RIB....................... JBX1RIG....................... JBX1RIJ....................... JBX1RIM....................... JBX1RIN....................... JBX1RIO....................... JBX1RIR....................... JBX1RIV....................... JBXBF1........................ JBXBR1........................ 290 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.18 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.24 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 P.28 JAXRA2251..................... JBX2MPA....................... JBX2MPB....................... JBX2MPG....................... JBX2MPJ....................... JBX2MPM....................... JBX2MPN....................... JBX2MPO....................... JBX2MPR....................... JBX2MPV....................... JBX2RIA....................... JBX2RIB....................... JBX2RIG....................... JBX2RIJ....................... JBX2RIM....................... JBX2RIN....................... JBX2RIO....................... JBX2RIR....................... JBX2RIV....................... JBXBF2........................ JBXBR2........................ JAXRA3251..................... JBX3MPA....................... JBX3MPB....................... JBX3MPG....................... JBX3MPJ....................... JBX3MPM....................... JBX3MPN....................... JBX3MPO....................... JBX3MPR....................... JBX3MPV....................... JBX3RIA....................... JBX3RIB....................... JBX3RIG....................... JBX3RIJ....................... JBX3RIM....................... JBX3RIN....................... JBX3RIO....................... JBX3RIR....................... JBX3RIV....................... JBXBF3........................ JBXBR3........................ Contacts JBX0CTFC07.................... JBX0CTFC09.................... JBX0CTMC07.................... JBX0CTMC09.................... JBX0STFC07.................... JBX0STFC09.................... JBX0STMC07.................... JBX0STMC09.................... JBX1CTFC07.................... JBX1CTFC09.................... JBX1CTFC13.................... JBX1CTMC07.................... JBX1CTMC09.................... JBX1CTMC13.................... JBX1STFC07.................... JBX1STFC09.................... JBX1STFC13.................... JBX1STMC07.................... JBX1STMC09.................... JBX1STMC13.................... P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.34 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.52 P.232 P.232 P.232 P.232 P.231 P.231 P.231 P.231 P.232 P.232 P.232 P.232 P.232 P.232 P.231 P.231 P.231 P.231 P.231 P.231 JBX2CTFC07.................... JBX2CTFC09.................... JBX2CTFC13.................... JBX2CTFC16.................... JBX2CTFC20.................... JBX2CTMC07.................... JBX2CTMC09.................... JBX2CTMC13.................... JBX2CTMC16.................... JBX2CTMC20.................... JBX2STFC07.................... JBX2STFC09.................... JBX2STFC13.................... JBX2STFC16.................... JBX2STFC20.................... JBX2STMC07.................... JBX2STMC09.................... JBX2STMC13.................... JBX2STMC16.................... JBX2STMC20.................... JBX3CTFC07.................... JBX3CTFC09.................... JBX3CTFC13.................... JBX3CTFC16.................... JBX3CTFC20.................... JBX3CTMC07.................... JBX3CTMC09.................... JBX3CTMC13.................... JBX3CTMC16.................... JBX3CTMC20.................... JBX3STFC07.................... JBX3STFC09.................... JBX3STFC13.................... JBX3STFC16.................... JBX3STFC20.................... JBX3STMC07.................... JBX3STMC09.................... JBX3STMC13.................... JBX3STMC16.................... JBX3STMC20.................... Tooling JBX0OUTLP07................... JBX0OUTLP09................... JBX1OUTLP13................... JBX2OUTLP16................... JBX2OUTLP20................... JBXOUTDC07.................... JBXOUTDC09.................... JBXOUTDC13.................... JBXOUTDC16.................... JBXOUTDC20.................... MIL-22520/1-01................ MIL-22520/7-01................ P.232 P.232 P.232 P.232 P.232 P.232 P.232 P.232 P.232 P.232 P.231 P.231 P.231 P.231 P.231 P.231 P.231 P.231 P.231 P.231 P.232 P.232 P.232 P.232 P.232 P.232 P.232 P.232 P.232 P.232 P.231 P.231 P.231 P.231 P.231 P.231 P.231 P.231 P.231 P.231 P.235 P.235 P.235 P.235 P.235 P.235 P.235 P.235 P.235 P.235 P.235 P.235 Your local contact Our contribution to environmental protection: This catalog is printed on PEFC certified paper Advancement of sustainable wood cultivation. www.pefc.org www.souriau-industrial.com contactindustry@souriau.com CAJBXEUSEN01 © Copyright SOURIAU 2015 - SOURIAU is a registered trademark All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. Reliable People, Reliable Solutions
JBXEP2G19FCSDS 价格&库存
很抱歉,暂时无法提供与“JBXEP2G19FCSDS”相匹配的价格&库存,您可以联系我们找货
