SS52-520 SERIES
SCHOTTKY
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
ROHS
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
MECHANICAL DATA
Case : JEDEC DO-214AB molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity : Color band denotes cathode end
Mounting Position: Any
Weight : 0.007 ounce, 0.25 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,
for capacitive load current derate by 20%.
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=110 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical thermal resistance (NOTE 1)
Operating junction and storage temperature range
Note:
SS58 SS510 SS515 SS520
SYMBOLS
SS52
SS54
SS56
VRRM
VRMS
VDC
40
21
40
60
28
80
56
100
70
150
105
200
150
60
80
100
150
200
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
5.0
Amp
IFSM
150.0
Amps
VF
IR
RθJA
TJ,TSTG
0.70
0.55
0.85
0.95
Volts
10.0
0.2
2.0
mA
0.5
20.0
C/W
C
50
-65 to +150
1.P.C.B. mounted with 8.0x8.0mm copper pad areas
Rev 8: Nov 2014
www.born-tw.com
Page 1 of 2
SS52-520 SERIES
SCHOTTKY
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
150
5.0
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
ROHS
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
SS52-SS56
SS58-SS520
1.0
120
90
60
30
50
75
100
125
150
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
AMBIENT TEMPERATURE, C
10
100
NUMBER OF CYCLES AT 60 Hz
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
50
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
CURRENT,AMPERES
TJ=25 C
10.0
1
SS52-SS54
SS55-SS56
SS58-SS515
SS520
0.1
0.01
0.4
0.6
0.8
1.0
1.2
1.4
10
TJ=100 C
1
0.1
TJ=25 C
0.01
0.001
30
60
90
120
150
PERCENT OF PEAK REVERSE VOLTAGE,%
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
JUNCTION CAPACITANCE, pF
1000
TRANSIENT THERMAL IMPEDANCE,
C/W
2000
TJ=25 C
100
10
1
0.1
10
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
Rev 8: Nov 2014
100
0.01
0.1
1
10
100
t,PULSE DURATION,sec.
www.born-tw.com
Page 2 of 2
很抱歉,暂时无法提供与“SS510SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.86411
- 50+0.70859
- 150+0.63083
- 500+0.57251
- 3000+0.44464
- 6000+0.42120
- 国内价格
- 1+0.65780
- 200+0.45320
- 1500+0.41250
- 3000+0.38500
