BSMD1206L-350
BSMD1206L-350
    BHFUSE(佰宏)
    PTC自恢复保险丝 1206 3.5A 6V
BSMD1206L-350 数据手册
BHFUSE BSMD1206L Series Surface Mount PTC Device  Features       Size 0.12*0.06 inch /3.2*1.6 mm RoHS compliant, lead-free and halogen-free Fast response to fault current Low resistance Low-profile Compatible with high temperature solders  Applications  Computer, Mobile phones, Multimedia  Automotive, Industrial controls, Telephony and broadband  Game machines, Portable electronics, Battery  Electrical Characteristics(25℃) Part Number Ihold (A) Itrip (A) Vmax (V) Imax (A) Pd (W) Time to trip (A) (Sec) Rmin (Ω) R1max (Ω) BSMD1206L-110 1.10 2.2 6.0 50 1.2 8.0 0.5 0.008 0.065 BSMD1206L-125 1.25 2.5 6.0 50 1.2 8.0 1.0 0.007 0.060 BSMD1206L-150 1.50 3.0 6.0 50 1.2 8.0 5.0 0.006 0.055 BSMD1206L-175 1.75 3.5 6.0 50 1.2 8.0 5.0 0.005 0.050 BSMD1206L-200 2.00 4.0 6.0 50 1.2 8.0 5.0 0.004 0.045 BSMD1206L-230 2.30 4.6 6.0 50 1.2 8.0 5.0 0.004 0.040 BSMD1206L-260 2.60 5.2 6.0 50 1.2 12.0 5.0 0.003 0.035 BSMD1206L-300 3.00 6.0 6.0 50 1.2 12.0 5.0 0.003 0.030 BSMD1206L-350 3.50 7.0 6.0 50 1.2 12.0 5.0 0.002 0.025 BSMD1206L-380 3.80 7.6 6.0 50 1.2 12.0 5.0 0.002 0.020 BSMD1206L-400 4.00 8.0 6.0 50 1.5 16.0 5.0 0.001 0.018 BSMD1206L-450 4.50 9.0 6.0 50 1.5 16.0 5.0 0.001 0.015 BSMD1206L-500 5.00 10.0 6.0 50 1.5 16.0 5.0 0.001 0.012 BSMD1206L-550 5.50 11.0 6.0 50 1.5 16.0 5.0 0.001 0.011 BSMD1206L-600 6.00 12.0 6.0 50 1.5 20.0 5.0 0.0008 0.010 BSMD1206L-650 6.50 13.0 6.0 50 1.5 20.0 5.0 0.0008 0.009 BSMD1206L-700 7.00 14.0 6.0 50 1.6 20.0 5.0 0.0005 0.009 BSMD1206L-750 7.50 15.0 6.0 50 1.6 20.0 5.0 0.0005 0.008 BSMD1206L-800 8.00 16.0 6.0 50 1.6 20.0 5.0 0.0005 0.007 BSMD1206L-850 8.50 17.0 6.0 50 1.6 20.0 5.0 0.0005 0.007 BSMD1206L-900 9.00 18.0 6.0 50 1.8 30.0 5.0 0.0004 0.006 BSMD1206L-950 9.50 19.0 6.0 50 1.8 30.0 5.0 0.0003 0.006 BSMD1206L-1000 10.00 20.0 6.0 50 1.8 30.0 5.0 0.0002 0.005 Specifications are subject to change without notice Revision 2017 Polymer PTC Thermistor 1/6 BHFUSE BSMD1206L Series Surface Mount PTC Device Ihold = Hold current: maximum current device will pass without tripping in 25℃ still air. Itrip = Trip current: minimum current at which the device will trip in 25℃ still air. Vmax = Maximum voltage device can withstand without damage at rated current (Imax) Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax) Pd typ. = Typical power dissipated from device when in the tripped state at 25℃ still air. Rmin = Minimum resistance of device in initial (un-soldered) state. R1max = Maximum resistance of device at 25℃ measured one hour after tripping or reflow soldering of 260℃ for 20 sec. Caution:Operation beyond the specified ratings may result in damage and possible arcing and flame.  WARNING  Users shall independently assess the suitability of these devices for each of their applications.  Operation of these devices beyond the stated maximum ratings could result in damage to the devices and lead to electrical arcing and/or fire.  These devices are intended to protect against the effects of temporary over-current or over-temperature conditions and are not intended to perform as protective devices where such conditions are expected to be repetitive or prolonged in duration.  Exposure to silicon-based oils, solvents, electrolytes, acids, and similar materials can adversely affect the performance of these PPTC devices.  These devices undergo thermal expansion under fault conditions, and thus shall be provided with adequate space and be protected against mechanical stresses.  Circuits with inductance may generate a voltage (L di/dt) above the rated voltage of the PPTC device. Specifications are subject to change without notice Revision 2017 Polymer PTC Thermistor 2/6 BHFUSE BSMD1206L Series Surface Mount PTC Device  Thermal Derating Chart Part Number Ambient operating temperature hold current(Ihold) -40℃ -20℃ 0℃ 25℃ 40℃ 50℃ 60℃ 70℃ BSMD1206L-110 1.5 1.3 1.2 1.1 0.9 0.8 0.7 0.6 BSMD1206L-125 1.7 1.5 1.4 1.25 1.1 1.0 0.9 0.7 BSMD1206L-150 2.0 1.8 1.6 1.5 1.2 1.1 1.0 0.9 BSMD1206L-175 2.3 2.0 1.9 1.75 1.4 1.3 1.2 1.0 BSMD1206L-200 2.7 2.3 2.2 2.0 1.6 1.5 1.4 1.1 BSMD1206L-230 3.1 2.7 2.5 2.3 1.9 1.7 1.6 1.3 BSMD1206L-260 3.5 3.0 2.8 2.6 2.1 1.9 1.8 1.5 BSMD1206L-300 4.0 3.5 3.2 3.0 2.5 2.2 2.0 1.7 BSMD1206L-350 4.7 4.1 3.8 3.5 2.9 2.6 2.4 2.0 BSMD1206L-380 5.1 4.4 4.1 3.8 3.1 2.8 2.6 2.2 BSMD1206L-400 5.4 4.7 4.3 4.0 3.3 3.0 2.7 2.3 BSMD1206L-450 6.0 5.3 4.9 4.5 3.7 3.3 3.1 2.6 BSMD1206L-500 7.5 6.5 5.5 5.0 4.5 3.5 3.3 3.0 BSMD1206L-550 8.3 7.2 6.1 5.5 5.0 3.9 3.6 3.3 BSMD1206L-600 9.0 7.8 6.6 6.0 5.4 4.2 3.9 3.6 BSMD1206L-650 9.8 8.5 7.2 6.5 5.9 4.6 4.2 3.9 BSMD1206L-700 10.5 9.1 7.7 7.0 6.3 4.9 4.6 4.2 BSMD1206L-750 11.3 9.8 8.3 7.5 6.8 5.3 4.9 4.5 BSMD1206L-800 12.0 10.4 8.8 8.0 7.2 5.6 5.2 4.8 BSMD1206L-850 12.8 11.1 9.4 8.5 7.7 6.0 5.5 5.1 BSMD1206L-900 13.5 11.7 9.9 9.0 8.1 6.3 5.9 5.4 BSMD1206L-950 14.3 12.4 10.5 9.5 8.6 6.7 6.2 5.7 BSMD1206L-1000 15.0 13.0 11.0 10.0 9.0 7.0 6.5 6.0 Specifications are subject to change without notice Revision 2017 Polymer PTC Thermistor 3/6 BHFUSE BSMD1206L Series Surface Mount PTC Device  Soldering Parameters Profile Feature Pb-Free Assembly Average Ramp-Up Rate(Tsmax to Tp) 3℃/second max Preheat -Temperature Min(Tsmin) -Temperature Max(Tsmax) -Time(Tsmin to Tsmax) 150℃ 200℃ 60~180 seconds Time maintained above: -Temperature(TL) -Time(tL) 217℃ 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~30℃,30%-60%RH  Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free.  Recommended maximum paste thickness is 0.25mm.  Devices can be cleaned using standard industry methods and solvents. Note 1: All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements.  Environmental Specifications Test Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C Specifications are subject to change without notice Revision 2017 Polymer PTC Thermistor 4/6 BHFUSE BSMD1206L Series Surface Mount PTC Device  Physical Dimensions & Recommended Pad Layout (mm) A 1.0 1.0 1.8 B 1.8 D E Part Number Quantity BSMD1206L-110 C A B C D E Min Max Min Max Min Max Min Min 4000 -- 3.50 -- 1.85 -- 0.8 0.25 0.10 BSMD1206L-125 4000 -- 3.50 -- 1.85 -- 0.8 0.25 0.10 BSMD1206L-150 4000 -- 3.50 -- 1.85 -- 0.8 0.25 0.10 BSMD1206L-175 4000 -- 3.50 -- 1.85 -- 0.8 0.25 0.10 BSMD1206L-200 4000 -- 3.50 -- 1.85 -- 0.8 0.25 0.10 BSMD1206L-230 4000 -- 3.50 -- 1.85 -- 1.0 0.25 0.10 BSMD1206L-260 4000 -- 3.50 -- 1.85 -- 1.0 0.25 0.10 BSMD1206L-300 4000 -- 3.50 -- 1.85 -- 1.0 0.25 0.10 BSMD1206L-350 4000 -- 3.50 -- 1.85 -- 1.0 0.25 0.10 BSMD1206L-380 4000 -- 3.50 -- 1.85 -- 1.0 0.25 0.10 BSMD1206L-400 4000 -- 3.50 -- 1.85 -- 1.0 0.25 0.10 BSMD1206L-450 4000 -- 3.50 -- 1.85 -- 1.0 0.25 0.10 BSMD1206L-500 3000 -- 3.50 -- 1.85 -- 1.2 0.25 0.10 BSMD1206L-550 3000 -- 3.50 -- 1.85 -- 1.2 0.25 0.10 BSMD1206L-600 3000 -- 3.50 -- 1.85 -- 1.2 0.25 0.10 BSMD1206L-650 3000 -- 3.50 -- 1.85 -- 1.2 0.25 0.10 BSMD1206L-700 3000 -- 3.50 -- 1.85 -- 1.2 0.25 0.10 BSMD1206L-750 3000 -- 3.50 -- 1.85 -- 1.3 0.25 0.10 BSMD1206L-800 3000 -- 3.50 -- 1.85 -- 1.3 0.25 0.10 BSMD1206L-850 3000 -- 3.50 -- 1.85 -- 1.3 0.25 0.10 BSMD1206L-900 3000 -- 3.50 -- 1.85 -- 1.3 0.25 0.10 BSMD1206L-950 3000 -- 3.50 -- 1.85 -- 1.3 0.25 0.10 BSMD1206L-1000 3000 -- 3.50 -- 1.85 -- 1.3 0.25 0.10 Specifications are subject to change without notice Revision 2017 Polymer PTC Thermistor 5/6 BHFUSE BSMD1206L Series Surface Mount PTC Device  Tape And Reel Specifications (mm) Governing Specifications BSMD1206L-110~ BSMD1206L-260 BSMD1206L-300~ BSMD1206L-450 BSMD1206L-500~ BSMD1206L-1000 W 8.0 ± 0.3 8.0 ± 0.3 8.0 ± 0.3 F 3.5 ± 0.05 3.5 ± 0.05 3.5 ± 0.05 E1 1.75 ± 0.1 1.75 ± 0.1 1.75 ± 0.1 D0 1.55 ± 0.05 1.55 ± 0.05 1.55 ± 0.05 D1 1.0 ± 0.1 1.0 ± 0.1 1.0 ± 0.1 P0 4.0 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 P1 4.0 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 P2 2.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 A0 1.95 ± 0.1 1.95 ± 0.1 1.95 ± 0.1 B0 3.65 ± 0.1 3.65 ± 0.1 3.65 ± 0.1 T 0.2 ± 0.1 0.2 ± 0.1 0.2 ± 0.1 K0 0.74 ± 0.1 1.04 ± 0.1 1.35 ± 0.1 Leader min 390 390 390 Trailer min 160 160 160 Reel Dimensions  C φ178 ± 1.0 D φ60.2 ± 0.5 H 11.0 ± 0.5 W 9.0 ± 1.5 Contact information SHENZHEN HCHC ELECTRONIC CO., LTD TEL: 0755-85259917 FAX: 0755-28704432 E-MAIL: sale@hchc-elec.com Specifications are subject to change without notice Revision 2017 Polymer PTC Thermistor 6/6
BSMD1206L-350 价格&库存
很抱歉,暂时无法提供与“BSMD1206L-350”相匹配的价格&库存,您可以联系我们找货
BSMD1206L-350
    • 5+0.86595
    • 50+0.66953
    • 800+0.49762
    • 1600+0.43871
    • 4000+0.40925
    库存:3560
