Wire Wound Chip Common Mode Choke Coil – SDCW-H Series
Operating Temp. : -40℃~+85℃
FEATURES
Winding type realizes small size and low profile
Suppress noise for the high-speed differential signal lines
Excellent solder ability
APPLICATIONS
High speed differential signal lines for HDMI, DVI, etc
PRODUCT IDENTIFICATION
SDCW
2012
H
①
②
③
②
①
SDCW
Type
Winding Type
Common Mode Choke
Coil
-900
④
⑤
Impedance
Nominal Value
90Ω
T
F
⑥
⑦
③
External Dimensions (L×W) (mm)
1210 [0504]
1.2×1.0
2012 [0805]
2.0×1.2
H
④
Number of Lines
2
⑤
Example
900
-2
⑦
⑥
Hazardous Substance
Free Products
Packing
T
Code
For High-speed
Differential Signal
Lines
Tape & Reel
F
SHAPE AND DIMENSIONS
SDCW1210H TYPE
Recommended Land Pattern
Unit: mm
Unit: mm
SDCW2012H TYPE
Sunlord
Specifications subject to change without notice. Please check our website for latest information.
Revised 2021/05/15
Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
SPECIFICATIONS
SDCW1210H TYPE
Part Number
Units
Symbol
SDCW1210H-2-350TF
SDCW1210H-2-900TF
Common Mode
Impedance @100MHz
Ω
Z
35±25%
90±25%
Max. DC
Resistance
Ω
DCR
0.32
0.50
Max. Rated
Current
mA
Ir
320
280
Common Mode
Impedance @100MHz
Ω
Z
67±25%
90±25%
120±25%
Max. DC
Resistance
Ω
DCR
0.30
0.40
0.40
Max. Rated
Current
mA
Ir
320
280
280
Min. Insulation
Resistance
MΩ
IR
10
10
Rated Voltage
Volts
V DC
SDCW2012H TYPE
Part Number
Units
Symbol
SDCW2012H-2-670TF
SDCW2012H-2-900TF
SDCW2012H-2-121TF
Min. Insulation
Resistance
MΩ
IR
10
10
10
Rated Voltage
Volts
V DC
※: Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales.
EQUIVALENT CIRCUIT
TYPICAL ELECTRICAL CHARACTERISTICS
Impedance vs. Frequency
SDCW1210H TYPE
SDCW2012H TYPE
Common Mode
SDCW2012H-2-121TF
SDCW2012H-2-900TF
SDCW2012H-2-670TF
SDCW2012H-2-121TF
SDCW2012H-2-900TF
SDCW2012H-2-670TF
Differential Mode
Frequency(MHz)
Sunlord
Frequency(MHz)
Revised 2021/05/15
Insertion Loss
SDCW1210H TYPE
SDCW2012H TYPE
SDCW2012H-2-670TF
SDCW2012H-2-900TF
SDCW2012H-2-121TF
SDCW2012-2-900TF
Frequency(MHz)
Frequency(MHz)
Differential Mode Impedance Characteristics
SDCW2012H-2-900TF
Sunlord
Revised 2021/05/15
很抱歉,暂时无法提供与“SDCW2012H-2-670TF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.38640
- 100+0.35190
- 500+0.31740
- 1000+0.28290
- 2000+0.25990
- 4000+0.25300
- 国内价格
- 5+0.71496
- 50+0.60264
- 150+0.54648
- 500+0.50436
- 2000+0.42423
- 4000+0.40738
