BHFUSE
BSMD1812 Series Surface Mount PTC Device
Features
Size 0.18*0.12 inch /4.5*3.2 mm
RoHS compliant, lead-free and halogen-free
Fast response to fault current
Low resistance
Low profile
Compatible with high temperature solders
Applications
Computer, Mobile phones, Multimedia
Automotive, Industrial controls, Telephony and broadband
Game machines, Portable electronics, Battery
Electrical Characteristics(25℃)
Part Number
Ihold
(A)
Itrip
(A)
Vmax
(Vdc)
Imax
(A)
Pd typ
(W)
Time to trip
(A)
(Sec)
Rmin
(Ω)
R1max
(Ω)
BSMD1812-010-30V
0.10
0.30
30
40
0.8
0.50
1.50
0.750
15.00
BSMD1812-010-60V
0.10
0.30
60
40
0.8
0.50
1.50
0.750
15.00
BSMD1812-014-60V
0.14
0.34
60
40
0.8
1.50
0.15
0.650
6.000
BSMD1812-020-30V
0.20
0.40
30
40
0.8
8.00
0.04
0.350
5.000
BSMD1812-020-60V
0.20
0.40
60
40
0.8
8.00
0.04
0.350
5.000
BSMD1812-030-30V
0.30
0.60
30
40
0.8
8.00
0.10
0.250
3.000
BSMD1812-030-60V
0.30
0.60
60
40
0.8
8.00
0.10
0.250
3.000
BSMD1812-050-15V
0.50
1.00
15
40
0.8
8.00
0.15
0.150
1.400
BSMD1812-050-24V
0.50
1.00
24
40
0.8
8.00
0.15
0.150
1.400
BSMD1812-050-30V
0.50
1.00
30
40
0.8
8.00
0.15
0.150
1.400
BSMD1812-050-60V
0.50
1.00
60
40
0.8
8.00
0.15
0.150
1.400
BSMD1812-075-13.2V
0.75
1.50
13.2
40
0.8
8.00
0.20
0.090
0.450
BSMD1812-075-16V
0.75
1.50
16
40
0.8
8.00
0.20
0.090
0.450
BSMD1812-075-24V
0.75
1.50
24
40
0.8
8.00
0.20
0.090
0.450
BSMD1812-075-33V
0.75
1.50
33
40
0.8
8.00
0.20
0.090
0.450
BSMD1812-110-8V
1.10
2.20
8
100
0.8
8.00
0.30
0.045
0.250
BSMD1812-110-16V
1.10
2.20
16
100
0.8
8.00
0.30
0.045
0.250
BSMD1812-110-24V
1.10
2.20
24
40
0.8
8.00
0.30
0.045
0.250
BSMD1812-110-33V
1.10
2.20
33
40
0.8
8.00
0.30
0.045
0.250
BSMD1812-125-16V
1.25
2.50
16
100
0.8
8.00
0.40
0.050
0.160
BSMD1812-125-24V
1.25
2.50
24
40
0.8
8.00
0.40
0.050
0.160
BSMD1812-150-16V
1.50
3.00
16
100
0.8
8.00
0.50
0.040
0.160
Specifications are subject to change without notice
Revision 2017
Polymer PTC Thermistor
1/7
BHFUSE
Part Number
Ihold
(A)
Itrip
(A)
Vmax
(Vdc)
Imax
(A)
Pd typ
(W)
Time to trip
(A)
(Sec)
Ri
(Ω)
R1max
(Ω)
BSMD1812-150-24V
1.50
3.00
24
40
0.8
8.00
0.50
0.040
0.160
BSMD1812-150-33V
1.50
3.00
33
40
0.8
8.00
0.50
0.040
0.160
BSMD1812-160-8V
1.60
3.20
8
100
0.8
8.00
1.00
0.030
0.130
BSMD1812-160-16V
1.60
3.20
16
100
0.8
8.00
1.00
0.030
0.130
BSMD1812-160-24V
1.60
3.20
24
40
0.8
8.00
1.00
0.030
0.130
BSMD1812-200-8V
2.00
4.00
8
100
0.8
8.00
2.00
0.020
0.100
BSMD1812-200-12V
2.00
4.00
12
100
0.8
8.00
2.00
0.020
0.100
BSMD1812-200-16V
2.00
4.00
16
100
0.8
8.00
2.00
0.020
0.100
BSMD1812-200-24V
2.00
4.00
24
40
0.8
8.00
2.00
0.020
0.100
BSMD1812-200-30V
2.00
4.00
30
40
0.8
8.00
2.00
0.020
0.100
BSMD1812-250-8V
2.50
5.00
8
40
0.8
8.00
2.50
0.015
0.080
BSMD1812-260-8V
2.60
5.20
8
100
0.8
8.00
2.50
0.010
0.050
BSMD1812-260-13.2V
2.60
5.20
13.2
40
0.8
8.00
2.50
0.010
0.050
BSMD1812-260-16V
2.60
5.20
16
40
0.8
8.00
2.50
0.010
0.050
BSMD1812-300-8V
3.00
6.00
8
100
0.8
8.00
4.00
0.010
0.040
BSMD1812-300-12V
3.00
6.00
12
100
0.8
8.00
4.00
0.010
0.040
BSMD1812-300-16V
3.00
6.00
16
40
0.8
8.00
4.00
0.010
0.040
BSMD1812-350-6V
3.50
7.00
6
100
2.0
10.00
4.00
0.008
0.035
BSMD1812-350-16V
3.50
7.00
16
100
2.0
10.00
4.00
0.008
0.035
BSMD1812-400-6V
4.00
8.00
6
100
2.0
10.00
4.00
0.005
0.025
Ihold = Hold current: maximum current device will pass without tripping in 25℃ still air.
Itrip = Trip current: minimum current at which the device will trip in 25℃ still air.
Vmax = Maximum voltage device can withstand without damage at rated current (Imax).
Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax).
Pd typ. = Typical power dissipated from device when in the tripped state at 25℃ still air.
Rmin = Minimum resistance of device in initial (un-soldered) state.
R1max = Maximum resistance of device at 25℃ measured one hour after tripping or reflow soldering of 260℃ for 20 sec.
Caution:Operation beyond the specified ratings may result in damage and possible arcing and flame.
WARNING
Users shall independently assess the suitability of these devices for each of their applications.
Operation of these devices beyond the stated maximum ratings could result in damage to the devices and lead to
electrical arcing and/or fire.
These devices are intended to protect against the effects of temporary over-current or over-temperature conditions
and are not intended to perform as protective devices where such conditions are expected to be repetitive or
prolonged in duration.
Exposure to silicon-based oils, solvents, electrolytes, acids, and similar materials can adversely affect the prolonged
of these PPTC devices.
These devices undergo thermal expansion under fault conditions, and thus shall be provided with adequate space
and be protected against mechanical stresses.
Circuits with inductance may generate a voltage (L di/dt) above the rated voltage of the PPTC device.
Revision 2017
2/7
BHFUSE
Thermal Derating Curve
Typical Time-to-Trip At 25℃
Thermal Derating Chart
Part Number
Ambient operating temperature hold current(Ihold)
-40℃
-20℃
0℃
25℃
40℃
50℃
60℃
70℃
85℃
BSMD1812-010
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.03
BSMD1812-014
0.23
0.19
0.17
0.14
0.12
0.10
0.09
0.08
0.06
BSMD1812-020
0.29
0.26
0.23
0.20
0.17
0.15
0.14
0.12
0.10
BSMD1812-030
0.44
0.39
0.35
0.30
0.26
0.23
0.21
0.18
0.15
BSMD1812-050
0.69
0.59
0.55
0.50
0.45
0.43
0.35
0.30
0.23
BSMD1812-075
1.10
0.99
0.87
0.75
0.63
0.57
0.49
0.45
0.35
BSMD1812-110
1.60
1.45
1.28
1.10
0.92
0.83
0.71
0.66
0.52
BSMD1812-125
2.00
1.75
1.52
1.25
1.00
0.95
0.90
0.75
0.53
BSMD1812-150
2.10
1.96
1.77
1.50
1.23
1.09
0.95
0.82
0.61
BSMD1812-160
2.30
2.05
1.88
1.60
1.26
1.12
0.98
0.84
0.63
BSMD1812-200
2.88
2.61
2.25
2.00
1.80
1.66
1.45
1.09
0.80
BSMD1812-260
3.90
3.42
2.96
2.60
2.22
2.07
1.94
1.35
1.00
BSMD1812-300
4.15
3.76
3.46
3.00
2.55
2.28
2.01
1.61
1.33
BSMD1812-350
4.84
4.39
4.04
3.50
2.98
2.66
2.35
1.88
1.55
BSMD1812-400
4.97
4.62
4.32
4.00
3.48
3.16
2.85
2.38
2.05
Revision 2017
3/7
BHFUSE
Soldering Parameters
Profile Feature
Pb-Free Assembly
Average Ramp-Up Rate(Tsmax to Tp)
3℃/second max
Preheat
-Temperature Min(Tsmin)
-Temperature Max(Tsmax)
-Time(Tsmin to Tsmax)
150℃
200℃
60~180 seconds
Time maintained above:
-Temperature(TL)
-Time(tL)
217℃
60~150 seconds
Peak Temperature(Tp)
260℃
Ramp-Down Rate
6℃/second max
Time 25℃ to Peak Temperature
8 minutes max
Storage Condition
0℃~30℃,30%-60%RH
Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free.
Recommended maximum paste thickness is 0.25mm.
Devices can be cleaned using standard industry methods and solvents.
Note 1: All temperature refer to topside of the package, measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements.
Environmental Specifications
Test
Conditions
Resistance change
Passive aging
+85°C, 1000 hrs.
±5% typical
Humidity aging
+85°C, 85% R.H. , 168 hours
±5% typical
Thermal shock
+85°C to -40°C, 20 times
±33% typical
Resistance to solvent
MIL-STD-202,Method 215
No change
Vibration
MIL-STD-202,Method 201
No change
Ambient operating conditions : - 40 °C to +85 °C
Maximum surface temperature of the device in the tripped state is 125 °C
Revision 2017
4/7
BHFUSE
Physical Dimensions & Recommended Pad Layout (mm)
1.78
A
1.78
D
Part Number
3.15
B
010
014
B
3.45
E
Marking
Quantity
BSMD1812-010-30V
B010
BSMD1812-010-60V
C
A
B
C
D
E
Min
Max
Min
Max
Min
Max
Min
Min
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
B010
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-014-60V
B014
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-020-30V
B020
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-020-60V
B020
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-030-30V
B030
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-030-60V
B030
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-050-15V
B050
1500
4.37
4.73
3.07
3.41
0.40
1.00
0.30
0.25
BSMD1812-050-24V
B050
1500
4.37
4.73
3.07
3.41
0.40
1.00
0.30
0.25
BSMD1812-050-30V
B050
1500
4.37
4.73
3.07
3.41
0.40
1.00
0.30
0.25
BSMD1812-050-60V
B050
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-075-13.2V
B075
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-075-16V
B075
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-075-24V
B075
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-075-33V
B075
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-110-8V
B110
1500
4.37
4.73
3.07
3.41
0.40
1.00
0.30
0.25
BSMD1812-110-16V
B110
1500
4.37
4.73
3.07
3.41
0.40
1.00
0.30
0.25
BSMD1812-110-24V
B110
1500
4.37
4.73
3.07
3.41
0.40
1.00
0.30
0.25
BSMD1812-110-33V
B110
1500
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
BSMD1812-125-16V
B125
1500
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
BSMD1812-125-24V
B125
1500
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
BSMD1812-150-8V
B150
1500
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
BSMD1812-150-16V
B150
1500
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
BSMD1812-150-24V
B150
1500
4.37
4.73
3.07
3.41
0.80
1.50
0.30
0.25
BSMD1812-150-33V
B150
1500
4.37
4.73
3.07
3.41
0.80
1.50
0.30
0.25
Revision 2017
5/7
BHFUSE
Part Number
Marking
Quantity
BSMD1812-160-8V
B160
BSMD1812-160-16V
A
B
C
D
E
Min
Max
Min
Max
Min
Max
Min
Min
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
B160
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-160-24V
B160
1500
4.37
4.73
3.07
3.41
0.50
1.10
0.30
0.25
BSMD1812-200-8V
B200
1500
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
BSMD1812-200-12V
B200
1500
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
BSMD1812-200-16V
B200
1500
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
BSMD1812-200-24V
B200
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-200-30V
B200
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-250-8V
B250
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-260-8V
B260
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-260-13.2V
B260
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-260-16V
B260
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-300-8V
B300
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-300-12V
B300
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-300-16V
B300
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-350-6V
B350
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-350-16V
B350
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
BSMD1812-400-6V
B400
1500
4.37
4.73
3.07
3.41
0.60
1.50
0.30
0.25
Revision 2017
6/7
BHFUSE
Tape And Reel Specifications (mm)
Governing
Specifications
BSMD1812-010-30V~
BSMD1812-075-33V
BSMD1812-110-16V~
BSMD1812-200-16V
BSMD1812-200-24V~
BSMD1812-400-6V
W
12.0 ± 0.3
12.0 ± 0.3
12.0 ± 0.3
F
5.5 ± 0.05
5.5 ± 0.05
5.5 ± 0.05
E1
1.75 ± 0.1
1.75 ± 0.1
1.75 ± 0.1
D0
1.55 ± 0.05
1.55 ± 0.05
1.55 ± 0.05
D1
1.55min
1.55min
1.55min
P0
4.0 ± 0.1
4.0 ± 0.1
4.0 ± 0.1
P1
8.0 ± 0.1
8.0 ± 0.1
8.0 ± 0.1
P2
2.0 ± 0.05
2.0 ± 0.05
2.0 ± 0.05
A0
3.58 ± 0.1
3.58 ± 0.1
3.58 ± 0.1
B0
4.93 ± 0.1
4.93 ± 0.1
4.93 ± 0.1
T
0.2 ± 0.1
0.2 ± 0.1
0.2 ± 0.1
K0
0.74 ± 0.1
1.04 ± 0.1
1.35 ± 0.1
Leader min
390
390
390
Trailer min
160
160
160
Reel Dimensions
C
φ178 ± 1.0
D
φ60.2 ± 0.5
H
16.0 ± 0.5
W
13.2 ± 1.5
Contact information
SHENZHEN HCHC ELECTRONIC CO., LTD
TEL: 0755-85259917 FAX: 0755-28704432
E-MAIL: sale@hchc-elec.com
Revision 2017
7/7
很抱歉,暂时无法提供与“BSMD1812-300-16V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33006
- 50+0.30546
- 200+0.28496
- 600+0.26446
- 1500+0.24806
- 3000+0.23781
- 国内价格
- 5+0.57143
- 50+0.44183
- 150+0.37703
- 1500+0.32843
- 3000+0.28955
- 4500+0.27000
- 国内价格
- 1+0.43670
- 50+0.25630
- 1500+0.23100
- 国内价格
- 5+0.57150
- 50+0.44190
- 150+0.37710
- 1500+0.32850
- 3000+0.28960
- 4500+0.27000
- 国内价格
- 10+0.43600
- 50+0.40690
- 200+0.37790
- 600+0.34870
- 1500+0.31970
- 3000+0.29070
