SS-969H
SS-969H
    PRO'SKIT(宝工)
    TOOL
    (Pro'skit) SS-969 柔风型 SMD 拆焊台
SS-969H 数据手册
SS-969 SMD Rework Station User’s Manual st , 1 Edition 2020 © 2020 Copyright by Prokit’s Industries Co., Ltd. SAFETY INSTRUCTIONS WARNING Warnings and cautions are placed at critical points in this manual to direct the operator’s attention to significant items. They are defined as follows: WARNING: Failure to comply with a WARNING may result in serious injury or death. CAUTION: Failure to comply with a CAUTION may result in injury to the operator, or damage to the items involved. Two examples are given below. NOTE: A NOTE indicates a procedure or point that is important to the process being described. EXAMPLE: AN EXAMPLE is given to demonstrate a particular procedure, point or process. Be sure to comply with following WARNINGS and CAUTIONS for your safety. WARNING Do not change or disassemble any components related to this product, it may cause product damaged. When you need to replace the fuse, be sure turn off the power before operating. During working period, do not turn off the power suddenly, the heat gun should be placed on the heat gun holder until cool off after power turn off, otherwise it will damage the product。 CAUTION When the power is ON, the temperature of the hot air and the nozzle ranges from 100 to 450℃(212 to 842℉). To avoid injury to personnel or damage to items in the work area, observe the following: ** Do not direct the hot air toward personnel or touch the metal parts near the nozzle. ** Do not use the product near combustible gases or flammable materials. ** Advise those in the work area that the unit can reach very high temperatures and should be considered potentially dangerous. ** Turn the power OFF when no longer using the Pro’sKit SS-969 or when leaving it unattended. ** Before replacing parts or storing the unit, allow the unit to cool and then turn the power OFF. 1 To prevent accidents and failures, be sure to take the following precautions: ** Do not strike the handpiece against hard surfaces or otherwise subject it to physical shock. ** Be sure the unit is grounded. Always connect power to a grounded receptacle. ** Do not disassemble the machine. ** Do not modify the unit. ** Use Pro’sKit provides replacement parts. ** Do not wet the unit or use the unit with wet hands. ** Remove power cord by holding the plug – not the wires. ** Make sure the work area is well ventilated. ** The Pro’sKit SS-969 is not intended for use by children or infirm persons without supervision. ** Children should be supervised to ensure that they do not play with the SS-969. Packing list and name of parts Name of Parts Heat gun holder Temperature Display Temperature adjustment button Airflow adjustment knob Power Switch Heat gun Packing List: SS-969 SMD Rework Station (include holder) x1 Heat Gun x1 Air nozzle x 3 Power cord x1 User’s manual x1 2 Features: 1. Microprocessor-controlled, closed circuit sensor design, high power and quick warm-up times 2. Adjustable air flow, air volume and temperature, suitable for a variety of applications. 3. Handle with sensor design switching work & sleep mode for real-time operation convenience. 4. Auto Cool-Off Process to prolong the life of heating element 5. Plastic shell, compact body, beautiful, small footprint. 6. Comes with brushless motor provides long service life, quiet in operation 7. Safe solder temperature-sensitive components, and won’t deform other plastic components. Also for heating shrink, viscidity removal, lacquer removal, preheating and more. Specification: Model No. Power Input SS-969E SS-969B SS-969H SS-969C 110V-120V~ 60Hz 220V-240V~ 50Hz 220V-240V~ 50Hz 240V~ 50Hz Power Consumption 700W Temperature Range 100-450℃ Air Volume 120L/min(Max) Heating Element Metal Heating core Equipment noise
SS-969H 价格&库存
很抱歉,暂时无法提供与“SS-969H”相匹配的价格&库存,您可以联系我们找货
SS-969H
  • 1+279.00000
库存:3
