MA729
MA729
    KUU(永裕泰)
    SOD-323
    VR=30V IF=200mA VF=0.55V IR=50uA 30pF 3ns
MA729 数据手册
MA729 FEATURES Pb z For super-high speed switching circuit. z For small current rectification. z Allowing to rectify under(IF(AV)=200mA) condition. z Allowing high-density mounting. Lead-free APPLICATIONS z Schottky epitaxial planar. SOD-323 ORDERING INFORMATION Type No. MA729 Marking Package Code 2B SOD-323 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Parameter Symbol Limits Unit DC reverse voltage VR 30 V Repetitive peak reverse voltage VRRM 30 V Peak forward Current IFM 300 mA Average forward Current IF(AV) 200 mA Non-repetitive peak forward Surge Current IFSM 1000 mA Power Dissipation Pd 200 mW Thermal resistance,junction to ambient air RθjA 635 ℃/W Junction temperature Tj 150 ℃ Storage temperature range Tstg -55-150 ℃ ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified 1/3 MA729 MA729 Parameter Symbol Conditions Min. Typ. Reverse Breakdown Voltage V(BR)R IR=10μA 30 Forward voltage VF IF=200mA 0.55 V Reverse leakage current IR VR=30V 50 μA Reverse recovery time trr IF= IR =100mA, Irr=10mA,RL=100Ω 3.0 ns Total capacitance CT VR=0V,f=1.0MHz 30 pF Unit V TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified 2/3 Max. MA729 MA729 Plastic surface mounted package SOD-323 SOD-323 K B C A D J Dim Min Max A 1.275 1.325 B 1.675 1.725 C E H 0.9 Typical D 0.25 0.35 E 0.27 0.37 H 0.02 0.1 J K 0.1 Typical 2.6 2.7 All Dimensions in mm SOLDERING FOOTPRINT Unit : mm 3/3
MA729 价格&库存
很抱歉,暂时无法提供与“MA729”相匹配的价格&库存,您可以联系我们找货
