ACW4532B-2-510TF
ACW4532B-2-510TF
    SUNLORD(顺络)
    SMD,4.5x3.2mm
    共模电感 -30,+50% 1Ω Original CHOKE_4.5X3.2MM_SM
ACW4532B-2-510TF 数据手册
Wire Wound Chip Common Mode Choke Coil – ACW Series Operating Temp. : -40℃~+125℃ FEATURES  Winding type realizes small size and low profile  Prevention of common mode noise at high frequency  Excellent solderability  AEC-Q200D verified APPLICATIONS  Common mode noise filtering for automotive CAN bus PRODUCT IDENTIFICATION ACW 4532 B ① ② ③ ② ① -110 ④ ⑤ Winding Type Common Mode Choke Coil ⑤ Inductance(uH) Example Nominal Value 110 11 220 22 510 51 101 100 T F ⑥ ⑦ ③ Code External Dimensions (L×W) (mm) 4532 [1812] 4.5×3.2 Type ACW -2 CAN For CAN bus B ④ Number of Lines 2 ⑦ Hazardous Substance Free Products F ⑥ Packing T Tape & Reel SHAPE AND DIMENSIONS ACW4532B TYPE Recommended Land Pattern Sunlord Specifications subject to change without notice. Please check our website for latest information. Unit: mm Revised 2018/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS ACW4532B TYPE Inductance Part Number Units Symbol ACW4532B-2-110TF ACW4532B-2-220TF ACW4532B-2-510TF ACW4532B-2-101TF +50%/-30% uH L 11(@ 100KHz/0.1V) 22(@ 100KHz/0.1V) 51(@ 1.0MHz/0.1V) 100(@ 1.0MHz/0.1V) DC Resistance Max Ω DCR 0.5 0.8 1.0 2.0 Rated Current Rated Voltage Max mA Ir 360 310 230 200 Volts VDC 50 50 50 50 Insulation Resistance Min MΩ IR 10 10 10 10 ※: Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales. EQUIVALENT CIRCUIT TYPICAL ELECTRICAL CHARACTERISTICS Impedance vs. Frequency Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2018/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
ACW4532B-2-510TF 价格&库存
很抱歉,暂时无法提供与“ACW4532B-2-510TF”相匹配的价格&库存,您可以联系我们找货
