SY7065/SY7065A
1.8V Minimum Input and 5. 5V Maximum Output
5A Peak Current Synchronous Boost with Output Disconnect
General Description
Features
The SY7065/SY7065A is a high efficiency
synchronous Boost regulator that converts down to
1.8V input and up to 5.5V output voltage. It adopts
NMOS for the main switch and PMOS for the
synchronous switch. It can disconnect the output from
input during the shutdown mode.
Ordering Information
SY7065 □(□□)□
Temperature Code
Package Code
Optional Spec Code
Note
Applications
芯
Package type
QFN2×2-10
QFN2×2-10
All Single-cell Li or Dual-cell Battery
Operated Products as MP-3 Player, PDAs, and
Other Portable Equipment
半
导
小
Ordering Number
SY7065QMC
SY7065AQMC
1.8V Minimum Input Voltage
Adjustable Output Voltage from 2.5V to 5.5V
5A Peak Current Limit
Input Under Voltage Lockout
Load Disconnect during Shutdown
Output Over Voltage Protection
Input Battery Voltage Monitor
Automatic Output Discharge at Shutdown:
SY7065: Auto Output Discharge Function
SY7065A: No Output Discharge Function
Low RDS(ON) (Main Switch/Synchronous
Switch) at 5.0V Output: 20/40mΩ
Compact Package: QFN2×2-10
tia
l-F
or
Typical Applications
96
LBO
SVOUT
C8
4.7uF
VOUT=5V
L1
1.5uH
R3
300kΩ
LX
PVOUT
R1
470kΩ
LBI
R4
50kΩ
FB
R2
EN PGND SGND 148.4kΩ
C4
22uF
C9
100uF
Efficiency (%)
fid
en
yC
C2
22uF
IN
Sil
erg
C1
22uF
98
R5
100kΩ
C6
1uF
on
VIN:1.8V~5.0V
Efficiency vs. Load Current
100
94
92
90
88
VIN=2.0V,VOUT=5.0V
VIN=3.3V,VOUT=5.0V
VIN=4.2V,VOUT=5.0V
86
84
0.0
1.0
2.0
3.0
4.0
5.0
Load Current (A)
Figure 1. Schematic Diagram
SY7065/A Rev. 0.9B
© 2020 Silergy Corp.
Figure 2. Efficiency Figure
Silergy Corp. Confidential- Prepared for Customer Use Only
1
All Rights Reserved.
SY7065/SY7065A
Pinout (top view)
10
9
8
7
FB
LBO
LBI
EN
PVOUT
1
2
LX
3
PGND
SVOUT 6
IN
5
SGND
4
(QFN2×2-10)
Top mark: RCxyz for SY7065 (Device code: RC, x=year code, y=week code, z= lot number code)
VLxyz for SY7065A (Device code: VL, x=year code, y=week code, z=lot number code)
Pin
Name
Pin
Number
PVOUT
1
LX
PGND
SGND
IN
2
3
4
5
SVOUT
6
EN
LBI
LBO
7
8
9
FB
10
Description
l-F
or
半
导
小
芯
Power output pin. Decouple this pin to the GND pin with at least a 22μF ceramic
capacitor.
Inductor node. Connect an inductor between the IN pin and the LX pin.
Power ground pin.
Signal ground pin.
Signal input pin.
Signal output pin. Decouple this pin to the GND pin with at least a 4.7μF ceramic
capacitor for noise immunity consideration.
Enable pin. Internal integrated with a 1MΩ pull-down resistor.
Low battery comparator input.
Low battery comparator output (open-drain) .
Feedback pin. Connect a resistor R1 between OUT and FB, and a resistor R2 between FB
and GND to program the output voltage. VOUT=1.2V×(R1/R2+1).
tia
Block Diagram
fid
en
LBI
IN
on
1.2V
Ref
LBO
IN
SVOUT
IN
yC
Sil
erg
SVOUT
PVOUT
VCC
Supply
FB
TG
GM
1.2V
Ref
PWM
Control
Zc
WELL
SWITCH
LX
BG
SGND
Current
Sense
PGND
EN
Enable
control
Figure3. Block Diagram
SY7065/A Rev. 0.9B
2
SY7065/SY7065A
Absolute Maximum Ratings (Note 1)
EN------------------------------------------------------------------------------------------------------------------------- VOUT+0.3V
Other Pins--------------------------------------------------------------------------------------------------------------------------- 6V
Power Dissipation, PD@ TA=25°C QFN2×2-10---------------------------------------------------------------------------- 2.5W
Package Thermal Resistance (Note 2)
θ JA ----------------------------------------------------------------------------------------------------------------- 50°C/W
θ JC ----------------------------------------------------------------------------------------------------------------- 10°C/W
Junction Temperature Range ------------------------------------------------------------------------------------------------ 150°C
Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C
Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C
Recommended Operating Conditions (Note 3)
Electrical Characteristics
芯
IN ---------------------------------------------------------------------------------------------------------------------- 1.8V to 5.25V
PVOUT, SVOUT------------------------------------------------------------------------------------------------------ 2.5V to 5.5V
EN -------------------------------------------------------------------------------------------- --------------------- 0V to VOUT+0.3V
All other pins ------------------------------------------------------------------------------------------------------------------ 0-5.5V
Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 125°C
Ambient Temperature Range -------------------------------------------------------------------------------------- -40°C to 85°C
Sil
erg
yC
on
fid
en
Soft-start Time
Input VIN UVLO Threshold
VIN UVLO Hysteresis
EN Rising Threshold
EN Falling Threshold
LBI Voltage Threshold
LBI Input Hysteresis
Low Side Main FET RON
Synchronous FET RON
Main FET Current Limit
Switching Frequency
Feedback Reference Voltage
Minimum ON Time
Minimum OFF Time
Max ON Time
Thermal Shutdown
Temperature
Thermal Shutdown Hysteresis
Output Discharge Resistor
SY7065/A Rev. 0.9B
半
Symbol
VIN
VOUT
IQ
l-F
or
tia
Linear Charge Current
导
小
(VIN =2.4V, VOUT=5V, IOUT=500mA, TA = 25°C unless otherwise specified)
Parameter
Input Voltage
Output Voltage Range
VIN
Quiescent Current
VOUT
Shutdown Current
ISHDN
ICHARGE
tSS
VUVLO
VHYS
VENH
VENL
VLBI
VLBI_HYS
RDS(ON)1
RDS(ON)2
ILIM1
fsw
VREF
VOVP
tON_MIN
tOFF_MIN
tON_MAX
Test Conditions
Min
1.8
2.5
Typ
10
27
0.1
1.2
1.0
1
Io=0A,VEN=VIN=1.8V,
VOUT=5.0V
VEN=0V, VIN=2.4V
VOUT≤1V
1V
很抱歉,暂时无法提供与“SY7065AQMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.39800
- 100+1.92500
- 750+1.71600
- 1500+1.61700
- 3000+1.54000
- 国内价格
- 1+3.32740
- 10+2.46130
- 100+2.10980
- 1000+1.75810
- 国内价格
- 1+3.98520
- 10+3.11040
- 30+2.73240
- 100+2.26800
- 500+1.97640
- 1000+1.84680
- 国内价格
- 1+3.65310
- 10+2.85120
- 600+1.81170
- 1200+1.79358
- 3000+1.75771
