Application Notes: AN_SY6875A
Programmable Current Limit Switch
矽力杰一级代理商,服务热线:13612957917 蓝先生 技术支持热线,QQ:455854573
Features
SY6875A is a programmable current limit switch with
input voltage range selection and output voltage
clamping. Extremely low RDS(ON) of the integrated
protection N-channel FET helps to reduce power loss
during the normal operation. Programmable soft-start
time controls the slew rate of the output voltage during
the start-up time. Independent enable control allows the
complicated system sequencing control. It integrates
the over-temperature protection shutdown and autorecovery with hystersis. This IC along with small
DFN3X3-10 footprint provides small PCB area
application.
• Wide Input Voltage Range from 2.5V to 15V with
surge up to 30V
• Extremely Low RDS(ON) for the Integrated
Protection Switch: 40 mΩ
• Programmable Soft-Start Time
• Programmable Current Limit
• Short-circuit Protection
• Selectable Input Range and Clamping Output
Voltage Threshold.
• Enable Interface Pin
• Thermal Shutdown Protection & Auto Recovery
• RoHS Compliant and Halogen Free
• Compact package: DFN3X3-10
ar
ed
fo
rH
SX
General Description
Ordering Information
Applications
Temperature Code
Package Code
Optional Spec Code
Package type
DFN3x3-10
Note
Notebook PC
I-pad Mini
Server
Service PC
.C
on
fid
en
Ordering Number
SY6875ADBC
tia
l-P
re
p
SY6875 □(□□)□
Sil
er
gy
Co
rp
Typical Applications
Figure 1. Schematic Diagram
AN_SY6875A Rev. 0.9
Silergy Corp. Confidential- Prepared for Customer Use Only
1
AN_SY6875A
Pinout (top view)
rH
SX
(DFN3x3-10)
Top mark: FNxyz for SY6875A (Device code: FN, x=year code, y=week code, z= lot number code)
Pin Name
Pin Number
Pin Description
GND
11(exposed paddle)
OUT
ILIM
8,9,10
5
SST
6
EN
VCP
7
4
Power input pin. Decouple high frequency noise by connecting at
least 0.1uF MLCC to ground.
Ground pin.
fo
1,2,3
Power output pin.
Current limit program pin. Program the current limit by
connecting a resister to ground.
Soft-start time program pin. Connect a capacitor to ground to
program the soft start time.
Enable interface pin. Pull it High to enable the IC.
Output clamp voltage selection based on the input voltage. Pull
VCP pin to High by connecting a resistor to IN, or pull VCP pin to
Low by connecting a resistor to ground, or float VCP Pin to select
different output clamping thresholds. Recommend to decoupling
this pin with 0.1uF capacitor.
Clamping Threshold
VCP
IN
Min
Typ
Max
Low
3.3V
Over 4V
3.6V
3.8V
4.0V
High
5V
Over 6V
5.4V
5.7V
6.0V
Open
12V
Over 14V 12.6V
13.3V
14V
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
IN
Sil
er
gy
Block Diagram
AN_SY6875A Rev. 0.9
2
AN_SY6875A
Absolute Maximum Ratings (Note 1)
Supply Input Voltage ----------------------------------------------------------------------------------------- 30V
EN pin, VCP pin, ---------------------------------------------------------------------------------------------- 30V
Power Dissipation, PD @ TA = 25°C DFN3X3-10, ------------------------------------------------------- 2.6W
Package Thermal Resistance (Note 2)
θ JA ------------------------------------------------------------------------------------------------------------- 38°C/W
θ JC ------------------------------------------------------------------------------------------------------------- 8°C/W
SX
Junction Temperature Range -------------------------------------------------------------------------------- 125°C
Lead Temperature (Soldering, 10 sec.) --------------------------------------------------------------------- 260°C
Storage Temperature Range ---------------------------------------------------------------------------------- -65°C to 150°C
Recommended Operating Conditions (Note 3)
Electrical Characteristics
ar
ed
fo
rH
Supply Input Voltage ----------------------------------------------------------------------------------------- 2.5V to 15V
Junction Temperature Range -------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range ------------------------------------------------------------------------------- -40°C to 85°C
(VIN = 5V, RLIM=10kΩ, CSST=105nF, CIN = 10uF, COUT = 10uF, TA = 25°C, unless otherwise specified )
UVLO hysteresis
VHYS
Co
rp
Sil
er
gy
Soft-start Time
Soft-start Time Accuaracy
EN Turn-on Threshold
EN Turn-off Threshold
Output Discharge Resistor
Thermal Shutdown
Temperature
Thermal Shutdown Hysteresis
Min
2.5
2.2
3.4
8.1
0.05
0.06
0.1
EN=0
fid
IBIAS
ISHDN
RDS(ON)
VCP=LOW
VCP=HIGH
VCP=OPEN
VCP=LOW
VCP=HIGH
VCP=OPEN
.C
on
Bias Current
Shutdown Current
Protection FET RON
Current Limit Accuracy
Current Limit Program Range
Clamping Output Voltage
Test Conditions
tia
l-P
re
p
Symbol
VIN
VUVLO
en
Parameter
Input Voltage Range
Input UVLO Threshold
ILIM
VCLP
TSST
VEN_ON
VEN_OFF
RDIS
TSD
THYS
(Note 5)
VCP=LOW
VCP=HIGH
VCP=OPEN
1
3.6
5.4
12.6
CSST=105nF(Note 4)
Typ
0.085
0.095
0.19
200
10
40
30%ILIM
3.8
5.7
13.3
29.4
±30%TSST
Max
30
2.4
3.8
9.0
0.13
0.15
0.29
70
5
4.0
6.0
14.0
2
V
µA
µA
mΩ
A
V
V
V
ms
30
140
V
V
Ω
°C
°C
0.4
EN=’0’
Unit
V
V
V
V
Note 1: Stresses beyond “Absolute Maximum Ratings” may cause permanent damage to the device. These are for
stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions may affect
device reliability.
AN_SY6875A Rev. 0.9
3
AN_SY6875A
Note 2: θJA is measured in the natural convection at TA = 25°C on a low effective single layer thermal conductivity
test board of JEDEC 51-3 thermal measurement standard. Test condition: Device mounted on 2” x 2” FR-4 substrate
PCB, 2oz copper, with minimum recommended pad on top layer and thermal vias to bottom layer ground plane.
Note 3. The device is not guaranteed to function outside its operating conditions
Note4. Recommended Soft-start Time Program Table
SST cap (nF)
Rise time (ms)
None
1.4
10
2.8
55
15.4
105
29.4
SX
Recommended Formula for CSST & Soft-start Time Calculation
fo
rH
TSS _ DLT , No external C SST
TSS = C SST
, TSS > TSS_DLT
I INT
Note5. Recommended Current Limit Program Table
11
1.0
5.5
2.0
4.4
2.5
3.7
3.0
tia
l-P
re
p
Current Limit Resistance (kΩ)
Current Limit (A)
ar
ed
Where, TSS_DLT is the internally fixed default soft-start time, about 1.4ms, which means there’s no any external
CSST; IINT is the internal current source, about 3.6uA.
3.1
3.5
2.8
4.0
2.4
4.5
2.2
5.0
Recommended Formula for RLIM & Current Limit Calculation
en
11k
(Ω ) .
I LIM
Sil
er
gy
Co
rp
.C
on
fid
RLIM =
AN_SY6875A Rev. 0.9
4
AN_SY6875A
Typical Performance Characteristics
Programmable Soft-start Time
( 3.3V Mode, IO=1A, CSST=100nF)
2.0V/div
VOUT
IO
2.0V/div
SX
ILIMIT(A)
VIN
rH
0.5A/div
fo
Time (20ms/div)
Shutdown
ar
ed
( 5.0V Mode, IO=1A, CSST=100nF)
VOUT
2.0V/div
IO
0.5A/div
en
2.0V/div
VIN
2.0V/div
VOUT
2.0V/div
IO
0.5A/div
.C
on
fid
VIN
tia
l-P
re
p
Time (10ms/div)
Sil
er
gy
Co
rp
Time (10ms/div)
AN_SY6875A Rev. 0.9
5
AN_SY6875A
Shutdown
( 12V Mode, IO=1A, CSST=100nF)
VIN
5.0V/div
VOUT
0.5A/div
rH
SX
IO
5.0V/div
Time (10ms/div)
fo
Over Voltage Protection
VOUT
2.0V/div
IO
0.5A/div
tia
l-P
re
p
5.0V/div
Sil
er
gy
Co
rp
.C
on
Time (20ms/div)
fid
en
VIN
ar
ed
( 5V Mode, VIN=8V, IO=1A)
AN_SY6875A Rev. 0.9
6
AN_SY6875A
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
fo
rH
SX
PCB Layout Guideline
Sil
Top Silkscreen
AN_SY6875A Rev. 0.9
Top Layer
Bottom Layer
7
AN_SY6875A
ar
ed
fo
rH
SX
DFN3x3-10 Package outline
PCB layout (recommended)
Side View
Sil
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
Top View
Detail A
Pin1 identifier: two options
Bottom View
Notes: All dimensions are in millimeters and exclude mold flash & metal burr.
AN_SY6875A Rev. 0.9
8
AN_SY6875A
Taping & Reel Specification
1. DFN3x3-10 taping orientation
3.9/4.1
tia
l-P
re
p
Feeding direction
ar
ed
fo
rH
SX
11.7/12.3
1.45/1.55
2. Carrier Tape & Reel specification for packages
.C
on
fid
en
Reel
Width
er
gy
Co
rp
Reel
Size
Sil
Package
types
DFN3x3
Tape width
(mm)
Pocket
pitch(mm)
Reel size
(Inch)
Reel
width(mm)
Trailer
length(mm)
Leader length
(mm)
Qty per
reel
10
8
13"
12.4
400
400
5000
3. Others: NA
AN_SY6875A Rev. 0.9
9
很抱歉,暂时无法提供与“SY6875ADBC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.61620
- 10+2.91060
- 30+2.55780
- 100+2.20500
- 国内价格
- 1+3.34400
- 100+2.68400
- 1250+2.38700
- 2500+2.26600
- 5000+2.14500
- 国内价格
- 1+3.98520
- 10+3.20760
- 30+2.81880
- 100+2.43000
- 500+2.20320
- 1000+2.08440
