BA151M
Order Code: BA151M
Version: A0 2018-01-04
Gas Discharge Tube
Features
Exterior
Small Size Design EIA 1812 4.5×3.2×2.7mm
Current Handling Capability 1,000A @ 8/20μ s
Low Capacitance and Insertion Loss
Fast Response and Long Service Life
Reliable to Protect Electrostatic Surge
Moisture sensitivity level: Level 1
SMD
Application Information
rmation
Package (Top View)
Coaxial
1
Agency Approvals
2
Schematic Symbol
Icon
Description
Compliance with 2011/65/EU
2
1
Compliance with IEC61249-2-21:2003
Mean lead free
Compliance with UL497B, Certificated E232249
Electrical Parameter
DC Breakdown Voltage 1)2)
Impulse Spark-over Voltage
100V/s
120-180
At 1kV/μs
for 99 % of measured values
At 1kV/μs
Typical values of distribution
V
750
650
V
V
Impulse Discharge Current 3)
8/20μs
1,000
A
Arc Voltage
At 1A
~8
V
Insulation Resistance
DC=50V
≥1
GΩ
Capacitance at 1 MHz
VDC=0.5V
≤1.0
pF
Weight
~0.20
g
Operating And Storage Temperature
-40-90
Marking
Without
1) At delivery AQL 0.65 level II ISO 2859
2) In ionized mode
3) Terms and waveforms in accordance with ITU-T Rec. K. 12; IEC 61643-21
1/4
www.bencent.com.cn
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
BA151M
Order Code: BA151M
Gas Discharge Tube
Product Characteristics
Characteristics
Part Numbering System
BA
151
M
(1)
(2)
(3)
Lead Material
Copper or iron nickel alloy
Body Material
Ceramics
Terminal Finish
100% Matte-Tin Plated
(1) Bencent Gas Discharge Tube
(2) Series: DC Breakdown Voltage, e.g.: 151=15×101=150V
(3) Tolerance of DC Breakdown Voltage, M=+-20%,
N=+-30%, the Specific tolerance is decided by the table of
“Electrical Parameter”
Environmental Reliability Characteristics
Testing items
Technical standards
Temperature: 90℃
Time: 2H
Temperature: -40℃
Time: 2H
Frequency: 10-500Hz
Amplitude: 0.15mm
Time: 45mins
Temperature: 260±5℃
Time of dip soldering: 10s, 1time
High Temperature Storage Test
Low Temperature Storage Test
Vibration
Resistance of soldering heat
Note: Up-screen program can be specified by customer’s request via contacting Bencent service
Solderability Test
Solderability
Solder Pot Temperature:
245℃±5℃
Solder Dwell Time:
4-6 seconds
Product Dimensions
A
C
REF
mm
inch
A
4.5±0.3
0.177±0.012
B
0.5±0.2
0.020±0.008
C
2.7±0.2
0.106±0.008
D
3.2±0.2
0.126±0.008
REF
mm
inch
A
5.5
0.217
B
3.5
0.138
C
3.5
0.138
D
B
Recommended Soldering Pad
A
B
C
2/4
www.bencent.com.cn
BA151M
Order Code: BA151M
Gas Discharge Tube
Reflow Profile
Reflow Condition
Heat
Temperature Min
150°C
Temperature Max
200°C
Time (min to max)
60 – 180 secs
Average ramp up rate (Liquids) Tamp
(TL) to peal
TS(max) to TL - Ramp-up Rate
3°C/second max
(Liquids)
- Temperature (TL)
Peak Temperature (TP)
217°C
60 – 150 seconds
TL
TS(max)
Ramp-down
Preheat
TS(min)
tS
260+0/-5 °C
Time within 5°C of actual peak
8 – 20 seconds
Temperature (tp)
Critical Zone
TL to TP
Ramp-up
TL
3°C/second max
- Temperature (TL)
Reflow
tP
TP
Temperature
Pre
Pb-Free assembly
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max.
Do not exceed
260°C
25
Time
time to peak temper ature
Package Reel Information
3/4
OUTLINE
REEL
(PCS)
PER CARTON
(PCS)
TAPING
2,500
40,000
www.bencent.com.cn
REF
mm
inch
A
3.7±0.2
0.146±0.008
B
5.0±0.1
0.197±0.004
d
Φ1.5±0.1
Φ0.059±0.004
E
1.75±0.1
0.069±0.004
F
5.5±0.1
0.217±0.002
P
8.0±0.1
0.315±0.004
P0
4.0±0.1
0.157±0.004
P1
2.0±0.1
0.079±0.004
W
12.0±0.2
0.472±0.008
D
Φ330.0
Φ13.0
D1
Φ50Min
Φ1.97Min
D2
Φ13±0.15
0.512±0.006
W1
16.8±2.0
0.661±0.079
REEL
DIAMETERS
(mm)
330
CARTON SIZE(mm)
L
W
H
360
360
380
很抱歉,暂时无法提供与“BA151M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.12048
- 50+1.63059
- 150+1.42064
- 500+1.15874
- 2500+1.04210
- 5000+0.97200
