B5G3600
B5G3600
    BENCENT(槟城)
    GDT_D5.5X6MM_TM
    陶瓷气体放电管 Φ5.5x6mm
B5G3600 数据手册
B5G3600 Order Code: B5G3600-01 Version: A2 2017-11-28 Gas Discharge Tube Features Exterior Size Design Φ5.5×6mm High Current Handling Capability 3,000A @ 8/20μ s Low Capacitance and Insertion Loss Fast Response and Long Service Life Reliable to Protect Electrostatic Surge Moisture sensitivity level: Level 1 Application Information rmation Package (Top View) AC Power ` 1 Agency Approvals 2 Schematic Symbol Icon Description Compliance with 2011/65/EU Compliance with IEC61249-2-21:2003 2 1 Mean lead free Compliance with UL1449, Certificated E337906 Electrical Parameter DC Breakdown Voltage1 )2) Impulse Spark-over Voltage Impulse Spark-over Voltage Impulse Discharge Current 3) 100V/s 1.2/50us-8/20us 6KV-3KA 3600(-20%~+30%) V  5500 V At 1kV/μs for 99 % of measured values  4700 V At 1kV/μs Typical values of distribution  4600 V 8/20μs ±5times 3 KA Arc Voltage At 1A ~15 V Insulation Resistance DC=100V ≥1 GΩ Capacitance at 1 MHz VDC=0.5V ≤1 pF Hi-pot Test ID=10mA ≥1875 V Weight ~0.75 g Operating and storage Temperature -40-90 ℃ Marking Bencent Logo, Voltage and date code 1) At delivery AQL 0.65 level II ISO 2859 2) In ionized mode 3) Terms and current waveforms in accordance with ITU-T Rec. K. 12; IEC 61643-21 1/3 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications B5G3600 Order Code: B5G3600-01 Version: A2 2017-11-28 Gas Discharge Tube Product Characteristics Characteristics Part Numbering System B5G XXXX (1) (2) (1) Bencent 2-Electrode DIP Gas Discharge Tube with dimension: Φ5.5×6 (D×L) (mm) (2) DC Breakdown Voltage, e.g., 3600=3600V Lead Material Copper Body Material Ceramics Iron-nickel electrode Terminal Finish 100% Matte-Tin Plated Environmental Reliability Characteristics Testing items High Temperature Storage Test Low Temperature Storage Test Vibration Resistance of soldering heat Technical standards Temperature: 90℃ Time: 2H Temperature: -40℃ Time: 2H Frequency: 10-500Hz Amplitude: 0.15mm Time: 45mins Temperature: 260±5℃ Time of dip soldering: 10s, 1time Note: Up-screen program can be specified by customer’s request via contacting Bencent service Solderability Test Solderability Solder Pot Temperature: 245℃±5℃ Solder Dwell Time: 4-6 seconds Product Dimensions 2/3 REF mm inch A 62±2 2.441±0.079 B 6±0.2 0.236±0.008 C Φ5.5±0.2 Φ5.5±0.008 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications B5G3600 Order Code: B5G3600-01 Version: A2 2017-11-28 Gas Discharge Tube Wave Soldering Profile 300 280 80 60 40 20 240 230 220 210 200 190 180 170 160 150 140 130 110 120 0 90 2-5 seconds 100 100 Solder Dwell Time 120 80 280℃ Max 140 70 Solder Pot Temperature 160 60 60 – 180 secs 180 50 Time (min to max) 200 40 150°C 220 30 Temperature Max 240 20 100°C 10 Heat Temperature Min 260 Temperature (℃)-Measured on bottom side of board Pre Pb-Free assembly 0 Wave Soldering Condition Time(Seconds) Preheat Time Cooling Time Dwell Time Package Reel Information W OUTLINE TAPING 3/3 REEL (PCS) PER CARTON (PCS) 1250 7500 www.bencent.com.cn REF mm inch W 65±3 2.559±0.118 P 10±1 0.394±0.039 A Φ340±2 Φ13.386±0.079 B Φ83±2 Φ3.268±0.079 C 73±3 2.874±0.118 CARTON SIZE(mm) L W H 480 350 360 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
B5G3600 价格&库存
很抱歉,暂时无法提供与“B5G3600”相匹配的价格&库存,您可以联系我们找货
