SS34 SMB
SS34 SMB
    BORN(伯恩半导体)
    SMB(DO-214AA)
    表面安装肖特基势垒整流器SMB(DO-214AA) VRRm=40V Io=3A IR=0.5mA
SS34 SMB 数据手册
SS32-36 SERIES SCHOTTKY SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS ROHS FEATURES For surface mounted applications Metal-Semiconductor junction with guardring Epitaxial construction Low forward voltage drop High current capability For sue in low voltage,high frequency inverters free wheeling,and polarity protection applications The plastic material carries U/L recognition 94V- O MECHANICAL DATA Case: JEDEC DO - 214Ab. molded plastic Polarity: Color band denotes cathode W eight: 0.009 ounce.0.25 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ℃ ambient temperature unless otherwise specified. Single phase. half wave. 60HZ. resistive or inductive load. For capacitive load. derate current by 20% SYMBOL SS32 SS33 SS34 SS35 SS36 UNITS Maximum Recurrent Peak Reverse Voltage VRRM 20 30 40 50 60 V Maximum RMS Voltage VRMS 14 21 28 35 42 V Maximum DC Blocking Voltage VDC 20 30 40 50 60 V Maximum Average Forward Rectified I(AV) 3.0 A 8.3ms Single half-sine-wave superimposed IFSM 100 A Current at TL = 100℃ Peak Forward Surge Current on rated load Maximum Forward Voltage at 3.0A DC VF Maximum Reverse Current 0.5 Tj = 25℃ at Rated DC Blocking Voltage 0.5 IR Tj = 100℃ 20 Typical Junction Capacitance ( Note 1 ) Cj Typical Thermal Resistance 0.7 250 RQJL ( Note 2,3 ) RQJA 10 50 V mA pF ℃/W Operating Junction Temperature Range Tj 55 to 125 ℃ Storage Temperature Range 55 to 150 ℃ NOTE: TSTG 1. Measured at 1.0MHZ and applied reverse voltage of 4.0V DC. 2. Thermal Resistance Junction to Lead. 3. Thermal Resistance Junction to Ambient. Rev 8: Nov 2014 www.born-tw.com Page 1 of 2 SS32-36 SERIES PEAK FORWARD SURGE CURRENT AMPERES SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS FIG. 1 -- FORWARD CURRENT DERATING CURVE CURRENT AMPERES AVERAGE FORWARD RECTIFIED SCHOTTKY FIG. 2 -- MAXIMUM NON-REPETITIVE SURGE Single Phase Half Wave 60HZ Resistive of inductive Load 4 3 2 1 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE / ℃ 10 4 10 Rev 8: Nov 2014 100 80 60 8.3 ms SINGLE HALF SINE-WAVE (JEDEC Method) 40 20 0 1 2 10 5 NUMBER OF CYCLES AT 60HZ INSTANTANEOUS FORWARD CURRENT(A) 100 INSTANTANEOUS REVERSE CURRENT(m A) Transient Thermal Impedance(℃/W) 1000 1 120 Fig.4-TYPICAL FORAWRD CHARACTERISTICS Fig.3-TYPICAL JUNCTION CAPACITANCE 0.1 ROHS 100 10 1 0 0.01 0 0.2 0.4 0.6 0.8 1.0 Fig.5-TYPICAL REVERSE CHARACTERISTICS 100 Tj=125℃ 10 Tj=100℃ 1 0.1 Tj=25℃ 0 0.001 0 20 40 60 www.born-tw.com 80 120 140 Page 2 of 2
SS34 SMB 价格&库存
很抱歉,暂时无法提供与“SS34 SMB”相匹配的价格&库存,您可以联系我们找货
SS34 SMB
  • 10+0.24570
  • 50+0.22950
  • 200+0.21600
  • 600+0.20250
  • 1500+0.19170
  • 3000+0.18495
库存:370
SS34 SMB
  • 1+0.37290
  • 200+0.24090
  • 1500+0.20900
  • 3000+0.18480
库存:6680
SS34 SMB
    • 1+0.26450
    库存:18
