SS34SMC
SS34SMC
    BORN(伯恩半导体)
    SMC(DO-214AB)
    表面安装肖特基势垒整流器SMC VRRM=40V Io=3A IR=0.5mA
SS34SMC 数据手册
SS32-320 SERIES SCHOTTKY SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS ROHS FEATURES  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Low reverse leakage  Built-in strain relief,ideal for automated placement  High forward surge current capability  High temperature soldering guaranteed: 250 C/10 seconds at terminals MECHANICAL DATA  Case : JEDEC DO-214AB molded plastic body  Terminals: Solder plated, solderable per MIL-STD-750, Method 2026  Polarity : Color band denotes cathode end  Mounting Position: Any  Weight : 0.007 ounce, 0.25 grams Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=110 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical thermal resistance (NOTE 1) Operating junction and storage temperature range Note: SS38 SS310 SS315 SS320 SYMBOLS SS32 SS34 SS36 VRRM VRMS VDC 20 14 40 21 40 60 28 80 56 100 70 150 105 200 150 60 80 100 150 200 20 UNITS VOLTS VOLTS VOLTS I(AV) 3.0 Amp IFSM 150.0 Amps VF IR RθJA TJ,TSTG 0.70 0.55 0.85 0.95 Volts 10.0 0.2 2.0 mA 0.5 20.0 C/W C 55 -65 to +150 1.P.C.B. mounted with 8.0x8.0mm copper pad areas Rev 8: Nov 2014 www.born-tw.com Page 1 of 2 SS32-320 SERIES SCHOTTKY SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 3.0 2.4 Single Phase Half Wave 60Hz Resistive or inductive Load 1.8 1.2 SS32-SS36 SS38-SS320 0.6 100 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE ROHS 80 60 40 20 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 0 0 25 50 75 100 125 150 175 0 1 AMBIENT TEMPERATURE, C 10 100 NUMBER OF CYCLES AT 60 Hz FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG. 4-TYPICAL REVERSE CHARACTERISTICS 100 50 INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES TJ=25 C 10.0 1 SS32-SS34 SS35-SS36 SS38-SS315 SS320 0.1 0.01 10 TJ=100 C 1 0.1 TJ=25 C 0.01 0.001 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 30 60 90 120 150 PERCENT OF PEAK REVERSE VOLTAGE,% INSTANTANEOUS FORWARD VOLTAGE, VOLTS FIG. 5-TYPICAL JUNCTION CAPACITANCE FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE JUNCTION CAPACITANCE, pF 1000 TRANSIENT THERMAL IMPEDANCE, C/W 2000 TJ=25 C 100 SS32-SS34 SS35-SS320 10 1 0.1 10 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS Rev 8: Nov 2014 100 0.01 0.1 1 10 100 t,PULSE DURATION,sec. www.born-tw.com Page 2 of 2
SS34SMC 价格&库存
很抱歉,暂时无法提供与“SS34SMC”相匹配的价格&库存,您可以联系我们找货
SS34SMC
    • 1+0.50610
    库存:2
    SS34SMC
      库存:999
      SS34SMC
        • 1+0.47310
        • 10+0.45400
        • 100+0.43060
        • 500+0.40970
        • 1000+0.39520
        库存:999
        SS34SMC
        • 1+0.53240
        • 200+0.34320
        • 1500+0.29810
        • 3000+0.26400
        库存:1783
