MB1SK THRU MB10SK
1A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
FEATURES:
PINNING
Glass Passivated Chip Junction
PIN
DESCRIPTION
1
Input Pin(~)
Reverse Voltage - 100 to 1000 V
2
Input Pin(~)
Forward Current - 1 A
3
Output Anode(+)
High Surge Current Capability
4
Output Cathode(-)
Designed for Surface Mount Application
3
MECHANICAL DATA
• Case: MBS
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 100mg / 0.0035oz
4
2
1
MBS Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
MB1SK
MB2SK
MB4SK
MB6SK
MB8SK
MB10SK
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
Parameter
Average Rectified Output Current
at Ta = 50 °C
IO
1.0
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
35
A
Maximum Forward Voltage at 1.0 A
VF
1.1
V
IR
5
40
μA
Cj
13
pF
RθJA
RθJL
85
30
°C/W
T j , T stg
-55 ~ +150
°C
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@ T A =25 °C
@ T A =125 °C
Typical Junction Capacitance(Note1)
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×(5×5mm 2 )copper pad.
REV.08
1 of 3
MB1SK THRU MB10SK
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
1.2
100LFM
1.0
0.8
0.6
0.4
Glass Epoxy PC Board
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
2.0
Peak Forward Surage Current (A)
80
100
100
120
140
T J =25°C
10
0.1
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
1.0
10
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
100
Number of Cycles
REV.08
60
1
0.5
Instaneous Forward Voltage (V)
1
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Ambient Temperature (°C)
2 of 3
100
MB1SK THRU MB10SK
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
MBS
A
∠ALL ROUND
C
a
L1
L
d
HE
e
D
e
E
MBS mechanical data
A
C
D
E
HE
d
e
L
L1
a
max
2.6
0.22
5.0
4.1
7.0
2.7
0.7
1.7
1.1
0.2
min
2.2
0.15
4.5
3.6
6.4
2.3
0.5
1.3
0.5
max
102
8.7
197
161
276
106
28
67
43
min
94
5.9
177
142
252
91
UNIT
mm
7°
mil
6.0
236
2.5
100
0.9
35
2.4
94
REV.08
mm
Unit :
(mil)
3 of 3
8
很抱歉,暂时无法提供与“MB6SK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14851
- 100+0.13501
- 500+0.12601
- 1000+0.11701
- 5000+0.10621
- 10000+0.10171
