ES1AG THRU ES1JG
Surface Mount Superfast Recovery Rectifier
PINNING
Reverse Voltage – 50 to 600 V Forward Current – 1 A
PIN
DESCRIPTION
FEATURES
1
Cathode
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
2
Anode
1
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
2
Top View
Marking Code: ES1A~ES1J
Simplified outline SMA and symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
Parameter
ES1AG ES1BG E S1CG E S1DG E S1EG E S1GG E S1JG
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
150
200
300
400
600
V
Maximum RMS voltage
V RMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
V DC
50
100
150
200
300
400
600
V
Maximum Average Forward Rectified Current
at T L = 100 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
30
A
Maximum Forward Voltage at 1 A
VF
Maximum DC Reverse Current
at Rated DC Blocking Voltage
Ta = 25 °C
Ta =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
Typical Thermal Resistance
(1)
(2)
Operating and Storage Temperature Range
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
REV.08
1.25
1
1.70
V
IR
5
100
μA
Cj
15
pF
t rr
35
ns
RθJA
110
°C/W
T j , T stg
-55 ~ +150
°C
(2)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas.
1 of 3
ES1AG THRU ES1JG
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
10 ohm
Noninductive
t rr
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
OSCILLOSCOPE
Note 1
NonInductive
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
300
1.2
1.0
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
0.8
0.6
0.4
0.2
Single phase half wave resistive or inductive
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
Case Temperature (°C)
Junction Capacitance ( pF)
Instaneous Forward Current (A)
ES1AG~ES1DG
ES1EG/ES1GG
0.1
ES1JG
0.01
0.001
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
35
30
25
10
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
REV.08
100
25
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
05
0.1
1
10
Reverse Voltage (V)
Fig.6 Maximum Non-Repetitive Peak
05
80
Fig.5 Typical Junction Capacitance
1.0
0.5
60
30
T J =25°C
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
10
2 of 3
100
ES1AG THRU ES1JG
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
The recommended mounting pad size
2.4
(94)
mm
Unit :
(mil)
REV.08
a
0.3
12
Marking
Type number
Marking code
ES1AG
ES1A
1.8
(71)
1.8
(71)
1.8
(71)
g
e
A
D
3 of 3
ES1BG
ES1B
ES1CG
ES1C
ES1DG
ES1D
ES1EG
ES1E
ES1GG
ES1G
ES1JG
ES1J
很抱歉,暂时无法提供与“ES1DG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05250
- 500+0.04725
- 5000+0.04375
- 10000+0.04200
- 30000+0.04025
- 50000+0.03920
- 国内价格
- 50+0.09245
- 500+0.07306
- 1500+0.06229
- 5000+0.05069
- 25000+0.04504
- 50000+0.04207
